Sonoff Touch
elmaya
soft compatible with Sonoff Touch T1 (1 Gang),
(2 Gang) and (3 Gang) + DS18B20 on Gpio 3 (RX)
state memory (on/off) in case of power failure.
configurable as bistable (light switch) or as monostable (stairs timer),
if we select light switch in the cloud the touch works as on/off,
if we select stairs timer in the cloud (after cycling on/off from the App ) the touchpad turns on for the same time as the App (it learns in time),
to return to bistable mode (light switch) we only have to change in the cloud and cycle on/off from the App.
full offline functionality.
WiFiConfig = Gpio0 10 seconds (the first Touch, channel 0)
Led on = not connected-connecting.
led blinks = WiFiConfig.
Led off = OK
To bring the device into configuration mode,hold the first touch for at least 10 seconds
When in configuration mode, the device goes into Access Point mode.
In order to enter or change the settings, you need to:
- Sign in at https://cloud.supla.org (registration is free of charge)
- Connect to WiFi called „Supla_Touch” from any computer with a wireless network card and Internet browser.
- access: http://192.168.4.1
- Enter user name and password to the WiFi through which the device will get Internet access.
- Enter Server address, Location ID and Location Password, which will be provided once you sign in at cloud.supla.org
- Supla Device Name (name with which it will be seen in the cloud)
- username and password for OTA Firmware update.
read-only field for Supla Last State.
- To finish click on Save to save the configuration data.
WiFi Firmware update (OTA) = http://"IP":81/update
username and password = defined in WiFiConfig
Supla_Touch_T1_DOUT_8Mbit.rar
with inverted LED function:
Led off = not connected-connecting.
Led on = OK
supla_Touch_T1_LEDi_DOUT_8Mbit.rar
elmaya
Arduino Sketch:
#include <FS.h>           // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define CUSTOMSUPLA_CPP
#include <CustomSupla.h>  //  ------ V 1.6.2C -------
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <Ticker.h>
#include <OneWire.h>
extern "C"
#include "user_interface.h"
 * Touch x 3 ESP8285
GPIO0 Touchpad # 1
GPIO9 Touchpad # 2
GPIO10 Touchpad # 3
GPIO12 Relay # 1
GPIO5 Relay # 2
GPIO4 Relay # 3
GPIO13 Blue LED
GPIO1 TX pin
GPIO3 RX pin Temperature DS18b20
#define ONE_WIRE_BUS 3
#define status_led 13   //      ----------------------- status Led -----------------------
#define BTN_COUNT 3
int relay_1 = 12;   //------------------- set relay Gpio -----
int relay_2 = 5;
int relay_3 = 4;
int button_1 = 0;   //------------------- set button Gpio ----
int button_2 = 9;
int button_3 = 10;
OneWire oneWire(ONE_WIRE_BUS);
DeviceAddress tempDeviceAddress;
DeviceAddress Thermometer_1;
int  resolution = 10;
Ticker ticker;
bool pr_wifi = true;
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int cero = 0;
unsigned long wifi_checkDelay = 60000;
unsigned long wifimilis;
unsigned long eep_milis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000;               // config delay 10 seconds
bool tikOn = false;
bool booton_action = false;
WiFiClient client;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
char Supla_status[51];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int timeout = 180;
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void tick(){
  //toggle Led state
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
  ticker.attach(1.0, tick);
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
  WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
  WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
  WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
  WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly");
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.addParameter(&custom_Supla_server);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_update_username);
  wifiManager.addParameter(&custom_update_password);
