@lukasz06
Poproszę jeszcze raz o poniższe polecenia, ale z użyciem wersji 0.7.84-16/05/2025 lub wyższej.
read-attribute nr_kanału_zaworu 0xFC11 0x5008
i
read-attribute nr_kanału_zaworu 0xFC11 0x5009
read-attribute nr_kanału_zaworu 0xFC11 0x5010
Inne urządzenia - zgłoszenia, błędy, uwagi i pomysły [bramka ZigBee]
Moderator: vajera
Proszę bardzovajera wrote: Fri May 16, 2025 1:27 pm @lukasz06
i
>Welcome
>Use quit to disconnect.
read-attribute 2 0xFC11 0x5008
>Device 36275
>>read-attribute 2 64529 20488
>>Reading attribute successful - data type is char string (0x42), string is empt yread-attribute 2 0xFC11 0x5009
>Device 36275
>>read-attribute 2 64529 20489
>>Reading attribute successful - data type is char string (0x42), string is empty
read-attribute 2 0xFC11 0x5010
>Device 36275
>>read-attribute 2 64529 20496
>>Reading attribute successful - data value is 0x3100, data type is 0x20
- Has thanked: 291 times
- Been thanked: 161 times
Thx! To lecimy dalejlukasz06 wrote: Fri May 16, 2025 2:06 pm Proszę bardzo(wersja 0.7.84)
>Welcome >Use quit to disconnect. read-attribute 2 0xFC11 0x5008 >Device 36275 >>read-attribute 2 64529 20488 >>Reading attribute successful - data type is char string (0x42), string is empt yread-attribute 2 0xFC11 0x5009 >Device 36275 >>read-attribute 2 64529 20489 >>Reading attribute successful - data type is char string (0x42), string is empty read-attribute 2 0xFC11 0x5010 >Device 36275 >>read-attribute 2 64529 20496 >>Reading attribute successful - data value is 0x3100, data type is 0x20
write-attribute 2 0xFC11 0x5010 U8 1 1
write-attribute 2 0xFC11 0x5010 U8 1 2
>Device 36275
>>write-attribute 2 0xFC11 0x5010 0x20 0x1
>Write attribute async request sent
>Device 36275
>>Reading attribute successful - data value is 0xdf00, data type is 0x20
>Device 36275
>>Reading attribute successful - data type is char string (0x42), string is emptywrite-attribute 2 0xFC11 0x5010 U8 1 2
Tu wyskoczył jakiś Error software i telenet się zawiesił.
Wpisałem jeszcze raz od tego momentu i dostałem to
>Device 36275
>Device 36275
>>Reading attribute successful - data value is 0x5100, data type is 0x20
>Device 36275
>>Reading attribute successful - data type is char string (0x42), string is empt -
A już zdążyłem pochwalić Sonoffa za trzymanie się standardów Zigbee :/
W takim razie wgraj proszę 0.7.85-16/05/2025 i powtórz te dwa polecenia:
read-attribute _nr_kanału_zaworu 0xFC11 0x5008
read-attribute _nr_kanału_zaworu 0xFC11 0x5009
vajera wrote: Fri May 16, 2025 5:57 pmA już zdążyłem pochwalić Sonoffa za trzymanie się standardów Zigbee :/
>Device 36275
>>Reading attribute failed
>Device 36275
Chyba zawór zasnął - spróbuj go obudzić przed wydaniem tych rozkazów, zobacz czy reaguje na ON/OFF.lukasz06 wrote: Fri May 16, 2025 6:37 pmvajera wrote: Fri May 16, 2025 5:57 pmA już zdążyłem pochwalić Sonoffa za trzymanie się standardów Zigbee :/
read-attribute _nr_kanału_zaworu 0xFC11 0x5009Code: Select all
read-attribute 2 0xFC11 0x5008 >Device 36275 >>read-attribute 2 64529 20488 >>Reading attribute failed >read-attribute 2 0xFC11 0x5009 >Device 36275 >>read-attribute 2 64529 20489 >>Reading attribute failed >
Wygląda na to, że zawór nie reaguje na on/of lub działa to z opóźnieniem.
Wydaje mi się, że aktualizacje coś psują, bo już kolejny raz tak mam.
A może moje Xiao się psuje? Jutro wgram nowy bin i dam znać.
Zawór mógł sie "zatkać" rozkazami - może wyjmij bu baterię ewentualnie ponownie sparuj.lukasz06 wrote: Fri May 16, 2025 7:53 pm Wygląda na to, że zawór nie reaguje na on/of lub działa to z opóźnieniem.
ps. jak będziesz wgrywał bin to wgraj ostatnią wersję - 0.7.86 albo późniejszą, o ile będą
Dobra, wgrałem 0.86 i sparowałem ponownie. Teraz mam 2 kanały on/off - tak ma być?vajera wrote: Fri May 16, 2025 8:00 pmZawór mógł sie "zatkać" rozkazami - może wyjmij bu baterię ewentualnie ponownie sparuj.lukasz06 wrote: Fri May 16, 2025 7:53 pm Wygląda na to, że zawór nie reaguje na on/of lub działa to z opóźnieniem.
ps. jak będziesz wgrywał bin to wgraj ostatnią wersję - 0.7.86 albo późniejszą, o ile będą![]()
Logi z Telenet
>Device 15303
>>Reading attribute successful - data type is 0x42, data size is 0xu
>Data = 0x0,
>Device 15303
>Data = 0x0,
