https://www.youtube.com/watch?v=qj_k_xXImMw
#include <Wire.h>
#include <SuplaDevice.h>
#include <supla/sensor/DS18B20.h>
Supla::ESPWifi wifi("xx, "xx");
#include <OneWire.h>
#include <Timers.h>
#include "ESPRotary.h"
#include <LiquidCrystal_I2C.h>
#include "Button2.h"
byte stopien[8] ={ // stopień
B01100,
B10010,
B10010,
B01100,
B00000,
B00000,
B00000,
B00000
#define ROTARY_PIN1 D6
#define ROTARY_PIN2 D0
#define BUTTON_PIN D7
// this number depends on your rotary encoder
#define CLICKS_PER_STEP 4
ESPRotary r;
Button2 b;
LiquidCrystal_I2C lcd(0x27, 16, 2);
int t1;
int t2;
int t3;
int t4;
int t5;
int tempMin = 25;
int tempMax = 27;
int przek1 = 0;
int tempUst = 0;
int wyslanoON = 0;
int wyslanoOFF = 0;
boolean lewy = false;
boolean prawy = false;
OneWire oneWire0(D3);//D1
DallasTemperature t123(&oneWire0);
DeviceAddress ds1 = {0x28, 0xC4, 0xC6, 0x57, 0x04, 0xE1, 0x3C, 0x8F};
DeviceAddress ds2 = {0x28, 0x3E, 0xBD, 0x57, 0x04, 0xE1, 0x3C, 0x2F};
DeviceAddress ds3 = {0x28, 0x85, 0x51, 0x57, 0x04, 0xE1, 0x3C, 0x2B};
OneWire oneWire1(D4);//D2
DallasTemperature t45(&oneWire1);
DeviceAddress ds4 = {0x28, 0xE2, 0x88, 0x57, 0x04, 0xE1, 0x3C, 0xC0};
DeviceAddress ds5 = {0x28, 0x73, 0xF6, 0x57, 0x04, 0xE1, 0x3C, 0x89};
Timer sekund30;
Timer sekund3;
Timer sekund10;
enum PIERWSZE {JEDEN=1,DWA,TRZY,CZTERY,PIEC,SZESC,SIEDEM,OSIEM,DZIEWIEC,DZIESIEC,JEDENASCIE,DWANASCIE,TRZYNASCIE,CZTERNASCIE,PIETNASCIE,SZESNASCIE};
int menu_1=JEDEN;
Supla::Control::Relay *relay1 = nullptr;
void setup() {
Serial.begin(9600);
sekund30.begin(29898);
sekund3.begin(2997);
sekund10.begin(60111);
r.begin(ROTARY_PIN1, ROTARY_PIN2, CLICKS_PER_STEP);
r.setLeftRotationHandler(showDirection);
r.setRightRotationHandler(showDirection);
b.begin(BUTTON_PIN);
b.setTapHandler(click);
b.setLongClickHandler(resetPosition);
b.setLongClickTime(3000);
b.setDoubleClickTime(700);
b.setTripleClickHandler(tripleClick);
Wire.begin(4, 5); //4, 5
char GUID[SUPLA_GUID_SIZE] = {xxx};
char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {xxx};
new Supla::Sensor::DS18B20(D3, ds1);
new Supla::Sensor::DS18B20(D3, ds2);
new Supla::Sensor::DS18B20(D3, ds3);
new Supla::Sensor::DS18B20(D4, ds4);
new Supla::Sensor::DS18B20(D4, ds5);
relay1 = new Supla::Control::Relay(D5, false);
//auto relay2 = new Supla::Control::Relay(D8, false);
"svrxx.supla.org", // SUPLA server address
"[email protected]", // Email address used to login to Supla Cloud
AUTHKEY);
t123.begin();
t45.begin();
dsSTART();
lcd.init();
lcd.backlight();
lcd.createChar(0, stopien);
void loop() {
SuplaDevice.iterate();
ds();
relayOnOff();
menu_glowne();
r.loop();
b.loop();
// on left or right rotation
void showDirection(ESPRotary& r) {
if(r.getDirection() == left){
// lewy = true;
if(menu_1==SZESC){
menu_1=DZIEWIEC;
lcd.clear();
else if(menu_1==SIEDEM) {
if(tempUst > (tempMin+2)){
tempUst = tempUst-1;
else if(menu_1==DZIESIEC){
if(tempUst>10){
// Serial.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!LEWO");
if(r.getDirection() == right){
//prawy = true;
if(menu_1==DZIEWIEC){
menu_1=SZESC;
lcd.clear();
else if(menu_1==SIEDEM){
if(tempUst<80){
tempUst = tempUst+1;
if(tempUst < (tempMax -2)){
//Serial.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!PRAWO");
// single click
void click(Button2& btn) {
// long click
void resetPosition(Button2& btn) {
r.resetPosition();
if(menu_1==SZESC){ // max->ustaw
menu_1=SIEDEM;
tempUst=tempMax;
sekund10.restart();
lcd.clear();
else if(menu_1==DZIEWIEC){ // min->ustaw
menu_1=DZIESIEC;
tempUst=tempMin;
sekund10.restart();
lcd.clear();
else if(menu_1==SIEDEM){ //max->ustawiono
tempMax=tempUst;
menu_1=OSIEM;
lcd.clear();
sekund3.restart();
else if(menu_1==DZIESIEC){ // min->ustawiono
