Kontaktron to SETTI+ SDS400 Zigbee.
Unknown model _TZ3000_yihvt3gp::TS0203, no binding is possibleModerator: vajera
Unknown model _TZ3000_yihvt3gp::TS0203, no binding is possibleCzyli z jednej partii produkcyjnejPijanySmerf wrote: Thu Oct 23, 2025 3:32 pm kolejnyCode: Select all
Unknown model _TZE284_gops3slb::TS0601, no binding is possible
Niestety dalej "Unknown model ::, no binding is possible"
[ 45752][V][ZigbeeCore.cpp:264] openNetwork(): Opening network for joining for 0 seconds
[ 46222][I][ZigbeeCore.cpp:432] esp_zb_app_signal_handler(): Network(0x489f) closed, devices joining not allowed.
[ 46223][I][Z2S_Gateway.ino:223] Z2S_onOpenNetwork(): Network closed
[ 46223][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[ 46224][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 46224][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[ 46570][V][ZigbeeCore.cpp:264] openNetwork(): Opening network for joining for 180 seconds
[ 47041][I][ZigbeeCore.cpp:427] esp_zb_app_signal_handler(): Network(0x489f) is open for 180 seconds
[ 47042][I][Z2S_Gateway.ino:216] Z2S_onOpenNetwork(): Network open for 180 s
[ 47042][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[ 47043][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 47043][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
Send: [53 55 50 4C 41 17 09 00 00 00 28 00 00 00 10 00 00 00 3F 7E FA 68 00 00 00 00 4D 3C 0F 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 09 00 00 00 32 00 00 00 10 00 00 00 20 62 FA 68 00 00 00 00 28 A9 07 00 00 00 00 00 53 55 50 4C 41 ]
[ 60001][I][Z2S_Gateway.ino:753] loop(): New UTC time 814561989, new local time 814561989
[ 60002][I][Z2S_Gateway.ino:799] loop():
Local Time Cluster Time status attribute 2
UTC time attribute 814561989
local time attribute 814561989
[ 60004][I][z2s_web_gui.cpp:754] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 4194304 B <b>| <i>Free Sketch Space:</b></i> 2621440 B<br><b><i>HeapSize:</b></i> 359196 B <b>| <i>FreeHeap:</b></i> 89488 B <b>| <i>MinimalFreeHeap:</b></i> 74208 B <b>| <i>MaxAllocHeap:</b></i> 67572 B<br><b><i>uxTaskGetStackHighWaterMark:</b></i> 2984 B <br><b><i>Total PSRAM:</b></i> 0 B <b>| <i>Free PSRAM:</b></i> 0 B<br><br><b><i>Local time:</i></b> Thu Oct 23 19:13:09 2025
<b><i>Supla uptime:</i></b> 60 s
[ 60010][I][Z2S_Gateway.ino:811] loop():
Memory information:
Flash chip real size: 4194304 B
Free Sketch Space: 2621440 B
Free Heap: 87584 B
Minimal Free Heap: 74208 B
HeapSize: 359196 B
MaxAllocHeap: 67572 B
Supla uptime: 60 s
[ 72087][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 72087][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0013, asdu_length: 12
APSDE INDICATION - dst_short_addr: 0xfffd, src_short_addr: 0xd97e
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 66, rx_time: 0
[ 72089][I][ZigbeeCore.cpp:370] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd97e)
[ 72090][V][ZigbeeCore.cpp:374] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 72283][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 72363][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 72364][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8006, asdu_length: 5
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xd97e
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 71, rx_time: 0
[ 72366][D][ZigbeeGateway.cpp:350] find_Cb(): BASIC cluster found: short address(0xffff), endpoint(255)
[ 72368][I][ZigbeeGateway.cpp:884] printJoinedDevices(): joined devices:
[ 72370][I][ZigbeeGateway.cpp:887] printJoinedDevices(): Device on endpoint 255, short address: 0xffff
[ 72371][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[ 72371][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 72372][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[ 72373][I][ZigbeeGateway.cpp:488] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 72375][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 72555][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 72556][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 113, cluster_id: 0x0013, asdu_length: 12
APSDE INDICATION - dst_short_addr: 0xfffd, src_short_addr: 0x3471
