Moderator: vajera
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
No i dodarł do Mnie czujnik natężenia światła
Logi ze skanera , jak były potrzebne z bramki to proszę o info .
https://pl.aliexpress.com/item/10050080 ... pt=glo2pol
Using 'COM13' as serial port.
Showing logs:
[20:41:32][132607][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[20:41:32][132610][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[20:41:32][133129][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x5352)
[20:41:32][133129][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80
[20:41:32][133129][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x5352), ieee_addr (0xa4):(0xc1):(0x38):(0x52):(0x8f):(0xa5):(0x43):(0xa5)
[20:41:32][133130][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x5352), ieee_addr (0xa4):(0xc1):(0x38):(0x52):(0x8f):(0xa5):(0x43):(0xa5)
[20:41:32][133151][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[20:41:32][133151][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x5352
[20:41:32][133247][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:32][133247][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[20:41:32][133248][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:32][133352][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[20:41:32][133460][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:32][133460][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:32][133461][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[20:41:32][133461][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[20:41:33][133851][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[20:41:33][133852][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[20:41:33][134125][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:33][134126][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:33][134127][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[20:41:33][134127][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_9kbbfeho"
[20:41:33][134352][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[20:41:33][134353][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[20:41:33][134462][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:33][134462][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:33][134463][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[20:41:33][134464][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[20:41:34][134585][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[20:41:34][134629][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x7bf1) is open for 180 seconds
[20:41:34][134853][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[20:41:34][134855][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[20:41:34][135355][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[20:41:35][135642][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:35][135643][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:35][135643][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(67)
[20:41:35][135644][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "67"
[20:41:35][135646][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[20:41:35][135762][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:35][135763][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:35][135763][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[20:41:35][135764][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "TS0222"
[20:41:35][136145][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[20:41:35][136146][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[20:41:35][136257][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:35][136257][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:35][136258][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:35][136375][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:35][136376][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:35][136376][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[20:41:35][136377][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
[20:41:36][136646][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[20:41:36][136647][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[20:41:36][137149][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[20:41:36][137389][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:41:36][137390][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:36][137390][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[20:41:36][137391][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[20:41:36][137395][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[20:41:36][137395][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:41:36][137396][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[20:41:37][137649][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 21330
[20:41:37][137705][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 21330, endpoints count 1
[20:41:37][137705][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[20:41:37][137826][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 21330, endpoint # 1
[20:41:37][137827][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 7, out clusters # 3
[20:41:37][137827][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 1
[20:41:37][137828][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[20:41:37][137828][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[20:41:37][137829][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 1029
[20:41:37][137829][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 1024
[20:41:37][137830][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 1280
[20:41:37][137830][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 7, id 0
[20:41:37][137830][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[20:41:37][137831][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[20:41:37][137831][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[20:41:37][137953][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][137953][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x1) for command (0xc) with status 0x84
[20:41:37][137954][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][137968][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][137968][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[20:41:37][137969][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][137983][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][137983][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x402) for command (0xc) with status 0x84
[20:41:37][137984][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][137998][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][137999][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x405) for command (0xc) with status 0x84
[20:41:37][137999][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][138013][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][138014][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x400) for command (0xc) with status 0x84
[20:41:37][138015][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][138028][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][138029][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x500) for command (0xc) with status 0x84
[20:41:37][138030][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][138043][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][138044][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[20:41:37][138045][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][138059][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][138059][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[20:41:37][138060][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:37][138074][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[20:41:37][138074][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:41:37][138074][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[20:41:37][138075][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[20:41:37][138075][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 5 size: 2
[20:41:37][138076][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[20:41:37][138076][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[20:41:37][138077][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x5352, 0x5352, 0x0, 0x0
[20:41:37][138077][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[20:41:37][138080][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:41:37][138081][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5352), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[20:41:37][138082][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:41:39][139677][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:39][139677][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:39][139678][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:39][139803][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:39][139804][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:41:39][139804][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:41:39][139805][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:41:40][141021][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:40][141021][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:40][141022][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:41][141616][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[20:41:41][141617][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:41:41][141617][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[20:41:41][141618][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[20:41:41][141618][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 16 size: 2
