Kompilowanie szkicu...
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\Z2S_Gateway.ino.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\Z2S_Gateway.ino.cpp.o"
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_electricity_meter.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_electricity_meter.cpp.o"
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_action_trigger.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_action_trigger.cpp.o"
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_dimmer.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_dimmer.cpp.o"
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_hvac.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_hvac.cpp.o"
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_iaszone.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_iaszone.cpp.o"
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_electricity_meter.cpp: In function 'void addZ2SDeviceElectricityMeter(ZigbeeGateway*, zbg_device_params_t*, bool, bool, uint8_t, int8_t, bool)':
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_electricity_meter.cpp:240:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
240 | "Electricity meter",
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_local_action_handler.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_local_action_handler.cpp.o"
In file included from C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\Z2S_Gateway.ino:39:
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_telnet_parser.h:18:8: warning: extra tokens at end of #endif directive [-Wendif-labels]
18 | #endif Z2S_TELNET_PARSER_H_
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_pressure.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_pressure.cpp.o"
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2507/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C6_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C6_DEV\"" "-DARDUINO_VARIANT=\"esp32c6\"" -DARDUINO_PARTITION_custom_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=8M,PartitionScheme=custom,DebugLevel=debug,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=4 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\examples\\Z2S_Gateway" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.5-07e9bf49-v1\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\variants\\esp32c6" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Z2S_Library\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPUI\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\LittleFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\FS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Async_WebServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\Async_TCP\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WiFi\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Network\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\ESPmDNS\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESPAsyncHTTPUpdateServer\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\SuplaDevice\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\ESP_Telnet\\src" "-Ic:\\Users\\Jacek\\Documents\\Arduino\\libraries\\base64_encode\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Hash\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Ticker\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\SPIFFS\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\Update\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\WebServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\HTTPUpdateServer\\src" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.2\\libraries\\EEPROM\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_rgb.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\E933CE886DD80CE7D55059184D728834\\sketch\\z2s_device_rgb.cpp.o"
In file included from C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.cpp:1:
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:17:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
17 | "LOCAL ACTION HANDLER",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:18:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
18 | "AND GATE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:19:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
19 | "OR GATE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:20:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
20 | "NOT GATE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:21:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
21 | "XOR GATE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:22:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
22 | "NAND GATE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:23:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
23 | "NOR GATE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:24:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
24 | "AND GATE (3 INPUTS)",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.h:25:3: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
25 | "OR GATE (3 INPUTS)"
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.cpp: In function 'const char* getZ2SDeviceLocalActionHandlerTypeName(int16_t)':
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.cpp:19:1: error: control reaches end of non-void function [-Werror=return-type]
19 | }
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.cpp: In function 'const char* getZ2SDeviceLocalActionHandlerLogicOperatorName(int16_t)':
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_local_action_handler.cpp:38:1: error: control reaches end of non-void function [-Werror=return-type]
38 | }
cc1plus.exe: some warnings being treated as errors
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_pressure.cpp: In function 'void addZ2SDevicePressure(zbg_device_params_t*, uint8_t)':
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_pressure.cpp:28:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
28 | "PRESSURE",
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_hvac.cpp: In function 'void addZ2SDeviceHvac(ZigbeeGateway*, zbg_device_params_t*, uint8_t, uint8_t)':
C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library\examples\Z2S_Gateway\z2s_device_hvac.cpp:211:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
211 | "THERMOSTAT",
Użycie biblioteki Z2S_Library z folderu C:\Users\Jacek\Documents\Arduino\libraries\Z2S_Library
Użycie biblioteki ESPUI w wersji 2.2.4 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\ESPUI
Użycie biblioteki ArduinoJson w wersji 7.4.2 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\ArduinoJson
Użycie biblioteki LittleFS w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\LittleFS
Użycie biblioteki FS w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\FS
Użycie biblioteki ESP Async WebServer w wersji 3.7.10 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\ESP_Async_WebServer
Użycie biblioteki Async TCP w wersji 3.4.6 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\Async_TCP
Użycie biblioteki WiFi w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\WiFi
Użycie biblioteki Networking w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\Network
Użycie biblioteki ESPmDNS w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\ESPmDNS
Użycie biblioteki ESPAsyncHTTPUpdateServer w wersji 3.0.0 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\ESPAsyncHTTPUpdateServer
Użycie biblioteki SuplaDevice w wersji 25.8.1 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\SuplaDevice
Użycie biblioteki ESP Telnet w wersji 2.2.3 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\ESP_Telnet
Użycie biblioteki base64_encode w wersji 2.0.5 z folderu: C:\Users\Jacek\Documents\Arduino\libraries\base64_encode
Użycie biblioteki Hash w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\Hash
Użycie biblioteki Ticker w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\Ticker
Użycie biblioteki SPIFFS w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\SPIFFS
Użycie biblioteki Update w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\Update
Użycie biblioteki NetworkClientSecure w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\NetworkClientSecure
Użycie biblioteki WebServer w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\WebServer
Użycie biblioteki HTTPUpdateServer w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\HTTPUpdateServer
Użycie biblioteki EEPROM w wersji 3.3.2 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\EEPROM
exit status 1
Compilation error: control reaches end of non-void function [-Werror=return-type]
