Mario78
bokk wrote: Mon Jun 30, 2025 9:34 am
przemekbial wrote: Mon Jun 30, 2025 9:30 am Hej. Proszę o informację czy https://allegro.pl/oferta/sonoff-zbmini ... 0bez%2520n jest już dodany i obsługiwany przez bramkę? Pozdrawiam
Jest dodany do bramki I działa bardzo dobrze
Tez polecam. Mach ich juz z 10. Jednym nawet schodowke ogarnolem sobie. To jedno z 1 urządzeń dodanych do bramki
lukasz06
Has thanked: 46 times
Been thanked: 21 times
Witam, doszło mi kilka urzadzeń :)
Na początek proszę o dodanie żarówki Gui10 od Sonoff
cpp:388] esp_zb_app_signal_handler(): Network(0x9dab) is open for 180 seconds
[155771][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[155774][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[155958][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x7bdc)
[155959][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[155959][D][ZigbeeGateway.cpp:518] zbDeviceAnnce(): zbDeviceAnnce short address (0x7bdc), ieee_addr (0xb4):(0xe8):(0x42):(0x8d):(0x9c):(0x3e):(0x0):(0x0)
[155960][D][ZigbeeGateway.cpp:521] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x7bdc), ieee_addr (0xb4):(0xe8):(0x42):(0x8d):(0x9c):(0x3e):(0x0):(0x0)
[155961][I][ZigbeeGateway.cpp:545] zbDeviceAnnce(): Tuya magic last hope
[156206][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 11
[156206][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[156207][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[156207][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0xdca
[156207][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 16 size: 2
[156208][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[156208][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0xC3
[156208][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x7bdc, 0x7bdc, 0x0, 0x0
[156209][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[156211][I][ZigbeeGateway.cpp:588] printJoinedDevices(): joined devices:
[156212][I][ZigbeeGateway.cpp:591] printJoinedDevices(): Device on endpoint 1, short address: 0x7bdc
[156255][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[156255][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): Received default response: from address(0x7bdc), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[156256][V][ZigbeeHandlers.cpp:279] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[156256][I][ZigbeeGateway.cpp:1617] zbCmdDefaultResponse(): tsn = 1, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 255
[156257][I][ZigbeeGateway.cpp:1630] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 1, _custom_cmd_last_tsn_flag = 255
[156258][I][ZigbeeGateway.cpp:1632] zbCmdDefaultResponse(): custom cmd rssi -94
[156412][I][ZigbeeGateway.cpp:1666] sendCustomClusterCmd(): _custom_cmd_last_tsn = 1
[156604][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[156612][I][ZigbeeGateway.cpp:1674] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[156613][I][ZigbeeGateway.cpp:349] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[156682][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[156683][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x7bdc) src endpoint(1) to dst endpoint(1) cluster(0x0)
[156684][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(7)
[156684][I][ZigbeeGateway.cpp:382] zbReadBasicCluster(): Peer Manufacturer is "eWeLink"
[157113][I][ZigbeeGateway.cpp:355] zbQueryDeviceBasicCluster(): basic tsn 0x2
[157114][I][ZigbeeGateway.cpp:349] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[157161][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[157161][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x7bdc) src endpoint(1) to dst endpoint(1) cluster(0x0)
[157162][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(31)
[157163][I][ZigbeeGateway.cpp:389] zbReadBasicCluster(): Peer Model is "CK-BL702-AL-01(7009_Z102LG03-1)"
[157614][I][ZigbeeGateway.cpp:355] zbQueryDeviceBasicCluster(): basic tsn 0x3
[157615][I][ZigbeeGateway.cpp:1261] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[157655][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[157655][V][ZigbeeHandlers.cpp:191] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x7bdc) src endpoint(1) to dst endpoint(1) cluster(0x0)
[157656][V][ZigbeeHandlers.cpp:198] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[158115][I][ZigbeeGateway.cpp:308] zbPrintDeviceDiscovery(): short_addr_req 31708
NLME Status Indication, status: 0x9
[158228][I][ZigbeeGateway.cpp:242] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 31708, endpoints count 2
[158228][I][ZigbeeGateway.cpp:245] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[158229][I][ZigbeeGateway.cpp:245] Z2S_active_ep_req_cb(): Endpont # 2, id 242
[158599][I][ZigbeeGateway.cpp:261] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 31708, endpoint # 1
[158599][I][ZigbeeGateway.cpp:262] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 11, out clusters # 1
[158600][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[158601][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[158601][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 3, id 4
[158601][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 4, id 5
[158602][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 5, id 6
[158602][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 6, id 8
[158603][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 7, id 768
[158603][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 8, id 4096
[158603][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 9, id 61184
[158604][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 10, id 64529
[158604][I][ZigbeeGateway.cpp:266] Z2S_simple_desc_req_cb(): In cluster # 11, id 64599
[158605][I][ZigbeeGateway.cpp:281] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[158760][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158790][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158820][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158845][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158876][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158901][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158932][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158958][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[159248][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[161692][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[161724][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[161748][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[161748][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[161749][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[161749][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x6
[161750][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 8 size: 2
[161750][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x0C
[161750][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0xC3
[161751][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x7bdc, 0x7bdc, 0x0, 0x0
[161751][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed----------------------------------------------------------
Edit1. Czujnik Temp Sonoff
