ZBMINI od Sonoff przestał działać z bramka na ESP32-C6 16mb tzn. nie mogę sterować z supli przekaźnikiem. Logi:
- Telnet: Telnet running
[ 40576][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xfcba), model id(0x4001), cluster id(0x6), rejoined(NO)
[ 40577][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[ 40577][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[ 40578][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 40578
[ 40578][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xda86), model id(0x2005), cluster id(0x6), rejoined(NO)
[ 40579][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[ 40579][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[ 40580][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 40580
[ 40580][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x2), short address(0xda86), model id(0x0), cluster id(0x500), rejoined(NO)
[ 40581][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[ 40581][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[ 40582][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 40582
[ 40585][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xd870), model id(0x4001), cluster id(0x6), rejoined(NO)
[ 40585][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[ 40586][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[ 40586][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 40586
Starting local web server
[ 40589][I][ZigbeeGateway.cpp:1101] sendAttributeRead(): Sending 'read attribute' command
[ 40791][I][ZigbeeGateway.cpp:1101] sendAttributeRead(): Sending 'read attribute' command
Recv: [53 55 50 4C 41 17 02 00 00 00 AD 02 00 00 1C 00 00 00 01 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 01 00 01 53 55 50 4C 41 ]
Received new device config
Processing AutomaticTimeSync config
Sending device config result OK (1)
Send: [53 55 50 4C 41 17 04 00 00 00 B7 02 00 00 0A 00 00 00 01 00 00 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Relay[0] updating timer value: remainingTime=0 state=0
SRPC sending: remaining time 0, channel 0, state 0
Send: [53 55 50 4C 41 17 05 00 00 00 69 00 00 00 E3 00 00 00 00 32 DD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 03 00 00 00 AA 02 00 00 32 00 00 00 00 82 00 00 00 00 2A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Channel[0] Received SetChannelConfig: fnc 130, config type 0, config size 42
Channel[0] handleChannelConfig, func 130, configtype 0, configsize 42
Relay[0] applyChannelConfig, func 130, configtype 0, configsize 42
Relay[0] OvercurrentMaxAllowed: 0, OvercurrentThreshold: 0
Channel[0] Sending SetChannelConfigResult OK (1)
Send: [53 55 50 4C 41 17 06 00 00 00 B4 02 00 00 03 00 00 00 01 00 00 ]
Relay[2] updating timer value: remainingTime=0 state=0
SRPC sending: remaining time 0, channel 2, state 0
Send: [53 55 50 4C 41 17 07 00 00 00 69 00 00 00 E3 00 00 00 02 32 DD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
[ 41018][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x85d6) is open for 180 seconds
Recv: [53 55 50 4C 41 17 04 00 00 00 AB 02 00 00 01 00 00 00 00 53 55 50 4C 41 ]
Channel[0] Received ChannelConfigFinished
Recv: [53 55 50 4C 41 17 05 00 00 00 AA 02 00 00 08 00 00 00 01 64 00 00 00 00 00 00 53 55 50 4C 41 ]
Channel[1] Received SetChannelConfig: fnc 100, config type 0, config size 0
Channel[1] handleChannelConfig, func 100, configtype 0, configsize 0
Binary[1]: processing channel config
Binary[1]: config missing on server
Channel[1] Sending SetChannelConfigResult OK (1)
Send: [53 55 50 4C 41 17 08 00 00 00 B4 02 00 00 03 00 00 00 01 00 01 ]
Send: [53 55 50 4C 41 17 09 00 00 00 80 02 00 00 15 00 00 00 00 64 00 00 0D 00 00 00 50 4F 57 45 52 20 53 57 49 54 43 48 00 ]
Recv: [53 55 50 4C 41 17 06 00 00 00 AB 02 00 00 01 00 00 00 01 53 55 50 4C 41 ]
Channel[1] Received ChannelConfigFinished
Binary[1]: setting default channel config
Channel[1] handleChannelConfig, func 0, configtype 0, configsize 32
Channel[1] disabled on server
Send: [53 55 50 4C 41 17 0A 00 00 00 80 02 00 00 15 00 00 00 02 64 00 00 0D 00 00 00 50 4F 57 45 52 20 53 57 49 54 43 48 00 ]
