[08:54:17]ESP-ROM:esp32c6-20220919
[08:54:17]Build:Sep 19 2022
[08:54:17]rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
[08:54:17]SPIWP:0xee
[08:54:17]mode:DIO, clock div:2
[08:54:17]load:0x40875720,len:0x1228
[08:54:17]load:0x4086c110,len:0xd9c
[08:54:17]load:0x4086e610,len:0x2f74
[08:54:17]entry 0x4086c110
[08:54:17][ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4204e382
[08:54:17][ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4204e346
[08:54:17][ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4204e30a
[08:54:17][ 35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4204e2ce
[08:54:17][ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4204e382
[08:54:17][ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4204e346
[08:54:17][ 69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4204e30a
[08:54:17][ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4204e2ce
[08:54:17][ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x42049054
[08:54:18][ 103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x42049054
[08:54:18][ 114][V][NetworkServer.h:41] NetworkServer(): NetworkServer::NetworkServer(port=23, ...)
[08:54:18][ 122][V][NetworkServer.h:41] NetworkServer(): NetworkServer::NetworkServer(port=80, ...)
[08:54:18][ 130][V][WebServer.cpp:49] WebServer(): WebServer::Webserver(port=80)
[08:54:18][ 137][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
[08:54:18][ 159][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081940c
[08:54:18][ 170][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081940c
[08:54:18][ 181][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40823484
[08:54:18][ 191][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40823484