Manufacturer - Sonoff
Model - SNZB-02LD
Edit2. Smart Knob
Peer Manufacturer is "_TZ3000_qja6nq5z"
Peer Model is "TS004F"
Pietras81
NIe wiem czy coś da się z tego wyczytać. Czujniki temperatury
[     1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinee TX power: 20
[ 10034][I][Z2S_Gateway.ino:1463] loop(): getZbgDeviceUnitLastSeenMs 0, current        millis 10034
PowerCycle: timeout, counter reset to 0
LittleFsConfig: writing to file "/supla-dev.cfg"
LittleFsConfig: writing to file "/supla-dev.cfg.bak"
Send: [53 55 50 4C 41 17 31 00 00 00 28 00 00 00 10 00 00 00 8A 0F 64 68 00 00 0        0 00 86 25 0F 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 32 00 00 00 32 00 00 00 10 00 00 00 6C F3 63 68 00 00 0        0 00 0F 0E 00 00 00 00 00 00 53 55 50 4C 41 ]
[ 47230][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x7df0), rejoin (NO)
[ 53621][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 53625][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 54140][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x2861)
[ 54141][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 54141][D][ZigbeeGateway.cpp:518] zbDeviceAnnce(): zbDeviceAnnce short address (0x2861), ieee_addr (0xa4):(0xc1):(0x38):(0xdb):(0xd2):(0xf6):(0x88):(0x89)
[ 54142][D][ZigbeeGateway.cpp:521] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x2861), ieee_addr (0xa4):(0xc1):(0x38):(0xdb):(0xd2):(0xf6):(0x88):(0x89)
[ 54143][I][ZigbeeGateway.cpp:545] zbDeviceAnnce(): Tuya magic last hope
[ 54346][I][ZigbeeGateway.cpp:588] printJoinedDevices(): joined devices:
[ 54347][I][ZigbeeGateway.cpp:591] printJoinedDevices(): Device on endpoint 1, short address: 0x2861
[ 54348][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 54348][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[ 54349][I][ZigbeeGateway.cpp:349] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 54654][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 11
[ 54654][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 54655][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 54656][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 54656][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 17 size: 2
[ 54656][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x20
[ 54657][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x82
[ 54657][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x2861, 0x2861, 0x0, 0x0
[ 54658][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 54662][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[ 54662][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 54663][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 54664][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 54664][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 19 size: 17
[ 54664][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 54665][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54665][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x20
[ 54666][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x93
[ 54666][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 54666][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54667][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54667][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x42
[ 54667][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x07
[ 54668][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x48
[ 54668][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x4F
[ 54668][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x42
[ 54669][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x45
[ 54669][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x49
[ 54669][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x41
[ 54669][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x4E
[ 54670][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x2861, 0x2861, 0x0, 0x0
[ 54670][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 54849][I][ZigbeeGateway.cpp:355] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 56168][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 56781][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x89d7) is open for 180 seconds
[ 56849][E][ZigbeeGateway.cpp:359] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 56850][I][Z2S_Gateway.ino:1500] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
Scheduling soft restart in 0 ms
LAST STATE ADDED: Software reset (54)
Current status: [41] Software reset
[ 56851][I][ZigbeeGateway.cpp:1261] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 57291][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 57292][V][ZigbeeHandlers.cpp:191] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x2861) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 57292][V][ZigbeeHandlers.cpp:198] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[ 57353][I][ZigbeeGateway.cpp:1261] sendAttributeWrite(): Sending 'write attribute' command - id (0x9), type (0x20), size (0x1), value (0x1)
[ 57807][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 57807][V][ZigbeeHandlers.cpp:191] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x2861) src endpoint(1) to dst endpoint(1) cluster(0xfcc0)
[ 57808][V][ZigbeeHandlers.cpp:198] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0xfcc0), attribute(0x9)
[ 57855][D][Z2S_Gateway.ino:2021] loop(): Unknown model ::, no binding is possible
[ 57855][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 57856][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
Reset requested. Reset device
[ 58982][V][AP.cpp:108] _onApEvent(): AP Started
[ 58983][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 130 - AP_START
[ 58983][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 130 - AP_START
[ 58987][V][AP.cpp:112] _onApEvent(): AP Stopped
[ 58988][V][AP.cpp:108] _onApEvent(): AP Started
[ 58988][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 131 - AP_STOP
[ 58989][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 131 - AP_STOP
[ 58989][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 130 - AP_START
[ 58990][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 130 - AP_START
[ 58991][V][AP.cpp:112] _onApEvent(): AP Stopped
[ 58992][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 131 - AP_STOP
[ 58992][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 131 - AP_STOP
[ 58997][V][STA.cpp:216] _onStaEvent(): STA Disconnected: SSID: Supla, BSSID: 82:ee:52:e0:2b:0e, Reason: 8
[ 58997][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 113 - STA_DISCONNECTED
[ 58998][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 113 - STA_DISCONNECTED
[ 58998][W][STA.cpp:137] _onStaArduinoEvent(): Reason: 8 - ASSOC_LEAVE
WiFi Station disconnected
[ 59001][V][STA.cpp:190] _onStaEvent(): STA Stopped
[ 59001][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 111 - STA_STOP
[ 59002][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 111 - STA_STOP
[ 59007][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 100 - WIFI_OFF
[ 59007][V][NetworkInterface.cpp:262] destroyNetif(): Unregistered event handler
Resetting in 0.5s...