Recv: [53 55 50 4C 41 17 07 00 00 00 AA 02 00 00 32 00 00 00 02 8C 00 00 00 00 2A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Channel[2] Received SetChannelConfig: fnc 140, config type 0, config size 42
Channel[2] handleChannelConfig, func 140, configtype 0, configsize 42
Relay[2] applyChannelConfig, func 140, configtype 0, configsize 42
Relay[2] OvercurrentMaxAllowed: 0, OvercurrentThreshold: 0
Channel[2] Sending SetChannelConfigResult OK (1)
Send: [53 55 50 4C 41 17 0B 00 00 00 B4 02 00 00 03 00 00 00 01 00 02 ]
Recv: [53 55 50 4C 41 17 08 00 00 00 AB 02 00 00 01 00 00 00 02 53 55 50 4C 41 ]
Channel[2] Received ChannelConfigFinished
Recv: [53 55 50 4C 41 17 09 00 00 00 AA 02 00 00 28 00 00 00 64 28 00 00 00 00 20 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Channel[100] Received SetChannelConfig: fnc 40, config type 0, config size 32
Channel[100] handleChannelConfig, func 40, configtype 0, configsize 32
Channel[100] temperature correction 0.00
Channel[100] humidity correction 0.00
Channel[100] Sending SetChannelConfigResult OK (1)
Send: [53 55 50 4C 41 17 0C 00 00 00 B4 02 00 00 03 00 00 00 01 00 64 ]
Recv: [53 55 50 4C 41 17 0A 00 00 00 AB 02 00 00 01 00 00 00 64 53 55 50 4C 41 ]
Channel[100] Received ChannelConfigFinished
Recv: [53 55 50 4C 41 17 0B 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
Activity timeout set to 30 s
Recv: [53 55 50 4C 41 17 0C 00 00 00 EA 01 00 00 1A 00 00 00 E9 07 05 09 06 11 2B 1D 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 1970-01-01 00:00:41
Clock: time diff (system-new): -1746812568 s
Clock: new time: 2025-05-09 17:43:29
Recv: [53 55 50 4C 41 17 0D 00 00 00 8A 02 00 00 16 00 00 00 00 64 00 00 1A 0D 00 00 00 50 4F 57 45 52 20 53 57 49 54 43 48 00 53 55 50 4C 41 ]
Channel[0] Receieved setChannelCaptionResult
Recv: [53 55 50 4C 41 17 0E 00 00 00 8A 02 00 00 16 00 00 00 02 64 00 00 1A 0D 00 00 00 50 4F 57 45 52 20 53 57 49 54 43 48 00 53 55 50 4C 41 ]
Channel[2] Receieved setChannelCaptionResult
Recv: [53 55 50 4C 41 17 0F 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Relay[0] turn ON (duration 0 ms)
Channel(0) value changed to 1
Send: [53 55 50 4C 41 17 0D 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Send: [53 55 50 4C 41 17 0E 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
LittleFsConfig: writing to file "/supla-dev.cfg"
LittleFsConfig: writing to file "/supla-dev.cfg.bak"
PowerCycle: timeout, counter reset to 0
NLME Status Indication, status: 0x6
NLME Status Indication, status: 0x0
Recv: [53 55 50 4C 41 17 10 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Relay[0] turn OFF (duration 0 ms)
Channel(0) value changed to 0
Send: [53 55 50 4C 41 17 0F 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Send: [53 55 50 4C 41 17 10 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
[ 58685][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd870)
[ 58686][D][ZigbeeCore.cpp:376] esp_zb_app_signal_handler(): Device already bound to endpoint 1
[ 60001][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800127827, new local time 800127827
[ 60002][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800127827, local time attribute 800127827
Recv: [53 55 50 4C 41 17 11 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 11 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Recv: [53 55 50 4C 41 17 12 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 12 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Send: [53 55 50 4C 41 17 13 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
[ 63299][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 63299][I][ZigbeeGateway.cpp:668] zbAttributeReporting(): zbAttributeReporting on/off report ON
[ 63300][I][z2s_devices_table.cpp:878] Z2S_onOnOffReceive(): onOnOffReceive 0xc:0xef:0xf6:0xff:0xfe:0x64:0xe5:0xd3, endpoint 0x1
[ 63301][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xc:0xef:0xf6:0xff:0xfe:0x64:0xe5:0xd3, endpoint 0x1, channel type 0xb54
Channel(2) value changed to 1
