Problem ze startem GUI
@krycha88 - nawiązując do wczorajszego tematu
Dzisiaj wziąłem innego WEMOSA (oryginał lilona) D1 mini (nie lite). Zainstalowałem GUI'a 1.8.2 za pomocą PyFlashera z danymi jak podałeś.
Moduł wstał i wszedł w konfigurację więc skonfigurowałem dostęp WIFI, config button (na A0), I2C (na D2 i D1) i DS (na D5) - nic więcej. Nic jeszcze nie podłączyłem oprócz kabelka USB z zasilaniem
I znowu problem z powstaniem :(
15:58:31.441 -> Storage initialization
15:58:31.441 -> readStorage: 8; Read: [53 55 50 4C 41 1 0 0 ]
15:58:31.441 -> Storage: Number of sections 0
15:58:31.441 -> Validating storage state section with current device configuration
15:58:31.486 -> Storage state section validation completed. Loading elements state...
15:58:38.736 -> B΃KT⸮D	⸮'⸮⸮u⸮@⸮[)⸮Xx⸮z⸮
15:58:38.736 -> %	)⸮@⸮^LRA⸮	K⸮P⸮⸮T	⸮P⸮⸮⸮
15:58:38.736 -> ⸮T⸮Creating OneWire bus for pin: 14
15:58:38.872 -> Initializing OneWire bus at pin 14
15:58:38.872 -> OneWire(pin 14) Parasite power is OFF
15:58:38.872 -> OneWire(pin 14) Found 0 devices:
15:58:39.642 -> Index 0 - address
15:58:39.642 -> Index 1 - address
15:58:39.642 -> Supla - starting initialization
15:58:39.642 -> Storage initialization
15:58:39.642 -> readStorage: 8; Read: [53 55 50 4C 41 1 0 0 ]
15:58:39.642 -> Storage: Number of sections 0
15:58:39.642 -> Validating storage state section with current device configuration
15:58:39.687 -> Storage state section validation completed. Loading elements state...
15:58:47.320 -> )⸮܃IV⸮⸮	⸮T'⸮⸮u⸮B⸮+⸮uH	)z⸮        	)z⸮                 	)⸮HB⸮⸮LZP⸮В⸮C	⸮⸮T		z⸮⸮⸮⸮⸮Creating OneWire bus for pin: 14
15:58:49.445 -> Initializing OneWire bus at pin 14
15:58:49.445 -> OneWire(pin 14) Parasite power is OFF
15:58:49.490 -> OneWire(pin 14) Found 0 devices:
15:58:50.209 -> Index 0 - address
15:58:50.209 -> Index 1 - address
15:58:50.209 -> Supla - starting initialization
15:58:50.254 -> Storage initialization
15:58:50.254 -> readStorage: 8; Read: [53 55 50 4C 41 1 0 0 ]
15:58:50.254 -> Storage: Number of sections 0
15:58:50.254 -> Validating storage state section with current device configuration
15:58:50.254 -> Storage state section validation completed. Loading elements state...
15:58:57.497 ->
i tak w kółko. Nawet kod się nie chce tutaj wkleić bo znaczki zawieszają niezawodną zwykle procedurę "ctrl+c -> ctrl+v"
Jakaś podpowiedź o co chodzi?
Edit:
jeżeli to ważne to soft z buildera w wersji 4MB
Edit 2:
kolejny wemos (clon zapewne) - problemów brak. Jedna różnica: config button przeniesiony na D6 - w dalszym ciągu bez fizycznego podłączenia czegokolwiek.
Goral64
A sczyściłeś gościa przed wgraniem softu?
adamdd1
a czy konfig na A0 nie resetuje go
Goral64 wrote: Fri Mar 26, 2021 5:13 pm A sczyściłeś gościa przed wgraniem softu?
Tak jak @krycha88 zalecił. PyFlasher z opcją czyszczenia.
adamdd1 wrote: Fri Mar 26, 2021 7:22 pm a czy konfig na A0 nie resetuje go
Sam z siebie? Tylko jako ustawienie? Fizycznie nic nie podłączone. Tylko zasilanie. I nie wstaje.
Goral64
Ma widać jakiś problem z odczytem pamięci, może moduł jest walnięty?
YoMan wrote: Fri Mar 26, 2021 9:21 pm
Wątpię aby ten pin jest dobrym wyborem, czemu go nie zmienisz?
pork
Dziś wgrałem 1.8.2 4MB jako rolety, czyszczone. Po konfiguracji nie łączył się i nie było go widać w sieci.
Wersja 1MB działa. Próbowałem kilka razy i ten sam efekt.
Goral64
pork wrote: Sat Mar 27, 2021 8:23 pm Dziś wgrałem 1.8.2 4MB jako rolety, czyszczone. Po konfiguracji nie łączył się i nie było go widać w sieci.
Na co, czym wgrywasz i czyścisz?
krycha88 wrote: Sat Mar 27, 2021 12:55 am
W tym pierwszym jest pin D0 i też ma problemy. Kiedyś pisałem na forum że też nie chcial wstać jak podłączyłem przekaźniki: pierwszy na D2 a drugi na D1. Jak odwrotnie to startował bez problemów.
Return to “GUI Generic”
