Musiałbym przekompilować.lukfud wrote: Wed Aug 04, 2021 10:26 pm Jest możliwość aby przycisk był na 4 ?
Jaka prędkość jest na serialu?
Najwcześniej rano.
74880
Jeśli to nie problem, to poproszę.
ip:192.168.100.209,mask:255.255.255.0,gw:192.168.100.1
sproto send count: 39 result: -5
ip:192.168.100.209,mask:255.255.255.0,gw:192.168.100.1Dzięki, wieczorem wrzucę na esp i będę obserwował.
20:03:52.206 -> connected with supla_dev, channel 9
20:03:52.206 -> dhcp client start...
20:03:52.206 -> WiFi Status: 1
20:03:54.713 -> ip:10.0.4.19,mask:255.255.255.0,gw:10.0.4.1
20:03:54.813 -> WiFi Status: 5
20:03:54.813 -> supla_esp_devconn_resolvandconnect
20:03:54.813 -> Disconnect 6
20:03:54.813 -> Resolv svr30.supla.org
20:03:54.813 -> supla_esp_devconn_dns__found
20:03:54.867 -> Disconnect 6
20:03:54.867 -> please start sntp first !
20:03:54.867 -> client handshake start.
20:03:54.951 -> client handshake ok!
20:03:54.951 -> supla_esp_devconn_connect_cb
20:03:55.083 -> Registered and ready.
20:03:55.083 -> Free heap size: 17880
20:04:02.187 -> pm open,type:2 0
20:08:14.415 -> ip:10.0.4.19,mask:255.0.0.0,gw:10.0.0.1
20:08:16.035 -> sproto send count: 39 result: -5
20:08:30.026 -> ACTIVITY TIMEOUT
20:08:30.026 -> Disconnect 4
20:08:30.026 -> WiFi - Connecting...
20:08:30.026 -> Disconnected
20:08:30.026 -> supla_esp_devconn_disconnect_cb
20:08:30.026 -> state: 5 -> 0 (0)
20:08:30.026 -> rm 0
20:08:30.026 -> pm close 7
20:08:30.180 -> scandone
20:08:30.180 -> state: 0 -> 2 (b0)
20:08:30.180 -> state: 2 -> 3 (0)
20:08:30.180 -> state: 3 -> 5 (10)
20:08:30.180 -> add 0
20:08:30.180 -> aid 1
20:08:30.180 -> cnt
20:08:30.180 ->
20:08:30.180 -> connected with supla_dev, channel 9
20:08:30.226 -> dhcp client start...
20:08:30.226 -> WiFi Status: 1
20:08:30.226 -> Disconnected
20:08:32.031 -> Disconnect 6
20:08:32.031 -> WiFi - Connecting...
20:08:32.031 -> state: 5 -> 0 (0)
20:08:32.031 -> rm 0
20:08:32.031 -> Disconnected
20:08:32.132 -> scandone
20:08:32.132 -> state: 0 -> 2 (b0)
20:08:32.132 -> state: 2 -> 3 (0)
20:08:32.166 -> state: 3 -> 5 (10)
20:08:32.166 -> add 0
20:08:32.166 -> aid 1
20:08:32.166 -> cnt
20:08:32.201 ->
20:08:32.201 -> connected with supla_dev, channel 9
20:08:32.201 -> dhcp client start...
20:08:34.893 -> ip:10.0.4.19,mask:255.255.255.0,gw:10.0.4.1
20:08:35.040 -> WiFi Status: 5
20:08:35.040 -> supla_esp_devconn_resolvandconnect
20:08:35.040 -> Disconnect 6
20:08:35.040 -> Resolv svr30.supla.org
20:08:35.040 -> supla_esp_devconn_dns__found
20:08:35.040 -> please start sntp first !
20:08:35.040 -> client handshake start.
20:08:35.193 -> client handshake ok!
20:08:35.193 -> supla_esp_devconn_connect_cb
20:08:35.294 -> Registered and ready.
20:08:35.294 -> Free heap size: 18016
20:08:42.159 -> pm open,type:2 0
20:13:16.232 -> ip:10.0.4.19,mask:255.0.0.0,gw:10.0.0.1
20:13:21.046 -> sproto send count: 39 result: -5
20:13:35.026 -> ACTIVITY TIMEOUT
20:13:35.026 -> Disconnect 4
20:13:35.026 -> WiFi - Connecting...
20:13:35.026 -> Disconnected
20:13:35.026 -> supla_esp_devconn_disconnect_cb
20:13:35.026 -> state: 5 -> 0 (0)
20:13:35.026 -> rm 0
20:13:35.026 -> pm close 7
20:13:35.126 -> scandone
20:13:35.126 -> state: 0 -> 2 (b0)
20:13:35.126 -> state: 2 -> 3 (0)
20:13:35.189 -> state: 3 -> 5 (10)
20:13:35.189 -> add 0
20:13:35.189 -> aid 1
20:13:35.189 -> cnt
20:13:35.189 ->
20:13:35.189 -> connected with supla_dev, channel 9
20:13:35.189 -> dhcp client start...
20:13:35.226 -> WiFi Status: 1
20:13:35.226 -> Disconnected
20:13:37.032 -> Disconnect 6
20:13:37.032 -> WiFi - Connecting...
20:13:37.032 -> state: 5 -> 0 (0)
20:13:37.032 -> rm 0
20:13:37.032 -> Disconnected
20:13:37.132 -> scandone
20:13:37.132 -> state: 0 -> 2 (b0)
20:13:37.132 -> state: 2 -> 3 (0)
20:13:37.132 -> state: 3 -> 5 (10)
20:13:37.132 -> add 0
20:13:37.132 -> aid 1
20:13:37.179 -> cnt
20:13:37.179 ->
20:13:37.179 -> connected with supla_dev, channel 9
20:13:37.179 -> dhcp client start...
20:13:39.686 -> ip:10.0.4.19,mask:255.255.255.0,gw:10.0.4.1
20:13:39.839 -> WiFi Status: 5
20:13:39.839 -> supla_esp_devconn_resolvandconnect
20:13:39.839 -> Disconnect 6
20:13:39.839 -> Resolv svr30.supla.org
20:13:39.839 -> supla_esp_devconn_dns__found
20:13:39.839 -> please start sntp first !
20:13:39.839 -> client handshake start.
20:13:39.940 -> client handshake ok!
20:13:39.940 -> supla_esp_devconn_connect_cb
20:13:40.087 -> Registered and ready.
20:13:40.087 -> Free heap size: 18008
20:13:47.160 -> pm open,type:2 0
Widzę, zastanawiam się skąd...klew wrote: Thu Aug 05, 2021 6:22 pm Wg logów zmienia się maska podsieci i urządzenie dostaje inny adres bramki.
No i to jest bardzo ciekawe. Na 2.8.0 też tak się dzieje ? Zobacz jak się zachowuje 2.7.x. Teoretycznie na 2.8.x powinno wszędzie działać tak samo. Może na 2.7.x inaczej ? Pewny jesteś, że masz jeden serwer dhcp w sieci ? Ten router ma jeden WAN czy więcej ? Jaką masz topologię sieci ? Generalnie wygląda to tak, że nie ma tu nic do rzeczy ESP tylko to co mu wysyła serwer DHCP. Jak się zmienia bramka co 5 min to naturalne jest, że będzie restartował połączenie.