[20:41:41][141618][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[20:41:41][141619][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[20:41:41][141619][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x5352, 0x5352, 0x0, 0x0
[20:41:41][141619][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[20:41:44][144681][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:44][144682][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:44][144682][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:44][144807][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:44][144808][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:41:44][144808][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:41:44][144809][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:41:49][149685][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:49][149685][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:49][149686][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:49][149810][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:49][149811][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:41:49][149811][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:41:49][149812][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:41:52][153493][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:52][153493][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:52][153494][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:54][154689][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:54][154689][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:54][154690][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:54][154814][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:54][154814][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:41:54][154815][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:41:54][154815][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:41:57][158223][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:57][158224][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:57][158224][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:59][159692][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:59][159692][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:41:59][159693][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:41:59][159816][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:41:59][159816][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:41:59][159817][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:41:59][159817][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:04][164696][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:04][164696][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:04][164697][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:04][164820][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:04][164820][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:04][164821][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:04][164822][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:09][169697][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:09][169697][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:09][169698][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:09][169822][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:09][169822][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:09][169823][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:09][169824][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:12][173143][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:12][173143][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:12][173144][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:14][174700][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:14][174700][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:14][174701][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:14][174824][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:14][174824][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:14][174825][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:14][174825][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:18][179458][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:18][179458][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:18][179459][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:19][179704][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:19][179704][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:19][179705][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:19][179828][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:19][179829][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:19][179829][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:19][179830][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:23][184197][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:23][184197][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:23][184198][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:24][184709][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:24][184710][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:24][184711][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:24][184833][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:24][184834][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:24][184834][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:24][184835][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:26][186566][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:26][186567][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:26][186567][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:29][189715][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:29][189715][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:29][189716][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:29][189840][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:29][189840][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:29][189841][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:29][189842][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:30][191302][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:30][191302][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:30][191303][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:33][193668][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:33][193669][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:33][193670][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:34][194721][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:34][194721][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:34][194722][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:34][194845][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:34][194845][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x1)
[20:42:34][194846][I][ZigbeeGateway.cpp:578] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[20:42:34][194846][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[20:42:34][195254][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:34][195254][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:34][195255][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:39][200336][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:42:39][200337][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:42:39][200337][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:42:50]
Serial port closed!
LukiSpajder
I żarówka niby RGB+C+W
https://pl.aliexpress.com/item/10050069 ... pt=glo2pol
Logi ze skanera :
Showing logs:
[20:51:10][500479][V][ZigbeeCore.cpp:226] openNetwork(): Opening network for joining for 180 seconds
[20:51:11][500946][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x7bf1) is open for 180 seconds
[20:51:15][504550][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[20:51:15][504554][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[20:51:15][504575][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x80de)
[20:51:15][504576][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[20:51:15][504576][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x80de), ieee_addr (0xa4):(0xc1):(0x38):(0xd5):(0x43):(0x63):(0x55):(0xa3)
[20:51:15][504577][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x80de), ieee_addr (0xa4):(0xc1):(0x38):(0xd5):(0x43):(0x63):(0x55):(0xa3)
[20:51:15][504589][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[20:51:15][504589][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x80de
[20:51:15][504606][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:15][504607][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[20:51:15][504608][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:15][504790][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[20:51:15][504807][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:15][504807][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:15][504808][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[20:51:15][504809][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[20:51:15][505289][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x14