See you soon!
ESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x4001975a
SPIWP:0xee
mode:DIO, clock div:2
load:0x40875720,len:0x1228
load:0x4086c110,len:0xd9c
load:0x4086e610,len:0x2f74
entry 0x4086c110
[     1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4206a3dc
[    12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4206a3ca
[    23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4206a3b8
[    35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4206a3a6
[    46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4206a3dc
[    57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4206a3ca
[    69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4206a3b8
[    80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4206a3a6
[    91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4206a3dc
[   103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4206a3ca
[   114][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4206a3b8
[   125][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4206a3a6
[   137][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x42062fca
[   148][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x42062fca
[   160][V][NetworkServer.h:41] NetworkServer(): NetworkServer::NetworkServer(port=23, ...)
[   168][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
[   200][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081bdf4
[   211][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081bdf4
[   221][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40827084
[   232][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40827084
=========== Before Setup Start ===========
                                          Chip Info:
        Model             : ESP32-C6
        Package           : 0
        Revision          : 0.01
        Cores             : 1
         CPU Frequency     : 160 MHz
                                      XTAL Frequency    : 40 MHz
        Features Bitfield : 0x00000052
        Embedded Flash    : No
        Embedded PSRAM    : No
        2.4GHz WiFi       : Yes
        Classic BT        : No
      BT Low Energy     : Yes
                               IEEE 802.15.4     : Yes
        INTERNAL Memory Info:
        Total Size        :   332508 B ( 324.7 KB)
                Free Bytes        :   277724 B ( 271.2 KB)
                                                            Allocated Bytes   :    42296 B (  41.3 KB)
        Minimum Free Bytes:   277724 B ( 271.2 KB)
        Largest Free Block:   249844 B ( 244.0 KB)
                                           Flash Info:
        Chip Size         :  8388608 B (8 MB)
        Block Size        :    65536 B (  64.0 KB)
        Sector Size       :     4096 B (   4.0 KB)
                                    Page Size         :      256 B (   0.2 KB)
        Bus Speed         : 40 MHz
        Bus Mode          : QIO
        Partitions Info:
                                                         nvs : addr: 0x00009000, size:    20.0 KB, type: DATA, subtype: NVS
        otadata : addr: 0x0000E000, size:     8.0 KB, type: DATA, subtype: OTA
                               app0 : addr: 0x00010000, size:  3328.0 KB, type:  APP, subtype: OTA_0
        app1 : addr: 0x00350000, size:  3328.0 KB, type:  APP, subtype: OTA_1
        spiffs : addr: 0x00690000, size:  1384.0 KB, type: DATA, subtype: SPIFFS
        zb_storage : addr: 0x007EA000, size:    16.0 KB, type: DATA, subtype: FAT
        zb_fct : addr: 0x007EE000, size:     4.0 KB, type: DATA, subtype: FAT
        rcp_fw : addr: 0x007EF000, size:     4.0 KB, type: DATA, subtype: SPIFFS
        coredump : addr: 0x007F0000, size:    64.0 KB, type: DATA, subtype: COREDUMP
        Software Info:
        Compile Date/Time : Jun 29 2025 10:13:25
        Compile Host OS   : linux
                  ESP-IDF Version   : v5.4.1-1-g2f7dcd862a-dirty
        Arduino Version   : 3.2.0
        Board Info:
        Arduino Board     : ESP32C6_DEV
                                Arduino Variant   : esp32c6
                                                             Arduino FQBN      : esp32:esp32:esp32c6:PartitionScheme=zigbee_zczr_8MB,ZigbeeMode=zczr,FlashSize=8M,CDCOnBoot=cdc,DebugLevel=verbose
     ============ Before Setup End ============
                                               [   355][I][Z2S_Gateway.ino:1140] setup(): setup start
[   356][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x42067ace
[   356][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
[   357][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x42067ace
[   357][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 3 successfully set to type GPIO (1) with bus 0x4
[   457][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x42067ace
[   458][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 14 successfully set to type GPIO (1) with bus 0xf
[   459][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x42067ace
[   459][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 8 successfully set to type GPIO (1) with bus 0x9
[   460][V][esp32-hal-rmt.c:454] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[   460][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type RMT_TX (10) successfully set to 0x42068eca
[   461][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type RMT_RX (11) successfully set to 0x42068eca
[   461][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 8 successfully set to type INIT (0) with bus 0x0
[   462][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 8 successfully set to type RMT_TX (10) with bus 0x40839710
[   463][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[   464][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
Storage initialization
readStorage: 8; Read: [53 55 50 4C 41 1 0 1 ]
Storage: Number of sections 1
Reading section: 0
readStorage: 7; Read: [3 13 0 E5 E4 E5 E4 ]
Section type: 3; size: 19
storedCRC 58597, CRC calc 58597
LittleFsConfig: file "/supla-dev.cfg" size 970
LittleFsConfig: initializing storage from file...