Send: [53 55 50 4C 41 17 14 00 00 00 67 00 00 00 0E 00 00 00 02 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 13 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 15 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Send: [53 55 50 4C 41 17 16 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 14 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 17 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Send: [53 55 50 4C 41 17 18 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 17 19 00 00 00 28 00 00 00 10 00 00 00 F6 3E 1E 68 00 00 00 00 2C C5 01 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 15 00 00 00 32 00 00 00 10 00 00 00 D6 22 1E 68 00 00 00 00 E3 0F 0E 00 00 00 00 00 53 55 50 4C 41 ]
[100593][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 100593
[100594][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 100594
[100595][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 100595
Send: [53 55 50 4C 41 17 1A 00 00 00 28 00 00 00 10 00 00 00 0F 3F 1E 68 00 00 00 00 A8 D8 01 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 16 00 00 00 32 00 00 00 10 00 00 00 EF 22 1E 68 00 00 00 00 60 FC 0E 00 00 00 00 00 53 55 50 4C 41 ]
[120004][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800127887, new local time 800127887
[120005][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800127887, local time attribute 800127887
Recv: [53 55 50 4C 41 17 17 00 00 00 6E 00 00 00 11 00 00 00 D8 0F 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 1B 00 00 00 78 00 00 00 06 00 00 00 00 D8 0F 00 00 01 ]
Send: [53 55 50 4C 41 17 1C 00 00 00 28 00 00 00 10 00 00 00 2C 3F 1E 68 00 00 00 00 87 EF 05 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 18 00 00 00 32 00 00 00 10 00 00 00 0D 23 1E 68 00 00 00 00 4A 03 03 00 00 00 00 00 53 55 50 4C 41 ]
[160602][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xfcba), model id(0x4001), cluster id(0x6), rejoined(NO)
[160603][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[160604][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[160604][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 160604
[160604][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xda86), model id(0x2005), cluster id(0x6), rejoined(NO)
[160605][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[160606][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[160606][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 160606
[160606][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x2), short address(0xda86), model id(0x0), cluster id(0x500), rejoined(NO)
[160607][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[160608][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[160608][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 160608
[160609][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xd870), model id(0x4001), cluster id(0x6), rejoined(YES)
[160609][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[160610][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[160610][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 160610
Send: [53 55 50 4C 41 17 1D 00 00 00 28 00 00 00 10 00 00 00 45 3F 1E 68 00 00 00 00 15 03 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 19 00 00 00 32 00 00 00 10 00 00 00 26 23 1E 68 00 00 00 00 02 E0 03 00 00 00 00 00 53 55 50 4C 41 ]
[180007][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800127947, new local time 800127947
[180008][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800127947, local time attribute 800127947
Send: [53 55 50 4C 41 17 1E 00 00 00 28 00 00 00 10 00 00 00 5E 3F 1E 68 00 00 00 00 C6 0E 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1A 00 00 00 32 00 00 00 10 00 00 00 3F 23 1E 68 00 00 00 00 31 B2 03 00 00 00 00 00 53 55 50 4C 41 ]
[220617][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 220617
[220618][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 220618
[220619][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 220619
[221018][I][ZigbeeCore.cpp:391] esp_zb_app_signal_handler(): Network(0x85d6) closed, devices joining not allowed.
