Potrzebuje jeszcze dodać PIN_STATUS_LED na gpio rx - 3 ale nie wiem jak to ogarnąć pomoże ktoś?
ps. jeszcze do tego dodać aktualizację przez wifi to by już całkiem było super
Hello. I converted the elmaya thermostat from MAX thermocouple thermostat to DS18b20.
I still need to add PIN_STATUS_LED on gpio rx - 3 but I do not know how to embrace it will help someone?
PS. add to this update via wifi it would be quite great
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#define supla_lib_config_h_ // silences debug messages
#include "LittleFS.h"
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <ESP8266TrueRandom.h>
#include <WiFiClientSecure.h>
#include <Ticker.h>
#include <SuplaDevice.h>
#include <supla/control/virtual_relay.h>
#include <supla/sensor/DS18B20.h>
#define STORAGE_OFFSET 512
#include <supla/storage/eeprom.h>
Supla::Eeprom eeprom(STORAGE_OFFSET);
Supla::ESPWifi wifi("SSID", "PASS"); //------ Do not change----wifimanager takes care------
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
//#define RX 3 //High at boot
//#define TX 1 //must not be pulled low during power on/reset
int wificonfig_pin = 0; //D3 -- 0
int LED_PIN = 13; //D7 -- 13
int relay_pin = 12; //D6 -- 12
int DS_pin = 1; //TX -- 1
int button_pin = 0; //D3 -- 0
int pin_status_led = 3; //RX -- 3
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // ---------------------- config delay 5 seconds ---------------------------
char Supla_server[81] = ("svr?.supla.org");
char Email[81] = ("your@email");
char Supla_name[51] = ("Thermostat");
char term_temp[5] = ("0.5");
char term_hist[5] = ("1.0");
char Supla_status[51] = ("No server address");
char Router_SSID[32];
char Router_Pass[64];
bool initialConfig = false;
bool starting = true;
unsigned long wifi_checkDelay = 30000;
unsigned long wifimilis;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
double ThermostatTemperature = 22.0;
bool doSaveTermSetTemp = false;
float Term_Temp = 0.5;
float Term_Hist = 1.0;
bool tikOn = true;
bool statusLedOn = LOW;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
Ticker ticker;
Supla::Control::VirtualRelay *relay_0 = nullptr;
Supla::Control::Relay *relay_1 = nullptr;
Supla::Sensor::DS18B20 *dsTemp = nullptr;
class TermostatTemp : public Supla::Sensor::Thermometer {
public:
TermostatTemp() {}
void onInit() {
// retrieve value from eeprom to variable "ThermostatTemperature"
channel.setNewValue(getValue() );
double getValue() {
// returns the variable "ThermostatTemperature"
return ThermostatTemperature;
void iterateAlways() {
if ( millis() - lastReadTime > 5000) {
lastReadTime = millis();
if (relay_0->isOn()) {
double actualTemp = dsTemp->getValue();
if (((relay_1->isOn()) && ( actualTemp >= (ThermostatTemperature))) || ( actualTemp < -100.0)) {
relay_1->turnOff();
} else if ((!relay_1->isOn()) && ( actualTemp <= ThermostatTemperature - Term_Hist)) {
relay_1->turnOn();
}; TermostatTemp *TerTemp = nullptr;
class TermostatSet : public Supla::Control::Relay {
public:
TermostatSet() : Relay(-1, true, 32) {}
void onInit() {
// do nothing here
void turnOn(_supla_int_t duration) {
// increase "ThermostatTemperature" by Term_Temp
ThermostatTemperature += Term_Temp;
channel.setNewValue(false);
doSaveTermSetTemp = true;
void turnOff(_supla_int_t duration) {
// decrease "ThermostatTemperature" by Term_Temp
ThermostatTemperature -= Term_Temp;
bool isOn() {
return false;
}; TermostatSet *TerSet = nullptr;
void saveConfigCallback () {
shouldSaveConfig = true;
ticker.detach();
digitalWrite(LED_PIN, statusLedOn);
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required");
WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required");
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51, "required");
