Powiadomienia pushover pomimo braku spełenia warunku
bigthomas
Dziś od godziny 11:46 mam problem z czujnikiem otwarcia.
Myśląc że chińskie urządzeni uległo uszkodzeniu w warunkach polowych podłączyłem pod serial monitor i sprawdzałem kiedy zmieni się stan pinu pod który podpięty jest kontrakton:
12:40:26.798 -> Sending: [53 55 50 4C 41 C 13 0 0 0 64 0 0 0 9 0 0 0 1 0 0 0 0 0 0 0 0 ]
12:40:26.838 -> Sending: [53 55 50 4C 41 ]
12:40:34.286 -> Channel(3) value changed to 1013.12
12:40:34.286 -> Channel(2) value changed to temp(23.049999), humi(56.412109)
12:40:34.286 -> Sending: [53 55 50 4C 41 C 14 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 60 F8 A8 8F 40 ]
12:40:34.326 -> Sending: [53 55 50 4C 41 ]
12:40:34.366 -> Sending: [53 55 50 4C 41 C 15 0 0 0 64 0 0 0 9 0 0 0 2 9 5A 0 0 5C DC 0 0 ]
12:40:34.446 -> Sending: [53 55 50 4C 41 ]
12:40:44.291 -> Channel(3) value changed to 1013.7
12:40:44.291 -> Channel(2) value changed to temp(23.059999), humi(56.469727)
12:40:44.291 -> Sending: [53 55 50 4C 41 C 16 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 80 A2 A8 8F 40 ]
12:40:44.331 -> Sending: [53 55 50 4C 41 ]
12:40:44.371 -> Sending: [53 55 50 4C 41 C 17 0 0 0 64 0 0 0 9 0 0 0 2 13 5A 0 0 95 DC 0 0 ]
12:40:44.451 -> Sending: [53 55 50 4C 41 ]
12:40:47.096 -> Sending: [53 55 50 4C 41 C 18 0 0 0 28 0 0 0 10 0 0 0 52 0 0 0 0 0 0 0 86 C9 C 0 0 0 0 0 ]
12:40:47.136 -> Sending: [53 55 50 4C 41 ]
12:40:47.176 -> Received: [53 55 50 4C 41 C 5 0 0 0 32 0 0 0 10 0 0 0 2F ED DE 60 0 0 0 0 C5 3C 7 0 0 0 0 0 53 55 50 4C 41 ]
12:40:54.293 -> Channel(3) value changed to 1013.9
12:40:54.293 -> Channel(2) value changed to temp(23.070000), humi(56.680664)
12:40:54.293 -> Sending: [53 55 50 4C 41 C 19 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 40 CA A8 8F 40 ]
12:40:54.453 -> Sending: [53 55 50 4C 41 ]
12:40:54.493 -> Sending: [53 55 50 4C 41 C 1A 0 0 0 64 0 0 0 9 0 0 0 2 1D 5A 0 0 68 DD 0 0 ]
12:40:54.533 -> Sending: [53 55 50 4C 41 ]
12:41:04.306 -> Channel(3) value changed to 1013.9
12:41:04.306 -> Channel(2) value changed to temp(23.090000), humi(56.870117)
12:41:04.306 -> Sending: [53 55 50 4C 41 C 1B 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 0 C6 A8 8F 40 ]
12:41:04.346 -> Sending: [53 55 50 4C 41 ]
12:41:04.386 -> Sending: [53 55 50 4C 41 C 1C 0 0 0 64 0 0 0 9 0 0 0 2 32 5A 0 0 26 DE 0 0 ]
12:41:04.426 -> Sending: [53 55 50 4C 41 ]
12:41:12.191 -> Sending: [53 55 50 4C 41 C 1D 0 0 0 28 0 0 0 10 0 0 0 6B 0 0 0 0 0 0 0 58 21 E 0 0 0 0 0 ]
12:41:12.231 -> Sending: [53 55 50 4C 41 ]
12:41:12.271 -> Received: [53 55 50 4C 41 C 6 0 0 0 32 0 0 0 10 0 0 0 48 ED DE 60 0 0 0 0 31 75 8 0 0 0 0 0 53 55 50 4C 41 ]
12:41:14.281 -> Channel(3) value changed to 1013.11