[20:51:15][505290][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[20:51:15][505308][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:15][505308][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:15][505309][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[20:51:15][505310][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "_TZ3210_bfwvfyx1"
[20:51:16][505792][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x15
[20:51:16][505792][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[20:51:16][505818][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:16][505818][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:16][505819][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[20:51:16][505820][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[20:51:16][505830][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[20:51:16][505854][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x7bf1) is open for 180 seconds
[20:51:16][506063][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[20:51:16][506064][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 6 from address 0x80de
[20:51:16][506065][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[20:51:16][506065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[20:51:16][506065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x1
[20:51:16][506066][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x51
[20:51:16][506066][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[20:51:16][506067][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[20:51:16][506067][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[20:51:16][506068][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0xff
[20:51:16][506068][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0xff
[20:51:16][506069][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0xff
[20:51:16][506069][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xc9
[20:51:16][506292][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x16
[20:51:16][506293][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[20:51:16][506310][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:16][506311][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:16][506311][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(101)
[20:51:16][506312][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "101"
[20:51:17][506794][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x17
[20:51:17][506795][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[20:51:17][506813][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:17][506813][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:17][506814][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[20:51:17][506814][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "TS0505B"
[20:51:17][507296][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x18
[20:51:17][507297][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[20:51:17][507314][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:17][507315][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:17][507315][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
[20:51:17][507316][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "1"
[20:51:18][507798][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x19
[20:51:18][507799][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[20:51:18][507816][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:51:18][507817][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:18][507817][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[20:51:18][507818][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[20:51:18][508301][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[20:51:18][508318][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[20:51:18][508318][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x80de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:51:18][508319][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[20:51:19][508801][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 32990
[20:51:19][508817][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 32990, endpoints count 2
[20:51:19][508817][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[20:51:19][508818][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 2, id 242
[20:51:19][508839][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 32990, endpoint # 1
[20:51:19][508840][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 9, out clusters # 2
[20:51:19][508840][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 3
[20:51:19][508841][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 4
[20:51:19][508841][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 5
[20:51:19][508842][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 6
[20:51:19][508842][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 4096
[20:51:19][508843][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 8
[20:51:19][508843][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 7, id 768
[20:51:19][508844][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 8, id 61184
[20:51:19][508844][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 9, id 0
[20:51:19][508844][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[20:51:19][508845][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[20:51:19][508902][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508903][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[20:51:19][508904][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508908][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508909][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[20:51:19][508910][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508919][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508920][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[20:51:19][508921][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508925][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508925][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x6) for command (0xc) with status 0x84
[20:51:19][508926][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508931][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508931][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x1000) for command (0xc) with status 0x84
[20:51:19][508932][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508936][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508937][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x8) for command (0xc) with status 0x84
[20:51:19][508938][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508949][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508949][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x300) for command (0xc) with status 0x84
[20:51:19][508950][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508952][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508952][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0xc) with status 0x84
[20:51:19][508953][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:19][508955][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:19][508956][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[20:51:19][508956][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:51:22][511867][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[20:51:22][511867][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:51:22][511868][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[20:51:22][511868][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[20:51:22][511869][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 19 size: 2
[20:51:22][511869][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[20:51:22][511869][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[20:51:22][511870][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x80de, 0x80de, 0x0, 0x0
[20:51:22][511870][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[20:51:22][511875][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[20:51:22][511875][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x80de), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[20:51:22][511876][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[20:52:31][580945][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:52:31][580945][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:52:31][580946][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:52:34][584040][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:52:34][584041][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:52:34][584041][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:52:59][609291][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[20:52:59][609292][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5352) src endpoint(1) to dst endpoint(1) cluster(0x400)
[20:52:59][609292][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x43a5), endpoint (1), cluster (0x400), attribute id (0x0), attribute data type (0x21)
[20:54:16][685855][I][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Network(0x7bf1) closed, devices joining not allowed.
mikus
Czujnik temperatury i wilgotności
https://www.zigbee2mqtt.io/devices/WSD500A.html
mikus
klimasstudio
Urządzenie: https://www.zigbee2mqtt.io/devices/E2123.html
Gogi z skanera po naciśnięciu parowania i przycisków:
Using 'COM5' as serial port.