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 107, rx_time: 0
[ 72558][I][ZigbeeCore.cpp:370] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x3471)
[ 72558][V][ZigbeeCore.cpp:374] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 72612][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 72613][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x3471
[ 72615][D][ZigbeeGateway.cpp:350] find_Cb(): BASIC cluster found: short address(0xffff), endpoint(255)
[ 73374][I][ZigbeeGateway.cpp:494] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 75374][E][ZigbeeGateway.cpp:498] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 75374][I][ZigbeeGateway.cpp:488] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 75376][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 76375][I][ZigbeeGateway.cpp:494] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 78154][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 78155][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 126, cluster_id: 0x0006, asdu_length: 9
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 102, rx_time: 0
[ 78375][E][ZigbeeGateway.cpp:498] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 78375][I][ZigbeeGateway.cpp:488] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 78377][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 78571][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 78572][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 113, cluster_id: 0x0006, asdu_length: 9
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 112, rx_time: 0
[ 79376][I][ZigbeeGateway.cpp:494] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 81376][E][ZigbeeGateway.cpp:498] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 81376][I][ZigbeeGateway.cpp:488] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 81378][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
NLME Status Indication, status: 0x0
[ 82377][I][ZigbeeGateway.cpp:494] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 84377][E][ZigbeeGateway.cpp:498] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 84377][I][ZigbeeGateway.cpp:488] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 84379][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 85378][I][ZigbeeGateway.cpp:494] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 87290][I][ZigbeeCore.cpp:454] esp_zb_app_signal_handler(): Device 0x3471 authorized (status: 0, type: 0)
[ 87378][E][ZigbeeGateway.cpp:498] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 87378][I][Z2S_Gateway.ino:969] loop(): Error while pairing - cann't read manufacturer id (5x). Gateway will restart, try to pair device once again!
Scheduling soft restart in 1000 ms
LAST STATE ADDED: Software reset (72)
[ 87380][I][Z2S_Gateway.ino:108] supla_callback_bridge(): event(0x22), action(0x4010)
Current status: [41] Software reset
[ 87381][D][Z2S_Gateway.ino:1480] loop(): Unknown model ::, no binding is possible
+BWNU 0.9.111-23/10/2025robertklepacki94 wrote: Thu Oct 23, 2025 3:33 pm Cześć, kupiłem dziś w Media Expert na promce czujnik otwarcia drzwi, bramka go jeszcze nie wykrywa.
Kontaktron to SETTI+ SDS400 Zigbee.Proszę o dodanie w miarę możliwościCode: Select all
Unknown model _TZ3000_yihvt3gp::TS0203, no binding is possible![]()
+BWNU 0.9.111-23/10/2025PijanySmerf wrote: Thu Oct 23, 2025 3:11 pm@Vajera Dziś otrzymałem nowe termostaty, identyczne z tymi, które już mam. Niestety, podczas próby parowania pojawił się problemCode: Select all
Unknown model _TZE204_gops3slb::TS0601, no binding is possible
+BWNU 0.9.111-23/10/2025PijanySmerf wrote: Thu Oct 23, 2025 3:32 pm kolejnyCode: Select all
Dziękuję.vajera wrote: Thu Oct 23, 2025 5:54 pm+BWNU 0.9.111-23/10/2025PijanySmerf wrote: Thu Oct 23, 2025 3:32 pm kolejnyCode: Select all
To urządzenie przedstawia się niezgodnie ze standardem Zigbee - zrobiłem takie małe obejście w 0.9.113-23/10/2025 - daj logi z parowania.zokopian wrote: Thu Oct 23, 2025 5:26 pm
Dzięki, działają bezbłędnievajera wrote: Thu Oct 23, 2025 5:53 pm+BWNU 0.9.111-23/10/2025robertklepacki94 wrote: Thu Oct 23, 2025 3:33 pm Cześć, kupiłem dziś w Media Expert na promce czujnik otwarcia drzwi, bramka go jeszcze nie wykrywa.
