Czujniki T/H/P/IL i IAS - zgłoszenia, uwagi, pomysły [bramka Zigbee]
Moderator: vajera
Beholder
Has thanked: 6 times
Been thanked: 2 times
Czujnik ruchu i światła Aqara (RTCGQ11LM)
14:37:14:085 -> [545129][V][ZigbeeCore.cpp:254] openNetwork(): Opening network for joining for 180 seconds
14:37:14:083 -> [545128][I][Z2S_Gateway.ino:291] Z2S_onTelnetCmd(): cmd: OPEN-NETWORK, param 180, param -
14:37:14:552 -> [545597][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x53db) is open for 180 seconds
14:37:19:083 -> [550128][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 550128
14:37:19:084 -> [550129][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 550129
14:37:19:084 -> [550130][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 507972, current millis 550130
14:37:19:085 -> [550131][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 507972, current millis 550131
14:37:23:567 -> Send: [53 55 50 4C 41 17 20 00 00 00 28 00 00 00 10 00 00 00 A4 1D FD 67 00 00 00 00 FA 3F 02 00 00 00 00 00 ]
14:37:23:568 -> Send: [53 55 50 4C 41 ]
14:37:23:686 -> Recv: [53 55 50 4C 41 17 1E 00 00 00 32 00 00 00 10 00 00 00 84 01 FD 67 00 00 00 00 0C 18 06 00 00 00 00 00 53 55 50 4C 41 ]
14:37:37:067 -> [568113][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:37:068 -> [568113][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0xb926) src endpoint(1) to dst endpoint(1) cluster(0x405)
14:37:37:068 -> [568114][I][ZigbeeGateway.cpp:595] zbAttributeReporting(): zbAttributeReporting humidity measurement 5.060000
14:37:37:069 -> [568115][I][z2s_devices_table.cpp:683] Z2S_onHumidityReceive(): onHumidityReceive 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1
14:37:37:069 -> [568115][I][z2s_devices_table.cpp:95] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1, channel type 0xbde
14:37:37:191 -> [568237][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:37:192 -> [568237][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0xb926) src endpoint(1) to dst endpoint(1) cluster(0x402)
14:37:37:192 -> [568238][I][ZigbeeGateway.cpp:586] zbAttributeReporting(): zbAttributeReporting temperature measurement 25.100000
14:37:37:192 -> [568239][I][z2s_devices_table.cpp:670] Z2S_onTemperatureReceive(): onTemperatureReceive 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1
14:37:37:193 -> [568240][I][z2s_devices_table.cpp:95] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1, channel type 0xbde
14:37:39:627 -> [570673][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:39:629 -> [570674][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0xb926) src endpoint(1) to dst endpoint(1) cluster(0x1)
14:37:39:629 -> [570675][I][ZigbeeGateway.cpp:697] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 20
14:37:39:629 -> [570675][I][z2s_devices_table.cpp:901] Z2S_onBatteryPercentageReceive(): onBatteryPercentageReceive 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1
14:37:39:630 -> [570676][I][z2s_devices_table.cpp:95] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1, channel type 0xffffffff
14:37:39:631 -> Channel[1] battery level changed to 10
14:37:39:631 -> [570677][I][z2s_devices_table.cpp:116] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1, channel type 0xffffffff
14:37:39:631 -> [570678][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:39:632 -> [570678][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0xb926) src endpoint(1) to dst endpoint(1) cluster(0x1)
14:37:39:633 -> [570679][I][ZigbeeGateway.cpp:704] zbAttributeReporting(): zbAttributeReporting power config battery voltage 26
14:37:39:633 -> [570680][I][z2s_devices_table.cpp:901] Z2S_onBatteryPercentageReceive(): onBatteryPercentageReceive 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1
14:37:39:634 -> [570680][I][z2s_devices_table.cpp:95] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1, channel type 0xffffffff
