I have a small problem, i am doing with supla esp8266 examples well. But every time i want to add any device to supla APP, i must added it to my supla cloud account (by http//:192.168.4.1) and make configuration to add it to supla APP.
My question is how to add this supla esp8266 device directly from APP not from http//:192.168.4.1?
Can any one support me by code and the way?
Hint: i entered the device to configuration mode to add it to supla APP but every time till me there is no device found.
I tried with supla examples like(egyiot-dimmer).
Add supla-esp8266 to supla AAP dirictly
- Been thanked: 59 times
To add a module from the application level, your website 192.168.4.1 must be compatible with this template:
https://github.com/SUPLA/supla-espressi ... nter.c#L91
Ahmedragab123
Thanks for your replay.pzygmunt wrote: Thu Oct 08, 2020 8:29 am To add a module from the application level, your website 192.168.4.1 must be compatible with this template:
Can you support me by esp relay code that have this template?
To make since to me
Ahmedragab123
Can you tell me how to use this code (files) to implement arduino code? because i tried to use it but I am failed.pzygmunt wrote: Thu Oct 08, 2020 8:47 am You can find everything you need here
https://github.com/SUPLA/supla-espressif-esp
Read the code.
I really need help.
I want any valid code contain the template that i want it or give block code of template that i should replace it with any supla esp code like (supla esp general code).
Thanks.