Send: [53 55 50 4C 41 17 1F 00 00 00 28 00 00 00 10 00 00 00 77 3F 1E 68 00 00 00 00 84 1A 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1B 00 00 00 32 00 00 00 10 00 00 00 58 23 1E 68 00 00 00 00 6E 76 03 00 00 00 00 00 53 55 50 4C 41 ]
[240010][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800128007, new local time 800128007
[240011][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800128007, local time attribute 800128007
Send: [53 55 50 4C 41 17 20 00 00 00 28 00 00 00 10 00 00 00 90 3F 1E 68 00 00 00 00 38 26 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1C 00 00 00 32 00 00 00 10 00 00 00 71 23 1E 68 00 00 00 00 0E 36 03 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 21 00 00 00 28 00 00 00 10 00 00 00 A9 3F 1E 68 00 00 00 00 FB 31 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1D 00 00 00 32 00 00 00 10 00 00 00 8A 23 1E 68 00 00 00 00 5C 49 03 00 00 00 00 00 53 55 50 4C 41 ]
[280626][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xfcba), model id(0x4001), cluster id(0x6), rejoined(NO)
[280627][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[280627][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[280628][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 280628
[280628][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xda86), model id(0x2005), cluster id(0x6), rejoined(NO)
[280629][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[280630][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[280630][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 280630
[280630][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x2), short address(0xda86), model id(0x0), cluster id(0x500), rejoined(NO)
[280631][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[280632][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[280632][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 280632
[280633][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xd870), model id(0x4001), cluster id(0x6), rejoined(YES)
[280634][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[280635][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[280635][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 280635
Send: [53 55 50 4C 41 17 22 00 00 00 28 00 00 00 10 00 00 00 C2 3F 1E 68 00 00 00 00 88 41 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1E 00 00 00 32 00 00 00 10 00 00 00 A3 23 1E 68 00 00 00 00 0D 63 04 00 00 00 00 00 53 55 50 4C 41 ]
[300013][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800128067, new local time 800128067
[300014][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800128067, local time attribute 800128067
Send: [53 55 50 4C 41 17 23 00 00 00 28 00 00 00 10 00 00 00 DB 3F 1E 68 00 00 00 00 2B 51 06 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1F 00 00 00 32 00 00 00 10 00 00 00 BC 23 1E 68 00 00 00 00 8C 8E 04 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 24 00 00 00 E0 01 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 20 00 00 00 EA 01 00 00 1A 00 00 00 E9 07 05 09 06 11 30 1D 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 2025-05-09 17:48:28
Clock: time diff (system-new): -1 s
Clock: new time: 2025-05-09 17:48:29
[340656][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 340656
[340657][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 340657
[340658][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 340658
[360016][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800128128, new local time 800128128
[360017][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800128128, local time attribute 800128128
Send: [53 55 50 4C 41 17 25 00 00 00 28 00 00 00 10 00 00 00 05 40 1E 68 00 00 00 00 AA 7A 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 21 00 00 00 32 00 00 00 10 00 00 00 E6 23 1E 68 00 00 00 00 25 FE 03 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 26 00 00 00 28 00 00 00 10 00 00 00 1E 40 1E 68 00 00 00 00 54 8A 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 22 00 00 00 32 00 00 00 10 00 00 00 FF 23 1E 68 00 00 00 00 0E 20 04 00 00 00 00 00 53 55 50 4C 41 ]
[400686][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xfcba), model id(0x4001), cluster id(0x6), rejoined(NO)
[400687][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[400687][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[400688][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 400688
[400688][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xda86), model id(0x2005), cluster id(0x6), rejoined(NO)
[400689][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[400690][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[400690][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 400690
[400690][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x2), short address(0xda86), model id(0x0), cluster id(0x500), rejoined(NO)
[400691][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[400692][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[400692][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 400692
[400692][I][Z2S_Gateway.ino:1104] loop(): Device on endpoint(0x1), short address(0xd870), model id(0x4001), cluster id(0x6), rejoined(YES)
[400693][I][Z2S_Gateway.ino:1106] loop(): Gateway version: 0.7.74-09/05/2025
[400694][I][Z2S_Gateway.ino:1109] loop(): Zigbee TX power: 20
[400694][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 400694
Send: [53 55 50 4C 41 17 27 00 00 00 28 00 00 00 10 00 00 00 37 40 1E 68 00 00 00 00 D1 9D 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 23 00 00 00 32 00 00 00 10 00 00 00 18 24 1E 68 00 00 00 00 DF FE 04 00 00 00 00 00 53 55 50 4C 41 ]
[420019][I][Z2S_Gateway.ino:1059] loop(): New UTC time 800128188, new local time 800128188
[420020][I][Z2S_Gateway.ino:1073] loop(): Local Time Cluster UTC time attribute 800128188, local time attribute 800128188
Send: [53 55 50 4C 41 17 28 00 00 00 28 00 00 00 10 00 00 00 50 40 1E 68 00 00 00 00 88 A9 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 24 00 00 00 32 00 00 00 10 00 00 00 31 24 1E 68 00 00 00 00 76 C6 04 00 00 00 00 00 53 55 50 4C 41 ]
[460716][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 460716
[460717][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 0, current millis 460717
[460718][I][Z2S_Gateway.ino:1112] loop(): getZbgDeviceUnitLastSeenMs 63299, current millis 460718
Send: [53 55 50 4C 41 17 29 00 00 00 28 00 00 00 10 00 00 00 69 40 1E 68 00 00 00 00 42 B5 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 25 00 00 00 32 00 00 00 10 00 00 00 4A 24 1E 68 00 00 00 00 4C A1 04 00 00 00 00 00 53 55 50 4C 41 ]