14:37:39:635 -> [570681][I][z2s_devices_table.cpp:116] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot 0xa4:0xc1:0x38:0xd9:0xcb:0x63:0x9a:0x92, endpoint 0x1, channel type 0xffffffff
14:37:39:637 -> Channel[1] sending channel state update
14:37:39:638 -> Send: [53 55 50 4C 41 17 21 00 00 00 FE 01 00 00 32 00 00 00 00 00 00 00 01 00 00 00 B7 01 00 00 00 00 00 00 C0 A8 02 8E F0 F5 BD 03 0C B4 0A 00 D8 64 00 00 3A 02 00 00 37 02 00 00 00 00 00 00 00 00 00 00 00 00 ]
14:37:39:640 -> Send: [53 55 50 4C 41 ]
14:37:42:800 -> [573846][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
14:37:42:803 -> [573849][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
14:37:43:088 -> [574134][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x1c26)
14:37:43:089 -> [574134][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
14:37:43:089 -> [574135][D][ZigbeeGateway.cpp:475] zbDeviceAnnce(): zbDeviceAnnce short address (0x1c26), ieee_addr (0x0):(0x15):(0x8d):(0x0):(0x3):(0x9):(0x91):(0x7e)
14:37:43:090 -> [574135][D][ZigbeeGateway.cpp:478] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x1c26), ieee_addr (0x0):(0x15):(0x8d):(0x0):(0x3):(0x9):(0x91):(0x7e)
14:37:43:090 -> [574136][I][ZigbeeGateway.cpp:502] zbDeviceAnnce(): Tuya magic last hope
14:37:43:295 -> [574341][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:43:296 -> [574342][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:43:297 -> [574343][I][ZigbeeGateway.cpp:717] zbAttributeReporting(): zbAttributeReporting from (0x917e), endpoint (1), cluster (0x0), attribute id (0x5), attribute data type (0x42)
14:37:43:298 -> [574343][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:43:298 -> [574344][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:43:299 -> [574345][I][ZigbeeGateway.cpp:717] zbAttributeReporting(): zbAttributeReporting from (0x917e), endpoint (1), cluster (0x0), attribute id (0x1), attribute data type (0x20)
14:37:43:299 -> [574346][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:43:300 -> [574346][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:43:300 -> [574347][I][ZigbeeGateway.cpp:717] zbAttributeReporting(): zbAttributeReporting from (0x917e), endpoint (1), cluster (0x0), attribute id (0xff01), attribute data type (0x42)
14:37:43:302 -> [574349][I][ZigbeeGateway.cpp:545] printJoinedDevices(): joined devices:
14:37:43:303 -> [574349][I][ZigbeeGateway.cpp:548] printJoinedDevices(): Device on endpoint 1, short address: 0x1c26
14:37:43:708 -> [574750][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
14:37:44:204 -> [575250][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x2
14:37:45:870 -> [576916][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:45:872 -> [576917][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:45:872 -> [576918][I][ZigbeeGateway.cpp:717] zbAttributeReporting(): zbAttributeReporting from (0x917e), endpoint (1), cluster (0x0), attribute id (0x5), attribute data type (0x42)
14:37:46:589 -> [577635][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:37:46:590 -> [577635][V][ZigbeeHandlers.cpp:154] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:46:590 -> [577636][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(4)
14:37:46:591 -> [577637][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "LUMI"
14:37:46:591 -> [577637][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
14:37:46:591 -> [577638][I][ZigbeeGateway.cpp:359] zbReadBasicCluster(): ZCL version id is "1"
14:37:46:592 -> [577638][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(5)
14:37:46:592 -> [577639][I][ZigbeeGateway.cpp:365] zbReadBasicCluster(): ZCL application version id is "5"
14:37:46:593 -> [577639][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(22)
14:37:46:594 -> [577640][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "lumi.sensor_motion.aq2"
14:37:46:594 -> [577641][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