  wifiManager.addParameter(&custom_Supla_status);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla_Touch")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
    ticker.detach();
    digitalWrite(status_led, HIGH);
   double t = -275;
    if ( sensors.getDeviceCount() > 0 ){ sensors.requestTemperatures();}
         t = sensors.getTempCByIndex(0);
    return t;
void iterate_botton() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin-1);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           delay(60);
           if (v==0)
              booton_action = true;
              if ( btn[a].ms > 10 ) {
                 if ( digitalRead(btn[a].relay_pin-1) == 1 ) {
                  CustomSupla.relayOff(a);
                  Serial.print("BTN Switsh off monostable relay: ");
                  Serial.println(a);
                 } else {
                  CustomSupla.relayOn(btn[a].channel, btn[a].ms);
                  Serial.print("monostable time: ");Serial.println(btn[a].ms);
              } else {
                 if ( (btn[a].mem) == 1 ) {
                  CustomSupla.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin-1);
                 } else {
                  CustomSupla.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
        pinMode(btn[a].pin-1, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin-1);
        btn[a].last_time = millis();
        pinMode(btn[a].relay_pin-1,OUTPUT);
int supla_DigitalRead(int channelNumber, uint8_t pin) {
     return digitalRead(btn[channelNumber].relay_pin-1);
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
     btn[channelNumber].mem =val;
           if ( (btn[channelNumber].mem) == 0 ) {
                  Serial.print("Switsh off relay ");
                  Serial.println(btn[channelNumber].relay_pin-1);
                  digitalWrite(btn[channelNumber].relay_pin-1, LOW);
                  eep_milis = millis() + 2000 ;
                 }else {
                  Serial.print("Switsh on relay ");
                  digitalWrite(btn[channelNumber].relay_pin-1, HIGH);
     if ((booton_action == false) && (CustomSupla.channel_pin[channelNumber].DurationMS != btn[channelNumber].ms)) {
            int durationMS = CustomSupla.channel_pin[channelNumber].DurationMS;
             if (durationMS < 0 ) durationMS = 0;
               Serial.print("button_duration: ");Serial.print(durationMS);
               Serial.print(" button: ");Serial.println(channelNumber);
               EEPROM.put((channelNumber * 10) + 200, durationMS);
               EEPROM.commit();
               btn[channelNumber].ms = durationMS;
  return;
void Eeprom_save() {
        if (start){
          return;
      for(int e=0;e<BTN_COUNT;e++) {
         if ( btn[e].ms > 0 ) {
        eep = (btn[e].mem);
        if (EEPROM.read(e) != 0){
         EEPROM.write(e,0);
         Serial.print(" channel monostable, mem off: ");
         Serial.println((btn[e].channel));
         EEPROM.commit();
        continue;
         } else {
        eep = (btn[e].mem);
        if (eep != EEPROM.read(e)){
         EEPROM.write(e,eep);
         Serial.print("EEPROM.");
         Serial.print(e);
         Serial.print(" write.");
         Serial.print((eep));
         Serial.print(" channel ");
         EEPROM.commit();
void Eepron_read() {
       if ( btn[epr].ms > 10 ) {
         return;
       } else {
         eep = EEPROM.read(epr);
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
          if (eep == HIGH){
            CustomSupla.relayOn(epr, 0);
void status_func(int status, const char *msg) {
  if (s != status){
     s=status;
     Serial.print("status: ");
     Serial.println(s);
         if (status != 10){
      strcpy(Supla_status, msg);
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  //Serial.begin(115200);
  delay(200);
  pinMode(status_led,OUTPUT);
  digitalWrite(status_led, LOW);
  EEPROM.begin(512);
  sensors.begin();
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  oneWire.reset_search();