12:41:14.281 -> Channel(2) value changed to temp(23.100000), humi(57.081055)
12:41:14.321 -> Sending: [53 55 50 4C 41 C 1E 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 EA A8 8F 40 ]
12:41:14.521 -> Sending: [53 55 50 4C 41 ]
12:41:14.561 -> Sending: [53 55 50 4C 41 C 1F 0 0 0 64 0 0 0 9 0 0 0 2 3C 5A 0 0 F9 DE 0 0 ]
12:41:14.641 -> Sending: [53 55 50 4C 41 ]
12:41:24.278 -> Channel(3) value changed to 1013.10
12:41:24.278 -> Channel(2) value changed to temp(23.129999), humi(57.224609)
12:41:24.278 -> Sending: [53 55 50 4C 41 C 20 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 60 E0 A8 8F 40 ]
12:41:24.348 -> Sending: [53 55 50 4C 41 ]
12:41:24.383 -> Sending: [53 55 50 4C 41 C 21 0 0 0 64 0 0 0 9 0 0 0 2 59 5A 0 0 88 DF 0 0 ]
12:41:24.418 -> Sending: [53 55 50 4C 41 ]
12:41:33.363 -> Received: [53 55 50 4C 41 C 7 0 0 0 F4 1 0 0 8 0 0 0 7D 1C 0 0 0 52 0 0 53 55 50 4C 41 ]
12:41:33.363 -> Sending: [53 55 50 4C 41 C 22 0 0 0 FE 1 0 0 32 0 0 0 7D 1C 0 0 0 0 0 0 B3 1 0 0 0 0 0 0 C0 A8 1 F8 F4 CF A2 68 6D 11 0 0 C1 4A 0 0 81 0 0 0 7C 0 0 0 0 0 0 0 0 0 0 0 0 0 ]
12:41:33.443 -> Sending: [53 55 50 4C 41 ]
12:41:34.283 -> Channel(3) value changed to 1013.14
12:41:34.283 -> Channel(2) value changed to temp(23.139999), humi(57.343750)
12:41:34.323 -> Sending: [53 55 50 4C 41 C 23 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 22 A9 8F 40 ]
12:41:34.363 -> Sending: [53 55 50 4C 41 ]
12:41:34.403 -> Sending: [53 55 50 4C 41 C 24 0 0 0 64 0 0 0 9 0 0 0 2 63 5A 0 0 FF DF 0 0 ]
12:41:34.483 -> Sending: [53 55 50 4C 41 ]
12:41:44.296 -> Channel(3) value changed to 1013.15
12:41:44.296 -> Channel(2) value changed to temp(23.160000), humi(57.473633)
12:41:44.296 -> Sending: [53 55 50 4C 41 C 25 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 60 34 A9 8F 40 ]
12:41:44.426 -> Sending: [53 55 50 4C 41 ]
12:41:44.466 -> Sending: [53 55 50 4C 41 C 26 0 0 0 64 0 0 0 9 0 0 0 2 77 5A 0 0 81 E0 0 0 ]
12:41:44.546 -> Sending: [53 55 50 4C 41 ]
12:41:54.321 -> Channel(3) value changed to 1013.11
12:41:54.321 -> Channel(2) value changed to temp(23.170000), humi(56.985352)
12:41:54.321 -> Sending: [53 55 50 4C 41 C 27 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 E1 A8 8F 40 ]
12:41:54.361 -> Sending: [53 55 50 4C 41 ]
12:41:54.401 -> Sending: [53 55 50 4C 41 C 28 0 0 0 64 0 0 0 9 0 0 0 2 82 5A 0 0 99 DE 0 0 ]
12:41:54.481 -> Sending: [53 55 50 4C 41 ]
12:41:58.166 -> Channel(1) value changed to 1
12:41:58.166 -> Sending: [53 55 50 4C 41 C 29 0 0 0 64 0 0 0 9 0 0 0 1 1 0 0 0 0 0 0 0 ]
12:41:58.206 -> Sending: [53 55 50 4C 41 ]
12:41:58.366 -> Sending: [53 55 50 4C 41 C 2A 0 0 0 28 0 0 0 10 0 0 0 9A 0 0 0 0 0 0 0 9C 9A 1 0 0 0 0 0 ]
12:41:58.566 -> Sending: [53 55 50 4C 41 ]