14:37:46:595 -> [577641][I][ZigbeeGateway.cpp:371] zbReadBasicCluster(): ZCL power source id is "3"
14:37:46:595 -> [577642][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
14:37:46:597 -> [577643][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
14:37:47:098 -> [578144][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x3
14:37:47:307 -> [578352][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x1005) callback
14:37:47:307 -> [578353][V][ZigbeeHandlers.cpp:274] zb_cmd_default_resp_handler(): Received default response: from address(0x1c26), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x81
14:37:47:308 -> [578354][V][ZigbeeHandlers.cpp:278] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
14:37:47:308 -> [578355][I][ZigbeeGateway.cpp:1400] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x2]
14:37:47:309 -> [578355][I][ZigbeeGateway.cpp:1402] zbCmdDefaultResponse(): custom cmd rssi -39
14:37:51:386 -> NLME Status Indication, status: 0x6
14:37:51:675 -> [582721][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:51:676 -> [582721][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:51:676 -> [582722][I][ZigbeeGateway.cpp:717] zbAttributeReporting(): zbAttributeReporting from (0x917e), endpoint (1), cluster (0x0), attribute id (0x5), attribute data type (0x42)
14:37:54:279 -> NLME Status Indication, status: 0x6
14:37:54:991 -> NLME Status Indication, status: 0x6
14:37:56:024 -> [587070][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x2000) callback
14:37:56:025 -> [587070][V][ZigbeeHandlers.cpp:132] zb_attribute_reporting_handler(): Received report from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:56:025 -> [587071][I][ZigbeeGateway.cpp:717] zbAttributeReporting(): zbAttributeReporting from (0x917e), endpoint (1), cluster (0x0), attribute id (0x5), attribute data type (0x42)
14:37:57:098 -> [588144][E][ZigbeeGateway.cpp:323] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x5
14:37:57:109 -> [588144][I][ZigbeeGateway.cpp:1093] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
14:37:57:349 -> [588395][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:37:57:351 -> [588396][V][ZigbeeHandlers.cpp:154] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:57:352 -> [588397][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(4)
14:37:57:352 -> [588398][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "LUMI"
14:37:57:599 -> [588645][I][ZigbeeGateway.cpp:1093] sendAttributeWrite(): Sending 'write attribute' command - id (0x9), type (0x20), size (0x1), value (0x1)
14:37:57:804 -> [588850][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
14:37:58:068 -> [589114][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x1000) callback
14:37:58:069 -> [589115][V][ZigbeeHandlers.cpp:154] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1c26) src endpoint(1) to dst endpoint(1) cluster(0x0)
14:37:58:070 -> [589116][V][ZigbeeHandlers.cpp:163] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(22)
14:37:58:070 -> [589116][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "lumi.sensor_motion.aq2"
14:37:58:101 -> [589147][D][Z2S_Gateway.ino:1214] loop(): Unknown model LUMI::lumi.sensor_motion.aq2, no binding is possible
Has thanked: 290 times
Been thanked: 161 times
Dodałem (0.7.33) ten czujnik otwarcia i wibracji - przetestowany:
https://www.leroymerlin.pl/produkty/czu ... 28867.html
lukasz06
Has thanked: 45 times
Been thanked: 21 times
Witam. Mój czujnik temperatury i wilgotności Xiaomi po tym jak zrobił się offline ze względu na zasięg, nie pokazuje nic, nawet po przeniesieniu go obok bramki i jej restarcie. Co mogę zrobić?
lukasz06 wrote: Thu Apr 17, 2025 3:14 pm Witam. Mój czujnik temperatury i wilgotności Xiaomi po tym jak zrobił się offline ze względu na zasięg, nie pokazuje nic, nawet po przeniesieniu go obok bramki i jej restarcie. Co mogę zrobić?
