Moderator: vajera
arqiu70
vajera wrote: Fri Feb 28, 2025 4:53 pm
arqiu70 wrote: Fri Feb 28, 2025 4:48 pm Spoko, jak coś mam kolejną. Tylko czy ten odczyt wystarczy, czy trzeba więcej?
[ 62033][I][ZigbeeGateway.cpp:337] zbReadBasicCluster(): Peer Model is "CK-BL702-AL-01(7009_Z102LG03-1)"
Jeszcze Manufacturer name.
O to chodzi:
[ 59825][I][ZigbeeGateway.cpp:330] zbReadBasicCluster(): Peer Manufacturer is "eWeLink"
Zibi_007
Has thanked: 10 times
Been thanked: 31 times
To ja poproszę o dodanie takiego cuda:
_TZ3210_0zabbfax::TS0503B
Logi w załączniku.
To sterownik RGB - taki:
walanar1
Proszę o dodanie repeatera
[16:51:14][ 71628][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0xfcc0), attribute(0x9)
[16:51:14][ 72107][D][Z2S_Gateway.ino:609] loop(): Unknown model _TZ3000_nkkl7uzv::TS0207, no binding is possible
[16:51:16][ 73634][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[16:51:16][ 73635][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[16:51:16][ 73635][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[16:51:16][ 73636][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[16:51:16][ 73636][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 2
[16:51:16][ 73636][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[16:51:16][ 73637][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:51:16][ 73637][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xe296, 0xe296, 0x0, 0x0
[16:51:16][ 73638][I][z2s_devices_table.cpp:522] Z2S_onCustomCmdReceive(): Z2S_onCustomCmdReceive cluster 0xa, command id 0x0, rssi: -79
[16:51:16][ 73638][I][z2s_devices_table.cpp:65] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x55:0x73:0x5f:0x5b:0x55, endpoint 0x1, channel type 0xffffffff
[16:51:16][ 73639][I][z2s_devices_table.cpp:527] Z2S_onCustomCmdReceive(): No channel found for address U[_sU8
[16:51:16][ 73640][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
W razie potrzeby mogę podesłać log ze scannera, ten powyżej jest z samej bramki ale chyba powinien wystarczyć
link: https://allegro.pl/oferta/repeater-zigb ... WOM3UpS55k
kowalskiW
Szukałem w bazie i chyba takiego czujna temperatury i wilgotności jeszcze niema
"_TZ3000_hzkeh3nv"
[  1562][I][ZigbeeCore.cpp:384] esp_zb_app_signal_handler(): Network(0x62c3) is open for 180 seconds
[  9959][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 13649][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 13651][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 13681][I][ZigbeeCore.cpp:353] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd625)
[ 13682][V][ZigbeeCore.cpp:357] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 13682][D][ZigbeeGateway.cpp:459] zbDeviceAnnce(): zbDeviceAnnce short address (0xd625), ieee_addr (0x50):(0x32):(0x5f):(0xff):(0xfe):(0x60):(0xf1):(0xaa)
[ 13683][D][ZigbeeGateway.cpp:462] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd625), ieee_addr (0x50):(0x32):(0x5f):(0xff):(0xfe):(0x60):(0xf1):(0xaa)
[ 13684][I][ZigbeeGateway.cpp:496] zbDeviceAnnce(): Tuya magic last hope
[ 13953][I][ZigbeeGateway.cpp:531] printJoinedDevices(): joined devices:
[ 13953][I][ZigbeeGateway.cpp:534] printJoinedDevices(): Device on endpoint 1, short address: 0xd625
[ 14111][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 14112][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xd625) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 14112][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 14113][I][ZigbeeGateway.cpp:330] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_hzkeh3nv"
[ 14113][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 14114][I][ZigbeeGateway.cpp:343] zbReadBasicCluster(): ZCL version id is "3"
[ 14115][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(68)
[ 14115][I][ZigbeeGateway.cpp:349] zbReadBasicCluster(): ZCL application version id is "68"
[ 14116][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 14116][I][ZigbeeGateway.cpp:337] zbReadBasicCluster(): Peer Model is "TS0201"
[ 14117][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 14117][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): ZCL power source id is "3"
[ 14118][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[ 14119][I][ZigbeeGateway.cpp:359] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[ 14122][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 14122][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xd625), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with
Nie mogę go również dodać do supli.
Has thanked: 291 times
Been thanked: 161 times
kowalskiW wrote: Sat Mar 01, 2025 4:51 pm Szukałem w bazie i chyba takiego czujna temperatury i wilgotności jeszcze niema
"_TZ3000_hzkeh3nv"
Dodałem - będzie w najbliższym update.
walanar1 wrote: Sat Mar 01, 2025 4:02 pm Proszę o dodanie repeatera
To jest sam repeater - niczego nie raportuje, nie ma tam żadnych bindingów do zrobienia, nie przełoży się też na żaden kanał Supla.
Można powiedzieć, że parując go z bramką już go dodałeś ;)
klimasstudio
vajera wrote: Sun Feb 23, 2025 11:19 pm
klimasstudio wrote: Thu Feb 20, 2025 7:16 am Przycisk IKEA 905.246.07 https://www.ikea.com/pl/pl/p/symfonisk- ... -90524607/
Mam nadzieję że tyle wystarczy z loga podczas klikania
Mam nadzieję że dobrze to zrobiłem i zczytałem poprawnie logi.
Dodałem kilka urządzeń IKEA, w tym ten Symfonisk gen 2 (na bazie egzemplarza, który zakupiłem).
Wrzuciłem kod na GitHub, release się właśnie tam tworzy.
Teraz, jak zacząłem pisać tę wiadomość, widzę, że Twój egzemplarz posługuje się chyba innym custom cluster - zweryfikuję to jeszcze, ale może przetestuj ten kontroler?
Dodałem ten pilot z IKEI. Wygląda to tak że te kanały oznaczone jako ON to działają. Nie działają kropki (pojedyńcza oraz podwójna)
Logi mówią:
[10:40:38][0;31mE (511252) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
[10:40:39][0;31mE (512749) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
[10:40:40][0;31mE (513704) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
[10:40:42][0;31mE (515343) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
[10:40:42][0;31mE (516043) ESP_ZIGBEE_ZCL_CUSTOM_CLUSTER: Failed to find the custom cluster(0xfc7f) on the endpoint(1)[0m
Na moje zbędne są te "wielofunkcje" dla kropek.
klimasstudio wrote: Tue Mar 04, 2025 9:41 am
Logi mówią:
Wygląda na to, że IKEA używa różnych custom clusters w tych samych urządzeniach, dodam ten Twój w najbliższym update.
klimasstudio
vajera wrote: Tue Mar 04, 2025 9:46 am
Logi mówią:
Super dzięki :]
Jeszcze pytanko. Po wpisaniu update w pasku adresu wyskakuje pytanie o login i hasło.
klimasstudio wrote: Tue Mar 04, 2025 10:35 am
Super dzięki :]
Dodałem w 0.4.2, który się właśnie buduje - proszę o testy. W temacie różnych akcji dla kropek - może się komuś przyda, jak nie zawsze można wyrzucić ;)
Jeszcze pytanko. Po wpisaniu update w pasku adresu wyskakuje pytanie o login i hasło. update.png
To standardowe admin/pass z httpUpdateServer ;)
Return to “Bramka ZigBee”
