Termostat na 5szt DS
SOYER
Cześć, na prośbę wklejam szkic do jednego z moich termostatów:
https://www.youtube.com/watch?v=qj_k_xXImMw
#include <Wire.h>
#include <SuplaDevice.h>
 Supla::ESPWifi wifi("xx, "xx");
#include <OneWire.h>
#include <Timers.h>
#include "ESPRotary.h"
#include <LiquidCrystal_I2C.h>
#include "Button2.h"
byte stopien[8] ={ // stopień
                      B01100,
                      B10010,
                      B10010,
                      B01100,
                      B00000,
                      B00000,
                      B00000,
                      B00000
#define ROTARY_PIN1  D6
#define ROTARY_PIN2 D0
#define BUTTON_PIN  D7
// this number depends on your rotary encoder
#define CLICKS_PER_STEP 4
ESPRotary r;
Button2 b;
LiquidCrystal_I2C lcd(0x27, 16, 2);
int t1;
int t2;
int t3;
int t4;
int t5;
int tempMin = 25;
int tempMax = 27;
int przek1 = 0;
int tempUst = 0;
int wyslanoON = 0;
int wyslanoOFF = 0;
boolean lewy = false;
boolean prawy = false;
OneWire oneWire0(D3);//D1
DallasTemperature t123(&oneWire0);
DeviceAddress ds1 = {0x28, 0xC4, 0xC6, 0x57, 0x04, 0xE1, 0x3C, 0x8F};
DeviceAddress ds2 = {0x28, 0x3E, 0xBD, 0x57, 0x04, 0xE1, 0x3C, 0x2F};
DeviceAddress ds3 = {0x28, 0x85, 0x51, 0x57, 0x04, 0xE1, 0x3C, 0x2B};
OneWire oneWire1(D4);//D2
DallasTemperature t45(&oneWire1);
DeviceAddress ds4 = {0x28, 0xE2, 0x88, 0x57, 0x04, 0xE1, 0x3C, 0xC0};
DeviceAddress ds5 = {0x28, 0x73, 0xF6, 0x57, 0x04, 0xE1, 0x3C, 0x89};
Timer sekund30;
Timer sekund3;
Timer sekund10;
enum PIERWSZE {JEDEN=1,DWA,TRZY,CZTERY,PIEC,SZESC,SIEDEM,OSIEM,DZIEWIEC,DZIESIEC,JEDENASCIE,DWANASCIE,TRZYNASCIE,CZTERNASCIE,PIETNASCIE,SZESNASCIE};
int menu_1=JEDEN;
Supla::Control::Relay *relay1 = nullptr;
void setup() {
  Serial.begin(9600);
  sekund30.begin(29898);
  sekund3.begin(2997);
  sekund10.begin(60111);
  r.begin(ROTARY_PIN1, ROTARY_PIN2, CLICKS_PER_STEP);
  r.setLeftRotationHandler(showDirection);
  r.setRightRotationHandler(showDirection);
  b.begin(BUTTON_PIN);
  b.setTapHandler(click);
  b.setLongClickHandler(resetPosition);
  b.setLongClickTime(3000);
  b.setDoubleClickTime(700);
  b.setTripleClickHandler(tripleClick);
  Wire.begin(4, 5); //4, 5
  char GUID[SUPLA_GUID_SIZE] = {xxx};
  char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {xxx};
  new Supla::Sensor::DS18B20(D3, ds1);
  new Supla::Sensor::DS18B20(D3, ds2);
  new Supla::Sensor::DS18B20(D3, ds3);
  new Supla::Sensor::DS18B20(D4, ds4);
  new Supla::Sensor::DS18B20(D4, ds5);
  relay1 = new Supla::Control::Relay(D5, false);
  //auto relay2 = new Supla::Control::Relay(D8, false);
                    "svrxx.supla.org",  // SUPLA server address
                    "[email protected]",   // Email address used to login to Supla Cloud
                    AUTHKEY);
t123.begin();
t45.begin();
dsSTART();
lcd.init();
lcd.backlight();
lcd.createChar(0, stopien);
void loop() {
SuplaDevice.iterate();
ds();
relayOnOff();
menu_glowne();
r.loop();
b.loop();
// on left or right rotation
void showDirection(ESPRotary& r) {
     if(r.getDirection() == left){
     // lewy = true;
     if(menu_1==SZESC){
        menu_1=DZIEWIEC;
        lcd.clear();
       else if(menu_1==SIEDEM)  {
        if(tempUst > (tempMin+2)){
          tempUst = tempUst-1;
       else if(menu_1==DZIESIEC){
        if(tempUst>10){
   // Serial.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!LEWO");
  if(r.getDirection() == right){
   //prawy = true;
    if(menu_1==DZIEWIEC){
        menu_1=SZESC;
        lcd.clear();
       else if(menu_1==SIEDEM){
        if(tempUst<80){
          tempUst = tempUst+1;
          if(tempUst < (tempMax -2)){
    //Serial.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!PRAWO");
// single click
void click(Button2& btn) {
// long click
void resetPosition(Button2& btn) {
  r.resetPosition();
  if(menu_1==SZESC){ // max->ustaw
    menu_1=SIEDEM;
    tempUst=tempMax;
    sekund10.restart();
    lcd.clear();
  else if(menu_1==DZIEWIEC){ // min->ustaw
    menu_1=DZIESIEC;
    tempUst=tempMin;
    sekund10.restart();
    lcd.clear();
  else if(menu_1==SIEDEM){ //max->ustawiono
    tempMax=tempUst;
    menu_1=OSIEM;
    lcd.clear();
    sekund3.restart();
  else if(menu_1==DZIESIEC){ // min->ustawiono
    tempMin=tempUst;