  1. naciśnij na krótko przycisk parowania (1-2 sekundy),
  2. wyjmij baterię na 20-30 sekund,
  3. jeżeli to nie pomoże włącz w bramce tryb parowania i wtedy zainicjuj na czujniku procedurę parowania-jeżeli zrobisz to w ten sposób nie utracisz żadnych ustawień Supla.
Zibi_007
Has thanked: 10 times
Been thanked: 31 times
Zdarza się. Też tak miałem. Jest procedura awaryjna na taką okoliczność. Zewrzyj te piny pod klapką (RST i GND) do momentu, aż pokażą się trzy poziome kreski. Nie zrażaj się, bo może to potrwać ponad 10 sekund. Po tej czynności termometr się zresetuje i będzie się chciał sparować. Włącz na bramce parowanie i wszystko wróci do normy.
lukasz06
vajera wrote: Thu Apr 17, 2025 3:37 pm
Niestety żadne z powyższych nie pomogło
Edit: Logi z parowania
Button[0] pressed
Button[0] released
[580675][I][Z2S_Gateway.ino:135] supla_callback_bridge(): supla_callback_bridge - event(0x4), action(0x0)
[580676][V][ZigbeeCore.cpp:254] openNetwork(): Opening network for joining for 180 seconds
[581144][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0xc5c2) is open for 180 seconds
[585836][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[585851][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb12d)
[585852][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
[585852][D][ZigbeeCore.cpp:375] esp_zb_app_signal_handler(): Device already bound to endpoint 1
Send: [53 55 50 4C 41 17 20 00 00 00 28 00 00 00 10 00 00 00 71 80 01 68 00 00 00 00 E7 C4 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 23 00 00 00 32 00 00 00 10 00 00 00 52 64 01 68 00 00 00 00 48 CA 06 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 21 00 00 00 E0 01 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 24 00 00 00 EA 01 00 00 1A 00 00 00 E9 07 04 11 05 16 1C 1B 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 2025-04-17 22:28:27
[612777][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0xb12d), model id(0x1001), cluster id(0x1), rejoined(YES)
[612778][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612778][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 612778
[612779][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0xb12d), model id(0x1001), cluster id(0x402), rejoined(NO)
[612780][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612780][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 612780
[612781][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0xb12d), model id(0x1001), cluster id(0x405), rejoined(NO)
[612781][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612782][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 612782
[612782][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x17cf), model id(0x2000), cluster id(0x1), rejoined(NO)
[612783][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612784][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 20701, current millis 612784
[612784][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x17cf), model id(0x2000), cluster id(0x500), rejoined(NO)
[612785][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612785][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 20701, current millis 612785
[612786][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x56a0), model id(0x2000), cluster id(0x1), rejoined(NO)
[612787][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612787][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 300877, current millis 612787
[612788][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x56a0), model id(0x2000), cluster id(0x500), rejoined(NO)
[612789][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612789][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 300877, current millis 612789
[612790][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x73d6), model id(0x2000), cluster id(0x1), rejoined(NO)
[612790][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612791][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 188578, current millis 612791
[612791][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x73d6), model id(0x2000), cluster id(0x500), rejoined(NO)
[612792][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[612793][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 188578, current millis 612793
Send: [53 55 50 4C 41 17 22 00 00 00 28 00 00 00 10 00 00 00 A3 80 01 68 00 00 00 00 D1 4B 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 25 00 00 00 32 00 00 00 10 00 00 00 84 64 01 68 00 00 00 00 D7 76 05 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 23 00 00 00 28 00 00 00 10 00 00 00 BC 80 01 68 00 00 00 00 87 5B 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 26 00 00 00 32 00 00 00 10 00 00 00 9D 64 01 68 00 00 00 00 F5 3C 06 00 00 00 00 00 53 55 50 4C 41 ]
[672799][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 672799
