8 buttons and 8 relays in esp with hc595
elmaya
Wed Sep 26, 2018 2:05 pm
Wifi manager with double reset to get in Config
and restore of channels after restart (Eeprom)
#include <FS.h>
#include <ShiftRegister74HC595.h>
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
// create shift register object (number of shift registers, data pin 14 on 74595, clock pin 11 on 74595, latch pin 12 on 74595)
ShiftRegister74HC595 sr (1, 15, 16, 0);
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <DoubleResetDetector.h>
#define DRD_TIMEOUT 30 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
#define DRD_ADDRESS 0 // RTC Memory Address for the DoubleResetDetector to use
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
bool eep = LOW;          //             ---------------- Eeprom ------------------
bool startEeprom = true; //             ---------------- Eeprom ------------------
int epr = 0;             //             ----------- Eepron read loops ------------
int s;                   //             ---------------- Status ------------------
unsigned long svr_update = 1800000; //mean time between update  30 minutes
unsigned long svr_update_lasttime;   //last time update
#define BEGIN_PIN 100
ADC_MODE(ADC_VCC);
#define BTN_COUNT 8
WiFiClient client;
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char Supla_server[40];
char Location_id[15];
char Location_Pass[20];
byte mac[6];
//flag for saving data
bool shouldSaveConfig = false;
bool initialConfig = false;
int timeout           = 120; // seconds to run for wifi config
void saveConfigCallback () {                 //callback notifying us of the need to save config
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
// The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //add all your parameters here
  wifiManager.addParameter(&custom_Supla_server);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wifiManager.setMinimumSignalQuality();
  // set configportal timeout
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla AP")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      //reset and try again, or maybe put it to deep sleep
      ESP.restart();
      delay(5000);
    //if you get here you have connected to the WiFi
    Serial.println("connected...yeey :)");
    //read updated parameters
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
// DS18B20 Sensor read implementation---------------------------------- Temp -------------------------------------------
    double t = -275;
     t = (ESP.getVcc()/1024.0);
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
                         //        ---- this happens every few seconds
      return t;
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_timer() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           if (v==0)
              if ( btn[a].ms > 0 ) {
                     SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( (btn[a].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
        pinMode(btn[a].pin, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin);
        btn[a].last_time = millis();
int supla_DigitalRead(int channelNumber, uint8_t pin) {
   if (pin > 100) {
      if (pin == 101){
        if (btn[0].mem ==0) return 0;
        else return 1;
      if (pin == 102){
        if (btn[1].mem ==0) return 0;
        else return 1;
      if (pin == 103){
        if (btn[2].mem ==0) return 0;
        else return 1;
      if (pin == 104){
        if (btn[3].mem ==0) return 0;
        else return 1;
      if (pin == 105){
        if (btn[4].mem ==0) return 0;
        else return 1;
      if (pin == 106){
        if (btn[5].mem ==0) return 0;
        else return 1;
      if (pin == 107){
        if (btn[6].mem ==0) return 0;
        else return 1;
      if (pin == 108){
        if (btn[7].mem ==0) return 0;
        else return 1;
    return digitalRead(pin);
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {  //------------------------------------------------  Virtual ----------------------------
    if (pin > 100) {
     if (pin == 101){
       btn[0].mem =val;
       sr.set(0, val); // set single pin
     if (pin == 102){
       btn[1].mem =val;
       sr.set(1, val); // set single pin
     if (pin == 103){
       btn[2].mem =val;
       sr.set(2, val); // set single pin
     if (pin == 104){
       btn[3].mem =val;
       sr.set(3, val); // set single pin
     if (pin == 105){
       btn[4].mem =val;
       sr.set(4, val); // set single pin
     if (pin == 106){
       btn[5].mem =val;
       sr.set(5, val); // set single pin
     if (pin == 107){
       btn[6].mem =val;
       sr.set(6, val); // set single pin
     if (pin == 108){
       btn[7].mem =val;
       sr.set(7, val); // set single pin
  return;
   digitalWrite(pin, val);
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
