Moderator: vajera
endrju_88
Has thanked: 3 times
Been thanked: 4 times
vajera wrote: Sun Feb 09, 2025 6:13 pm
endrju_88 wrote: Sat Feb 08, 2025 12:09 pm Witam
Proszę o dodanie gniazdka z pomiarem energii.
_TZ3000_okaz9tjs::TS011F,
dodane - będzie w najbliższym update - musisz sprawdzić czy raportuje dane czy to ta odmiana, którą ma @Zibi_007 - wtedy mu zmienię definicję.
@vajera , nie wiem jak mam rozumieć czy raportuje dane . Może poprostu wkleję logi jakie wyskakują po włączeniu i wyłączeniu gniazdka ...
19:28:56.855 -> [     1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Dein3 55 50 4C 41 17 18 00 00 00 28 00 00 00 10 00 00 00 68 53 AA 67 00 00 00 00 3C C1 00 00 00 00 00 00 ]
19:28:56.855 -> Send: [53 55 50 4C 41 ]
19:28:56.855 -> Recv: [53 55 50 4C 41 17 1E 00 00 00 32 00 00 00 10 00 00 00 58 45 AA 67 00 00 00 00 71 32 09 00 00 00 00 00 53 55 50 4C 41 ]
19:28:56.855 -> Recv: [53 55 50 4C 41 17 1F 00 00 00 6E 00 00 00 11 00 00 00 78 01 00 00 0A 00 00 00 00 01 00 00 00 00 00 00 00 53 55 50 4C 41 ]
19:28:56.855 -> Relay[10] turn ON (duration 0 ms)
19:28:56.949 -> [ 49225][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
19:28:56.949 -> [ 49226][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xafeb) src endpoint(1) to dst endpoint(1) cluster(0x6)
19:28:56.949 -> [ 49227][I][ZigbeeGateway.cpp:517] zbAttributeReporting(): zbAttributeReporting on/off report ON
19:28:56.949 -> [ 49227][I][z2s_devices_table.cpp:267] Z2S_onOnOffReceive(): onOnOffReceive 0x70:0xb3:0xd5:0x2b:0x60:0x12:0x56:0xa4, endpoint 0x1
19:28:56.949 -> [ 49228][I][z2s_devices_table.cpp:59] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0x70:0xb3:0xd5:0x2b:0x60:0x12:0x56:0xa4, endpoint 0x1, channel type 0xb54
19:28:56.949 -> Channel(10) value changed to 1
19:28:56.949 -> [ 49230][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x56a4), endpoint (1), cluster (0x6), attribute id (0x0), attribute data type (0x10)
19:28:57.043 -> [ 49310][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
19:28:57.043 -> [ 49310][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xafeb), src_endpoint(1) to dst_endpoint(1), cluster(0x6) for command (0x1) with status 0x0
19:28:57.043 -> [ 49311][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
19:28:57.090 -> Send: [53 55 50 4C 41 17 19 00 00 00 78 00 00 00 06 00 00 00 0A 78 01 00 00 01 ]
19:28:57.090 -> Send: [53 55 50 4C 41 ]
19:28:57.090 -> Send: [53 55 50 4C 41 17 1A 00 00 00 67 00 00 00 0E 00 00 00 0A 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
19:29:21.855 -> Send: [53 55 50 4C 41 17 1B 00 00 00 28 00 00 00 10 00 00 00 91 53 AA 67 00 00 00 00 D7 EF 0A 00 00 00 00 00 ]
19:29:21.902 -> Send: [53 55 50 4C 41 ]
19:29:26.886 -> Send: [53 55 50 4C 41 17 1C 00 00 00 28 00 00 00 10 00 00 00 96 53 AA 67 00 00 00 00 A2 F2 0A 00 00 00 00 00 ]
19:29:26.886 -> Send: [53 55 50 4C 41 ]
19:29:31.902 -> Send: [53 55 50 4C 41 17 1D 00 00 00 28 00 00 00 10 00 00 00 9B 53 AA 67 00 00 00 00 A2 F2 0A 00 00 00 00 00 ]
19:29:31.902 -> Send: [53 55 50 4C 41 ]
19:29:31.902 -> Recv: [53 55 50 4C 41 17 20 00 00 00 6E 00 00 00 11 00 00 00 78 01 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
19:29:31.902 -> Relay[10] turn OFF (duration 0 ms)
19:29:31.995 -> [ 84248][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
19:29:31.995 -> [ 84249][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xafeb) src endpoint(1) to dst endpoint(1) cluster(0x6)
19:29:31.995 -> [ 84250][I][ZigbeeGateway.cpp:517] zbAttributeReporting(): zbAttributeReporting on/off report OFF
19:29:31.995 -> [ 84251][I][z2s_devices_table.cpp:267] Z2S_onOnOffReceive(): onOnOffReceive 0x70:0xb3:0xd5:0x2b:0x60:0x12:0x56:0xa4, endpoint 0x1
19:29:31.995 -> [ 84252][I][z2s_devices_table.cpp:59] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0x70:0xb3:0xd5:0x2b:0x60:0x12:0x56:0xa4, endpoint 0x1, channel type 0xb54
19:29:31.995 -> Channel(10) value changed to 0
19:29:31.995 -> [ 84253][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x56a4), endpoint (1), cluster (0x6), attribute id (0x0), attribute data type (0x10)
19:29:32.089 -> [ 84330][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
19:29:32.089 -> [ 84330][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xafeb), src_endpoint(1) to dst_endpoint(1), cluster(0x6) for command (0x0) with status 0x0
19:29:32.089 -> [ 84331][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
19:29:32.089 -> Send: [53 55 50 4C 41 17 1E 00 00 00 78 00 00 00 06 00 00 00 0A 78 01 00 00 01 ]
19:29:32.089 -> Send: [53 55 50 4C 41 ]
19:29:32.089 -> Send: [53 55 50 4C 41 17 1F 00 00 00 67 00 00 00 0E 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
19:29:32.136 -> Recv: [53 55 50 4C 41 17 21 00 00 00 32 00 00 00 10 00 00 00 82 45 AA 67 00 00 00 00 56 2B 04 00 00 00 00 00 53 55 50 4C 41 ]
19:29:32.136 -> Recv: [53 55 50 4C 41 17 22 00 00 00 32 00 00 00 10 00 00 00 87 45 AA 67 00 00 00 00 18 28 04 00 00 00 00 00 53 55 50 4C 41 ]
19:29:32.136 -> Recv: [53 55 50 4C 41 17 23 00 00 00 32 00 00 00 10 00 00 00 8C 45 AA 67 00 00 00 00 B2 48 04 00 00 00 00 00 53 55 50 4C 41 ]
Iksmon
Witam, prosiłbym o dodanie. Pozdrawiam
_TZ3000_h1ipgkwn
https://pl.aliexpress.com/item/1005007419060826.html
https://xmon.eu.org/
andras
Has thanked: 2 times
Proszę o dodanie czujnika obecności :
https://pl.aliexpress.com/item/10050071 ... ry_from%3A
_TZE200_2aae1wxk::TS0225
oraz kontroler RGBCCT
https://pl.aliexpress.com/item/1005002928432005.html
_TZ3210_31btuxgp::TS0505B
brodaa
Proszę o dodanie czujnika dymu:
[ 26094][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 26096][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 26424][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x19da)
[ 26425][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x84
[ 26425][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x19da), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0xa3):(0x37):(0x98):(0x65)
[ 26426][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x19da), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0xa3):(0x37):(0x98):(0x65)
[ 26507][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[ 26507][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x19da