LittleFsConfig: init result success
ConfigTypesBitmap: Set config type 0 to 1
Channel[110] initial caption set to 'IAS ZONE NOTIFICATIONS'
Button[0] setHoldTime: 2000
Button[0] setMulticlickTime: 500
Button[0]::configureAsConfigButton
Button[0] setHoldTime: 5000
Button[0] setMulticlickTime: 300
[   610][I][z2s_devices_table.cpp:563] Z2S_loadZBDevicesTable(): Z2S_getZBDevicesTableSize 4864, sizeof(z2s_zb_devices_table) 4864, sizeof(z2s_zb_device_params_t) 152, sizeof(bool)1
[   635][I][z2s_devices_table.cpp:640] Z2S_loadZBDevicesTable(): Zigbee devices table load success!
[   636][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     0
RECORD ID               1
MANUFACTURER NAME       _TZ3000_wkai4ga5
MODEL NAME              TS0044
IEEE ADDRESS            A4:C1:38:AE:2F:E0:CE:E1
SHORT ADDRESS           0x42E9
ENDPOINTS COUNT         0x4
POWER SOURCE            0x0
MODEL                   20736
LAST RSSI               0
LAST SEEN (MS)          2771
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              148
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             0
SUPLA CH[1]             1
SUPLA CH[2]             2
SUPLA CH[3]             3
SUPLA CH[4]             4
SUPLA CH[5]             5
SUPLA CH[6]             6
SUPLA CH[7]             7
SUPLA CH[8]             8
SUPLA CH[9]             9
SUPLA CH[10]            10
SUPLA CH[11]            11
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
[   639][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     1
RECORD ID               1
MANUFACTURER NAME       _TZ3210_up3pngle
MODEL NAME              TS0205
IEEE ADDRESS            A4:C1:38:2F:FD:D:4:14
SHORT ADDRESS           0xACB6
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8192
LAST RSSI               0
LAST SEEN (MS)          2771
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              228
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             12
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
[   641][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     2
RECORD ID               1
MANUFACTURER NAME       _TZE200_n8dljorx
MODEL NAME              TS0601
IEEE ADDRESS            A4:C1:38:45:60:A9:D0:79
SHORT ADDRESS           0x671A
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8192
LAST RSSI               0
LAST SEEN (MS)          2771
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              148
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             13
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
[   644][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     3
RECORD ID               1
MANUFACTURER NAME       _TZE284_myd45weu
MODEL NAME              TS0601
IEEE ADDRESS            A4:C1:38:34:1A:6B:6B:7B
SHORT ADDRESS           0x3EB6
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   4353
LAST RSSI               0
LAST SEEN (MS)          195827
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              178
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             14
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
[   646][I][z2s_devices_table.cpp:206] Z2S_loadDevicesTable(): Z2S_getDevicesTableSize 15360, sizeof(z2s_devices_table) 15360, sizeof(z2s_device_params_t) 120, sizeof(bool)1
[   675][I][z2s_devices_table.cpp:335] Z2S_loadDevicesTable(): Devices table load success!
[   676][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     0
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           0
SUPLA SECONDARY CHANNEL 255
SUPLA CHANNEL TYPE      11000
SUPLA CHANNEL NAME      BUTTON #1 PRESSED
SUPLA CHANNEL FUNCTION  130
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   678][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     1
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           1
SUPLA CHANNEL NAME      BUTTON #1 DOUBLE PRESSED
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   679][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     2
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           2
SUPLA CHANNEL NAME      BUTTON #1 HELD
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   681][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     3
ENDPOINT                0x2
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           3
SUPLA CHANNEL NAME      BUTTON #2 PRESSED
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   683][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     4
ENDPOINT                0x2
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           4
SUPLA CHANNEL NAME      BUTTON #2 DOUBLE PRESSED
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   685][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     5
ENDPOINT                0x2
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           5
SUPLA CHANNEL NAME      BUTTON #2 HELD
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   687][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     6
ENDPOINT                0x3
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           6
SUPLA CHANNEL NAME      BUTTON #3 PRESSED
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   689][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     7
ENDPOINT                0x3
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           7
SUPLA CHANNEL NAME      BUTTON #3 DOUBLE PRESSED
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   691][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     8
ENDPOINT                0x3
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           8
SUPLA CHANNEL NAME      BUTTON #3 HELD
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   693][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     9
ENDPOINT                0x4
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           9
SUPLA CHANNEL NAME      BUTTON #4 PRESSED
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   695][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     10
ENDPOINT                0x4
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           10
SUPLA CHANNEL NAME      BUTTON #4 DOUBLE PRESSED
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   697][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     11
ENDPOINT                0x4
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           11
SUPLA CHANNEL NAME      BUTTON #4 HELD
