Log do sprawdzenia po instalacji
Mac
witam
Postawiłem od nowa SUPLA Cloud 23.09.
Po restarcie supla-dockera na poczatku wyrzuca błędy z GoogleHomeGraph a później dochodzi ten błąd "PUSH gateways from the AD server failed"
P.S. nie moge połączyć urządzeń supla z google home.
ERR[17:18:35.161301] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:35.608785] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:35.907487] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:36.015416] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:36.177362] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:36.193320] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
INFO[17:18:59.417402] Connection accepted: 10.0.6.46:19163 ClientSD: 111 Secure: 1
INFO[17:18:59.550705] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 111
INFO[17:18:59.697378] Device registration started. ClientSD: 111 Protocol Version: 7 ThreadID: 62 GUID: EC6A094F
INFO[17:18:59.918903] Connection accepted: 10.0.6.45:31513 ClientSD: 27 Secure: 1
INFO[17:18:59.931733] Device registered. ID: 55, ClientSD: 111 Protocol Version: 7 ThreadID: 62 GUID: EC6A094F ResultCode: 3
INFO[17:19:00.048251] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 27
INFO[17:19:00.159075] Device registration started. ClientSD: 27 Protocol Version: 7 ThreadID: 63 GUID: 7EE3D0D7
INFO[17:19:00.325416] Device registered. ID: 54, ClientSD: 27 Protocol Version: 7 ThreadID: 63 GUID: 7EE3D0D7 ResultCode: 3
INFO[17:19:04.625352] Connection accepted: 192.168.1.1:8476 ClientSD: 104 Secure: 1
INFO[17:19:04.763167] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 104
INFO[17:19:04.873789] Device registration started. ClientSD: 104 Protocol Version: 16 ThreadID: 66 GUID: 6D9F87FD
INFO[17:19:04.991743] Device registered. ID: 53, ClientSD: 104 Protocol Version: 16 ThreadID: 66 GUID: 6D9F87FD ResultCode: 3
INFO[17:19:20.229942] Connection accepted: 192.168.1.1:46490 ClientSD: 108 Secure: 1
INFO[17:19:20.276368] Cipher: TLS_AES_256_GCM_SHA384, SSL Version: TLSv1.3, ClientSD: 108
INFO[17:19:20.541706] Client registered. ClientSD: 108 Protocol Version: 20
ERR[17:19:29.730214] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
INFO[17:19:53.115923] Connection accepted: 10.0.6.39:59117 ClientSD: 105 Secure: 1
INFO[17:19:53.323737] Cipher: AES128-SHA256, SSL Version: TLSv1.2, ClientSD: 105
INFO[17:19:53.405865] Device registration started. ClientSD: 105 Protocol Version: 16 ThreadID: 81 GUID: 4117B75E
INFO[17:19:53.505473] Device registered. ID: 40, ClientSD: 105 Protocol Version: 16 ThreadID: 81 GUID: 4117B75E ResultCode: 3
ERR[17:20:29.923230] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:21:30.116491] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:22:29.334102] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:23:29.532748] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:24:29.724274] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
INFO[17:24:39.240726] Connection accepted: 10.0.6.39:65373 ClientSD: 114 Secure: 1
INFO[17:24:39.455009] Cipher: AES128-SHA256, SSL Version: TLSv1.2, ClientSD: 114
INFO[17:24:39.538071] Device registration started. ClientSD: 114 Protocol Version: 16 ThreadID: 165 GUID: 4117B75E
INFO[17:24:39.614997] Device registered. ID: 40, ClientSD: 114 Protocol Version: 16 ThreadID: 165 GUID: 4117B75E ResultCode: 3
ERR[17:25:29.915947] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:26:30.106151] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
root@raspberrypi:/home/pi# docker logs --since=5m supla-server
ERR[17:27:29.297468] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
root@raspberrypi:/home/pi# docker logs --since=3m supla-server
ERR[17:28:29.493479] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
mgolaszewski
U mnie to samo, i status unhealthy
Z tych logów nic nie wynika poza tym, że google nie wie co za urządzenia ta instancja mu raportuje, a próba uzyskania tokena do push-y kończy się niepowodzeniem co jest zgodne ze stanem faktycznym. Widać też, że zarejestrowały się urządzenia więc nie wiem co tam może nie działać.
Mac
aktualizacja
Poprzednie logi ustały po zarejestrowaniu supli
google home działa , własciwie to wszystko działa jednak log wywala taki:
pi@raspberrypi:~ $ docker logs --tail=50 supla-server
ERR[14:28:44.344443] Could not get any token for PUSH gateway from AD server.
ERR[14:29:44.536605] Could not get any token for PUSH gateway from AD server.
ERR[14:30:44.727128] Could not get any token for PUSH gateway from AD server.
ERR[14:31:44.920927] Could not get any token for PUSH gateway from AD server.
ERR[14:32:45.111120] Could not get any token for PUSH gateway from AD server.
ERR[14:33:44.303769] Could not get any token for PUSH gateway from AD server.
ERR[14:34:44.493955] Could not get any token for PUSH gateway from AD server.
ERR[14:35:44.688129] Could not get any token for PUSH gateway from AD server.
ERR[14:36:44.879588] Could not get any token for PUSH gateway from AD server.
