Zgłoszenia błędów [bramka ZigBee]
Moderator: vajera
klimasstudio
Zakupilem ESP32 C6 16MB. Wgrałem najnowszy FW i nie moge wlaczyc trybu parowania ani przyciskiem BOOT ani poprzez WebGUI.
[08:54:17]ESP-ROM:esp32c6-20220919
[08:54:17]Build:Sep 19 2022
[08:54:17]rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
[08:54:17]SPIWP:0xee
[08:54:17]mode:DIO, clock div:2
[08:54:17]load:0x40875720,len:0x1228
[08:54:17]load:0x4086c110,len:0xd9c
[08:54:17]load:0x4086e610,len:0x2f74
[08:54:17]entry 0x4086c110
[08:54:17][     1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4204e382
[08:54:17][    12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4204e346
[08:54:17][    23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4204e30a
[08:54:17][    35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4204e2ce
[08:54:17][    46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4204e382
[08:54:17][    57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4204e346
[08:54:17][    69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4204e30a
[08:54:17][    80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4204e2ce
[08:54:17][    91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x42049054
[08:54:18][   103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x42049054
[08:54:18][   114][V][NetworkServer.h:41] NetworkServer(): NetworkServer::NetworkServer(port=23, ...)
[08:54:18][   122][V][NetworkServer.h:41] NetworkServer(): NetworkServer::NetworkServer(port=80, ...)
[08:54:18][   130][V][WebServer.cpp:49] WebServer(): WebServer::Webserver(port=80)
[08:54:18][   137][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
[08:54:18][   159][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081940c
[08:54:18][   170][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081940c
[08:54:18][   181][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40823484
[08:54:18][   191][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40823484
W logu tylko tyle informacji widze i zero reakcji.
Has thanked: 291 times
Been thanked: 161 times
klimasstudio wrote: Sat Apr 12, 2025 6:58 am Zakupilem ESP32 C6 16MB. Wgrałem najnowszy FW i nie moge wlaczyc trybu parowania ani przyciskiem BOOT ani poprzez WebGUI.
Ubogie te logi - żadnych danych ze startu Supla ani bramki? Może spróbuj jeszcze raz?
lukasz06
Has thanked: 46 times
Been thanked: 21 times
Pewnie wygrałeś nie ten soft.
klimasstudio
lukasz06 wrote: Sat Apr 12, 2025 7:30 am Pewnie wygrałeś nie ten soft.
Z2S_Gateway.ino.merged.8MB.OTA.logs.bin
lukasz06
To powinno być ok. Może nie to USB?
To z prawej strony patrząc od dołu?
Zenon
Has thanked: 2 times
Czym wygrywasz? Może tu leży problem?
Zibi_007
Has thanked: 10 times
Been thanked: 32 times
Użyj ESP-Flasher. Jeśli się tym wgra, a nie zadziała, to znaczy, że wina softu.
Tutaj cudów nie ma, bo ten program automatycznie rozpoznaje chip, wielkość pamięci itp., potem kasuje całą pamięć i wgrywa nowy soft.
Lomax1983
Połączyłem z bramką(bramka na ESP32-C6 16mb) ZBMINI od Sonoff i z aplikacji Supla czy z clouda wszystko działa. Ale gdy załączę przekaźnik manualnie przyciskiem to w aplikacji Supla nie zmienia się stan przekaźnika mimo że przekaźnik zmienia stan. Softa z dzisiaj. Co może być przyczyną?
RomanG
Has thanked: 26 times
Been thanked: 7 times
Może to zbyt proste, ale spróbuj "zabić" aplikację i sprawdź, czy po tym stan się zgadza. Zauważyłem, że po wybudzeniu telefonu z otwartą apką nie ma w niej reakcji na zmiany. Pomaga to, co napisałem. Może należałoby to zgłosić? :)
Lomax1983 wrote: Sat Apr 12, 2025 2:15 pm Połączyłem z bramką(bramka na ESP32-C6 16mb) ZBMINI od Sonoff i z aplikacji Supla czy z clouda wszystko działa. Ale gdy załączę przekaźnik manualnie przyciskiem to w aplikacji Supla nie zmienia się stan przekaźnika mimo że przekaźnik zmienia stan. Softa z dzisiaj. Co może być przyczyną?
Czy stan zmienia się w Cloud czy tam również brak zmian?
Return to “Bramka ZigBee”
