Postawiłem od nowa SUPLA Cloud 23.09.
Po restarcie supla-dockera na poczatku wyrzuca błędy z GoogleHomeGraph a później dochodzi ten błąd "PUSH gateways from the AD server failed"
P.S. nie moge połączyć urządzeń supla z google home.
ERR[17:18:35.161301] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:35.608785] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:35.907487] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:36.015416] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:36.177362] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
ERR[17:18:36.193320] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
INFO[17:18:59.417402] Connection accepted: 10.0.6.46:19163 ClientSD: 111 Secure: 1
INFO[17:18:59.550705] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 111
INFO[17:18:59.697378] Device registration started. ClientSD: 111 Protocol Version: 7 ThreadID: 62 GUID: EC6A094F
INFO[17:18:59.918903] Connection accepted: 10.0.6.45:31513 ClientSD: 27 Secure: 1
INFO[17:18:59.931733] Device registered. ID: 55, ClientSD: 111 Protocol Version: 7 ThreadID: 62 GUID: EC6A094F ResultCode: 3
INFO[17:19:00.048251] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 27
INFO[17:19:00.159075] Device registration started. ClientSD: 27 Protocol Version: 7 ThreadID: 63 GUID: 7EE3D0D7
INFO[17:19:00.325416] Device registered. ID: 54, ClientSD: 27 Protocol Version: 7 ThreadID: 63 GUID: 7EE3D0D7 ResultCode: 3
INFO[17:19:04.625352] Connection accepted: 192.168.1.1:8476 ClientSD: 104 Secure: 1
INFO[17:19:04.763167] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 104
INFO[17:19:04.873789] Device registration started. ClientSD: 104 Protocol Version: 16 ThreadID: 66 GUID: 6D9F87FD
INFO[17:19:04.991743] Device registered. ID: 53, ClientSD: 104 Protocol Version: 16 ThreadID: 66 GUID: 6D9F87FD ResultCode: 3
INFO[17:19:20.229942] Connection accepted: 192.168.1.1:46490 ClientSD: 108 Secure: 1
INFO[17:19:20.276368] Cipher: TLS_AES_256_GCM_SHA384, SSL Version: TLSv1.3, ClientSD: 108
INFO[17:19:20.541706] Client registered. ClientSD: 108 Protocol Version: 20
ERR[17:19:29.730214] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
INFO[17:19:53.115923] Connection accepted: 10.0.6.39:59117 ClientSD: 105 Secure: 1
INFO[17:19:53.323737] Cipher: AES128-SHA256, SSL Version: TLSv1.2, ClientSD: 105
INFO[17:19:53.405865] Device registration started. ClientSD: 105 Protocol Version: 16 ThreadID: 81 GUID: 4117B75E
INFO[17:19:53.505473] Device registered. ID: 40, ClientSD: 105 Protocol Version: 16 ThreadID: 81 GUID: 4117B75E ResultCode: 3
ERR[17:20:29.923230] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:21:30.116491] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:22:29.334102] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:23:29.532748] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:24:29.724274] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
INFO[17:24:39.240726] Connection accepted: 10.0.6.39:65373 ClientSD: 114 Secure: 1
INFO[17:24:39.455009] Cipher: AES128-SHA256, SSL Version: TLSv1.2, ClientSD: 114
INFO[17:24:39.538071] Device registration started. ClientSD: 114 Protocol Version: 16 ThreadID: 165 GUID: 4117B75E
INFO[17:24:39.614997] Device registered. ID: 40, ClientSD: 114 Protocol Version: 16 ThreadID: 165 GUID: 4117B75E ResultCode: 3
ERR[17:25:29.915947] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
ERR[17:26:30.106151] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
root@raspberrypi:/home/pi# docker logs --since=5m supla-server
ERR[17:27:29.297468] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
root@raspberrypi:/home/pi# docker logs --since=3m supla-server
ERR[17:28:29.493479] An attempt to obtain tokens for PUSH gateways from the AD server failed. Result code: 403
