Has thanked: 291 times
Zibi_007 wrote: Mon Jul 07, 2025 9:14 pm Proszę o dodanie czujnika ruchu:
HOBEIAN::ZG-204Z
Dokładnie takiego:
https://www.zigbee2mqtt.io/devices/ZG-204Z.html
+BWNU
m.quirkCheckinInterval(15000),
            // Occupancy reporting interval is 60s, so allow for one dropped update plus a small safety margin of 5s
            m.iasZoneAlarm({
                zoneType: "occupancy",
                zoneAttributes: ["alarm_1", "battery_low"],
                keepAliveTimeout: 125,
        exposes: [
            e.battery(),
            e.battery_voltage(),
            e.enum("sensitivity", ea.ALL, ["low", "medium", "high"]).withDescription("PIR sensor sensitivity"),
            e.enum("keep_time", ea.ALL, [30, 60, 120]).withDescription("PIR keep time in seconds"),
key: ["sensitivity", "keep_time"],
    convertSet: async (entity, key, value, meta) => {
        switch (key) {
            case "sensitivity":
                await entity.write("ssIasZone", {currentZoneSensitivityLevel: utils.getFromLookup(value, {low: 0, medium: 1, high: 2})});
                break;
            case "keep_time":
                await entity.write("ssIasZone", {61441: {value: utils.getFromLookup(value, {30: 0, 60: 1, 120: 2}), type: 0x20}});
Been thanked: 32 times
vajera wrote: Wed Jul 09, 2025 8:58 pm
HOBEIAN::ZG-204Z
Dokładnie takiego:
+BWNU
            m.iasZoneAlarm({
        exposes: [
            e.battery(),
        switch (key) {
            case "sensitivity":
                break;
            case "keep_time":
Dziękuję. Jestem ciekawy tej czułości. Nigdy do tej pory tego nie było w tych małych g.... ;-), albo nie zwróciłem na to uwagi :)
Widzę też, że będą przebudowy w kodzie. Idzie nowe :) Brawo!
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Proszę o dodanie czujnika gazu na 230 V
https://pl.aliexpress.com/item/10050071 ... pt=glo2pol
Using 'COM3' as serial port.
Showing logs:
[15:44:24]NLME Status Indication, status: 0x6
[15:44:26]NLME Status Indication, status: 0x6
[15:44:27][452325][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[15:44:30]Send: [53 55 50 4C 41 17 2B 00 00 00 28 00 00 00 10 00 00 00 D9 DF 6F 68 00 00 00 00 34 35 06 00 00 00 00 00 ]
[15:44:30]Send: [53 55 50 4C 41 ]
[15:44:30]Recv: [53 55 50 4C 41 17 24 00 00 00 32 00 00 00 10 00 00 00 B9 C3 6F 68 00 00 00 00 D9 31 0C 00 00 00 00 00 53 55 50 4C 41 ]
[15:44:36]NLME Status Indication, status: 0x6
[15:44:38][464035][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[15:44:39][465169][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[15:44:39][465172][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[15:44:40][465211][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xf334)
[15:44:40][465211][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[15:44:40][465211][D][ZigbeeGateway.cpp:532] zbDeviceAnnce(): zbDeviceAnnce short address (0xf334), ieee_addr (0xa4):(0xc1):(0x38):(0xc0):(0xc2):(0xc6):(0x21):(0x8b)
[15:44:40][465212][D][ZigbeeGateway.cpp:535] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xf334), ieee_addr (0xa4):(0xc1):(0x38):(0xc0):(0xc2):(0xc6):(0x21):(0x8b)
[15:44:40][465213][I][ZigbeeGateway.cpp:559] zbDeviceAnnce(): Tuya magic last hope
[15:44:40][465416][I][ZigbeeGateway.cpp:602] printJoinedDevices(): joined devices:
[15:44:40][465416][I][ZigbeeGateway.cpp:605] printJoinedDevices(): Device on endpoint 1, short address: 0xf334
[15:44:40][465419][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[15:44:40][465419][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[15:44:40][465421][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[15:44:40]NLME Status Indication, status: 0x9
[15:44:40][465453][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[15:44:40][465454][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xf334) src endpoint(1) to dst endpoint(1) cluster(0x0)
[15:44:40][465455][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[15:44:40][465455][I][ZigbeeGateway.cpp:396] zbReadBasicCluster(): Peer Manufacturer is "_TZE284_chbyv06x"
[15:44:40][465456][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[15:44:40][465457][I][ZigbeeGateway.cpp:416] zbReadBasicCluster(): ZCL version id is "3"
[15:44:40][465457][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(78)
[15:44:40][465458][I][ZigbeeGateway.cpp:422] zbReadBasicCluster(): ZCL application version id is "78"
[15:44:40][465458][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[15:44:40][465459][I][ZigbeeGateway.cpp:403] zbReadBasicCluster(): Peer Model is "TS0601"
[15:44:40][465459][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
[15:44:40][465460][I][ZigbeeGateway.cpp:428] zbReadBasicCluster(): ZCL power source id is "1"
[15:44:40][465461][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[15:44:40][465461][I][ZigbeeGateway.cpp:432] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[15:44:40][465921][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x0
[15:44:40][465921][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[15:44:40][465952][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[15:44:40][465953][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:44:40][465953][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[15:44:40][465954][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[15:44:40][465954][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 14 size: 14
[15:44:40][465954][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x12
[15:44:40][465955][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[15:44:40][465955][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x86
[15:44:40][465955][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[15:44:40][465956][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[15:44:40][465956][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x42
[15:44:40][465956][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x06
[15:44:40][465957][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x54
[15:44:40][465957][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x53
[15:44:40][465957][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x30
[15:44:40][465958][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x36
[15:44:40][465958][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x30
[15:44:40][465958][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x31
[15:44:40][465959][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xf334, 0xf334, 0x0, 0x0
[15:44:40][465959][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[15:44:41][466424][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x0
[15:44:41][466465][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[15:44:41][466733][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x7bc2) is open for 180 seconds
[15:44:42][467213][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:42][467214][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:42][467214][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:42][467214][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:42][467215][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:42][467215][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x23