WiFiManagerParameter custom_term_temp("step", "Step +/-", term_temp, 5, "required");
WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5, "required");
WiFiManagerParameter custom_html_id21("<div><h4> - Supla State - ");
WiFiManagerParameter custom_html_id22(Supla_status);
WiFiManagerParameter custom_html_id23("</h4></div>");
wifiManager.setBreakAfterConfig(true);
wifiManager.addParameter(&custom_Email);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_term_temp);
wifiManager.addParameter(&custom_term_hist);
wifiManager.addParameter(&custom_html_id21);
wifiManager.addParameter(&custom_html_id22);
wifiManager.addParameter(&custom_html_id23);
wifiManager.setCustomHeadElement(logo);
wifiManager.setMinimumSignalQuality(8);
//wifiManager.setShowStaticFields(true); // force show static ip fields
//wifiManager.setShowDnsFields(true); // force show dns field always
wifiManager.setConfigPortalTimeout(300);
if (!wifiManager.startConfigPortal("DS_Thermostat")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)");
strcpy(Email, custom_Email.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(term_temp, custom_term_temp.getValue());
strcpy(term_hist, custom_term_hist.getValue());
wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33);
wifiManager.getWiFiPass().toCharArray(Router_Pass, 65);
if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0) {
Serial.println("new guid & authkey.");
EEPROM.write(300, 0);
EEPROM.commit();
delay(100);
ESP.reset();
if (shouldSaveConfig) {
DynamicJsonDocument json(1024);
json["Email"] = Email;
json["Supla_name"] = Supla_name;
json["term_temp"] = term_temp;
json["term_hist"] = term_hist;
json["Router_SSID"] = Router_SSID;
json["Router_Pass"] = Router_Pass;
File configFile = LittleFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
serializeJsonPretty(json, Serial);
serializeJson(json, configFile);
configFile.close();
WiFi.mode(WIFI_STA);
delay(5000);
ESP.restart();
WiFi.softAPdisconnect(true); // close AP
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
if (s != status) {
s = status;
if (s != 10) {
strcpy(Supla_status, msg);
void guid_authkey(void) {
if (EEPROM.read(300) != 60) {
int eep_gui = 301;
ESP8266TrueRandom.uuid(uuidNumber);
String uuidString = "";
for (int i = 0; i < 16; i++) {
int topDigit = uuidNumber[i] >> 4;
int bottomDigit = uuidNumber[i] & 0x0f;
uuidString += "0123456789abcdef"[topDigit];
uuidString += "0123456789abcdef"[bottomDigit];
int length_uuid = uuidString.length();
for (int i = 0; i < length_uuid; ++i) {
EEPROM.put(eep_gui + i, uuidString[i]);
int eep_aut = 341;
String uuidString2 = "";
uuidString2 += "0123456789abcdef"[topDigit];
uuidString2 += "0123456789abcdef"[bottomDigit];
int length_uuid2 = uuidString2.length();
for (int i = 0; i < length_uuid2; ++i) {
EEPROM.put(eep_aut + i, uuidString2[i]);
EEPROM.write(300, 60);
EEPROM.commit();
delay(0);
read_guid();
read_authkey();
//Serial.print("GUID : ");Serial.println(read_guid());
//Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
String read_eeprom = "";
int i, ii = 0;
int eep_star = 301;
int end_guid = eep_star + SUPLA_GUID_SIZE;
String temp_read = "0x";
for (i = eep_star; i < end_guid + 16; i = i + 1) {
temp_read += char(EEPROM.read(i));
read_eeprom += char(EEPROM.read(i));
if ( (i % 2) == 0) {
char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
GUID[ii] = strtoul( _guid, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
String read_authkey(void) {
int i, ii = 0;
int eep_star = 341;
int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
for (i = eep_star; i < end_authkey + 16; i = i + 1) {
char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
void tick() {
int state = digitalRead(LED_PIN);
