Sonoff Pow R2 Arduino
elmaya
To access the Wi-Fi configuration, press button for at least 5 seconds, Led winks in wificonfig.
in the configuration page enter the data for "suplaServer, Email and Supla Device Name (name with which it will be seen in the cloud and DHCP)"
expectedVoltage - for calibration.
expectedActivePower - for calibration.
clear counter - reset pulse counter.
calibration process:
connect a resistive load with a known consumption, for example a 60W bulb.
access wificonfig (button pressed 5 seconds)
in the "expectedVoltage" field set the voltage of your line for example 227.
in the "expectedActivePower" field, set the consumption of the connected load, for example 60.
press save.
The procedure takes about 15 seconds, then the device restarts and the readings will be correct.
the calibration is only executed if there are data in both fields "expectedVoltage" and "expectedActivePower"
This allows for example to change the Wi-Fi network without recalibrating.
#define supla_lib_config_h_  // silences unnecessary debug messages "should be disabled by default"
#include "LittleFS.h"
#include <SuplaDevice.h>
#include <supla/sensor/one_phase_electricity_meter.h>
#include <supla/io.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- V6 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <Ticker.h>      //for LED status
#include <ESP8266TrueRandom.h>
#include "CSE7766.h"
extern "C"
#include "user_interface.h"
GPIO00  Button1
GPIO01  CSE7766 Tx
GPIO03  CSE7766 Rx
GPIO12  Relay1
GPIO13  Led1i
#define CSE7766_RX_PIN 3
#define status_led 13
#define wificonfig_pin 0
#define relay_pin  12
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 5000;                      // config delay 5 seconds  new
int C_W_state2 = HIGH;
long C_W_delay2 = 100;
unsigned long eep_milis = 10000;
bool recover = true;
char Supla_server[81]=("Set server address");
char Email[81]=("set email address");
char Supla_name[51];
char Supla_status[51];
char Volt[8];
char Wats[8];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int s = 0;
bool starting = true;
bool Tik = true;
unsigned long  mem_energy_milis = 300000;
float mem_energy = 0;
float _mem_energy = 0;
int customFieldLength = 40;
WiFiManagerParameter custom_field;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
static const char custom_radio_str[] PROGMEM = "<br><div style='text-align:center; width:100%; padding:0;'><label for='customfieldid'>Counter mem</label><input type='radio' name='customfieldid' value='0' checked>keep Storage<input type='radio' name='customfieldid' value='1'>clear Storage</div>";
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
Ticker ticker;
Supla::ESPWifi wifi("", "");  //------ Do not edit----wifimanager takes care------
Supla::Control::Relay *relay1 = nullptr;
#define CSE7766_CURRENT_RATIO             16030
#define CSE7766_VOLTAGE_RATIO             190770
#define CSE7766_POWER_RATIO               5195000
CSE7766 myCSE7766;
class MyCSE7766 : public Supla::Sensor::OnePhaseElectricityMeter {
    public:
        MyCSE7766()  {
        void onInit() {
            readValuesFromDevice();
            updateChannelValues();
        virtual void readValuesFromDevice() {
          myCSE7766.handle();
            // voltage in 0.01 V
            setVoltage(0,myCSE7766.getVoltage() * 100);
            // current in 0.001 A
            setCurrent(0, myCSE7766.getCurrent() * 1000);
            // power in 0.00001 kW
            setPowerActive(0, myCSE7766.getActivePower() * 100000);
            // energy in 0.00001 kWh
            setFwdActEnergy(0, ((float)myCSE7766.getEnergy() + mem_energy) / 6 / 6 );
            // power in 0.00001 kVA
            setPowerApparent(0, myCSE7766.getApparentPower() * 100000);
            // power in 0.00001 kvar
            setPowerReactive(0, myCSE7766.getReactivePower() * 100000);
            // power in 0.001
            setPowerFactor(0, myCSE7766.getPowerFactor() * 1000);
            //float powerFactor = 0; setPowerFactor(0, powerFactor * 1000);
void tick() {
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void calibrate_CSE7766() {
   int ex_volt = atoi(Volt);
   int ex_pow = atoi(Wats);
   double ex_amps = ((float)ex_pow / (float)ex_volt);
   digitalWrite(relay_pin,HIGH);
    myCSE7766.handle();
    unsigned long timeout1 = millis();
    while ((millis() - timeout1) < 10000) { delay(10);}
    myCSE7766.handle();
    myCSE7766.expectedPower(ex_pow);
    myCSE7766.expectedVoltage(ex_volt);
    myCSE7766.expectedCurrent(ex_amps);
    unsigned long timeout2 = millis();
    while ((millis() - timeout2) < 2000) {delay(10);}
    double current_multi = myCSE7766.getCurrentRatio();
    double voltage_multi = myCSE7766.getVoltageRatio();
    double power_multi = myCSE7766.getPowerRatio();
    EEPROM.put(400, current_multi);