[15:44:42][467216][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[15:44:42][467216][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[15:44:42][467217][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:42][467217][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:42][467217][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[15:44:42][467403][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:42][467404][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:42][467404][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:42][467405][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[15:44:42][467405][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:42][467406][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x24
[15:44:42][467406][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[15:44:42][467407][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[15:44:42][467407][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:42][467408][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[15:44:42][467408][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:42][467408][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[15:44:42][467409][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[15:44:42][467409][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[15:44:42][467590][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:42][467591][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:42][467591][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:42][467592][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:42][467592][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:42][467592][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x25
[15:44:42][467593][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6
[15:44:42][467593][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[15:44:42][467594][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:42][467594][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:42][467595][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:42][467781][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:42][467781][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:42][467782][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:42][467782][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[15:44:42][467782][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:42][467783][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x26
[15:44:42][467783][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[15:44:42][467784][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[15:44:42][467784][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:42][467785][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[15:44:42][467785][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:42][467786][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[15:44:42][467786][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[15:44:42][467786][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xb4
[15:44:42][467967][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:42][467968][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:42][467968][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:42][467969][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:42][467969][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:42][467970][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x27
[15:44:42][467970][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x8
[15:44:42][467970][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[15:44:42][467971][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:42][467971][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:42][467972][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:42][468154][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:42][468155][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:42][468155][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:42][468156][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:42][468156][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:42][468157][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x28
[15:44:42][468157][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x9
[15:44:42][468157][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[15:44:43][468158][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:43][468158][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:43][468159][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[15:44:43][468341][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:43][468342][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:43][468342][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:43][468342][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:43][468343][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:43][468343][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x29
[15:44:43][468344][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xa
[15:44:43][468344][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[15:44:43][468345][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:43][468345][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:43][468346][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:43][468424][E][ZigbeeGateway.cpp:373] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x5
[15:44:43][468425][I][ZigbeeGateway.cpp:1358] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[15:44:43][468454][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[15:44:43][468454][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:44:43][468455][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[15:44:43][468455][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[15:44:43][468456][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 26 size: 24
[15:44:43][468456][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x11
[15:44:43][468457][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[15:44:43][468457][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x86
[15:44:43][468457][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[15:44:43][468458][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[15:44:43][468458][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x42
[15:44:43][468458][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x10
[15:44:43][468459][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x5F
[15:44:43][468459][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x54
[15:44:43][468459][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x5A
[15:44:43][468460][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x45
[15:44:43][468460][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x32
[15:44:43][468460][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x38
[15:44:43][468461][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x34
[15:44:43][468461][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x5F
[15:44:43][468461][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x63