Showing logs:
[09:08:16]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -71 dBm
[09:08:17]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -74 dBm
[09:08:17]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -76 dBm
[09:08:17]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -67 dBm
[09:08:20]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -63 dBm
[09:08:20]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -62 dBm
[09:08:20]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -64 dBm
[09:08:21]Received Touchlink scan request from 94:de:b8:ff:fe:6a:6e:c8, RSSI: -63 dBm
[09:08:25][ 16239][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x4, command id: 4
[09:08:25][ 16240][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:25][ 16240][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:25][ 16241][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:25][ 16241][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 13 size: 0
[09:08:25][ 16241][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:25][ 16242][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:26][ 17245][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x4, command id: 0
[09:08:26][ 17245][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:26][ 17245][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:26][ 17246][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:26][ 17246][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 15 size: 10
[09:08:26][ 17247][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x62
[09:08:26][ 17247][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xC9
[09:08:26][ 17247][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[09:08:26][ 17248][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x64
[09:08:26][ 17248][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x65
[09:08:26][ 17248][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x66
[09:08:26][ 17249][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x61
[09:08:26][ 17249][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x75
[09:08:26][ 17249][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6C
[09:08:26][ 17250][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x74
[09:08:26][ 17250][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:26][ 17251][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:27][ 18253][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x3, command id: 64
[09:08:27][ 18254][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:27][ 18254][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:27][ 18255][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:27][ 18255][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 18 size: 2
[09:08:27][ 18255][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:27][ 18256][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:27][ 18256][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:27][ 18257][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:27][ 18258][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x12) callback
[09:08:27][ 18258][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x12) callback
[09:08:27][ 18261][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x1000, command id: 64
[09:08:27][ 18261][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:27][ 18262][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:27][ 18262][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:27][ 18263][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 19 size: 16
[09:08:27][ 18263][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xC8
[09:08:27][ 18263][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6E
[09:08:27][ 18264][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6A
[09:08:27][ 18264][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFE
[09:08:27][ 18264][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[09:08:27][ 18265][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xB8
[09:08:27][ 18265][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xDE
[09:08:27][ 18265][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x94
[09:08:27][ 18266][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x5C
[09:08:27][ 18266][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xE3
[09:08:27][ 18266][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:27][ 18266][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x04
[09:08:27][ 18267][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:27][ 18267][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x06
[09:08:27][ 18267][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:27][ 18268][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:27][ 18268][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:27][ 18269][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:31][ 22753][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 5
[09:08:31][ 22754][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:31][ 22754][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:31][ 22755][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:31][ 22755][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 2
[09:08:31][ 22756][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:31][ 22756][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[09:08:31][ 22756][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:31][ 22757][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:31][ 22758][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:31][ 22758][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
[09:08:31][ 22759][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:31][ 22760][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x6), attribute(0x0), data size(1)
[09:08:31][ 22860][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:31][ 22861][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
[09:08:32][ 23760][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 5
[09:08:32][ 23760][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:32][ 23761][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:32][ 23761][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:32][ 23762][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 2
[09:08:32][ 23762][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:32][ 23762][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[09:08:32][ 23763][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:32][ 23763][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:32][ 23864][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:32][ 23865][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
[09:08:32][ 23866][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:32][ 23866][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x6), attribute(0x0), data size(1)
[09:08:33][ 24827][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 2
[09:08:33][ 24828][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:33][ 24828][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:33][ 24829][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:33][ 24829][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 6
[09:08:33][ 24829][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:33][ 24830][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:33][ 24830][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:33][ 24831][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:33][ 24831][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:33][ 24832][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:33][ 24933][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:33][ 24934][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
[09:08:35][0;31mE (31057) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
[09:08:35][ 26590][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 2
[09:08:35][ 26590][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:35][ 26591][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:35][ 26591][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:35][ 26592][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 6
[09:08:35][ 26592][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:35][ 26593][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:35][ 26594][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:35][ 26594][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:35][ 26594][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:35][ 26696][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:35][ 26697][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
[09:08:36][ 27339][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 2
[09:08:36][ 27339][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:36][ 27340][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:36][ 27340][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:36][ 27341][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 27 size: 6
[09:08:36][ 27341][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:36][ 27342][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[09:08:36][ 27342][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:36][ 27343][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[09:08:36][ 27343][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:36][ 27344][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:37][0;31mE (33082) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
[09:08:37][ 28834][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x6, command id: 2
[09:08:37][ 28835][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[09:08:37][ 28835][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
[09:08:37][ 28836][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[09:08:37][ 28836][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 28 size: 0
[09:08:37][ 28836][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe35c, 0xe35c, 0x0, 0x0
[09:08:37][ 28837][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[09:08:37][ 28838][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:37][ 28838][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
[09:08:37][ 28839][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:37][ 28839][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x6), attribute(0x0), data size(1)
[09:08:37][ 28940][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x0) callback
[09:08:37][ 28941][V][ZigbeeHandlers.cpp:102] zb_attribute_set_handler(): Received attribute set message: endpoint(1), cluster(0x8), attribute(0x0), data size(1)
andras
Has thanked: 2 times
Been thanked: 4 times
Proszę o dodanie przełącznika 2 dotykowego :
https://pl.aliexpress.com/item/10050074 ... ry_from%3A
_TZ3000_c7xsiexw::TS0002,
endrju_88
Has thanked: 3 times
Czy jest szansa na dodanie czujnika deszczu Model: RB-SRAIN01 ?