    EEPROM.put(410, voltage_multi);
    EEPROM.put(420, power_multi);
    EEPROM.write(430, 60);
    EEPROM.commit();
  yield();
void get_CSE7766_config(){
  if (EEPROM.read(430) == 60){
       double p_m;double v_m;double c_m;
        EEPROM.get(400,c_m);
         EEPROM.get(410,v_m);
          EEPROM.get(420,p_m);
           myCSE7766.setCurrentRatio(c_m);
            myCSE7766.setVoltageRatio(v_m);
             myCSE7766.setPowerRatio(p_m);
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
   ticker.attach(0.15, tick); // new (old 1.5)
   WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
   WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
   WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
   WiFiManagerParameter custom_html_id21("<div><h4> - Supla State -   ");
   WiFiManagerParameter custom_html_id22( Supla_status);
   WiFiManagerParameter custom_html_id23( "</h4></div>");
   WiFiManagerParameter custom_Volt("Volt", "expectedVoltage", Volt, 8);
   WiFiManagerParameter custom_Wats("Wats", "expectedActivePower", Wats, 8);
   new (&custom_field) WiFiManagerParameter(custom_radio_str); // custom html input
   wifiManager.setBreakAfterConfig(true);
   wifiManager.setSaveConfigCallback(saveConfigCallback);
   wifiManager.setSaveParamsCallback(saveParamCallback);
   wifiManager.addParameter(&custom_Supla_server);
   wifiManager.addParameter(&custom_Email);
   wifiManager.addParameter(&custom_Supla_name);
   wifiManager.addParameter(&custom_html_id21);
   wifiManager.addParameter(&custom_html_id22);
   wifiManager.addParameter(&custom_html_id23);
   wifiManager.addParameter(&custom_Volt);
   wifiManager.addParameter(&custom_Wats);
   wifiManager.addParameter(&custom_field);
   wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
   wifiManager.setMinimumSignalQuality(8);
   //wifiManager.setShowStaticFields(true); // force show static ip fields
   //wifiManager.setShowDnsFields(true);    // force show dns field always
   wifiManager.setConfigPortalTimeout(180);
   if (!wifiManager.startConfigPortal("Sonoff_POW_R2")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Email, custom_Email.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(Volt, custom_Volt.getValue());
    strcpy(Wats, custom_Wats.getValue());
    if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
      Serial.println("new guid & authkey.");
      EEPROM.write(300, 0);
      EEPROM.commit();
      ESP.reset();
    if ((strlen(Volt) != 0) && (strlen(Wats) != 0)){
      calibrate_CSE7766();
    WiFi.softAPdisconnect(true);   //  close AP
void status_func(int status, const char *msg) {    //    ------------------------ Status --------------------------
  if (s != status){
    s = status;
      if (s != 10){
        strcpy(Supla_status, msg);
String getParam(String name){
  String value;
  if(wifiManager.server->hasArg(name)) {
    value = wifiManager.server->arg(name);
      if (value == "1"){
        float cler = 0.0;
         EEPROM.put(460, cler);
          EEPROM.commit();
  return value;
void saveParamCallback(){
 // Serial.println("[CALLBACK] saveParamCallback fired");
 // Serial.println("PARAM customfieldid = " + getParam("customfieldid"));
void Eeprom_save(){
  if (digitalRead(relay_pin)!= EEPROM.read(431)){
    _mem_energy = (double)myCSE7766.getEnergy() + mem_energy;
    EEPROM.put(460, _mem_energy);
    EEPROM.write(431,digitalRead(relay_pin));
    EEPROM.commit();
void guid_authkey(void) {
  if (EEPROM.read(300) != 60){
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    float cler = 0.0;
    EEPROM.write(300, 60);
    EEPROM.commit();
  read_guid();
  read_authkey();
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(4800);
  Serial.println();
  EEPROM.begin(1024);
  pinMode(wificonfig_pin, INPUT_PULLUP);
  pinMode(status_led,OUTPUT);
  digitalWrite(relay_pin, EEPROM.read(431));
  guid_authkey();
  ticker.attach(0.8, tick);
  if (WiFi.SSID()==""){ initialConfig = true;}
  if (LittleFS.begin()) {  // ------------------------- wificonfig read -----------------
    Serial.println("mounted file system");
    if (LittleFS.exists("/config.json")) {
      Serial.println("reading config file");
       File configFile = LittleFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
         size_t size = configFile.size();
         std::unique_ptr<char[]> buf(new char[size]);
         configFile.readBytes(buf.get(), size);
        DynamicJsonDocument json(1024);
        DeserializationError deserializeError = deserializeJson(json, buf.get());
        serializeJsonPretty(json, Serial);
        if (!deserializeError) {Serial.println("\nparsed json");
          if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
          if (json.containsKey("Email")) strcpy(Email, json["Email"]);
          if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