[15:44:43][468462][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x68
[15:44:43][468462][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x62
[15:44:43][468462][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x79
[15:44:43][468463][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x76
[15:44:43][468463][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x30
[15:44:43][468463][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x36
[15:44:43][468464][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x78
[15:44:43][468464][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xf334, 0xf334, 0x0, 0x0
[15:44:43][468464][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[15:44:43][468469][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[15:44:43][468469][V][ZigbeeHandlers.cpp:192] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xf334) src endpoint(1) to dst endpoint(1) cluster(0x0)
[15:44:43][468470][V][ZigbeeHandlers.cpp:199] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[15:44:43][468471][I][ZigbeeGateway.cpp:925] zbWriteAttrResponse(): tsn = 19, _write_attr_last_tsn = 19, _write_attr_last_tsn_flag = 2
[15:44:43][468471][I][ZigbeeGateway.cpp:939] zbWriteAttrResponse(): zbWriteAttrResponse async, tsn = 19, _set_config_last_tsn_flag = 2
[15:44:43][468528][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:43][468529][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:43][468529][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:43][468530][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:43][468530][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:43][468531][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2a
[15:44:43][468531][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xd
[15:44:43][468531][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[15:44:43][468532][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:43][468532][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:43][468533][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[15:44:43][468627][I][ZigbeeGateway.cpp:1358] sendAttributeWrite(): Sending 'write attribute' command - id (0x9), type (0x20), size (0x1), value (0x1)
[15:44:43][468689][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xfcc0, command id: 11
[15:44:43][468689][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:44:43][468690][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[15:44:43][468690][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[15:44:43][468691][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 19 size: 2
[15:44:43][468691][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[15:44:43][468691][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x84
[15:44:43][468692][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xf334, 0xf334, 0x0, 0x0
[15:44:43][468692][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[15:44:45][470658][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:45][470659][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:45][470659][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:45][470660][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:45][470660][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:45][470660][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2b
[15:44:45][470661][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[15:44:45][470661][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[15:44:45][470662][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:45][470662][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:45][470663][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[15:44:45][470830][E][ZigbeeGateway.cpp:1373] sendAttributeWrite(): Semaphore timeout writing attribute 0x9 - device 0xf334, endpoint 0x1, cluster 0xfffffcc0
[15:44:45][470830][D][Z2S_Gateway.ino:2033] loop(): Unknown model _TZE284_chbyv06x::TS0601, no binding is possible
[15:44:45][470831][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[15:44:45][470832][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[15:44:45][470849][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:45][470849][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:45][470850][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:45][470850][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[15:44:45][470850][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:45][470851][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2c
[15:44:45][470851][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[15:44:45][470852][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[15:44:45][470852][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:45][470853][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[15:44:45][470853][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:45][470853][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[15:44:45][470854][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[15:44:45][470854][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[15:44:45][471035][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:45][471036][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:45][471036][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:45][471037][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:45][471037][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:45][471037][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2d
[15:44:45][471038][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6
[15:44:45][471038][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[15:44:45][471039][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:45][471039][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:45][471040][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:46][471225][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:46][471225][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:46][471225][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:46][471226][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[15:44:46][471226][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:46][471227][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2e
[15:44:46][471227][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[15:44:46][471228][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[15:44:46][471228][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:46][471228][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[15:44:46][471229][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:46][471229][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[15:44:46][471230][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[15:44:46][471230][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xb4
[15:44:46][471412][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:46][471413][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:46][471414][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:46][471414][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:46][471415][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:46][471415][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2f