    if (startEeprom == true){             // ----- don't change memorized state until connected and restored all the channels
      return;
      for(int i=0;i<BTN_COUNT;i++) {  //  ---check relay except it have delay (staircase)
         if ( btn[i].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[i].mem);                    //  --- read relay state
        if (eep != EEPROM.read(i)){            //  --- compare relay state with memorized state
         EEPROM.write(i,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(i);
         Serial.print(" write.");
         Serial.println((eep));
         Serial.print(" channel ");
         Serial.println((btn[i].channel));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
   // for(int i=0;i<BTN_COUNT;i++){      //  ---check relay except der have delay (staircase)
     //if ( (btn[i].ms) > 0 ) {
                //     continue;
        // } else {
        eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
        if (eep == HIGH){                    //  --- if 1 send relay on
          SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
    if (epr == (BTN_COUNT-1)) {startEeprom = false;  }     //  --- once finished we do not need more
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
 // Serial.begin(115200);
  EEPROM.begin(512);
   if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    ondemandwifiCallback ();
  } else {
    Serial.println("No Double Reset Detected");
  if (WiFi.SSID()==""){
    //Serial.println("We haven't got any access point credentials, so get them now");
    initialConfig = true;
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        //json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Supla_server, json["Supla_server"]);
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
   uint8_t mac[WL_MAC_ADDR_LENGTH];
  WiFi.macAddress(mac);
  char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6],
                                mac[WL_MAC_ADDR_LENGTH - 5],
                                mac[WL_MAC_ADDR_LENGTH - 4],
                                mac[WL_MAC_ADDR_LENGTH - 3],
                                mac[WL_MAC_ADDR_LENGTH - 2],
                                mac[WL_MAC_ADDR_LENGTH - 1]};
  SuplaDevice.addRelay(101, false);
  SuplaDevice.addRelay(102, false);
  SuplaDevice.addRelay(103, false);
  SuplaDevice.addRelay(104, false);
  SuplaDevice.addRelay(105, false);
  SuplaDevice.addRelay(106, false);
  SuplaDevice.addRelay(107, false);
  SuplaDevice.addRelay(108, false);
  // CHANNEL8 - Thermometer DS18B20
  memset(btn, 0, sizeof(btn));
  btn[0].pin =5;          // pin gpio buton  0 = no buton
  btn[0].relay_pin =101;  // pin gpio Relay
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =4;          // pin gpio buton  0 = no buton
  btn[1].relay_pin =102;  // pin gpio Relay
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =2;          // pin gpio buton  0 = no buton
  btn[2].relay_pin =103;  // pin gpio Relay
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  btn[3].pin =14;         // pin gpio buton  0 = no buton
  btn[3].relay_pin =104;  // pin gpio Relay
  btn[3].channel =3;      // channel
  btn[3].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[3].mem =0;
  btn[4].pin =12;         // pin gpio buton  0 = no buton
  btn[4].relay_pin =105;  // pin gpio Relay
  btn[4].channel =4;      // channel
  btn[4].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[4].mem =0;
  btn[5].pin =13;         // pin gpio buton  0 = no buton
  btn[5].relay_pin =106;  // pin gpio Relay
  btn[5].channel =5;      // channel
  btn[5].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[5].mem =0;
  btn[6].pin =3;         // pin gpio buton  0 = no buton
  btn[6].relay_pin =107;    // pin gpio Relay
  btn[6].channel =6;      // channel
  btn[6].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[6].mem =0;
  btn[7].pin =1;          // pin gpio buton  0 = no buton
  btn[7].relay_pin =108;  // pin gpio Relay
  btn[7].channel =7;      // channel
  btn[7].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[7].mem =0;
  supla_btn_init();
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);    //            ------Send Value to server -------
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);   //        -------  Read Value from server   -------
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);    //   ----------------------------- Status -----------------------------
  SuplaDevice.setName("Supla 595");
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
// read_initial_relay_state();
void loop() {
  // Call the double reset detector loop method every so often,
  // so that it can recognise when the timeout expires.
  // You can also call drd.stop() when you wish to no longer
  // consider the next reset as a double reset.
