Android App
ElCid
I have remove all my post. You asked me to post here for help. You did not help. Then you tried to use these posts to cover the bad rating i gave due to App not working.
- Been thanked: 59 times
Officially, we do not support TV boxes.
Here you can find an unofficial version with unlocked landspace mode. (Not all windows work correctly in this mode)
https://drive.google.com/file/d/1PKG0Up ... p=drivesdk
Ethernet - We do not block communication via Ethernet. Please check your router settings if it blocks ports 2016,2015,443. They should not be blocked.
ElCid
You must unlock the ability to install applications outside of Google Play. As I mentioned. Supla officially does not support TV. We plan to introduce TV support in the future.
ElCid
ElCid
ElCid
