SuplaDevice - otwieranie linków
daniel
Witam, potrzebuję Waszej pomocy. Tworzę szkic w Arduino IDE dla ESP8266 gdzie rdzeń programu ma być umieszczony w funkcji supla_timer(). Próbuję wywołać z niej funkcję openLink(), niestety https.GET() z tego miejsca zwraca -1 a wywołany z setup() działa poprawnie.
 * Supla.org NodeMCU WiFi minimal example
 * Author: Programistyk - Kamil Kaminski <[email protected]>
 * This example shows how to configure SuplaDevice for building for NodeMCU within Arduino IDE
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
int v;
int v1;
WiFiClient client;
// Setup Supla connection
const char* ssid     = ".......";
const char* password = ".......";
void setup() {
  Serial.begin(9600);
  delay(10);
  // Replace the falowing GUID
  char GUID[SUPLA_GUID_SIZE] = {.....};
  // Ethernet MAC address
  uint8_t mac[6] = {.......};
  // CHANNEL0 - RELAY
  SuplaDevice.addRelay(D1);           // 44 - Pin number where the relay is connected
                                      // Call SuplaDevice.addRelay(44, true) with an extra "true" parameter
                                      // to enable "port value inversion"
                                      // where HIGH == LOW, and LOW == HIGH
  SuplaDevice.setTimerFuncImpl(&supla_timer);
                    "svrX.supla.org",  // SUPLA server address
                    0000,                 // Location ID
                    "....");               // Location Password
   openLink();
void loop() {
  SuplaDevice.iterate();
void supla_timer() {
  v = digitalRead(D1);
  if (v != v1){
    Serial.println(v);
    openLink();
  v1 = v;
void openLink() {
  std::unique_ptr<BearSSL::WiFiClientSecure>client1(new BearSSL::WiFiClientSecure);
  client1->setInsecure();
  HTTPClient https;
  if (https.begin(*client1, "https://supla.fracz.com/api/scenes/public/..........")) {  // HTTPS
    Serial.println("[HTTPS] GET...");
    int httpCode = https.GET();
    Serial.println(httpCode);
    // httpCode will be negative on error
    if (httpCode > 0) {
      // HTTP header has been send and Server response header has been handled
      Serial.printf("[HTTPS] GET... code: %d\n", httpCode);
      // file found at server?
      if (httpCode == HTTP_CODE_OK) {
        String p = https.getString();
        Serial.println(String("[HTTPS] Received: ") + p);
    } else {
      Serial.printf("[HTTPS] GET... failed, error: %s\n\r", https.errorToString(httpCode).c_str());
    https.end();
  } else {
    Serial.printf("[HTTPS] Unable to connect\n\r");
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       // Serial.println("WiFi init");
        WiFi.begin(ssid, password);
            delay(500);
        //    Serial.print(".");
        //Serial.print("\nlocalIP: ");
        //Serial.println(WiFi.localIP());
        //Serial.print("subnetMask: ");
        //Serial.println(WiFi.subnetMask());
        //Serial.print("gatewayIP: ");
        //Serial.println(WiFi.gatewayIP());
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
Co robię nie tak :roll: ?