  drd.loop();
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["Supla_server"] = Supla_server;
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    //end save
  if (WiFi.status() != WL_CONNECTED)
    WiFi_up();
  SuplaDevice.iterate();
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
  case 17:      // -----     STATUS_REGISTERED_AND_READY
  if (epr<BTN_COUNT){
  Serial.print("Eepron_read...");
  Serial.println(epr);
   Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
   epr = epr+1;                   // -------- 1 loop for each output 8 in total ----------
   if (millis() > svr_update_lasttime + svr_update)  {
    epr = 0 ;
     startEeprom = true;
      Serial.println("svr update");
            svr_update_lasttime = millis();
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       WiFi_up();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = &get_temperature;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up() // conect to wifi
  WiFi.begin();
  for (int x = 10; x > 0; x--)
    if (WiFi.status() == WL_CONNECTED)
      break;
    else
      Serial.print(".");
      delay(500);
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
  else
    Serial.println("");
    Serial.println("not connected");
If you like my work please support it by buying me a cup of coffee :)
www.paypal.me/elmayasevilla
elmaya
Thu Nov 08, 2018 11:09 pm
Added temperature sensor "NTC 10Kohn"
#include <FS.h>
#include <ShiftRegister74HC595.h>   //https://github.com/Simsso/ShiftRegister74HC595
ShiftRegister74HC595 sr (2, 15, 16, 0);
#include <math.h>
#include <EEPROM.h>
unsigned long wifi_checkDelay = 60000;  // wifi reconect delay
unsigned long wifimilis;
unsigned int Rs = 100000;
double Vcc = 3.3;
#define BTN_COUNT 16
WiFiClient client;
byte mac[6];
  //WiFiManager
  //defaults to 8%
    if (!wifiManager.startConfigPortal("Supla 595")) {
      delay(3000);
      ESP.restart();
      delay(5000);
double get_temperature(int channelNumber, double last_val) {  // 10k Ntc Adc to Gnd and 100k Resistor Adc to +3,3v
      int val = 0;
      for(int i = 0; i < 10; i++) {
      val += analogRead(A0);
      delay(1);
      val = val / 10;
      double V_NTC = (double)val / 1023;
      double R_NTC = (Rs * V_NTC) / (Vcc - V_NTC);
      R_NTC = log(R_NTC);
      double t = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * R_NTC * R_NTC ))* R_NTC );
      t = t - 273.15;
      return t;
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  bool mem;
} _btn_t;
  char v;
           if (v==0)
                 } else {
                 } else {
      if (channelNumber == 0){
        else return 1;
      if (channelNumber == 1){
        else return 1;
      if (channelNumber == 2){
        else return 1;
      if (channelNumber == 3){
        else return 1;
      if (channelNumber == 4){
        else return 1;
      if (channelNumber == 5){
        else return 1;
      if (channelNumber == 6){
        else return 1;
      if (channelNumber == 7){
        else return 1;
      if (channelNumber == 8){
        if (btn[8].mem ==0) return 0;
        else return 1;
      if (channelNumber == 9){
        if (btn[9].mem ==0) return 0;
        else return 1;
      if (channelNumber == 10){
        if (btn[10].mem ==0) return 0;
        else return 1;
      if (channelNumber == 11){
        if (btn[11].mem ==0) return 0;
        else return 1;
      if (channelNumber == 12){
        if (btn[12].mem ==0) return 0;
        else return 1;
      if (channelNumber == 13){
        if (btn[13].mem ==0) return 0;
        else return 1;
      if (channelNumber == 14){
        if (btn[14].mem ==0) return 0;
        else return 1;
      if (channelNumber == 15){
        if (btn[15].mem ==0) return 0;
        else return 1;
       btn[0].mem =val;
       btn[1].mem =val;
       btn[2].mem =val;
       btn[3].mem =val;
       btn[4].mem =val;
       btn[5].mem =val;
       btn[6].mem =val;
       btn[7].mem =val;
       btn[8].mem =val;
       sr.set(8, val); // set single pin
       btn[9].mem =val;
       sr.set(9, val); // set single pin
       btn[10].mem =val;
       sr.set(10, val); // set single pin
       btn[11].mem =val;
       sr.set(11, val); // set single pin
       btn[12].mem =val;
       sr.set(12, val); // set single pin
       btn[13].mem =val;
       sr.set(13, val); // set single pin
       btn[14].mem =val;
       sr.set(14, val); // set single pin
       btn[15].mem =val;
       sr.set(15, val); // set single pin
  return;
      return;
                     continue;
         } else {
         Serial.print(i);
         EEPROM.commit();
                //     continue;
        // } else {
         Serial.print(epr);
      startEeprom = false;                //  --- once finished we do not need more
  EEPROM.begin(512);
  } else {
      if (configFile) {
        } else {
  } else {
  SuplaDevice.addRelay(109, false);
  SuplaDevice.addRelay(110, false);
  SuplaDevice.addRelay(111, false);
  SuplaDevice.addRelay(112, false);
  SuplaDevice.addRelay(113, false);
  SuplaDevice.addRelay(114, false);
  SuplaDevice.addRelay(115, false);
  SuplaDevice.addRelay(116, false);
  btn[0].mem =0;
  btn[1].mem =0;
  btn[2].mem =0;
  btn[3].mem =0;
  btn[4].mem =0;
  btn[5].mem =0;
  btn[6].mem =0;