[ 26708][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 27208][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 29270][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 29271][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x81
[ 29272][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 29320][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 29320][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 29321][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 29322][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 29323][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 29406][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[ 29406][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[ 29438][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 29438][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 29439][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[ 29440][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "Heiman"
[ 29823][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 29823][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 30323][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 30723][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 30724][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 30724][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 30725][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 30726][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[ 31226][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 32011][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 32011][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 32012][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(3)
[ 32013][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "3"
[ 32014][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 32514][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 33300][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 33300][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 33301][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(8)
[ 33302][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "SMOK_V16"
[ 33303][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[ 33803][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[ 34563][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 34563][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 34564][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 34565][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
[ 34566][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[ 35066][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 35566][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 6618
[ 35844][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 35844][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35845][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 35861][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 35861][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35862][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[ 37119][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 6618, endpoints count 1
[ 37120][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 38404][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 6618, endpoint # 1
[ 38405][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 1
[ 38405][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 38406][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 38406][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[ 38407][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[ 38407][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 9
[ 38408][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 1282
[ 38408][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 39671][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 39672][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 39673][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 39699][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 39699][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 39700][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 40965][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40966][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x500) for command (0xc) with status 0x84
[ 40967][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41014][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41014][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x1) for command (0xc) with status 0x84
[ 41015][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41097][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 42241][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 42241][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 42242][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43508][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 43508][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x502) for command (0xc) with status 0x84
[ 43509][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43557][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 43557][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 43558][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 43558][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x6
[ 43558][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 10 size: 2
[ 43559][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 43559][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 43559][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x19da, 0x19da, 0x0, 0x0
[ 43560][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 43578][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 43602][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
oraz zasilanego 230V czujnika gazu:
6] esp_zb_app_signal_handler(): Network(0x9622) is open for 180 seconds
[ 25579][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 36075][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 36077][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 36392][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x10de)