digitalWrite(LED_PIN, !state);
void setup() {
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
//WiFi.setOutputPower(17.5);
delay(10);
pinMode(wificonfig_pin, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
ticker.attach(0.5, tick);
EEPROM.begin(1024);
initialConfig = true;
guid_authkey();
if (WiFi.SSID() == "") {
if (LittleFS.begin()) { // ------------------------- wificonfig read -----------------
if (LittleFS.exists("/config.json")) {
File configFile = LittleFS.open("/config.json", "r");
if (configFile) {
DeserializationError deserializeError = deserializeJson(json, buf.get());
if (!deserializeError) {
Serial.println("\nparsed json");
if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
if (json.containsKey("Email")) strcpy(Email, json["Email"]);
if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
if (json.containsKey("term_temp")) {
strcpy(term_temp, json["term_temp"]);
Term_Temp = (String(term_temp).toFloat());
if (Term_Temp < 0.1) {
Term_Temp = 0.1;
else if (Term_Temp > 50.0) {
Term_Temp = 50.0;
strcpy(term_hist, json["term_hist"]);
Term_Hist = (String(term_hist).toFloat());
if (Term_Hist < 0.1) {
Term_Hist = 0.1;
else if (Term_Hist > 50.0) {
Term_Hist = 50.0;
if (json.containsKey("Router_SSID")) strcpy(Router_SSID, json["Router_SSID"]);
if (json.containsKey("Router_Pass")) strcpy(Router_Pass, json["Router_Pass"]);
} else {
configFile.close();
} else {
Serial.println("failed to mount FS");
Serial.print("Term_Temp: "); Serial.println(Term_Temp);
Serial.print("Term_Hist: "); Serial.println(Term_Hist);
wifi_station_set_hostname(Supla_name);
EEPROM.get(381, ThermostatTemperature);
if ((ThermostatTemperature > 1000.0) || isnan(ThermostatTemperature)) {
EEPROM.put(381, ThermostatTemperature);
EEPROM.commit();
Serial.println("ThermostatTemperature reset to 22.0ºC");
relay_0 = new Supla::Control::VirtualRelay(32);
relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
relay_0->setDefaultStateRestore();
relay_0->disableChannelState();
relay_1 = new Supla::Control::Relay(relay_pin, true);
relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
relay_1->setDefaultStateOff();
relay_1->disableChannelState();
dsTemp = new Supla::Sensor::DS18B20(DS_pin);
TerTemp = new TermostatTemp();
TerSet = new TermostatSet();
TerSet->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
TerSet->disableChannelState();
auto button_1 = new Supla::Control::Button(button_pin, true, true);
button_1->addAction(Supla::TOGGLE, relay_0, Supla::ON_PRESS);
button_1->setSwNoiseFilterDelay(50);
relay_0->addAction(Supla::TURN_OFF, relay_1, Supla::ON_TURN_OFF);
SuplaDevice.setName(Supla_name);
wifi.setSsid(Router_SSID);
wifi.setPassword(Router_Pass);
SuplaDevice.setStatusFuncImpl(&status_func);
wifi.enableSSL(false);
SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY);
void loop() {
if (initialConfig == true) {
ondemandwifiCallback();
int C_W_read = digitalRead(wificonfig_pin); {
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
C_W_state = C_W_read;
if (C_W_state == LOW) {
ondemandwifiCallback () ;
last_C_W_state = C_W_read;
if (WiFi.status() == WL_CONNECTED) {
if (starting) {
httpUpdater.setup(&httpServer, "/update", "admin", "pass");
httpServer.begin();
starting = false;
Serial.print("get DS18B20 temperature: ");
Serial.println(dsTemp->getValue());
httpServer.handleClient();
} else {
if ((millis() - wifimilis) > wifi_checkDelay) {
WiFi.begin(Router_SSID, Router_Pass);
Serial.println("CONNECT WIFI!!");
wifimilis = millis() ;
tikOn = true;
SuplaDevice.iterate();
delay(25);
if (doSaveTermSetTemp) {
EEPROM.commit();
if (s == STATUS_REGISTERED_AND_READY) {
if (tikOn) {
ticker.detach();
digitalWrite(LED_PIN, !statusLedOn);
tikOn = false;
} else if (!tikOn) {
tikOn = true;