  if (!oneWire.search(Thermometer_1)) Serial.println("Unable to find address for Thermometer 1");
  sensors.setResolution(Thermometer_1, resolution);
  sensors.setWaitForConversion(false);
  if (WiFi.SSID()==""){
    initialConfig = true;
  WiFi.mode(WIFI_STA);
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  CustomSupla.addRelay(101, false);
  CustomSupla.addRelay(102, false);
  CustomSupla.addRelay(103, false);
  CustomSupla.addDS18B20Thermometer();
  int btn0ms;EEPROM.get(200,btn0ms);Serial.print("initial_button_duration 0: ");Serial.println(btn0ms);
  int btn1ms;EEPROM.get(210,btn1ms);Serial.print("initial_button_duration 1: ");Serial.println(btn1ms);
  int btn2ms;EEPROM.get(220,btn2ms);Serial.print("initial_button_duration 2: ");Serial.println(btn2ms);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =button_1 +1;
  btn[0].relay_pin =relay_1 +1;
  btn[0].channel =0;
  btn[0].ms = btn0ms;
  btn[0].mem =0;
  btn[1].pin =button_2 +1;
  btn[1].relay_pin =relay_2 +1;
  btn[1].channel =1;
  btn[1].ms = btn1ms;
  btn[1].mem =0;
  btn[2].pin =button_3 +1;
  btn[2].relay_pin =relay_3 +1;
  btn[2].channel =2;
  btn[2].ms = btn2ms;
  btn[2].mem =0;
  supla_btn_init();
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
          if (json.containsKey("Location_id")) strcpy(Location_id, json["Location_id"]);
          if (json.containsKey("Location_Pass")) strcpy(Location_Pass, json["Location_Pass"]);
          if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
          if (json.containsKey("update_username")) strcpy(update_username, json["update_username"]);
          if (json.containsKey("update_password")) strcpy(update_password, json["update_password"]);
        } else {
          Serial.println("failed to load json config");
   } else {
     Serial.println("failed to mount FS");
  wifi_station_set_hostname(Supla_name);
  CustomSupla.setDigitalReadFuncImpl(&supla_DigitalRead);
  CustomSupla.setDigitalWriteFuncImpl(&suplaDigitalWrite);
  CustomSupla.setStatusFuncImpl(&status_func);
  CustomSupla.setTemperatureCallback(&get_temperature);
  CustomSupla.setName(Supla_name);
  int LocationID = atoi(Location_id);
  CustomSupla.begin(GUID, mac, Supla_server, LocationID, Location_Pass);
void loop() {
  if (initialConfig){
    for(int i=0;i<BTN_COUNT;i++){
        EEPROM.write(i, 0);
        EEPROM.put((i * 10) + 200, cero);
      EEPROM.commit();
    ondemandwifiCallback () ;
  if (start){
     if ( (btn[i].ms) > 0 ) {
      digitalWrite(btn[i].relay_pin-1, LOW);
        continue;
         } else {
        eep = EEPROM.read(i);
       if (eep >= 2 ){
         EEPROM.write(i,0);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         Serial.println((btn[i].channel));
         btn[i].mem =eep;
         digitalWrite(btn[i].relay_pin-1, eep);
                  Serial.print((btn[i].relay_pin) -1);
                  Serial.print(" set ");
                  Serial.println(eep);
    start = false;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["Supla_server"] = Supla_server;
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    json["Supla_name"] = Supla_name;
    json["update_username"] = update_username;
    json["update_password"] = update_password;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {Serial.println("failed to open config file for writing");}
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    ticker.detach();
    ESP.restart();
    delay(5000);
  if (millis() > eep_milis){
     Eeprom_save() ;
     eep_milis = millis() + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
    case 17:
    if (epr<BTN_COUNT){
     Eepron_read() ;
     epr = epr+1;
      if (tikOn == true){
        tikOn = false;
        Serial.println("supla.Ready");}
      break;
     case 10:
      epr = 0 ;
      break;
  int C_W_read = digitalRead(btn[0].pin-1);{
   if (C_W_read != last_C_W_state) {time_last_C_W_change = millis(); }