12:41:58.606 -> Received: [53 55 50 4C 41 C 8 0 0 0 32 0 0 0 10 0 0 0 76 ED DE 60 0 0 0 0 73 7E D 0 0 0 0 0 53 55 50 4C 41 ]
12:42:00.328 -> Channel(1) value changed to 0
12:42:00.328 -> Sending: [53 55 50 4C 41 C 2B 0 0 0 64 0 0 0 9 0 0 0 1 0 0 0 0 0 0 0 0 ]
12:42:00.488 -> Sending: [53 55 50 4C 41 ]
12:42:04.293 -> Channel(3) value changed to 1013.14
12:42:04.293 -> Channel(2) value changed to temp(23.180000), humi(56.916992)
12:42:04.333 -> Sending: [53 55 50 4C 41 C 2C 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 0 20 A9 8F 40 ]
12:42:04.373 -> Sending: [53 55 50 4C 41 ]
12:42:04.453 -> Sending: [53 55 50 4C 41 C 2D 0 0 0 64 0 0 0 9 0 0 0 2 8C 5A 0 0 54 DE 0 0 ]
12:42:04.493 -> Sending: [53 55 50 4C 41 ]
12:42:14.306 -> Channel(3) value changed to 1013.13
12:42:14.306 -> Channel(2) value changed to temp(23.190001), humi(56.696289)
12:42:14.306 -> Sending: [53 55 50 4C 41 C 2E 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 60 1B A9 8F 40 ]
12:42:14.386 -> Sending: [53 55 50 4C 41 ]
12:42:14.426 -> Sending: [53 55 50 4C 41 C 2F 0 0 0 64 0 0 0 9 0 0 0 2 96 5A 0 0 78 DD 0 0 ]
12:42:14.466 -> Sending: [53 55 50 4C 41 ]
12:42:23.598 -> Sending: [53 55 50 4C 41 C 30 0 0 0 28 0 0 0 10 0 0 0 B3 0 0 0 0 0 0 0 C8 1C 5 0 0 0 0 0 ]
12:42:23.638 -> Sending: [53 55 50 4C 41 ]
12:42:23.718 -> Received: [53 55 50 4C 41 C 9 0 0 0 32 0 0 0 10 0 0 0 8F ED DE 60 0 0 0 0 BD 4 F 0 0 0 0 0 53 55 50 4C 41 ]
12:42:24.318 -> Channel(3) value changed to 1013.18
12:42:24.318 -> Channel(2) value changed to temp(23.209999), humi(57.106445)
12:42:24.318 -> Sending: [53 55 50 4C 41 C 31 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 20 80 A9 8F 40 ]
12:42:24.478 -> Sending: [53 55 50 4C 41 ]
12:42:24.518 -> Sending: [53 55 50 4C 41 C 32 0 0 0 64 0 0 0 9 0 0 0 2 A9 5A 0 0 12 DF 0 0 ]
12:42:24.558 -> Sending: [53 55 50 4C 41 ]
12:42:34.328 -> Channel(3) value changed to 1013.16
12:42:34.328 -> Channel(2) value changed to temp(23.230000), humi(57.505859)
12:42:34.328 -> Sending: [53 55 50 4C 41 C 33 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 A0 4D A9 8F 40 ]
12:42:34.408 -> Sending: [53 55 50 4C 41 ]
12:42:34.448 -> Sending: [53 55 50 4C 41 C 34 0 0 0 64 0 0 0 9 0 0 0 2 BD 5A 0 0 A1 E0 0 0 ]
12:42:34.488 -> Sending: [53 55 50 4C 41 ]
12:42:44.306 -> Channel(3) value changed to 1013.11
12:42:44.306 -> Channel(2) value changed to temp(23.270000), humi(57.626953)
12:42:44.346 -> Sending: [53 55 50 4C 41 C 35 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 0 E7 A8 8F 40 ]
12:42:44.466 -> Sending: [53 55 50 4C 41 ]
12:42:44.506 -> Sending: [53 55 50 4C 41 C 36 0 0 0 64 0 0 0 9 0 0 0 2 E6 5A 0 0 1A E1 0 0 ]
12:42:44.626 -> Sending: [53 55 50 4C 41 ]