[ 36392][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 36393][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x10de), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0x5b):(0x30):(0x34):(0x1e)
[ 36393][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x10de), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0x5b):(0x30):(0x34):(0x1e)
[ 36442][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[ 36442][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x10de
[ 36472][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 36472][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x81
[ 36473][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 36643][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 36679][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 36680][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 36680][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 36681][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 36950][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[ 36951][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[ 37143][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 37143][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 37165][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 37166][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 37166][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[ 37167][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "Heiman"
[ 37645][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 37645][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 37666][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 37666][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 37667][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 37668][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 38146][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 38146][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[ 38181][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 38181][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38182][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(0)
[ 38183][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "0"
[ 38647][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 38647][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 38676][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 38677][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38677][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[ 38678][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "GAS_V15"
[ 39149][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 39149][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[ 39194][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 39195][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 39196][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
[ 39196][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "1"
[ 39651][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[ 39651][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[ 39685][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 39686][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 39686][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 40153][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 40191][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 40191][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 40192][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[ 40653][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 4318
[ 40698][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 4318, endpoints count 1
[ 40699][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 40743][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 4318, endpoint # 1
[ 40744][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
[ 40744][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 40745][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 40745][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[ 40746][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 9
[ 40746][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
NLME Status Indication, status: 0x9
[ 40832][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40832][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 40833][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 40868][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40869][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 40869][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 40889][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40889][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x500) for command (0xc) with status 0x84
[ 40890][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43791][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 43792][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 43793][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43801][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 43801][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 43802][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 43802][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x6
[ 43802][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 3 size: 2
[ 43803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 43803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 43804][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x10de, 0x10de, 0x0, 0x0
[ 43804][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 51078][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 51225][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
Has thanked: 291 times
Been thanked: 161 times
endrju_88 wrote: Mon Feb 10, 2025 6:33 pm @vajera , nie wiem jak mam rozumieć czy raportuje dane . Może po prostu wkleję logi jakie wyskakują po włączeniu i wyłączeniu gniazdka ...
Włącz, podłącz suszarkę i zobaczy czy raportuje V, A, W i kWh.
andras
Proszę o dodanie 4 przyciskowego przełącznika scen :
https://pl.aliexpress.com/item/10050077 ... ry_from%3A
_TZ3000_mh9px7cq::TS0044
maniex36
Witam. Urządzenia Sonoff też działają?