https://pl.aliexpress.com/item/10050074 ... gIz1_D_BwE
_TZ3210_tgvtvdoc::TS0207,
logi z seriala:
15:18:45.784 -> zbInit
15:18:45.784 -> [   603][D][ZigbeeCore.cpp:124] zigbeeInit(): Initialize Zigbee stack
15:18:45.878 -> [   675][D][ZigbeeCore.cpp:131] zigbeeInit(): Register all Zigbee EPs in list
15:18:45.878 -> [   676][I][ZigbeeCore.cpp:139] zigbeeInit(): List of registered Zigbee EPs:
15:18:45.878 -> [   676][I][ZigbeeCore.cpp:141] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
15:18:45.878 -> [   680][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
15:18:45.878 -> [   681][I][ZigbeeCore.cpp:220] esp_zb_app_signal_handler(): Zigbee stack initialized
15:18:45.878 -> [   683][I][ZigbeeCore.cpp:226] esp_zb_app_signal_handler(): Device started up in  factory-reset mode
15:18:45.878 -> [   683][I][ZigbeeCore.cpp:230] esp_zb_app_signal_handler(): Start network formation
15:18:48.269 -> [  3051][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Network(0x0985) closed, devices joining not allowed.
15:18:48.269 -> [  3052][I][ZigbeeCore.cpp:261] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: f0:f5:bd:ff:fe:0e:ee:7c, PAN ID: 0x0985, Channel:25, Short Address: 0x0000)
15:18:48.738 -> [  3520][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x0985) is open for 180 seconds
15:18:48.738 -> [  3522][I][ZigbeeCore.cpp:276] esp_zb_app_signal_handler(): Network steering started
15:18:50.800 -> [  5608][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
15:18:50.800 -> [  5610][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
15:18:50.847 -> [  5627][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:18:50.847 -> [  5628][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:18:51.363 -> [  6144][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xe9f6)
15:18:51.363 -> [  6145][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
15:18:51.456 -> [  6250][I][ZigbeeGateway.cpp:86] find_Cb(): Found sensor
15:18:51.456 -> [  6250][D][ZigbeeGateway.cpp:95] find_Cb(): Sensor found: short address(0xe9f6), endpoint(1)
15:18:51.550 -> [  6332][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:18:51.550 -> [  6333][I][ZigbeeGateway.cpp:161] printJoinedDevices(): Device on endpoint 1, short address: 0xe9f6
15:18:51.550 -> [  6334][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
15:18:51.550 -> [  6334][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
15:18:51.550 -> [  6335][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:18:51.644 -> [  6450][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
15:18:51.644 -> [  6450][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x0)
15:18:51.644 -> [  6451][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
15:18:51.644 -> [  6452][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3210_tgvtvdoc"
15:18:51.644 -> [  6335][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3210_tgvtvdoc
15:18:51.784 -> [  6559][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
15:18:51.784 -> [  6559][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x0)
15:18:51.784 -> [  6560][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
15:18:51.784 -> [  6561][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0207"
15:18:51.784 -> [  6561][I][Zigbee_Gateway_2.ino:169] loop(): model TS0207
15:18:51.784 -> [  6562][D][Zigbee_Gateway_2.ino:180] loop(): Unknown model TS0207, no binding is possible
15:18:52.769 -> [  7574][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
15:18:52.909 -> [  7684][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x0985) is open for 180 seconds
15:18:55.863 -> [ 10671][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:18:55.863 -> [ 10672][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:00.878 -> [ 15681][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:00.878 -> [ 15682][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:05.894 -> [ 20696][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:05.894 -> [ 20697][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:10.909 -> [ 25706][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:10.909 -> [ 25707][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:15.933 -> [ 30721][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:15.933 -> [ 30722][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:20.949 -> [ 35731][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:20.949 -> [ 35732][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:25.964 -> [ 40747][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:25.964 -> [ 40748][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:30.949 -> [ 45757][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:30.949 -> [ 45758][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:35.996 -> [ 50772][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:35.996 -> [ 50773][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:40.964 -> [ 55782][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:40.964 -> [ 55783][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:45.980 -> [ 60797][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:45.980 -> [ 60798][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:50.996 -> [ 65807][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:50.996 -> [ 65808][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:19:56.018 -> [ 70822][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:19:56.018 -> [ 70823][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:01.018 -> [ 75832][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:01.018 -> [ 75833][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:06.049 -> [ 80847][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:06.049 -> [ 80848][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:11.065 -> [ 85857][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:11.065 -> [ 85858][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:16.081 -> [ 90872][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:16.081 -> [ 90873][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:19.565 -> [ 94374][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1031) callback