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
[   699][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     12
ENDPOINT                0x1
CLUSTER                 0x500
MODEL                   2000
SUPLA CHANNEL           12
SUPLA CHANNEL TYPE      1000
SUPLA CHANNEL NAME
SUPLA CHANNEL FUNCTION  0
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            1
[   701][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     13
ENDPOINT                0x1
CLUSTER                 0x500
MODEL                   2000
SUPLA CHANNEL           13
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            2
[   703][I][z2s_telnet_server.cpp:47] log_i_telnet(): ENTRY                     14
ENDPOINT                0x1
CLUSTER                 0xEF00
MODEL                   1101
SUPLA CHANNEL           14
SUPLA CHANNEL TYPE      3038
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            3
[   704][I][z2s_devices_table.cpp:687] Z2S_initSuplaChannels(): initSuplaChannels starting
Channel[0] initial caption set to 'BUTTON #1 PRESSED'
Channel[1] initial caption set to 'BUTTON #1 DOUBLE PRESSED'
Channel[2] initial caption set to 'BUTTON #1 HELD'
Channel[3] initial caption set to 'BUTTON #2 PRESSED'
Channel[4] initial caption set to 'BUTTON #2 DOUBLE PRESSED'
Channel[5] initial caption set to 'BUTTON #2 HELD'
Channel[6] initial caption set to 'BUTTON #3 PRESSED'
Channel[7] initial caption set to 'BUTTON #3 DOUBLE PRESSED'
Channel[8] initial caption set to 'BUTTON #3 HELD'
Channel[9] initial caption set to 'BUTTON #4 PRESSED'
Channel[10] initial caption set to 'BUTTON #4 DOUBLE PRESSED'
Channel[11] initial caption set to 'BUTTON #4 HELD'
Notification: registered - context 12
Notification: registered - context 13
[   708][D][ZigbeeCore.cpp:86] addEndpoint(): Endpoint: 1, Device ID: 0x0050
 *** Supla - starting initialization (platform 0)
 *** Supla - Config initalization
Automatic firmware update is disabled
Device mode: 0
Security level: Supla CA
 *** Supla - Config load for elements
RemoteDeviceConfig: Registering field 0x00000010
Clock: automaticTimeSync: 1
Channel[110] function missing. Using SW defaults
Button[0] don't load config
PowerCycle: 0 (enabled)
Channel[0] function missing. Using SW defaults
Channel[1] function missing. Using SW defaults
Channel[2] function missing. Using SW defaults
Channel[3] function missing. Using SW defaults
Channel[4] function missing. Using SW defaults
Channel[5] function missing. Using SW defaults
Channel[6] function missing. Using SW defaults
Channel[7] function missing. Using SW defaults
Channel[8] function missing. Using SW defaults
Channel[9] function missing. Using SW defaults
Channel[10] function missing. Using SW defaults
Channel[11] function missing. Using SW defaults
Channel[12] loaded function: 236
Binary[12] setServerInvertLogic 0
Binary[12] config serverInvertLogic 0
Channel[13] loaded function: 230
Binary[13] setServerInvertLogic 0
Binary[13] config serverInvertLogic 0
Channel[14] temperature correction 0.00
Channel[14] humidity correction 0.00
 *** Supla - Config load for elements done
 *** Supla - Load state storage
Validating storage state section with current device configuration
Storage state section validation successful
readStorage: 4; Read: [0 0 0 0 ]
readStorage: 1; Read: [0 ]
Relay[110] restored relay state: OFF
readStorage: 1; Read: [1 ]
 *** Supla - Load state storage done
 *** Supla - Init elements
Relay[110] turn OFF (duration 0 ms)
Button[0]: Initialized: pin 9, pullUp 1, invertLogic 1, state 1
Channel(13) value changed to 1
Channel(14) value changed to temp(-275.00), humi(-1.00)
 *** Supla - Init elements done
GUID: CF49D4EC0031305AAA0D93377F219553
Device name: Zigbee to Supla Gateway
Device software version: SDK 25.06.01-dev
 *** Supla - Initializing network layer
[Wi-Fi] Network AP/hostname: ZIGBEE-TO-SUPLA-GA-F0F5BD03090C
Using Supla protocol version 23
Current status: [5] SuplaDevice initialized
Enter normal mode
[Wi-Fi] setNormalMode
 *** Supla - Initialization done
=========== After Setup Start ============
        Free Bytes        :   272308 B ( 265.9 KB)
      Allocated Bytes   :    45504 B (  44.4 KB)
                                                  Minimum Free Bytes:   268388 B ( 262.1 KB)
        Largest Free Block:   245748 B ( 240.0 KB)
        GPIO Info:
                                           GPIO : BUS_TYPE[bus/unit][chan]
        3 : GPIO
        8 : RMT_TX
        9 : GPIO
        12 : USB_DM
        13 : USB_DP
        14 : GPIO
               16 : UART_TX[0]
                                  17 : UART_RX[0]
                                                 ============ After Setup End =============
WiFi: establishing connection with SSID: "Supla"
[   862][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 101 - WIFI_READY
[   940][V][STA.cpp:186] _onStaEvent(): STA Started
[   940][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 110 - STA_START
[   940][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 110 - STA_START
[   989][V][STA.cpp:206] _onStaEvent(): STA Connected: SSID: Supla, BSSID: 82:ee:52:e0:2b:0e, Channel: 3, Auth: WPA2_PSK
[   990][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 112 - STA_CONNECTED
[   991][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 112 - STA_CONNECTED
[  2014][V][NetworkInterface.cpp:78] _onIpEvent(): sta Got New IP: 192.168.0.126 MASK: 255.255.255.0 GW: 192.168.0.10
[  2014][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 115 - STA_GOT_IP
[  2015][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 115 - STA_GOT_IP
[  2015][V][STA.cpp:171] _onStaArduinoEvent(): STA IP: 192.168.0.126, MASK: 255.255.255.0, GW: 192.168.0.10
Connected BSSID: 82:EE:52:E0:2B:0E
local IP: 192.168.0.126
subnetMask: 255.255.255.0
gatewayIP: 192.168.0.10
Signal strength (RSSI): -30 dBm
Establishing encrypted connection with: beta-cloud.supla.org (port: 2016)
[  2044][D][NetworkManager.cpp:83] hostByName(): Clearing DNS cache
[  2057][D][NetworkManager.cpp:127] hostByName(): DNS found IPv4 95.217.7.69
[  2057][V][ssl_client.cpp:68] start_ssl_client(): Free internal heap before TLS 215808
[  2058][V][ssl_client.cpp:75] start_ssl_client(): Starting socket (domain 2)
[  2099][V][ssl_client.cpp:170] start_ssl_client(): Seeding the random number generator
[  2104][V][ssl_client.cpp:178] start_ssl_client(): Setting up the SSL/TLS structure...