tempMin=tempUst;
menu_1=JEDENASCIE;
lcd.clear();
sekund3.restart();
//Serial.println("LLLLLLLLLLLLOOOOOOOOOOOOOOONNNNNNNNNNNNNNNNNNNNNNNNNGGGGGGGGGGGGGGGGG");
void tripleClick(Button2& btn) {
//Serial.println("..................................................tripleeeeeeeeeeeeee");
menu_1=SZESC;
sekund10.restart();
lcd.clear();
void ds(){
if(sekund30.available()){
t123.requestTemperatures();
t1 = (t123.getTempC(ds1));
t2 = (t123.getTempC(ds2));
t3 = (t123.getTempC(ds3));
t45.requestTemperatures();
t4 = (t45.getTempC(ds4));
t5 = (t45.getTempC(ds5));
if((t1>tempMax) || (t2>tempMax) || (t3>tempMax) || (t4>tempMax) || (t5>tempMax)){
przek1=1;
else if((t1<tempMin) && (t2<tempMin) && (t3<tempMin) && (t4<tempMin) && (t5<tempMin)){
przek1=0;
sekund30.restart();
void dsSTART(){
/*if(((t1) || (t2) || (t3) || (t4) || (t5))>tempMax){
przek1=1;
else if(((t1) && (t2) && (t3) && (t4) && (t5))<tempMin){
przek1=0;
void relayOnOff(){
if((przek1 == 1) && (wyslanoON == 0)){
relay1->turnOn();
wyslanoON = 1;
wyslanoOFF = 0;
else if((przek1==0) && (wyslanoOFF==0)){
relay1->turnOff();
wyslanoOFF = 1;
wyslanoON = 0;
void menu_glowne(){
switch(menu_1){
case JEDEN:
one();
if(sekund3.available()){
menu_1=DWA;
lcd.clear();
sekund3.restart();
break;
case DWA:
two();
menu_1=TRZY;
lcd.clear();
sekund3.restart();
break;
case TRZY:
three();
menu_1=CZTERY;
lcd.clear();
sekund3.restart();
break;
case CZTERY:
four();
menu_1=PIEC;
lcd.clear();
sekund3.restart();
break;
case PIEC:
five();
menu_1=JEDEN;
lcd.clear();
sekund3.restart();
break;
case SZESC:
six();
if(sekund10.available()){
menu_1=JEDEN;
lcd.clear();
sekund3.restart();
break;
case SIEDEM:
seven();
menu_1=JEDEN;
lcd.clear();
sekund3.restart();
break;
case OSIEM:
eight();
menu_1=JEDEN;
lcd.clear();
sekund3.restart();
break;
case DZIEWIEC:
nine();
menu_1=JEDEN;
lcd.clear();
sekund3.restart();
break;
case DZIESIEC:
ten();
menu_1=JEDEN;
lcd.clear();
sekund3.restart();
break;
case JEDENASCIE:
eleven();
menu_1=JEDEN;
sekund3.restart();
break;
void one(){
lcd.setCursor(0,0);
lcd.print("Temp. 1: ");
lcd.print(t1);
lcd.write(byte(0));
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Temp. 2: ");
lcd.print(t2);
lcd.write(byte(0));
lcd.print("C");
void two(){
lcd.setCursor(0,0);
lcd.print(t2);
lcd.write(byte(0));
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Temp. 3: ");
lcd.print(t3);
lcd.write(byte(0));
lcd.print("C");
void three(){
lcd.setCursor(0,0);
lcd.print(t3);
lcd.write(byte(0));
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Temp. 4: ");
lcd.print(t4);
lcd.write(byte(0));
lcd.print("C");
void four(){
lcd.setCursor(0,0);
lcd.print(t4);
lcd.write(byte(0));
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Temp. 5: ");
lcd.print(t5);
lcd.write(byte(0));
lcd.print("C");
void five(){
lcd.setCursor(0,0);
lcd.print(t5);
lcd.write(byte(0));
lcd.print("C");
lcd.setCursor(0,1);
lcd.print(t1);
lcd.write(byte(0));
lcd.print("C");
void six(){
lcd.setCursor(0,0);
lcd.print("Temperatura MAX:");
lcd.setCursor(0,1);
lcd.print("temp MAX: ");
lcd.print(tempMax);
lcd.write(byte(0));
lcd.print("C");
void seven(){
lcd.setCursor(0,0);
lcd.print("* Ustaw MAX *");
lcd.setCursor(0,1);
lcd.print(tempUst);
lcd.write(byte(0));
lcd.print("C");
void eight(){
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" !!ZMIENIONA!!");
void nine(){
lcd.setCursor(0,0);
lcd.print("Temperatura MIN:");
lcd.setCursor(0,1);
lcd.print("temp MIN: ");
lcd.print(tempMin);
lcd.write(byte(0));
lcd.print("C");
void ten(){
lcd.setCursor(0,0);
lcd.print("* Ustaw MIN *");
lcd.setCursor(0,1);
lcd.print(tempUst);
lcd.write(byte(0));
lcd.print("C");
void eleven(){
lcd.setCursor(0,0);
lcd.setCursor(0,1);
