docker logs --tail=50 supla-cloud
docker logs --tail=50 supla-server
Moderator: fracz
pi@raspberrypi:~/supla-docker $ docker logs --tail=50 supla-cloud
[Doctrine\DBAL\Driver\PDOException]
SQLSTATE[HY000] [1045] Access denied for user 'supla'@'supla-cloud.supla_de
fault' (using password: YES)
[PDOException]
doctrine:database:create [--shard SHARD] [--connection [CONNECTION]] [--if-not-exists] [-h|--help] [-q|--quiet] [-v|vv|vvv|--verbose] [-V|--version] [--ansi] [--no-ansi] [-n|--no-interaction] [-e|--env ENV] [--no-debug] [--] <command>
[RuntimeException]
Could not connect to to the database.
Application Migrations
10:34:42 ERROR [console] Error thrown while running command "doctrine:migrations:migrate --no-interaction --allow-no-migration". Message: "An exception occured in driver: SQLSTATE[HY000] [1045] Access denied for user 'supla'@'supla-cloud.supla_default' (using password: YES)" ["error" => Doctrine\DBAL\Exception\ConnectionException { …},"command" => "doctrine:migrations:migrate --no-interaction --allow-no-migration","message" => "An exception occured in driver: SQLSTATE[HY000] [1045] Access denied for user 'supla'@'supla-cloud.supla_default' (using password: YES)"] []
10:34:42 ERROR [console] Command "doctrine:migrations:migrate --no-interaction --allow-no-migration" exited with code "1" ["command" => "doctrine:migrations:migrate --no-interaction --allow-no-migration","code" => 1] []
[Doctrine\DBAL\Exception\ConnectionException]
[PDOException]
doctrine:migrations:migrate [--write-sql] [--dry-run] [--query-time] [--allow-no-migration] [--configuration [CONFIGURATION]] [--db-configuration [DB-CONFIGURATION]] [--db DB] [--em EM] [--shard SHARD] [-h|--help] [-q|--quiet] [-v|vv|vvv|--verbose] [-V|--version] [--ansi] [--no-ansi] [-n|--no-interaction] [-e|--env ENV] [--no-debug] [--] <command> [<version>]
pi@raspberrypi:~/supla-docker $ docker logs --tail=50 supla-server
INFO[1520507417.428180] Started at Thu Mar 8 11:10:17 2018
INFO[1520507417.442449] Server version 1.8.5 [Protocol v8]
INFO[1520507417.486697] Started at Thu Mar 8 11:10:17 2018
ERR[1520507417.794402] MySQL - Failed to connect to database.
2018-03-08 11:10:17,798 INFO success: supla-scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2018-03-08 11:10:17,802 INFO success: supla-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
ERR[1520507418.10121] MySQL - Failed to connect to database.
ERR[1520507418.846690] MySQL - Failed to connect to database.
ERR[1520507419.894381] MySQL - Failed to connect to database.Code: Select all
[code]pi@raspberrypi:~/supla-docker $ docker logs --tail=50 supla-db
180308 10:16:08 [Note] Event Scheduler: Purging the queue. 0 events
180308 10:16:08 InnoDB: Starting shutdown...
180308 10:16:09 InnoDB: Shutdown completed; log sequence number 2658393
180308 10:16:09 [Note] mysqld: Shutdown complete
180308 10:17:36 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
180308 10:17:36 [Note] mysqld (mysqld 5.5.58-0+deb7u1) starting as process 1 ...
180308 10:17:36 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
180308 10:17:36 [Note] Plugin 'FEDERATED' is disabled.
180308 10:17:36 InnoDB: The InnoDB memory heap is disabled
180308 10:17:36 InnoDB: Mutexes and rw_locks use GCC atomic builtins
180308 10:17:36 InnoDB: Compressed tables use zlib 1.2.7
180308 10:17:36 InnoDB: Using Linux native AIO
180308 10:17:37 InnoDB: Initializing buffer pool, size = 128.0M
180308 10:17:37 InnoDB: Completed initialization of buffer pool
180308 10:17:37 InnoDB: highest supported file format is Barracuda.
180308 10:17:38 InnoDB: Waiting for the background threads to start
180308 10:17:39 InnoDB: 5.5.58 started; log sequence number 2658393
180308 10:17:39 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
180308 10:17:39 [Note] - '0.0.0.0' resolves to '0.0.0.0';
180308 10:17:39 [Note] Server socket created on IP: '0.0.0.0'.
180308 10:17:39 [Note] Event Scheduler: Loaded 0 events
180308 10:17:39 [Note] mysqld: ready for connections.
Version: '5.5.58-0+deb7u1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian)
180308 10:35:35 [Note] mysqld: Normal shutdown
180308 10:35:35 [Note] Event Scheduler: Purging the queue. 0 events
180308 10:35:35 InnoDB: Starting shutdown...
180308 10:35:36 InnoDB: Shutdown completed; log sequence number 2658393
180308 10:35:36 [Note] mysqld: Shutdown complete
180308 11:09:49 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
180308 11:09:49 [Note] mysqld (mysqld 5.5.58-0+deb7u1) starting as process 1 ...
180308 11:09:50 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
180308 11:09:50 [Note] Plugin 'FEDERATED' is disabled.
180308 11:09:50 InnoDB: The InnoDB memory heap is disabled
180308 11:09:50 InnoDB: Mutexes and rw_locks use GCC atomic builtins
180308 11:09:50 InnoDB: Compressed tables use zlib 1.2.7
180308 11:09:50 InnoDB: Using Linux native AIO
180308 11:09:50 InnoDB: Initializing buffer pool, size = 128.0M
180308 11:09:50 InnoDB: Completed initialization of buffer pool
180308 11:09:50 InnoDB: highest supported file format is Barracuda.
180308 11:09:51 InnoDB: Waiting for the background threads to start
180308 11:09:52 InnoDB: 5.5.58 started; log sequence number 2658393
180308 11:09:52 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
180308 11:09:52 [Note] - '0.0.0.0' resolves to '0.0.0.0';
180308 11:09:52 [Note] Server socket created on IP: '0.0.0.0'.
180308 11:09:52 [Note] Event Scheduler: Loaded 0 events
180308 11:09:52 [Note] mysqld: ready for connections.
Ja mam RPi b - a one dość znacząco się różnią od siebie.dawkor wrote: Fri Mar 09, 2018 7:32 am Ja mam na 3 postawione 2 dockery i nie ma problemu. Jeden server cloud a drugi scripts. wiec nie jest to problem rpi3. poza tym 2 od 3 niczym za bardzo się nie rożni.
Było by super.Lector wrote: Fri Mar 09, 2018 7:41 am U mnie stoi to na Pi Zero W.
Może zakupię drugą sztukę i opiszę gdzieś w osobny wątku jak postawić i jak zrobić aby wstawała bo braku zasilania.
docker stop $(docker ps -a -q)
docker system prune -fa
cd supla-docker
rm -fr var/*
git checkout .
git checkout src
./supla.sh start
