Access denied for mysql database
psp50
i want to access mysql database but i got problem in it.
here is my command line
root@supla:~# docker exec -it supla-db bash
root@5392d9096538:/# mysql -uroot -proot
mysql: [Warning] Using a password on the command line interface can be insecure.
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
what is default password for mysql database.
Please help me to connect to mysql database.
Just type "mysql"
psp50
pzygmunt wrote: Mon Nov 22, 2021 10:55 am Just type "mysql"
Got same problem.
all people facing the same problem?
It is hosted on digital ocean.
psp50
Can anybody help me with this?
docker exec -it supla-cloud bash
cat /var/www/cloud/app/config/parameters.yml - Here you will find your database access credentials.
psp50
Thank you so much for your support.
now I'm able to access the database on host "supla-db"
but here I can not able to access it on localhost.
how can I access outside of localhost?
when I try to add user to the database i got error of privileges.
Any solution for that?
You must grant the appropriate permissions in SQL and make port 3306 available outside the container.
Return to “Help”