12:42:48.713 -> Sending: [53 55 50 4C 41 C 37 0 0 0 28 0 0 0 10 0 0 0 CC 0 0 0 0 0 0 0 FF B6 6 0 0 0 0 0 ]
12:42:48.773 -> Sending: [53 55 50 4C 41 ]
12:42:48.773 -> Received: [53 55 50 4C 41 C A 0 0 0 32 0 0 0 10 0 0 0 A9 ED DE 60 0 0 0 0 63 22 1 0 0 0 0 0 53 55 50 4C 41 ]
12:42:54.321 -> Channel(3) value changed to 1013.14
12:42:54.321 -> Channel(2) value changed to temp(23.309999), humi(57.420898)
12:42:54.321 -> Sending: [53 55 50 4C 41 C 38 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 2C A9 8F 40 ]
12:42:54.481 -> Sending: [53 55 50 4C 41 ]
12:42:54.521 -> Sending: [53 55 50 4C 41 C 39 0 0 0 64 0 0 0 9 0 0 0 2 D 5B 0 0 4C E0 0 0 ]
12:42:54.561 -> Sending: [53 55 50 4C 41 ]
12:43:04.333 -> Channel(3) value changed to 1013.16
12:43:04.333 -> Channel(2) value changed to temp(23.340000), humi(57.531250)
12:43:04.333 -> Sending: [53 55 50 4C 41 C 3A 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 A0 48 A9 8F 40 ]
12:43:04.373 -> Sending: [53 55 50 4C 41 ]
12:43:04.413 -> Sending: [53 55 50 4C 41 C 3B 0 0 0 64 0 0 0 9 0 0 0 2 2C 5B 0 0 BB E0 0 0 ]
12:43:04.493 -> Sending: [53 55 50 4C 41 ]
12:43:13.773 -> Sending: [53 55 50 4C 41 C 3C 0 0 0 28 0 0 0 10 0 0 0 E5 0 0 0 0 0 0 0 C7 A 8 0 0 0 0 0 ]
12:43:13.853 -> Sending: [53 55 50 4C 41 ]
12:43:13.903 -> Received: [53 55 50 4C 41 C B 0 0 0 32 0 0 0 10 0 0 0 C2 ED DE 60 0 0 0 0 48 D4 2 0 0 0 0 0 53 55 50 4C 41 ]
12:43:14.323 -> Channel(3) value changed to 1013.22
12:43:14.323 -> Channel(2) value changed to temp(23.379999), humi(57.571289)
12:43:14.323 -> Sending: [53 55 50 4C 41 C 3D 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 C0 CC A9 8F 40 ]
12:43:14.523 -> Sending: [53 55 50 4C 41 ]
12:43:14.603 -> Sending: [53 55 50 4C 41 C 3E 0 0 0 64 0 0 0 9 0 0 0 2 53 5B 0 0 E3 E0 0 0 ]
12:43:14.643 -> Sending: [53 55 50 4C 41 ]
12:43:24.335 -> Channel(3) value changed to 1013.13
12:43:24.335 -> Channel(2) value changed to temp(23.379999), humi(57.093750)
12:43:24.335 -> Sending: [53 55 50 4C 41 C 3F 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 60 18 A9 8F 40 ]
12:43:24.375 -> Sending: [53 55 50 4C 41 ]
12:43:24.455 -> Sending: [53 55 50 4C 41 C 40 0 0 0 64 0 0 0 9 0 0 0 2 53 5B 0 0 5 DF 0 0 ]
12:43:24.495 -> Sending: [53 55 50 4C 41 ]
12:43:34.318 -> Channel(2) value changed to temp(23.389999), humi(56.162109)
12:43:34.358 -> Sending: [53 55 50 4C 41 C 41 0 0 0 64 0 0 0 9 0 0 0 2 5D 5B 0 0 62 DB 0 0 ]
12:43:34.398 -> Sending: [53 55 50 4C 41 ]
12:43:38.883 -> Sending: [53 55 50 4C 41 C 42 0 0 0 28 0 0 0 10 0 0 0 FE 0 0 0 0 0 0 0 DD B0 9 0 0 0 0 0 ]
12:43:38.963 -> Sending: [53 55 50 4C 41 ]
12:43:39.003 -> Received: [53 55 50 4C 41 C C 0 0 0 32 0 0 0 10 0 0 0 DB ED DE 60 0 0 0 0 A0 2F 4 0 0 0 0 0 53 55 50 4C 41 ]
