Welcome to the ioT world
Pelikano
Welcome to the world of iot! Till now it is very good loocking but I do not see how I can make my own devices. I am using esp8266 and other iot platforms but would like to try Supla. I am honored to be the first user.
To help Supla become populair, some more information is needed. For example, manual or sketches. Will there be an Arduino library?
best regards,
Leon
Hi. Thank you for your interest. For beginning you can run "SUPLA WiFi Socket" on your ESP8266 module. All you nead to do is:
1. Flash firmware to the chip, it is avaiable at
https://github.com/SUPLA/ESP8266/tree/m ... t-firmware
or
https://github.com/SUPLA/ESP8266/tree/m ... are-gpio54
the different between firmware images is an GPIO PORTS definitions.
Sources: https://github.com/SUPLA/supla-core/tre ... SP8266_IOT
2. Run the device and connect it to the SUPLA server. To do this, please read user manual
https://www.supla.org/download/wifisocket-manual-en.pdf
You can also run supla device based on any raspberry pi.
To do this, just move this card image:
https://www.supla.org/download/rbpiext01.zip
on to your SD Card, and fill location settings in /boot/location.txt file
(Card size: minimum 3GB)
Regarding to Arduino. Software will be ready until 29 feb 2016
Return to “General discussion”
