Hello,
I installed supla-docker on raspberry -> all ok
I interfaced it with supla-script -> all ok
Now I'm trying to interface it to Alexa but I can't, this is the answer:
We could not connect to your SUPLA Cloud instance. Your istance is not registered or is trying to authorize an application that is not published.
I don't know how to register the instance. Any indication?
PS: when an English version of supla-script?
Thanks
Supla-docker on Raspberry Pi3B+ with Alexa
Atzek
Thanks for the reply.
I think I have problems with the SSL certificate
Do you use free certificates?
- Been thanked: 59 times
You can use free certificates like Let’s Encrypt.
To test the certificate, use the following command.
openssl s_client -showcerts -connect yourdomain.com:443SUPLA.... Nareszcie w domu.
Atzek
pi@raspberrypi:~ $ openssl s_client -showcerts -connect ************** 43CONNECTED(00000003)
depth=0 C = PL, ST = SUPLA, L = SUPLA, O = SUPLA, CN = SUPLA
verify error:num=18:self signed certificate
verify return:1
verify return:1
Certificate chain
0 s:C = PL, ST = SUPLA, L = SUPLA, O = SUPLA, CN = SUPLA
i:C = PL, ST = SUPLA, L = SUPLA, O = SUPLA, CN = SUPLA
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Server certificate
subject=C = PL, ST = SUPLA, L = SUPLA, O = SUPLA, CN = SUPLA
issuer=C = PL, ST = SUPLA, L = SUPLA, O = SUPLA, CN = SUPLA
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: RSA
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 1586 bytes and written 438 bytes
Verification error: self signed certificate
New, TLSv1.2, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-GCM-SHA384
Session-ID: 152DE6E77FC4EE5B9B19A2F86294FDD7E5CC000D5F95997FF48CAF65BB5496B0
Session-ID-ctx:
Master-Key: 1F81B0076AAADF1FCB89309AEB19CA60E41F82527E15C44D3A2FB135221ABE0D5F254628AA6982B37771C68DD55227EB
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 300 (seconds)
TLS session ticket:
0000 - 4e ba e1 b9 d2 77 f7 e8-6f e5 1b 7d 06 17 01 2d N....w..o..}...-
0010 - 89 d8 ca d5 97 74 6e a0-4e f6 7b ca b2 46 ef ae .....tn.N.{..F..
0020 - 07 9e 02 f6 ca b8 41 00-8b 15 34 2f 41 09 a8 db ......A...4/A...
0030 - b5 6c ed 06 59 89 ac 38-11 22 8d 1f 77 0e 05 e3 .l..Y..8."..w...
0040 - c4 2f 22 38 13 f3 2a d6-ca 56 c9 2a 5d e7 24 4e ./"8..*..V.*].$N
0050 - 1e a7 62 50 cc cd b7 5d-43 bc dc 55 7b 03 88 73 ..bP...]C..U{..s
0060 - 6f 24 17 db aa 2d c6 51-da 6d 2e b7 19 ca a8 69 o$...-.Q.m.....i
0070 - c2 0b 2c c5 4e 2d 24 8e-60 21 0d 9d 0c f2 21 6a ..,.N-$.`!....!j
0080 - 26 85 52 3f 92 46 c7 98-cd 7c c4 7a 33 3b 42 f5 &.R?.F...|.z3;B.
0090 - 2f ab 57 b7 35 ac 44 c9-18 48 0e ed 44 a6 b7 73 /.W.5.D..H..D..s
00a0 - 36 3e af 10 4e 2b 12 df-e6 9a 7e 6e 04 b3 e8 ea 6>..N+....~n....
00b0 - 69 95 9d 0f 3a f0 21 bb-57 c1 97 5d 9d 10 a0 0a i...:.!.W..]....
00c0 - 55 76 55 9f 5a 1e d9 37-ab d2 20 ee f3 cc e5 72 UvU.Z..7.. ....r
Start Time: 1567268450
Timeout : 7200 (sec)
Verify return code: 18 (self signed certificate)
Extended master secret: no
closedNow i try let's encrypt
Atzek
ok everything works.
I followed these post:
installation on Rpi --> viewtopic.php?f=23&t=4081
registration --> viewtopic.php?p=42333#p42333
tnx
tnx