12:43:44.330 -> Channel(3) value changed to 1013.19
12:43:44.330 -> Channel(2) value changed to temp(23.389999), humi(56.219727)
12:43:44.330 -> Sending: [53 55 50 4C 41 C 43 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 40 88 A9 8F 40 ]
12:43:44.530 -> Sending: [53 55 50 4C 41 ]
12:43:44.570 -> Sending: [53 55 50 4C 41 C 44 0 0 0 64 0 0 0 9 0 0 0 2 5D 5B 0 0 9B DB 0 0 ]
12:43:44.610 -> Sending: [53 55 50 4C 41 ]
12:43:54.345 -> Channel(3) value changed to 1013.17
12:43:54.345 -> Channel(2) value changed to temp(23.379999), humi(56.312500)
12:43:54.345 -> Sending: [53 55 50 4C 41 C 45 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 6D A9 8F 40 ]
12:43:54.385 -> Sending: [53 55 50 4C 41 ]
12:43:54.425 -> Sending: [53 55 50 4C 41 C 46 0 0 0 64 0 0 0 9 0 0 0 2 53 5B 0 0 F8 DB 0 0 ]
12:43:54.465 -> Sending: [53 55 50 4C 41 ]
12:44:04.015 -> Sending: [53 55 50 4C 41 C 47 0 0 0 28 0 0 0 10 0 0 0 17 1 0 0 0 0 0 0 E5 1B B 0 0 0 0 0 ]
12:44:04.205 -> Sending: [53 55 50 4C 41 ]
12:44:04.405 -> Channel(3) value changed to 1013.16
12:44:04.405 -> Channel(2) value changed to temp(23.379999), humi(56.184570)
12:44:04.405 -> Sending: [53 55 50 4C 41 C 48 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 40 51 A9 8F 40 ]
12:44:04.565 -> Sending: [53 55 50 4C 41 ]
12:44:04.645 -> Sending: [53 55 50 4C 41 C 49 0 0 0 64 0 0 0 9 0 0 0 2 53 5B 0 0 78 DB 0 0 ]
12:44:04.725 -> Sending: [53 55 50 4C 41 ]
12:44:04.805 -> Received: [53 55 50 4C 41 C D 0 0 0 32 0 0 0 10 0 0 0 F4 ED DE 60 0 0 0 0 5D 27 8 0 0 0 0 0 53 55 50 4C 41 ]
12:44:14.405 -> Channel(3) value changed to 1013.14
12:44:14.405 -> Channel(2) value changed to temp(23.379999), humi(56.534180)
12:44:14.405 -> Sending: [53 55 50 4C 41 C 4A 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 80 31 A9 8F 40 ]
12:44:14.485 -> Sending: [53 55 50 4C 41 ]
12:44:14.525 -> Sending: [53 55 50 4C 41 C 4B 0 0 0 64 0 0 0 9 0 0 0 2 53 5B 0 0 D6 DC 0 0 ]
12:44:14.565 -> Sending: [53 55 50 4C 41 ]
12:44:24.418 -> Channel(3) value changed to 1013.16
12:44:24.418 -> Channel(2) value changed to temp(23.400000), humi(56.524414)
12:44:24.418 -> Sending: [53 55 50 4C 41 C 4C 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 60 55 A9 8F 40 ]
12:44:24.498 -> Sending: [53 55 50 4C 41 ]
12:44:24.538 -> Sending: [53 55 50 4C 41 C 4D 0 0 0 64 0 0 0 9 0 0 0 2 67 5B 0 0 CC DC 0 0 ]
12:44:24.578 -> Sending: [53 55 50 4C 41 ]
12:44:29.785 -> Sending: [53 55 50 4C 41 C 4E 0 0 0 28 0 0 0 10 0 0 0 31 1 0 0 0 0 0 0 D5 12 8 0 0 0 0 0 ]
12:44:29.825 -> Sending: [53 55 50 4C 41 ]
12:44:29.905 -> Received: [53 55 50 4C 41 C E 0 0 0 32 0 0 0 10 0 0 0 E EE DE 60 0 0 0 0 3F D0 2 0 0 0 0 0 53 55 50 4C 41 ]
12:44:34.428 -> Channel(3) value changed to 1013.17