[email protected]
Has thanked: 18 times
Been thanked: 26 times
maniex36 wrote: Tue Feb 11, 2025 3:29 pm Witam. Urządzenia Sonoff też działają?
Działają te których ktoś próbował , lista na githubie
maniex36
Dzięki.
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Mam taki Zigbee Dimmmer Module 2 kanały ściemniacz - dorzuciłem to do paczki :D
Czy idzie to w ogóle dodać do bramki :D ? Jak coś to mogę Ci to wysłać
https://pl.aliexpress.com/item/10050070 ... pt=glo2pol
Using 'COM13' as serial port.
Showing logs:
[20:42:39][ 43597][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[20:42:39][ 43599][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[20:42:39][ 43630][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x1615)
[20:42:39][ 43631][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[20:42:39][ 43631][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x1615), ieee_addr (0xa4):(0xc1):(0x38):(0x69):(0xdd):(0xc4):(0xec):(0xa5)
[20:42:39][ 43632][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x1615), ieee_addr (0xa4):(0xc1):(0x38):(0x69):(0xdd):(0xc4):(0xec):(0xa5)
[20:42:39][ 43720][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[20:42:39][ 43720][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x1615
[20:42:39][ 43737][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:39][ 43738][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[20:42:39][ 43739][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:40][ 43922][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[20:42:40][ 43938][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:40][ 43939][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:40][ 43939][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[20:42:40][ 43940][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[20:42:40][ 44421][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[20:42:40][ 44422][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[20:42:40][ 44445][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:40][ 44445][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:40][ 44446][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[20:42:40][ 44446][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "_TZE204_jtbgusdc"
[20:42:41][ 44879][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[20:42:41][ 44900][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x7bf1) is open for 180 seconds
[20:42:41][ 44923][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[20:42:41][ 44924][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[20:42:41][ 44945][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:41][ 44946][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:41][ 44946][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[20:42:41][ 44947][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[20:42:41][ 45425][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[20:42:41][ 45426][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[20:42:41][ 45443][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:41][ 45443][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:41][ 45444][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(74)
[20:42:41][ 45445][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "74"
[20:42:42][ 45927][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[20:42:42][ 45928][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[20:42:42][ 45945][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:42][ 45946][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:42][ 45947][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[20:42:42][ 45947][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "TS0601"
[20:42:42][ 46429][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[20:42:42][ 46430][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[20:42:42][ 46447][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:42][ 46448][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:42][ 46448][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
[20:42:42][ 46449][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "1"
[20:42:43][ 46930][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[20:42:43][ 46931][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[20:42:43][ 46948][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:42:43][ 46948][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:43][ 46949][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[20:42:43][ 46950][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[20:42:43][ 47433][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[20:42:43][ 47454][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[20:42:43][ 47455][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:43][ 47455][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[20:42:44][ 47935][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 5653
[20:42:44][ 47961][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 5653, endpoints count 2
[20:42:44][ 47962][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[20:42:44][ 47962][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 2, id 242
[20:42:44][ 47983][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 5653, endpoint # 1
[20:42:44][ 47983][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 2
[20:42:44][ 47984][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 4
[20:42:44][ 47984][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[20:42:44][ 47985][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 61184
[20:42:44][ 47985][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 0
[20:42:44][ 47986][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[20:42:44][ 47986][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[20:42:44]NLME Status Indication, status: 0x9
[20:42:44][ 48070][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:44][ 48071][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[20:42:44][ 48072][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:44][ 48076][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:44][ 48076][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0xc) with status 0x84
[20:42:44][ 48077][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:46][ 49930][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:42:46][ 49931][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0x1615
[20:42:46][ 49931][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[20:42:46][ 49932][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:42:46][ 49932][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x6
[20:42:46][ 49933][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x44
[20:42:47]NLME Status Indication, status: 0x9
[20:42:47][ 51058][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:47][ 51059][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[20:42:47][ 51060][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:47][ 51064][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:47][ 51064][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[20:42:47][ 51065][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:47][ 51300][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[20:42:47][ 51300][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:42:47][ 51301][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[20:42:47][ 51301][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[20:42:47][ 51302][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 7 size: 2
[20:42:47][ 51302][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[20:42:47][ 51303][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[20:42:47][ 51303][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x1615, 0x1615, 0x0, 0x0