        } else {
          Serial.println("failed to load json config");
        configFile.close();
   } else {
    Serial.println("failed to mount FS");
   wifi_station_set_hostname(Supla_name);
     myCSE7766.setCurrentRatio(CSE7766_CURRENT_RATIO);
     myCSE7766.setVoltageRatio(CSE7766_VOLTAGE_RATIO);
     myCSE7766.setPowerRatio(CSE7766_POWER_RATIO);
     myCSE7766.setRX(CSE7766_RX_PIN);
     myCSE7766.begin(); // will initialize serial to 4800 bps
     get_CSE7766_config();
    EEPROM.get(460, mem_energy);
    _mem_energy = mem_energy;
    relay1 = new Supla::Control::Relay(relay_pin);
    new MyCSE7766();
    SuplaDevice.setName(Supla_name);
    SuplaDevice.setStatusFuncImpl(&status_func);
    wifi.enableSSL(false);
    SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
char buffer[50];
void loop() {
  if (initialConfig == true){ondemandwifiCallback();EEPROM.write(431, 0); EEPROM.commit();}
   int C_W_read = digitalRead(wificonfig_pin);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay2) {
     if (C_W_read != C_W_state2) {
       C_W_state2 = C_W_read;
       if (C_W_state2 == LOW) {
         if (!relay1->isOn()) {
          relay1->turnOn();
          yield();
          Eeprom_save() ;
       }else{
         relay1->turnOff();
         yield();
         Eeprom_save() ;
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
        ondemandwifiCallback () ;
   last_C_W_state = C_W_read;
  if (shouldSaveConfig == true) { // ------------------------ wificonfig save --------------
    Serial.println(" config...");
    json["Supla_server"] = Supla_server;
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    File configFile = LittleFS.open("/config.json", "w");
    if (!configFile) {Serial.println("failed to open config file for writing");}
    serializeJson(json, configFile);
    delay(5000);
    configFile.close();
    Serial.println("Config written successfully");
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
  if (s == 17){
    if ((Tik == true) && (WiFi.status() == WL_CONNECTED)){ticker.detach();digitalWrite(status_led, LOW);Tik = false;}
    if(millis() > eep_milis){
     Eeprom_save() ;
     eep_milis = millis() + 3000 ;
    if (recover){
      if (EEPROM.read(431) == true){
       relay1->turnOn();
        yield();
       recover = false;
  if (((s != 17) || (WiFi.status() != WL_CONNECTED)) && (Tik == false)) { ticker.attach(0.8, tick);Tik = true; }
  if (s == 10){recover = true;}
   SuplaDevice.iterate();
   delay(25);
   if (WiFi.status() == WL_CONNECTED){
    if (starting){
      httpUpdater.setup(&httpServer, "/update", "admin", "pass"); // -- set here path, username and password for OTA. --
      httpServer.begin();
      starting = false;
    httpServer.handleClient();
   if(millis() > mem_energy_milis){
    if ((float(myCSE7766.getEnergy()) + mem_energy > _mem_energy) && (digitalRead(relay_pin) == HIGH)){
      _mem_energy = (float)myCSE7766.getEnergy() + mem_energy;
      EEPROM.commit();
     mem_energy_milis = millis() + 600000 ;
POW2_DOUT_8Mbit.rar
Sonoff_pow_2.rar
PioKar
Cześć @elmaya.
Działa super.
Koledzy pytają czy dało by się dodać DS18b20 pod io4 lub io3.
Jeśli to nie problem to poproszę .bin
Pozdrawiam.
Piotr.
elmaya
I will not add DS18B20 for your own safety.
This device does not have galvanic isolation, the DS18B20 would be connected to the "240vAC" electrical network.
it would be too dangerous!
PioKar
ok.
I tak dziękuję.
martinok
Cześć @elmaya
A czy jest szansa żeby ten soft przerobić pod listwę GOSUND P1?
https://templates.blakadder.com/gosund_P1.html
"Wiedza bez Praktyki jest Bezużyteczna , praktyka bez wiedzy Niebezpieczna"...
elmaya
martinok wrote: Fri Feb 19, 2021 8:09 am Cześć @elmaya
Do you have it or are you thinking of buying?
martinok
I have it tomorrow or Monday.
elmaya
martinok wrote: Fri Feb 19, 2021 11:30 am I have it tomorrow or Monday.
okay
It seems that the 3 buttons to turn on and off the 3 plugs are connected to the analog input, this requires some testing.
I will contact you through private for the tests. ;)
Hi,
I have Gosund P1. Today I undressed it and measured the ESP8285 leads. Something like this came out:
Gosund P1 sends an alarm to the Tuya Smart application when we overload the USB power supply.
Edit: Picture replacement.
Last edited by Robert Błaszczak on Sun Feb 21, 2021 3:48 pm, edited 2 times in total.
elmaya
@Robert Błaszczak could you add what reading is the A0 if there is no button pressed?
in Gpio4 is it in low state while the overload lasts or does USB power turn off?
on buttons 1-3 are there LEDs that indicate the status?
I think I'm going to use the white led to indicate if USB power is on / off or flashing in case of overload.
with Gpio 16 "input" to connect / disconnect USB power and WiFiConfig "10 seconds"
Return to “Sonoff POW”