12:44:34.428 -> Channel(2) value changed to temp(23.400000), humi(55.988281)
12:44:34.428 -> Sending: [53 55 50 4C 41 C 4F 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 0 66 A9 8F 40 ]
12:44:34.508 -> Sending: [53 55 50 4C 41 ]
12:44:34.548 -> Sending: [53 55 50 4C 41 C 50 0 0 0 64 0 0 0 9 0 0 0 2 67 5B 0 0 B4 DA 0 0 ]
12:44:34.588 -> Sending: [53 55 50 4C 41 ]
12:44:44.390 -> Channel(3) value changed to 1013.13
12:44:44.390 -> Channel(2) value changed to temp(23.400000), humi(56.116211)
12:44:44.425 -> Sending: [53 55 50 4C 41 C 51 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 17 A9 8F 40 ]
12:44:44.460 -> Sending: [53 55 50 4C 41 ]
12:44:44.495 -> Sending: [53 55 50 4C 41 C 52 0 0 0 64 0 0 0 9 0 0 0 2 67 5B 0 0 34 DB 0 0 ]
12:44:44.565 -> Sending: [53 55 50 4C 41 ]
12:44:54.405 -> Channel(3) value changed to 1013.15
12:44:54.445 -> Channel(2) value changed to temp(23.410000), humi(55.930664)
12:44:54.445 -> Sending: [53 55 50 4C 41 C 53 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 0 34 A9 8F 40 ]
12:44:54.525 -> Sending: [53 55 50 4C 41 ]
12:44:54.565 -> Sending: [53 55 50 4C 41 C 54 0 0 0 64 0 0 0 9 0 0 0 2 71 5B 0 0 7A DA 0 0 ]
12:44:54.565 -> Sending: [53 55 50 4C 41 ]
12:44:54.885 -> Sending: [53 55 50 4C 41 C 55 0 0 0 28 0 0 0 10 0 0 0 4A 1 0 0 0 0 0 0 2D C0 9 0 0 0 0 0 ]
12:44:54.925 -> Sending: [53 55 50 4C 41 ]
12:44:55.005 -> Received: [53 55 50 4C 41 C F 0 0 0 32 0 0 0 10 0 0 0 27 EE DE 60 0 0 0 0 C5 2F 4 0 0 0 0 0 53 55 50 4C 41 ]
12:45:04.428 -> Channel(3) value changed to 1013.16
12:45:04.428 -> Channel(2) value changed to temp(23.420000), humi(55.885742)
12:45:04.428 -> Sending: [53 55 50 4C 41 C 56 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 20 53 A9 8F 40 ]
12:45:04.628 -> Sending: [53 55 50 4C 41 ]
12:45:04.668 -> Sending: [53 55 50 4C 41 C 57 0 0 0 64 0 0 0 9 0 0 0 2 7C 5B 0 0 4D DA 0 0 ]
12:45:04.708 -> Sending: [53 55 50 4C 41 ]
12:45:14.430 -> Channel(3) value changed to 1013.16
12:45:14.430 -> Channel(2) value changed to temp(23.420000), humi(55.910156)
12:45:14.430 -> Sending: [53 55 50 4C 41 C 58 0 0 0 64 0 0 0 9 0 0 0 3 0 0 0 E0 50 A9 8F 40 ]
12:45:14.510 -> Sending: [53 55 50 4C 41 ]
12:45:14.550 -> Sending: [53 55 50 4C 41 C 59 0 0 0 64 0 0 0 9 0 0 0 2 7C 5B 0 0 66 DA 0 0 ]
12:45:14.590 -> Sending: [53 55 50 4C 41 ]
Jak widać z logów, tylko raz (i to kontrolnie uruchomiłem kontrakton samodzielnie):
Natomiast z skryptów
Warunki mam wpisane już od dawna nic nie zmieniałem:
Wyzwalanie w oparciu o stan kanałów
{{not state(XXXXX).hi and state(XXXXX).connected}}
Warunek wykonania
{{not state(XXXXX).hi}}
A powiadomienia pushover przychodzą, pomimo braku spełnienia warunków.
Sprawdzanie connected powinno być w "warunku wykonania".