[672800][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 672800
[672801][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 20701, current millis 672801
[672802][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 300877, current millis 672802
[672803][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 300877, current millis 672803
[672803][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 188578, current millis 672803
[672804][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 188578, current millis 672804
Send: [53 55 50 4C 41 17 24 00 00 00 28 00 00 00 10 00 00 00 D5 80 01 68 00 00 00 00 29 67 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 27 00 00 00 32 00 00 00 10 00 00 00 B6 64 01 68 00 00 00 00 2E 09 06 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 25 00 00 00 28 00 00 00 10 00 00 00 EE 80 01 68 00 00 00 00 E0 72 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 28 00 00 00 32 00 00 00 10 00 00 00 CF 64 01 68 00 00 00 00 C8 D2 05 00 00 00 00 00 53 55 50 4C 41 ]
[732822][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0xb12d), model id(0x1001), cluster id(0x1), rejoined(YES)
[732823][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732823][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 732823
[732824][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0xb12d), model id(0x1001), cluster id(0x402), rejoined(NO)
[732825][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732825][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 732825
[732827][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0xb12d), model id(0x1001), cluster id(0x405), rejoined(NO)
[732828][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732828][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 732828
[732829][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x17cf), model id(0x2000), cluster id(0x1), rejoined(NO)
[732829][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732830][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 20701, current millis 732830
[732831][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x17cf), model id(0x2000), cluster id(0x500), rejoined(NO)
[732831][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732832][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 20701, current millis 732832
[732832][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x56a0), model id(0x2000), cluster id(0x1), rejoined(NO)
[732833][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732834][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 300877, current millis 732834
[732834][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x56a0), model id(0x2000), cluster id(0x500), rejoined(NO)
[732835][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732835][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 300877, current millis 732835
[732836][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x73d6), model id(0x2000), cluster id(0x1), rejoined(NO)
[732837][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732837][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 188578, current millis 732837
[732838][I][Z2S_Gateway.ino:838] loop(): Device on endpoint(0x1), short address(0x73d6), model id(0x2000), cluster id(0x500), rejoined(NO)
[732839][I][Z2S_Gateway.ino:840] loop(): Gateway version: 0.7.22-07/04/2025
[732839][I][Z2S_Gateway.ino:843] loop(): getZbgDeviceUnitLastSeenMs 188578, current millis 732839
Send: [53 55 50 4C 41 17 26 00 00 00 28 00 00 00 10 00 00 00 07 81 01 68 00 00 00 00 9A 7E 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 29 00 00 00 32 00 00 00 10 00 00 00 E8 64 01 68 00 00 00 00 58 BB 05 00 00 00 00 00 53 55 50 4C 41 ]
[761145][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xc5c2) closed, devices joining not allowed.
Zibi_007
lukasz06 wrote: Thu Apr 17, 2025 8:21 pm
A robiłeś, co ja napisałem?
Jeszcze mi się taki nie trafił (a przeszło ich przez moje ręce sporo), co po twardym resecie by nie wstał i nie dał się sparować, ale wszystko jest możliwe...
Możesz zawsze powtórzyć procedurę, którą opisałem.
EDIT: A do zwykłej bramki Tuya Ci się paruje (dodaje)?
lukasz06
Tak, robiłem już tak zanim napisałeś, ale zrobiłem raz jeszcze i nic,
czujnik jest dostępny, ale nie wysyła pomiaru, bynajmniej w apce są tylko kreski
Zibi_007
lukasz06 wrote: Thu Apr 17, 2025 9:43 pm Tak, robiłem już tak zanim napisałeś, ale zrobiłem raz jeszcze i nic,
OK, no to działamy dalej. Wymień baterię na nową. Nie ważne ile stara pokazywała.
lukasz06
W między czasie usunąłem kanał termometru, ale cała bramka stała się offline, więc wgrałem najnowszą wersję, dodałem ten termometr i jest ok, bateria 68%. Nie wiem co mu było, może nowy czujnik okna coś namieszał ;)
Teraz pozostaje pododawać resztę i będę obserwował.
Return to “Bramka ZigBee”