  btn[7].mem =0;
  btn[8].pin =22;          // pin gpio buton  0 = no buton
  btn[8].relay_pin =109;  // pin gpio Relay
  btn[8].channel =8;      // channel
  btn[8].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[8].mem =0;
  btn[9].pin =22;          // pin gpio buton  0 = no buton
  btn[9].relay_pin =110;  // pin gpio Relay
  btn[9].channel =9;      // channel
  btn[9].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[9].mem =0;
  btn[10].pin =22;          // pin gpio buton  0 = no buton
  btn[10].relay_pin =111;  // pin gpio Relay
  btn[10].channel =10;      // channel
  btn[10].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[10].mem =0;
  btn[11].pin =22;         // pin gpio buton  0 = no buton
  btn[11].relay_pin =112;  // pin gpio Relay
  btn[11].channel =11;      // channel
  btn[11].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[11].mem =0;
  btn[12].pin =22;         // pin gpio buton  0 = no buton
  btn[12].relay_pin =113;  // pin gpio Relay
  btn[12].channel =12;      // channel
  btn[12].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[12].mem =0;
  btn[13].pin =22;         // pin gpio buton  0 = no buton
  btn[13].relay_pin =114;  // pin gpio Relay
  btn[13].channel =13;      // channel
  btn[13].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[13].mem =0;
  btn[14].pin =22;         // pin gpio buton  0 = no buton
  btn[14].relay_pin =115;    // pin gpio Relay
  btn[14].channel =14;      // channel
  btn[14].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[14].mem =0;
  btn[15].pin =22;          // pin gpio buton  0 = no buton
  btn[15].relay_pin =116;  // pin gpio Relay
  btn[15].channel =15;      // channel
  btn[15].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[15].mem =0;
  supla_btn_init();
  SuplaDevice.setName("Supla 8x16");
                     continue;
         } else {
        eep = EEPROM.read(i);               //  ---read relay state
         Serial.print("Recover.");
         Serial.print(i);
       // if (eep == HIGH){                    //  --- if 1 send relay on
          sr.set(btn[i].channel, eep); // set single pin
          //SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
void loop() {
  drd.loop();
    if (!configFile) {
    configFile.close();
    //end save
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
  if (epr<BTN_COUNT){
    epr = 0 ;
     startEeprom = true;
    break;
    case 9:      // --------------------- DISCONNECTED  ----------------------
    svr_update = 5000;
    break;
    case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    svr_update = 5000;
    break;
        if ( size > 0 ) {
        return -1;
         client.stop();
       WiFi_up();
          return cb;
  if (millis() > wifimilis)  {
  WiFi.begin();
    if (x == 1){
    wifimilis = (millis() + wifi_checkDelay) ;
     return; // break;
    else
     yield();
     delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.print(rssi);
  else
    Serial.println("");
elmaya
Wed Nov 28, 2018 5:37 pm
It is fascinating
More than 5000 visits and not even a comment
Thu Nov 29, 2018 5:05 pm
nice Job but I have Errors:
8 buttons and 8 relays in esp with hc595 :
line 424:
error:
C:\Documents and Settings\RK\Moje dokumenty\Arduino\Wemos_8_przek\Wemos_8_przek.ino: In function 'void setup()':
Wemos_8_przek:311: error: 'DynamicJsonBuffer' was not declared in this scope
C:\Documents and Settings\RK\Moje dokumenty\Arduino\Wemos_8_przek\Wemos_8_przek.ino:311:9: note: suggested alternative:
In file included from K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\ArduinoJson\src/ArduinoJson/DynamicJsonDocument.hpp:10:0,
                 from K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\ArduinoJson\src/ArduinoJson.hpp:9,
                 from K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\ArduinoJson\src/ArduinoJson.h:9,
                 from C:\Documents and Settings\RK\Moje dokumenty\Arduino\Wemos_8_przek\Wemos_8_przek.ino:12:
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\ArduinoJson\src/ArduinoJson/Memory/DynamicJsonBuffer.hpp:159:5: note:   'ArduinoJson::Internals::DynamicJsonBuffer'
     DynamicJsonBuffer;
Wemos_8_przek:311: error: expected ';' before 'jsonBuffer'
Wemos_8_przek:312: error: 'jsonBuffer' was not declared in this scope
Wemos_8_przek:314: error: 'class ArduinoJson::JsonObject' has no member named 'success'
C:\Documents and Settings\RK\Moje dokumenty\Arduino\Wemos_8_przek\Wemos_8_przek.ino: In function 'void loop()':
Wemos_8_przek:424: error: 'DynamicJsonBuffer' was not declared in this scope
C:\Documents and Settings\RK\Moje dokumenty\Arduino\Wemos_8_przek\Wemos_8_przek.ino:424:5: note: suggested alternative:
     DynamicJsonBuffer;
Wemos_8_przek:424: error: expected ';' before 'jsonBuffer'
Wemos_8_przek:425: error: 'jsonBuffer' was not declared in this scope
Wemos_8_przek:434: error: 'class ArduinoJson::JsonObject' has no member named 'prettyPrintTo'
Wemos_8_przek:435: error: 'class ArduinoJson::JsonObject' has no member named 'printTo'
exit status 1
EDIT:
the problem was the json library. It must be in ver 5.13.3 . Not higher
Thu Nov 29, 2018 7:35 pm
Compiles, uploads the firmware. after reboot the diode will flash twice, SuplaAP appears but does not give an IP address.