[  2105][V][ssl_client.cpp:198] start_ssl_client(): Loading CA cert
[  2114][V][ssl_client.cpp:292] start_ssl_client(): Setting hostname for TLS session...
[  2114][V][ssl_client.cpp:313] ssl_starttls_handshake(): Performing the SSL/TLS handshake...
[  2876][V][ssl_client.cpp:334] ssl_starttls_handshake(): Verifying peer X.509 certificate...
[  2876][V][ssl_client.cpp:342] ssl_starttls_handshake(): Certificate verified.
[  2877][V][ssl_client.cpp:358] ssl_starttls_handshake(): Free internal heap after TLS 177056
Connected via IP 192.168.0.126
SSL error: 48, UNKNOWN ERROR CODE (0030)
LAST STATE ADDED: UNKNOWN ERROR CODE (0030)
Connected to Supla Server
Initializing SRPC (proto: 23)
LAST STATE ADDED: Register in progress
Current status: [10] Register in progress
Send: [53 55 50 4C 41 17 01 00 00 00 4B 00 00 00 78 04 00 00 70 69 65 74 72 61 73 2D 38 31 40 74 6C 65 6E 2E 70 6C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 FB A5 87 43 98 39 7D B0 66 C2 53 2B E7 43 AE CF 49 D4 EC 00 31 30 5A AA 0D 93 37 7F 21 95 53 5A 69 67 62 65 65 20 74 6F 20 53 75 70 6C 61 20 47 61 74 65 77 61 79 00 00 00 00 00 00 00 00 00 00 00 ]
CH[110], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [6E 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[0], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [00 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[1], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [01 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[2], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [02 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[3], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [03 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[4], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [04 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[5], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [05 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[6], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [06 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[7], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [07 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[8], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [08 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[9], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [09 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[10], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [0A 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[11], type: 2900, FuncList: 0xEF, function: 130, flags: 0x9010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [0B 54 0B 00 00 EF 00 00 00 82 00 00 00 00 00 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[12], type: 1000, FuncList: 0x0, function: 236, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
Send: [0C E8 03 00 00 00 00 00 00 EC 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[13], type: 1000, FuncList: 0x0, function: 230, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [01 00 00 00 00 00 00 00]
Send: [0D E8 03 00 00 00 00 00 00 E6 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 ]
CH[14], type: 3038, FuncList: 0x0, function: 45, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [c8 cd fb ff 18 fc ff ff]
Send: [0E DE 0B 00 00 00 00 00 00 2D 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 C8 CD FB FF 18 FC FF FF 00 ]
Recv: [53 55 50 4C 41 17 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 1B 01 53 55 50 4C 41 ]
Device registered (activity timeout 120 s, server version: 27, server min version: 1)
LAST STATE ADDED: Registered and ready
Current status: [17] Registered and ready
Changing activity timeout to 30 s
Send: [53 55 50 4C 41 17 02 00 00 00 D2 00 00 00 01 00 00 00 1E ]
Notification: sending registration for context 12
Send: [53 55 50 4C 41 17 03 00 00 00 4C 04 00 00 0B 00 00 00 05 0C 00 00 00 00 00 00 00 00 00 ]
Notification: sending registration for context 13
Send: [53 55 50 4C 41 17 04 00 00 00 4C 04 00 00 0B 00 00 00 05 0D 00 00 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 17 05 00 00 00 E0 01 00 00 00 00 00 00 ]
[  3067][I][Z2S_Gateway.ino:1346] loop(): Starting Zigbee subsystem
[  3068][D][ZigbeeCore.cpp:167] zigbeeInit(): Initialize Zigbee stack
[  3071][D][ZigbeeCore.cpp:174] zigbeeInit(): Register all Zigbee EPs in list
[  3077][I][ZigbeeCore.cpp:182] zigbeeInit(): List of registered Zigbee EPs:
[  3077][I][ZigbeeCore.cpp:184] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[  3086][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[  3087][I][ZigbeeCore.cpp:276] esp_zb_app_signal_handler(): Zigbee stack initialized
[  3092][I][ZigbeeCore.cpp:391] esp_zb_app_signal_handler(): Network(0x89d7) closed, devices joining not allowed.