15:20:19.565 -> [ 94375][V][ZigbeeHandlers.cpp:153] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x500)
15:20:19.565 -> [ 94375][V][ZigbeeHandlers.cpp:160] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: status(1), cluster(0x500)
15:20:19.565 -> [ 94376][V][ZigbeeHandlers.cpp:162] zb_cmd_ias_zone_status_change_handler(): calling (*it)->zbIASZoneStatusChangeNotification(message)
15:20:19.565 -> [ 94377][I][ZigbeeGateway.cpp:177] zbIASZoneStatusChangeNotification(): short address 59894, src id 59894
15:20:19.565 -> [ 94377][I][ZigbeeGateway.cpp:188] zbIASZoneStatusChangeNotification(): ieee addr 164:193:56:213:143:199:16:176
15:20:19.565 -> [ 94378][I][ZigbeeGateway.cpp:191] zbIASZoneStatusChangeNotification(): zone status 1
15:20:19.565 -> in sz_ias_zone_nitification
15:20:19.565 -> 1
15:20:19.565 -> 176
15:20:21.081 -> [ 95882][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:21.081 -> [ 95883][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:26.096 -> [100897][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:26.096 -> [100898][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:31.112 -> [105907][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:31.112 -> [105908][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:36.127 -> [110922][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:36.127 -> [110923][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:41.143 -> [115932][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:41.143 -> [115933][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:46.159 -> [120947][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:46.159 -> [120948][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:51.144 -> [125957][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:51.144 -> [125958][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:53.394 -> [128183][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1031) callback
15:20:53.394 -> [128183][V][ZigbeeHandlers.cpp:153] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x500)
15:20:53.394 -> [128184][V][ZigbeeHandlers.cpp:160] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: status(0), cluster(0x500)
15:20:53.394 -> [128185][V][ZigbeeHandlers.cpp:162] zb_cmd_ias_zone_status_change_handler(): calling (*it)->zbIASZoneStatusChangeNotification(message)
15:20:53.394 -> [128185][I][ZigbeeGateway.cpp:177] zbIASZoneStatusChangeNotification(): short address 59894, src id 59894
15:20:53.394 -> [128186][I][ZigbeeGateway.cpp:188] zbIASZoneStatusChangeNotification(): ieee addr 164:193:56:213:143:199:16:176
15:20:53.394 -> [128187][I][ZigbeeGateway.cpp:191] zbIASZoneStatusChangeNotification(): zone status 0
15:20:53.394 -> in sz_ias_zone_nitification
15:20:53.394 -> 0
15:20:53.394 -> 176
15:20:56.159 -> [130972][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:20:56.159 -> [130973][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:20:58.628 -> [133445][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1031) callback
15:20:58.628 -> [133445][V][ZigbeeHandlers.cpp:153] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x500)
15:20:58.628 -> [133446][V][ZigbeeHandlers.cpp:160] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: status(1), cluster(0x500)
15:20:58.628 -> [133447][V][ZigbeeHandlers.cpp:162] zb_cmd_ias_zone_status_change_handler(): calling (*it)->zbIASZoneStatusChangeNotification(message)
15:20:58.628 -> [133447][I][ZigbeeGateway.cpp:177] zbIASZoneStatusChangeNotification(): short address 59894, src id 59894
15:20:58.628 -> [133448][I][ZigbeeGateway.cpp:188] zbIASZoneStatusChangeNotification(): ieee addr 164:193:56:213:143:199:16:176
15:20:58.628 -> [133448][I][ZigbeeGateway.cpp:191] zbIASZoneStatusChangeNotification(): zone status 1
15:20:58.628 -> in sz_ias_zone_nitification
15:20:58.628 -> 1
15:20:58.628 -> 176
15:21:01.175 -> [135982][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:01.175 -> [135983][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:06.190 -> [140997][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:06.190 -> [140998][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:11.222 -> [146007][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:11.222 -> [146008][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:16.237 -> [151022][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:16.237 -> [151023][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:21.222 -> [156032][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:21.222 -> [156033][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:26.253 -> [161048][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:26.253 -> [161049][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:31.253 -> [166058][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:31.253 -> [166059][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:36.289 -> [171073][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:36.289 -> [171074][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:41.305 -> [176083][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:41.305 -> [176084][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:46.320 -> [181098][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:46.320 -> [181099][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:51.305 -> [186108][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:51.305 -> [186109][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:21:52.898 -> [187685][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Network(0x0985) closed, devices joining not allowed.