elmaya
Thu Nov 29, 2018 7:54 pm
Thu Nov 29, 2018 9:11 pm
OK. IT work . BUT !: You have to manually set the computer's wifi card IP address: 192.168.4.2 and the mask 255.255.255.0
Automatically, the ESP module will not do it.
It works great.
elmaya
Mon Dec 03, 2018 2:06 pm
Compiled firmware
supla_595_8x16_10K-ntc.rar
(237.84 KiB) Downloaded 44 times
supla_595_8x8_10K-ntc.rar
(237.56 KiB) Downloaded 56 times
elmaya
Fri Jan 25, 2019 6:53 pm
16 push button, 16 relay
PORTS SETTINGS:
GPIO5 /D1 Switching_Relay_Button Channel 1- On the port must be pull-up. Active - connect to GND
GPIO4 /D2 Switching_Relay_Button Channel 2- On the port must be pull-up. Active - connect to GND
GPIO2 /D4 Switching_Relay_Button Channel 3- On the port must be pull-up. Active - connect to GND
GPI14 /D5 Switching_Relay_Button Channel 4- On the port must be pull-up. Active - connect to GND
GPIO12/D6 Switching_Relay_Button Channel 5- On the port must be pull-up. Active - connect to GND
GPIO13/D7 Switching_Relay_Button Channel 6- On the port must be pull-up. Active - connect to GND
GPIO3 /RX Switching_Relay_Button Channel 7- On the port must be pull-up. Active - connect to GND
GPIO1 /TX Switching_Relay_Button Channel 8- On the port must be pull-up. Active - connect to GND
Channel 9 to 16 A0 with resistive divider 8 x 1kohm
GPIO15/D8 shift registers, data pin 14 on 74595
GPIO16/D0 shift registers, clock pin 11 on 74595
GPIO0 /D3 shift registers, latch pin 12 on 74595
fisrt shift registers Q7´pin 9 ,to second shift registers data pin 14
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
ShiftRegister74HC595 sr (2, 15, 16, 0); // create shift register object (number of shift registers, data pin 14 on 74595, clock pin 11 on 74595, latch pin 12 on 74595)
#include <math.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
extern "C"
#include "user_interface.h"
int uno = 1;
int an;
int buttonValue = 0;
unsigned long eep_milis;
unsigned long an_milis;
WiFiClient client;
byte mac[6];
    if (!wifiManager.startConfigPortal("Supla16x16")) {
      delay(3000);
      ESP.restart();
      delay(5000);
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  bool mem;
} _btn_t;
  char v;
           if (v==0)
                 } else {
                 } else {
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
        else return 1;
       btn[0].mem =val;
       btn[1].mem =val;
       btn[2].mem =val;
       btn[3].mem =val;
       btn[4].mem =val;
       btn[5].mem =val;
       btn[6].mem =val;
       btn[7].mem =val;
       btn[8].mem =val;
       btn[9].mem =val;
       btn[10].mem =val;
       btn[11].mem =val;
       btn[12].mem =val;
       btn[13].mem =val;
       btn[14].mem =val;
       btn[15].mem =val;
  return;
      return;
                     continue;
         } else {
         Serial.print(i);
         EEPROM.commit();
                //     continue;
        // } else {
         Serial.print(epr);
  wifi_set_sleep_type(NONE_SLEEP_T);
  EEPROM.begin(512);
  } else {
  if (WiFi.SSID()==""){  //Serial.println("We haven't got any access point credentials, so get them now");
      if (configFile) {
        } else {
      } else {
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  btn[0].mem =0;
  btn[1].mem =0;
  btn[2].mem =0;
  btn[3].mem =0;
  btn[4].mem =0;
  btn[5].mem =0;
  btn[6].mem =0;
  btn[7].mem =0;
  btn[8].mem =0;
  btn[9].mem =0;
  btn[10].mem =0;
  btn[11].mem =0;
  btn[12].mem =0;
  btn[13].mem =0;
  btn[14].mem =0;
  btn[15].mem =0;
  supla_btn_init();
  SuplaDevice.setName("Supla16x16");
                     continue;
         } else {
       if (eep > uno ){
         EEPROM.write(i,uno);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print(i);