[  3094][I][ZigbeeCore.cpp:282] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[  3094][I][ZigbeeCore.cpp:295] esp_zb_app_signal_handler(): Device rebooted
[  3094][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[  3095][D][ZigbeeCore.cpp:542] searchBindings(): Requesting binding table for address 0x0000
[  3097][D][ZigbeeCore.cpp:482] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[  3098][D][ZigbeeCore.cpp:485] bindingTableCb(): Binding table info: total 9, index 0, count 3
[  3098][D][ZigbeeCore.cpp:495] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0006, dst_addr_mode 3
[  3099][I][z2s_devices_table.cpp:1602] Z2S_onBTCBoundDevice(): BTC bound device(0x42e9) on endpoint(0x1), cluster id(0x6)
[  3100][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x1, channel type 0xffffffff
[  3101][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x1, channel type 0xffffffff
[  3102][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x1, channel type 0xffffffff
[  3103][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x1, channel type 0xffffffff
[  3104][I][ZigbeeGateway.cpp:998] addBoundDevice(): New Zigbee device unit registered - IEEE address a4:c1:38:ae:2f:e0:ce:e1, short address 0x42e9, model id 0x5100, last seen (ms) 0
[  3104][D][ZigbeeCore.cpp:512] bindingTableCb(): Device bound to EP 1 -> device endpoint: 108, short addr: 0x4083, ieee addr: 40:82:03:70:40:82:03:70
[  3105][D][ZigbeeCore.cpp:495] bindingTableCb(): Binding table record: src_endp 1, dst_endp 2, cluster_id 0x0006, dst_addr_mode 3
[  3106][I][z2s_devices_table.cpp:1602] Z2S_onBTCBoundDevice(): BTC bound device(0x42e9) on endpoint(0x2), cluster id(0x6)
[  3106][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x2, channel type 0xffffffff
[  3107][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x2, channel type 0xffffffff
[  3108][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x2, channel type 0xffffffff
[  3109][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x2, channel type 0xffffffff
[  3109][I][ZigbeeGateway.cpp:984] addBoundDevice(): Zigbee device unit already registered, last short address 0x42e9, current short address 0x42e9
[  3110][D][ZigbeeCore.cpp:512] bindingTableCb(): Device bound to EP 1 -> device endpoint: 148, short addr: 0x4083, ieee addr: 40:86:77:F8:40:82:03:70
[  3111][D][ZigbeeCore.cpp:495] bindingTableCb(): Binding table record: src_endp 1, dst_endp 3, cluster_id 0x0006, dst_addr_mode 3
[  3112][I][z2s_devices_table.cpp:1602] Z2S_onBTCBoundDevice(): BTC bound device(0x42e9) on endpoint(0x3), cluster id(0x6)
[  3112][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x3, channel type 0xffffffff
[  3113][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x3, channel type 0xffffffff
[  3114][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x3, channel type 0xffffffff
[  3115][I][ZigbeeGateway.cpp:984] addBoundDevice(): Zigbee device unit already registered, last short address 0x42e9, current short address 0x42e9
[  3116][D][ZigbeeCore.cpp:512] bindingTableCb(): Device bound to EP 1 -> device endpoint: 164, short addr: 0x4084, ieee addr: 40:85:A1:4C:40:82:03:70
[  3117][D][ZigbeeCore.cpp:482] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[  3118][D][ZigbeeCore.cpp:485] bindingTableCb(): Binding table info: total 9, index 3, count 3
[  3118][D][ZigbeeCore.cpp:495] bindingTableCb(): Binding table record: src_endp 1, dst_endp 4, cluster_id 0x0006, dst_addr_mode 3
[  3119][I][z2s_devices_table.cpp:1602] Z2S_onBTCBoundDevice(): BTC bound device(0x42e9) on endpoint(0x4), cluster id(0x6)
[  3120][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x4, channel type 0xffffffff
[  3120][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x4, channel type 0xffffffff
[  3121][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x4, channel type 0xffffffff
[  3122][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:ae:2f:e0:ce:e1, endpoint 0x4, channel type 0xffffffff
[  3123][I][ZigbeeGateway.cpp:984] addBoundDevice(): Zigbee device unit already registered, last short address 0x42e9, current short address 0x42e9
[  3123][D][ZigbeeCore.cpp:512] bindingTableCb(): Device bound to EP 1 -> device endpoint: 200, short addr: 0x4084, ieee addr: 40:86:76:EC:40:82:03:70
[  3124][D][ZigbeeCore.cpp:495] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0001, dst_addr_mode 3
[  3125][I][z2s_devices_table.cpp:1602] Z2S_onBTCBoundDevice(): BTC bound device(0xacb6) on endpoint(0x1), cluster id(0x1)
[  3125][I][z2s_devices_table.cpp:103] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot a4:c1:38:2f:fd:d:4:14, endpoint 0x1, channel type 0xffffffff
[  3126][I][z2s_devices_table.cpp:124] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot a4:c1:38:2f:fd:d:4:14, endpoint 0x1, channel type 0xffffffff
[  3127][I][ZigbeeGateway.cpp:998] addBoundDevice(): New Zigbee device unit registered - IEEE address a4:c1:38:2f:fd:d:4:14, short address 0xacb6, model id 0x2000, last seen (ms) 0
https://pietras-81.aqi.eco/
Pietras81
Pietras81 wrote: Tue Jul 01, 2025 2:43 pm NIe wiem czy coś da się z tego wyczytać. Czujniki temperatury
See you soon!