ERR[14:37:45.069461] Could not get any token for PUSH gateway from AD server.
ERR[14:38:44.266760] Could not get any token for PUSH gateway from AD server.
ERR[14:39:44.458135] Could not get any token for PUSH gateway from AD server.
ERR[14:40:44.648356] Could not get any token for PUSH gateway from AD server.
INFO[14:40:47.758731] Connection accepted: 10.0.6.39:54641 ClientSD: 42 Secure: 1
INFO[14:40:47.978773] Cipher: AES128-SHA256, SSL Version: TLSv1.2, ClientSD: 42
INFO[14:40:48.059208] Device registration started. ClientSD: 42 Protocol Version: 16 ThreadID: 4464 GUID: 4117B75E
INFO[14:40:48.096432] Device registered. ID: 40, ClientSD: 42 Protocol Version: 16 ThreadID: 4464 GUID: 4117B75E ResultCode: 3
ERR[14:41:44.849835] Could not get any token for PUSH gateway from AD server.
ERR[14:42:45.042203] Could not get any token for PUSH gateway from AD server.
ERR[14:43:44.236605] Could not get any token for PUSH gateway from AD server.
ERR[14:44:44.427257] Could not get any token for PUSH gateway from AD server.
ERR[14:45:44.618522] Could not get any token for PUSH gateway from AD server.
ERR[14:46:44.809976] Could not get any token for PUSH gateway from AD server.
INFO[14:47:29.745608] Connection accepted: 194.165.16.37:5007 ClientSD: 112 Secure: 1
INFO[14:47:29.788693] Connection accepted: 194.165.16.37:5245 ClientSD: 36 Secure: 1
INFO[14:47:29.873251] Connection accepted: 194.165.16.37:5678 ClientSD: 43 Secure: 1
ERR[14:47:45.001440] Could not get any token for PUSH gateway from AD server.
ERR[14:48:44.192989] Could not get any token for PUSH gateway from AD server.
ERR[14:49:44.384502] Could not get any token for PUSH gateway from AD server.
ERR[14:50:44.578804] Could not get any token for PUSH gateway from AD server.
ERR[14:51:44.771430] Could not get any token for PUSH gateway from AD server.
ERR[14:52:44.962194] Could not get any token for PUSH gateway from AD server.
ERR[14:53:45.156662] Could not get any token for PUSH gateway from AD server.
ERR[14:54:44.350438] Could not get any token for PUSH gateway from AD server.
ERR[14:55:44.541742] Could not get any token for PUSH gateway from AD server.
INFO[14:56:06.581799] Connection accepted: 10.0.6.41:50915 ClientSD: 36 Secure: 1
INFO[14:56:16.277530] Connection accepted: 10.0.6.41:62558 ClientSD: 79 Secure: 1
INFO[14:56:20.219799] Cipher: ECDHE-RSA-CHACHA20-POLY1305, SSL Version: TLSv1.2, ClientSD: 79
INFO[14:56:21.189487] Device registration started. ClientSD: 79 Protocol Version: 12 ThreadID: 4670 GUID: 0C4F1E9F
INFO[14:56:21.238178] Device registered. ID: 57, ClientSD: 79 Protocol Version: 12 ThreadID: 4670 GUID: 0C4F1E9F ResultCode: 3
ERR[14:56:44.732251] Could not get any token for PUSH gateway from AD server.
ERR[14:57:44.925777] Could not get any token for PUSH gateway from AD server.
ERR[14:58:45.120637] Could not get any token for PUSH gateway from AD server.
ERR[14:59:44.313435] Could not get any token for PUSH gateway from AD server.
ERR[15:00:44.506104] Could not get any token for PUSH gateway from AD server.
ERR[15:01:44.698322] Could not get any token for PUSH gateway from AD server.
ERR[15:02:44.889686] Could not get any token for PUSH gateway from AD server.
ERR[15:03:45.083648] Could not get any token for PUSH gateway from AD server.
ERR[15:04:44.277603] Could not get any token for PUSH gateway from AD server.
ERR[15:05:44.471654] Could not get any token for PUSH gateway from AD server.
co to znaczy? Could not get any token for PUSH gateway from AD server.
Obecnie prywatne instancje nie mają dostępu do PUSH-y. Stąd ten log.
Mac
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
21c4b5b4fcf4 suplascripts_suplascripts "docker-php-entrypoi…" 3 days ago Up 7 hours 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp suplascripts
f226c68cbfed hypriot/rpi-mysql:5.5 "/entrypoint.sh mysq…" 3 days ago Up 7 hours 3306/tcp suplascripts-db
3d90157fe26d supla/supla-server:arm32v7 "/usr/bin/server-ent…" 3 days ago Up 7 hours (unhealthy) 0.0.0.0:2015-2016->2015-2016/tcp, :::2015-2016->2015-2016/tcp supla-server
544c55019942 supla/supla-cloud:arm32v7 "docker-php-entrypoi…" 3 days ago Up 7 hours (unhealthy) 0.0.0.0:2112->80/tcp, :::2112->80/tcp, 0.0.0.0:2113->443/tcp, :::2113->443/tcp supla-cloud
4a62cba49a56 hypriot/rpi-mysql:5.5 "/entrypoint.sh mysq…" 3 days ago Up 7 hours 3306/tcp
Też mam 2 x unehalthy