15:21:53.414 -> [188194][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1031) callback
15:21:53.414 -> [188195][V][ZigbeeHandlers.cpp:153] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x500)
15:21:53.414 -> [188195][V][ZigbeeHandlers.cpp:160] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: status(0), cluster(0x500)
15:21:53.414 -> [188196][V][ZigbeeHandlers.cpp:162] zb_cmd_ias_zone_status_change_handler(): calling (*it)->zbIASZoneStatusChangeNotification(message)
15:21:53.414 -> [188197][I][ZigbeeGateway.cpp:177] zbIASZoneStatusChangeNotification(): short address 59894, src id 59894
15:21:53.414 -> [188197][I][ZigbeeGateway.cpp:188] zbIASZoneStatusChangeNotification(): ieee addr 164:193:56:213:143:199:16:176
15:21:53.414 -> [188198][I][ZigbeeGateway.cpp:191] zbIASZoneStatusChangeNotification(): zone status 0
15:21:53.414 -> in sz_ias_zone_nitification
15:21:53.414 -> 0
15:21:53.414 -> 176
15:21:56.320 -> [191123][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:21:56.320 -> [191124][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:22:01.320 -> [196134][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:22:01.320 -> [196135][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:22:06.351 -> [201149][I][ZigbeeGateway.cpp:149] printGatewayDevices(): gateway devices:
15:22:06.351 -> [201150][I][ZigbeeGateway.cpp:158] printJoinedDevices(): joined devices:
15:22:09.586 -> [204379][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1031) callback
15:22:09.586 -> [204380][V][ZigbeeHandlers.cpp:153] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xe9f6) src endpoint(1) to dst endpoint(1) cluster(0x500)
15:22:09.586 -> [204380][V][ZigbeeHandlers.cpp:160] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: status(1), cluster(0x500)
15:22:09.586 -> [204381][V][ZigbeeHandlers.cpp:162] zb_cmd_ias_zone_status_change_handler(): calling (*it)->zbIASZoneStatusChangeNotification(message)
15:22:09.586 -> [204381][I][ZigbeeGateway.cpp:177] zbIASZoneStatusChangeNotification(): short address 59894, src id 59894
15:22:09.586 -> [204382][I][ZigbeeGateway.cpp:188] zbIASZoneStatusChangeNotification(): ieee addr 164:193:56:213:143:199:16:176
15:22:09.586 -> [204382][I][ZigbeeGateway.cpp:191] zbIASZoneStatusChangeNotification(): zone status 1
15:22:09.586 -> in sz_ias_zone_nitification
Has thanked: 37 times
Been thanked: 27 times
Poproszę o dodanie:
Czujnik otwarcia okna/drzwi AQARA DW-S03D
Log:
14:27:00.409 -> [ 79979][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
14:27:40.192 -> [119800][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
14:27:41.247 -> [120830][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
14:27:41.247 -> [120832][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
14:27:41.510 -> [121095][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xef0e)
14:27:41.510 -> [121095][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80
14:27:41.510 -> [121096][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0xef0e), ieee_addr (0x54):(0xef):(0x44):(0x10):(0x0):(0xae):(0x72):(0xf3)
14:27:41.510 -> [121097][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xef0e), ieee_addr (0x54):(0xef):(0x44):(0x10):(0x0):(0xae):(0x72):(0xf3)
14:27:41.543 -> [121153][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
14:27:41.588 -> [121153][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0xef0e
14:27:41.775 -> [121354][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
14:27:41.995 -> [121597][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
14:27:41.995 -> [121598][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xef0e), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3
14:27:41.995 -> [121598][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
14:27:41.995 -> [121604][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:42.039 -> [121604][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:42.039 -> [121605][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
14:27:42.039 -> [121606][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
14:27:42.245 -> [121854][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0xf
14:27:42.245 -> [121854][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
14:27:42.336 -> [121909][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
14:27:42.428 -> [122002][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:42.428 -> [122003][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:42.428 -> [122003][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(4)
14:27:42.428 -> [122004][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "LUMI"
14:27:42.520 -> [122108][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0xe5e9) is open for 180 seconds
14:27:42.746 -> [122355][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x10
14:27:42.746 -> [122355][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
14:27:43.293 -> [122856][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x11
14:27:44.897 -> [124459][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:44.897 -> [124459][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:44.897 -> [124460][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
14:27:44.897 -> [124460][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