     if ((millis() - time_last_C_W_change) > C_W_delay) {
       if (C_W_read != C_W_state) {
         Serial.println("Triger sate changed");
         C_W_state = C_W_read;
         if (C_W_state == LOW) {
    last_C_W_state = C_W_read;
    CustomSupla.iterate();
    delay(50);
    iterate_botton();
   if (WiFi.status() == WL_CONNECTED){
    if (pr_wifi == true){
     Serial.println("");
     Serial.println("CONNECTED");
     Serial.print("local IP: ");
     Serial.print("subnetMask: ");
     Serial.print("gatewayIP: ");
     long rssi = WiFi.RSSI();
     Serial.print("Signal Strength (RSSI): ");
     Serial.print(rssi);
     Serial.println(" dBm");
     pr_wifi = false;
     httpUpdater.setup(&httpServer, update_path, update_username, update_password);
     httpServer.begin();
    httpServer.handleClient();
   } else {
     WiFi_up();
  if (s != 17){
    CustomSupla.iterateOfline();
    tikOn = true;
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
CustomSuplaCallbacks supla_arduino_get_callbacks(void) {
          CustomSuplaCallbacks cb;
          cb.get_temperature = &get_temperature;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){
  if (millis() > wifimilis)  {
    WiFi.begin();
    pr_wifi = true;
    tikOn = true;
    Serial.println("CONNECTING WIFI");
    wifimilis = (millis() + wifi_checkDelay) ;
edm
If there is no internet connection, there is no flash of light? no need to add a capacitor to Sonoff Touch?
Once it was necessary to add capacitors.
Sonoff Touch 1CH http://cnc.otzo.com/supla/SonoffTouch1C ... ch_1CH.jpg
Sonoff Touch 2CH http://cnc.otzo.com/supla/SonoffTouch2C ... ch_2CH.jpg
elmaya
edm wrote: Mon Apr 13, 2020 11:01 am If there is no internet connection, there is no flash of light? no need to add a capacitor to Sonoff Touch?
edm
This soft is universal to (1 Gang),
(2 Gang) and (3 Gang)?.
Is it possible to add DHT22 and BME280 support in the future by selecting from the configuration menu?.
Sorry to make it up, but it would be great (full option).
elmaya
edm wrote: Mon Apr 13, 2020 12:42 pm This soft is universal to (1 Gang),
For sonoff T1 (1 Gang),(2 Gang) and (3 Gang)
GPIO0 Touchpad # 1
GPIO9 Touchpad # 2
GPIO10 Touchpad # 3
GPIO12 Relay # 1
GPIO5 Relay # 2
GPIO4 Relay # 3
GPIO13 Blue LED
GPIO1 TX pin
ds18b20 is because in Supla it seems like a tradition."I don't understand why everything has to have a temperature measurement!"
There will be no DHT22, BME or OLED screen.
It would also look very nice hanging next to the Touch. :lol: :lol: :lol:
edm
elmaya wrote: Mon Apr 13, 2020 1:02 pm ds18b20 is because in Supla it seems like a tradition."I don't understand why everything has to have a temperature measurement!"
My goal is to use as few ESP modules with wifi as possible. Therefore, using Sonoff Touch I would like to use it to measure temperature and humidity in every room. That is why DHT22, optional BME280 pressure, ok maybe overkill or maybe not. I do not see the point of adding another ESP wifi module just to add a DHT22 sensor. Because of this, I love all in one firmware that is difficult to make.
A bit off topic. My vision is that in the main switchboard (in the garage), have the smallest required number of ESP modules for wifi (using supla solutions that interest me), and distribute the rest with cables. I have prepared the electrical installation for it, so-called on the "star".
scorpio
Elmaya, I have uploaded your software to my brand new Sonoff TX T2EU1C, and is the best.
However, I think I found small bug.
If Sonoff is connected to my Wi-Fi network, ewerything is fine. When I unplug cable from WAN port of my router, it work not as it should. Response to touch is sporadic.
But when Sonoff is not connected to any Wi-Fi, ewerything is great. Like you say: full offline functionality.
Could you check that?
elmaya
What router do you have?
scorpio
elmaya wrote: Mon May 11, 2020 6:42 pm What router do you have?
Linksys EA6400.
Return to “Ideas and concepts”
