Supla ova Virtual Machine
Post Reply
tecnico_asc
Post by tecnico_asc » Mon Apr 01, 2019 10:19 am
Hello Everybody,
I tried to download and install a supla cloud server using the Supla-Server.ova. I am not able to use it. Is there someone that can help me with a guide or other download?
Thanks in advance.
Contact:
Re: Supla ova Virtual Machine
Post by pzygmunt » Mon Apr 01, 2019 10:20 am
What processor do you have?
PS.
Instead of a virtual machine, you can use the docker.
https://github.com/SUPLA/supla-docker
tecnico_asc
Post by tecnico_asc » Mon Apr 01, 2019 10:55 am
Thanks for your reply. So I need to install debian server VM and then I've to do the procedure in your link. Isn't it?
Contact:
Post by pzygmunt » Mon Apr 01, 2019 11:17 am
You can use any host to run a SUPLA working in containers.
However, the most convenient will be Debian. You can also use Container Station in QNAP if you have one.
tecnico_asc
Post by tecnico_asc » Mon Apr 01, 2019 1:56 pm
Sorry, can you please help me with the attached error?
fracz
Post by fracz » Mon Apr 01, 2019 3:06 pm
You have something on the port 80 already. Check out the Troubleshooting section here https://github.com/SUPLA/supla-docker/b ... leshooting
tecnico_asc
Post by tecnico_asc » Mon Apr 01, 2019 3:26 pm
Thanks, I solved using OVA on Virtualbox
Post Reply