Build:Sep 19 2022
Saved PC:0x4001975a
SPIWP:0xee
entry 0x4086c110
                                          Chip Info:
        Model             : ESP32-C6
        Package           : 0
        Revision          : 0.01
        Cores             : 1
        Embedded Flash    : No
        Embedded PSRAM    : No
        2.4GHz WiFi       : Yes
        Classic BT        : No
      BT Low Energy     : Yes
                               IEEE 802.15.4     : Yes
                                           Flash Info:
        Bus Speed         : 40 MHz
        Bus Mode          : QIO
        Partitions Info:
        Software Info:
        Board Info:
Reading section: 0
RECORD ID               1
MODEL NAME              TS0044
ENDPOINTS COUNT         0x4
POWER SOURCE            0x0
MODEL                   20736
LAST RSSI               0
LAST SEEN (MS)          2771
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              148
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             0
SUPLA CH[1]             1
SUPLA CH[2]             2
SUPLA CH[3]             3
SUPLA CH[4]             4
SUPLA CH[5]             5
SUPLA CH[6]             6
SUPLA CH[7]             7
SUPLA CH[8]             8
SUPLA CH[9]             9
SUPLA CH[10]            10
SUPLA CH[11]            11
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
RECORD ID               1
MODEL NAME              TS0205
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8192
LAST RSSI               0
LAST SEEN (MS)          2771
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              228
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             12
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
RECORD ID               1
MODEL NAME              TS0601
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8192
LAST RSSI               0
LAST SEEN (MS)          2771
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              148
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             13
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
RECORD ID               1
MODEL NAME              TS0601
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   4353
LAST RSSI               0
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
BATTERY ()              178
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             14
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           0
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           1
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           2
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x2
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           3
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x2
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           4
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x2
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           5
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x3
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           6
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x3
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           7
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x3
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           8
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x4
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           9
SUB ID                  0
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x4
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           10
SUB ID                  1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x4
CLUSTER                 0x6
MODEL                   5100
SUPLA CHANNEL           11
SUB ID                  2
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENDPOINT                0x1
CLUSTER                 0x500
MODEL                   2000
SUPLA CHANNEL           12
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            1
ENDPOINT                0x1
CLUSTER                 0x500
MODEL                   2000
SUPLA CHANNEL           13
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            2
ENDPOINT                0x1
CLUSTER                 0xEF00
MODEL                   1101
SUPLA CHANNEL           14
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            3
Device mode: 0
Enter normal mode
        GPIO Info:
        3 : GPIO
        8 : RMT_TX
        9 : GPIO
        12 : USB_DM
        13 : USB_DP
        14 : GPIO
               16 : UART_TX[0]
                                  17 : UART_RX[0]
Has thanked: 291 times
[ 56850][Z2S_Gateway.ino:1500] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
Niestety, nie doszło do odczytania manufacturer id - musisz spróbować ponownie.
cinas wrote: Mon Jun 30, 2025 4:17 pm Proszę o dodanie licznika energii 1-f dwukierunkowy
Peer Manufacturer is "_TZE284_iwn0gpzz"
Peer Model is "TS0601"
Licznik identyczny z wcześniej dodawanym tylko poparzeni był 3-faz
Licznik 3-faz któy działa poprawnie
Peer Manufacturer is "_TZE284_dikb3dp6"
+BWNU
lukasz06 wrote: Mon Jun 30, 2025 9:40 pm Witam, doszło mi kilka urzadzeń :)
[157163][ZigbeeGateway.cpp:389] zbReadBasicCluster(): Peer Model is "CK-BL702-AL-01(7009_Z102LG03-1)"
Ta żarówka jest już od dawna (0.7.12) w bazie ;)
Model - SNZB-02LD
+BWNU (jako T/H póki co)
Edit2. Smart Knob
Ten jest w bramce bodajże od lutego ;)
Pietras81
O to chodzi
[ 35118][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x1bdc)
[ 35118][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 35119][D][ZigbeeGateway.cpp:518] zbDeviceAnnce(): zbDeviceAnnce short address (0x1bdc), ieee_addr (0xa4):(0xc1):(0x38):(0xdb):(0xd2):(0xf6):(0x88):(0x89)
[ 35119][D][ZigbeeGateway.cpp:521] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x1bdc), ieee_addr (0xa4):(0xc1):(0x38):(0xdb):(0xd2):(0xf6):(0x88):(0x89)
[ 35120][I][ZigbeeGateway.cpp:545] zbDeviceAnnce(): Tuya magic last hope
[ 35324][I][ZigbeeGateway.cpp:588] printJoinedDevices(): joined devices:
[ 35324][I][ZigbeeGateway.cpp:591] printJoinedDevices(): Device on endpoint 1, short address: 0x1bdc
[ 35325][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 35326][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[ 35327][I][ZigbeeGateway.cpp:349] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 35704][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 35704][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1bdc) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35705][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(7)
[ 35705][I][ZigbeeGateway.cpp:382] zbReadBasicCluster(): Peer Manufacturer is "HOBEIAN"
[ 35706][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 35706][I][ZigbeeGateway.cpp:402] zbReadBasicCluster(): ZCL version id is "3"
[ 35707][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(147)
[ 35708][I][ZigbeeGateway.cpp:408] zbReadBasicCluster(): ZCL application version id is "147"
[ 35708][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[ 35709][I][ZigbeeGateway.cpp:389] zbReadBasicCluster(): Peer Model is "ZG-227Z"
[ 35709][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 35710][I][ZigbeeGateway.cpp:414] zbReadBasicCluster(): ZCL power source id is "3"
[ 35710][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 35714][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[ 35715][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 35715][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 35716][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 35716][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 21 size: 17
