Mail configuration problem
davidlin147
My own sever not send mail confirmation of the account creation.
this is my supla docker .env file
# Where the SUPLA Cloud will be accessible? Put domain or IP address here with port.
CLOUD_DOMAIN=115.74.124.134
# Initial user account details; delete these settings after the first launch
FIRST_USER_EMAIL=[email protected]
FIRST_USER_PASSWORD=xxxxxxxx160
# Google ReCaptcha settings
RECAPTCHA_ENABLED=false
RECAPTCHA_PUBLIC_KEY=
RECAPTCHA_PRIVATE_KEY=
# Mailer settings (SMTP)
MAILER_HOST=smtp.gmail.com
MAILER_PORT=587
MAILER_USER=[email protected]
MAILER_PASSWORD=xxxxxxx160
MAILER_ENCRYPTION=tls
MAILER_FROM=[email protected]
# If you want to be notified about some server errors, set this
ADMIN_EMAIL=
# Where to store SUPLA Cloud's data
VOLUME_DATA=./var
# On which ports the SUPLA Cloud shoAccount Activationuld listen (only if standalone mode)
PORT_HTTP=80
PORT_HTTPS=443
REQUIRE_REGULATIONS_ACCEPTANCE=false
REQUIRE_COOKIE_POLICY_ACCEPTANCE=false
BRUTE_FORCE_AUTH_PREVENTION_ENABLED=true
ACCOUNTS_REGISTRATION_ENABLED=true
# These options protect your application
DB_PASSWORD=5vKHikKhYRkH6CbxY7XU1vW2bJuJTyvP
SECRET=tD7phcwV8XQWJabF7gkqOtkQg2XmSAh8
COMPOSE_PROJECT_NAME=supla
COMPOSE_PATH_SEPARATOR=:
COMPOSE_FILE=docker-compose.yml:docker-compose.standalone.yml:docker-compose.arm32v7.yml
Someone who knows how to fix this problem, reply to help me. please.
thanks.
lukfud
Has thanked: 13 times
Been thanked: 11 times
https://support.google.com/accounts/answer/185833?hl=en
You probably need to generate an application password. I checked with port 465 (SSL) - it works.
https://smartnerzeczy.pl
davidlin147
I created application password but it does not work. I created an account but it didn't send me the activation mail.
lukfud
Change the port and encryption in the .env file and try again.
After editing the .env file, run the command:
./supla-docker/supla.sh start
davidlin147
It worked. thanks bro.
lukfud
Return to “Help”