[20:42:47][ 51303][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[20:42:50][ 54013][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:50][ 54014][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[20:42:50][ 54015][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:50][ 54019][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[20:42:50][ 54019][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:42:50][ 54020][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[20:42:50][ 54020][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[20:42:50][ 54021][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 10 size: 2
[20:42:50][ 54021][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[20:42:50][ 54021][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[20:42:50][ 54022][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x1615, 0x1615, 0x0, 0x0
[20:42:50][ 54022][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[20:42:50][ 54026][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:42:50][ 54027][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x1615), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[20:42:50][ 54027][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:42:54][ 58073][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:42:54][ 58073][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:42:54][ 58074][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:42:54][ 58074][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:42:54][ 58074][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x77
[20:42:54][ 58075][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[20:42:54][ 58075][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:42:54][ 58076][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:42:54][ 58076][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:42:54][ 58076][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[20:42:54]NLME Status Indication, status: 0x0
[20:42:54][ 58586][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:54][ 58586][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:54][ 58587][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xeca5), endpoint (1), cluster (0x0), attribute id (0x1), attribute data type (0x20)
[20:42:54][ 58588][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:54][ 58588][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:54][ 58589][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xeca5), endpoint (1), cluster (0x0), attribute id (0xffe2), attribute data type (0x20)
[20:42:54][ 58590][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:54][ 58590][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1615) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:42:54][ 58591][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xeca5), endpoint (1), cluster (0x0), attribute id (0xffe4), attribute data type (0x20)
[20:42:57][ 61585][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:42:57][ 61585][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:42:57][ 61586][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:42:57][ 61586][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:42:57][ 61587][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x78
[20:42:57][ 61587][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[20:42:57][ 61587][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:42:57][ 61588][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:42:57][ 61588][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:42:57][ 61589][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[20:42:59][ 63154][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:42:59][ 63155][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:42:59][ 63155][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:42:59][ 63155][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:42:59][ 63156][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x79
[20:42:59][ 63156][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[20:42:59][ 63157][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:42:59][ 63157][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:42:59][ 63157][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:42:59][ 63158][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[20:43:04][ 68044][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:43:04][ 68044][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:43:04][ 68045][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:43:04][ 68045][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:43:04][ 68045][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x7a
[20:43:04][ 68046][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[20:43:04][ 68046][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:43:04][ 68047][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:43:04][ 68047][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:43:04][ 68048][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[20:43:31][ 95450][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:43:31][ 95450][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:43:31][ 95451][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:43:31][ 95451][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:43:31][ 95452][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x7b
[20:43:31][ 95452][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[20:43:31][ 95453][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:43:31][ 95453][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:43:31][ 95454][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:43:31][ 95454][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[20:43:36][100557][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:43:36][100557][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:43:36][100558][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:43:36][100558][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:43:36][100559][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x7c
[20:43:36][100559][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[20:43:36][100559][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:43:36][100560][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:43:36][100560][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:43:36][100561][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[20:43:39][103643][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:43:39][103643][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:43:39][103644][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:43:39][103644][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:43:39][103645][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x7d
[20:43:39][103645][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[20:43:39][103646][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:43:39][103646][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:43:39][103647][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:43:39][103647][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[20:43:43][107512][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:43:43][107512][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1615
[20:43:43][107513][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[20:43:43][107513][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:43:43][107514][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x7e
[20:43:43][107514][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[20:43:43][107515][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[20:43:43][107515][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:43:43][107516][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[20:43:43][107516][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[20:43:55]
Serial port closed!
Return to “Bramka ZigBee”