    menu_1=JEDENASCIE;
    lcd.clear();
    sekund3.restart();
   //Serial.println("LLLLLLLLLLLLOOOOOOOOOOOOOOONNNNNNNNNNNNNNNNNNNNNNNNNGGGGGGGGGGGGGGGGG");
 void tripleClick(Button2& btn) {
    //Serial.println("..................................................tripleeeeeeeeeeeeee");
    menu_1=SZESC;
    sekund10.restart();
    lcd.clear();
void ds(){
  if(sekund30.available()){
  t123.requestTemperatures();
  t1 = (t123.getTempC(ds1));
  t2 = (t123.getTempC(ds2));
  t3 = (t123.getTempC(ds3));
  t45.requestTemperatures();
  t4 = (t45.getTempC(ds4));
  t5 = (t45.getTempC(ds5));
 if((t1>tempMax) || (t2>tempMax) || (t3>tempMax) || (t4>tempMax) || (t5>tempMax)){
    przek1=1;
 else if((t1<tempMin) && (t2<tempMin) && (t3<tempMin) && (t4<tempMin) && (t5<tempMin)){
    przek1=0;
  sekund30.restart();
void dsSTART(){
  /*if(((t1) || (t2) || (t3) || (t4) || (t5))>tempMax){
    przek1=1;
  else if(((t1) && (t2) && (t3) && (t4) && (t5))<tempMin){
    przek1=0;
void relayOnOff(){
  if((przek1 == 1) && (wyslanoON == 0)){
   relay1->turnOn();
   wyslanoON = 1;
   wyslanoOFF = 0;
  else if((przek1==0) && (wyslanoOFF==0)){
   relay1->turnOff();
   wyslanoOFF = 1;
   wyslanoON = 0;
void menu_glowne(){
 switch(menu_1){
 case JEDEN:
  one();
    if(sekund3.available()){
      menu_1=DWA;
      lcd.clear();
      sekund3.restart();
 break;
 case DWA:
   two();
      menu_1=TRZY;
      lcd.clear();
      sekund3.restart();
 break;
 case TRZY:
   three();
      menu_1=CZTERY;
      lcd.clear();
      sekund3.restart();
 break;
 case CZTERY:
   four();
      menu_1=PIEC;
      lcd.clear();
      sekund3.restart();
 break;
 case PIEC:
   five();
      menu_1=JEDEN;
      lcd.clear();
      sekund3.restart();
 break;
 case SZESC:
   six();
    if(sekund10.available()){
      menu_1=JEDEN;
      lcd.clear();
      sekund3.restart();
 break;
 case SIEDEM:
   seven();
      menu_1=JEDEN;
      lcd.clear();
      sekund3.restart();
 break;
 case OSIEM:
   eight();
      menu_1=JEDEN;
      lcd.clear();
      sekund3.restart();
 break;
 case DZIEWIEC:
  nine();
      menu_1=JEDEN;
      lcd.clear();
      sekund3.restart();
 break;
 case DZIESIEC:
  ten();
      menu_1=JEDEN;
      lcd.clear();
      sekund3.restart();
 break;
 case JEDENASCIE:
  eleven();
      menu_1=JEDEN;
      sekund3.restart();
 break;
void one(){
  lcd.setCursor(0,0);
  lcd.print("Temp. 1:  ");
  lcd.print(t1);
  lcd.write(byte(0));
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print("Temp. 2:  ");
  lcd.print(t2);
  lcd.write(byte(0));
  lcd.print("C");
 void two(){
  lcd.setCursor(0,0);
  lcd.print(t2);
  lcd.write(byte(0));
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print("Temp. 3:  ");
  lcd.print(t3);
  lcd.write(byte(0));
  lcd.print("C");
 void three(){
  lcd.setCursor(0,0);
  lcd.print(t3);
  lcd.write(byte(0));
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print("Temp. 4:  ");
  lcd.print(t4);
  lcd.write(byte(0));
  lcd.print("C");
void four(){
  lcd.setCursor(0,0);
  lcd.print(t4);
  lcd.write(byte(0));
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print("Temp. 5:  ");
  lcd.print(t5);
  lcd.write(byte(0));
  lcd.print("C");
 void five(){
  lcd.setCursor(0,0);
  lcd.print(t5);
  lcd.write(byte(0));
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print(t1);
  lcd.write(byte(0));
  lcd.print("C");
 void six(){
  lcd.setCursor(0,0);
  lcd.print("Temperatura MAX:");
  lcd.setCursor(0,1);
  lcd.print("temp MAX: ");
  lcd.print(tempMax);
  lcd.write(byte(0));
  lcd.print("C");
 void seven(){
  lcd.setCursor(0,0);
  lcd.print("*   Ustaw MAX  *");
  lcd.setCursor(0,1);
  lcd.print(tempUst);
  lcd.write(byte(0));
  lcd.print("C");
 void eight(){
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("  !!ZMIENIONA!!");
 void nine(){
  lcd.setCursor(0,0);
  lcd.print("Temperatura MIN:");
  lcd.setCursor(0,1);
  lcd.print("temp MIN: ");
  lcd.print(tempMin);
  lcd.write(byte(0));
  lcd.print("C");
 void ten(){
  lcd.setCursor(0,0);
  lcd.print("*   Ustaw MIN  *");
  lcd.setCursor(0,1);
  lcd.print(tempUst);
  lcd.write(byte(0));
  lcd.print("C");
 void eleven(){
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
https://kryry01.aqi.eco/pl
https://github.com/Soyer79