[15:44:46][471415][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x8
[15:44:46][471416][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[15:44:46][471416][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:46][471417][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:46][471417][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:46][471516][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:46][471516][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0xf334
[15:44:46][471517][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:46][471517][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[15:44:46][471517][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:46][471518][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x2b
[15:44:46][471518][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x42
[15:44:46][471599][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:46][471600][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:46][471601][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:46][471601][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:46][471602][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:46][471602][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x30
[15:44:46][471602][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x9
[15:44:46][471603][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[15:44:46][471603][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:46][471604][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:46][471604][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[15:44:46][471798][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:46][471799][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:46][471799][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:46][471799][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:46][471800][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:46][471800][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x31
[15:44:46][471801][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xa
[15:44:46][471801][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[15:44:46][471801][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:46][471802][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:46][471802][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[15:44:46][471833][E][AsyncTCP.cpp:1499] begin(): bind error: -8
[15:44:46][471973][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1040) callback
[15:44:46][471974][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xf334
[15:44:46][471974][I][ZigbeeHandlers.cpp:372] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[15:44:46][471975][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[15:44:46][471975][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[15:44:46][471976][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x32
[15:44:46][471976][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xd
[15:44:46][471977][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[15:44:46][471977][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[15:44:46][471977][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[15:44:46][471978][I][ZigbeeHandlers.cpp:375] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[15:44:46][471978][I][z2s_device_tuya_custom_cluster.cpp:1244] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[15:44:46][471979][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:c0:c2:c6:21:8b, endpoint 0x1, channel type 0xffffffff
[15:44:46][471980][I][z2s_device_tuya_custom_cluster.cpp:1172] processTuyaDataReport(): processTuyaDataReport failed - no Supla channel for that device
[15:44:46][472055][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[15:44:46][472055][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:44:46][472055][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[15:44:46][472056][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[15:44:46][472057][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 16 size: 2
[15:44:46][472057][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x07
[15:44:46][472057][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[15:44:46][472058][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xf334, 0xf334, 0x0, 0x0
[15:44:46][472058][I][z2s_devices_table.cpp:1469] Z2S_onCustomCmdReceive(): Z2S_onCustomCmdReceive cluster 0xa, command id 0x0, rssi: -68
[15:44:46][472059][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:c0:c2:c6:21:8b, endpoint 0x1, channel type 0xffffffff
[15:44:46][472059][I][z2s_devices_table.cpp:1474] Z2S_onCustomCmdReceive(): No channel found for address !8
[15:44:46][472060][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[15:44:47]
Serial port closed!
LukiSpajder
HOBEIAN::ZG-204Z
Dokładnie takiego:
+BWNU
Jeśli chodzi o ten czujnik to przeszedł dziś do Mnie ten sam model , dodaje się do bramki pojawia się dwa kanały low battery i czujnik otwarcia drzwi :D
maniex36
Zibi_007 wrote: Wed Jul 09, 2025 8:52 pm
maniex36 wrote: Wed Jul 09, 2025 6:44 pm
vajera wrote: Tue Jul 08, 2025 7:47 pm
Widać, że czujnik jakieś komunikaty wysyła (gateway last seen ms > 0), więc skoro nie widzisz żadnej reakcji w Supla, to potrzebne będą logi z seriala.
A jak odczytać takie logi z seriala? Bo
Podłączyć bramkę pod USB w komputerze i skorzystać z dowolnego serial monitora.
Dzięki.
HOBEIAN::ZG-204Z
Dokładnie takiego:
+BWNU
            m.iasZoneAlarm({
        exposes: [
            e.battery(),
        switch (key) {
            case "sensitivity":
                break;
            case "keep_time":
Urządzenie się dodało, a dodatkowo doszedł jeszcze jedn kanał. To jest zamierzone?
endrju_88
Has thanked: 3 times
Been thanked: 4 times
Można prosić o dodanie czujnika wykrywania deszczu?
_TZ3000_otwpdq1d::TS0207
https://pl.aliexpress.com/item/10050087 ... gKHKvD_BwE
LukiSpajder wrote: Thu Jul 10, 2025 1:47 pm Proszę o dodanie czujnika gazu na 230 V
Już jest - razem z custom GUI do testów.
LukiSpajder
vajera wrote: Mon Jul 28, 2025 1:55 pm
Już myślałem że przepadły te dane czujnika w czeluściach forum :D
Wgrane wszystko od nowa , co prawda dodał się za trzecim razem .
No i moim oczom ukazał się ten widok ;) :
Łał rewelacja nawet nie wiedziałem że można zmienić melodyjki ( ogólnie jak na czujnik gazu to jest bardzo cichy )
Nie wiem czy to "0,, do wysyłania melodyjek tak miało być ? Ale działa zmiana dźwięku
Test - działa
Wyciszenie (kasowanie alarmu) działa
Zmiana czasu trwania alarmu - nie działa , nie reaguje
W cloud pojawły się cztery kanały :
Stan przycisku - działa
Grzanie czujnik - pokazuje
Stężenie - pokazuje max był 351
Czujnik gazu ikona - działa zmienia stan chociaż musiałem w cloud odwrócić logikę
Czy wysyłać Ci jakieś logi odnośnie zmiany czasu , czy może musi być jakaś procedura aby to zadziałało ?
szagal
Mam takie czujniki
i one działają dziwnie ... po resecie bramki bardzo długo trzeba czekać na jakieś pomiary, a na zmianę reaguja z dużym opóźnieniem co można zrobić z tym żeby lepsze osiągnąć pomiary ?