void loop() {
  drd.loop();
  if (initialConfig){
        EEPROM.write(i,0);
    ondemandwifiCallback () ;
    if (!configFile) {
    configFile.close();
    ESP.restart();
    delay(5000);
    WiFi_up();
  //if (millis() > an_milis){
   analog_switch();
    //an_milis = an_milis + 200;
  if (millis() > eep_milis){
     eep_milis = eep_milis + 5000 ;
  if (epr<BTN_COUNT){
    break;
    epr = 0 ;
     startEeprom = true;
    break;
        if ( size > 0 ) {
        return -1;
         client.stop();
       WiFi_up();
          cb.get_temperature = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
  WiFi.begin();
    if (x == 1){
     break;
    else
     yield();
     delay(500);
      Serial.print(".");
  if (WiFi.status() == WL_CONNECTED){
    Serial.println("");
    Serial.print(rssi);
  else
    Serial.println("");
void analog_switch(){
  buttonValue = analogRead(A0); //Read analog value from A0 pin
  if (buttonValue<=50){   //For no button:
  delay (100);
  return;
  else
   delay (50);
   Serial.print ("analog read: ");
   Serial.println(buttonValue);
  if (buttonValue>=113 && buttonValue<=153){ //For 1st button:
    Serial.println("read: 9 ");
    an = 8;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=256 && buttonValue<=296){//For 2nd button:
    Serial.println("read: 10 ");
    an = 9;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=389  && buttonValue<=429){//For 3rd button:
    Serial.println("read: 11 ");
    an = 10;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=525  && buttonValue<=565){//For 4th button:
    Serial.println("read: 12 ");
    an = 11;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=654  && buttonValue<=694){//For 5rd button:
    Serial.println("read: 13 ");
    an = 12;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=796  && buttonValue<=836){//For 6th button:
    Serial.println("read: 14 ");
    an = 13;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=930  && buttonValue<=970){//For 7rd button:
    Serial.println("read: 15 ");
    an = 14;
    analogRelay() ;
    delay (500);
    return;
  else if (buttonValue>=1000 ){//For 8th button:
    Serial.println("read: 16 ");
    an = 15;
    analogRelay() ;
    delay (500);
    return;
void analogRelay(){
   if ( btn[an].ms > 0 ) {
                     SuplaDevice.relayOn(btn[an].channel, btn[an].ms);
                 } else {
                 if ( (btn[an].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[an].channel);
                  Serial.println(btn[an].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[an].channel, 0);
             delay (500);
Initial parameters for "ESP Falsh Download Tool":
CreystalFreq 26M
SPI SPEED 40 MHz
SPI MODE QIO
BAUDRATE 11520
FLASH SIZE 32Mbit (4MByte)
supla_595_reset_to_Config16_x16.bin ------------> 0x00000
// CFG MODE - SWITCH
To bring the device into configuration mode, in this case press Reset_Button 2 times
When in configuration mode, the device goes into Access Point mode.
In order to enter or change the settings, you need to:
- Sign in at https://cloud.supla.org (registration is free of charge)
- Connect to WiFi called (Supla16x16) from any computer with a wireless network card and Internet browser.
- Open access page: http://192.168.4.1
- Enter user name and password to the WiFi through which the device will get Internet access.
- Enter Server address, Location ID and Location Password, which will be provided once you sign in at cloud.supla.org
supla_595_reset_to_Config16_x16.rar
(456.53 KiB) Downloaded 35 times
selo
Sun Mar 24, 2019 12:32 am
Thanks for this.
How can i use it for roller shutters?
Post Reply