14:27:44.897 -> [124461][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
14:27:45.394 -> [124962][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x12
14:27:45.892 -> [125475][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:45.892 -> [125475][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:45.892 -> [125476][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(30)
14:27:45.892 -> [125477][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "30"
14:27:45.892 -> [125477][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
14:27:46.390 -> [125978][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x13
14:27:46.885 -> [126493][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:46.885 -> [126493][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:46.885 -> [126494][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(17)
14:27:46.885 -> [126495][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "lumi.magnet.agl02"
14:27:46.921 -> [126496][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
14:27:47.431 -> [126996][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x14
14:27:47.942 -> [127510][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:47.942 -> [127510][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:47.942 -> [127511][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
14:27:47.942 -> [127512][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
14:27:47.942 -> [127513][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
14:27:48.404 -> [128013][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
14:27:48.936 -> [128513][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 61198
14:27:48.936 -> [128526][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:27:48.936 -> [128527][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:48.936 -> [128528][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
14:27:49.979 -> [129543][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
14:27:49.979 -> [129543][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xef0e) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:27:49.979 -> [129544][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
14:27:50.989 -> [130560][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 61198, endpoints count 1
14:27:50.989 -> [130560][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
14:27:52.187 -> [131778][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 61198, endpoint # 1
14:27:52.187 -> [131778][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
14:27:52.187 -> [131779][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
14:27:52.187 -> [131779][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
14:27:52.187 -> [131780][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
14:27:52.188 -> [131780][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
14:27:52.188 -> [131781][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
14:27:53.419 -> [132995][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
14:27:53.419 -> [132995][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xef0e), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
14:27:53.419 -> [132996][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
14:27:54.440 -> [134011][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
14:27:54.440 -> [134011][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xef0e), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
14:27:54.440 -> [134012][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
14:27:55.420 -> [135027][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
14:27:55.420 -> [135028][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xef0e), src_endpoint(1) to dst_endpoint(1), cluster(0x500) for command (0xc) with status 0x84
14:27:55.420 -> [135028][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
14:27:56.475 -> [136044][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
14:27:56.475 -> [136045][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xef0e), src_endpoint(1) to dst_endpoint(1), cluster(0x1) for command (0xc) with status 0x84
14:27:56.475 -> [136045][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
14:27:57.484 -> [137060][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
14:27:57.484 -> [137061][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
14:27:57.484 -> [137061][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
14:27:57.484 -> [137062][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x8
14:27:57.484 -> [137062][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 3 size: 2
14:27:57.484 -> [137062][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
14:27:57.484 -> [137063][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
14:27:57.484 -> [137063][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xef0e, 0xef0e, 0x0, 0x0
14:27:57.484 -> [137063][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
Has thanked: 291 times
Been thanked: 161 times
Robert Błaszczak wrote: Sat Feb 15, 2025 1:33 pm Poproszę o dodanie:
+BWNU
endrju_88 wrote: Fri Feb 14, 2025 3:43 pm Czy jest szansa na dodanie czujnika deszczu Model: RB-SRAIN01 ?
+BWNU
ps. wiesz, że to jest czujnik kontaktowy 0/1?
Return to “Bramka ZigBee”
