Zauważyłem że w cloudzie po wyłączeniu bramki znów nie zmienia stanu trzeba dać sobie z tym czujnikiem spokój szkoda czasu.
Dziękuję za poświęcony czas.
Moderator: vajera
13:36:41.633 > Flash chip real size: 4194304 B
13:36:41.634 > Free Sketch Space: 2621440 B
13:36:41.634 > Free Heap: 102564 B
13:36:41.640 > Minimal Free Heap: 50440 B
13:36:41.640 > HeapSize: 359756 B
13:36:41.645 > MaxAllocHeap: 67572 B
13:36:41.645 > Supla uptime: 60 sCode: Select all
13:43:18.252 > [159528][E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():302]: (-32512) SSL - Memory allocation failed
13:43:18.259 > [159539][I][NetworkClientSecure.cpp:153] connect(): Actual TLS start postponed.
13:43:18.269 > [159547][E][NetworkClientSecure.cpp:159] connect(): start_ssl_client: connect failed: -32512Code: Select all
13:53:21.332 > Memory information:
13:53:21.338 > Flash chip real size: 4194304 B
13:53:21.338 > Free Sketch Space: 2621440 B
13:53:21.338 > Free Heap: 102640 B
13:53:21.344 > Minimal Free Heap: 80060 B
13:53:21.344 > HeapSize: 359756 B
13:53:21.348 > MaxAllocHeap: 81908 B
13:53:21.348 > Supla uptime: 60 sCode: Select all
13:57:30.983 > Memory information:
13:57:30.988 > Flash chip real size: 4194304 B
13:57:30.988 > Free Sketch Space: 2621440 B
13:57:30.988 > Free Heap: 39700 B
13:57:30.994 > Minimal Free Heap: 31464 B
13:57:30.994 > HeapSize: 359756 B
13:57:30.999 > MaxAllocHeap: 23028 B
13:57:30.999 > Supla uptime: 60 sCode: Select all
14:03:19.406 > Memory information:
14:03:19.411 > Flash chip real size: 4194304 B
14:03:19.411 > Free Sketch Space: 2621440 B
14:03:19.411 > Free Heap: 30336 B
14:03:19.418 > Minimal Free Heap: 25872 B
14:03:19.418 > HeapSize: 359756 B
14:03:19.422 > MaxAllocHeap: 14324 B
14:03:19.422 > Supla uptime: 60 sWiesz... jak nie podasz co to za liczniki (identyfikatory), to jest mała szansa na to, że @vajera ze szklanej kuli odczyta ich id i poprawi w programie...[email protected] wrote: Sun Nov 09, 2025 6:09 pm Powitać,
Mam problem z licznikami energii mam ich dwa i na obydwu ten sam błąd, moce, prądy i napięcie pokazuje prawidłowo ale co do zużycia kWh to obecnie mam przecinek przesunięty o dwa miejsca w prawo, np. pokazuje 1823 kWh powinno być 18,23 kWh
Szukasz nowego GG? Jest tutaj: https://forum.supla.org/viewtopic.php?t=18036Jasne, sorki..Zibi_007 wrote: Sun Nov 09, 2025 6:15 pmWiesz... jak nie podasz co to za liczniki (identyfikatory), to jest mała szansa na to, że @vajera ze szklanej kuli odczyta ich id i poprawi w programie...[email protected] wrote: Sun Nov 09, 2025 6:09 pm Powitać,
Ten drugi to jest sensor IAS ZONE?[email protected] wrote: Sun Nov 09, 2025 6:47 pmJasne, sorki..Zibi_007 wrote: Sun Nov 09, 2025 6:15 pmWiesz... jak nie podasz co to za liczniki (identyfikatory), to jest mała szansa na to, że @vajera ze szklanej kuli odczyta ich id i poprawi w programie...[email protected] wrote: Sun Nov 09, 2025 6:09 pm Powitać,
liczniki to
_TZ3000_ww6drja5::TS011F
_TZ3210_up3pngle::TS0205
przepraszam za zamieszanie, coś nie to mi się wkleiło ten drugi tovajera wrote: Mon Nov 10, 2025 9:23 pmTen drugi to jest sensor IAS ZONE?[email protected] wrote: Sun Nov 09, 2025 6:47 pmJasne, sorki..Zibi_007 wrote: Sun Nov 09, 2025 6:15 pm
liczniki to
Jeżeli jesteś w 100% pewny, że pomiary energii w przypadku tych dwóch liczników są x100, to wypróbuj 0.9.144-11/11/2025[email protected] wrote: Mon Nov 10, 2025 10:50 pm przepraszam za zamieszanie, coś nie to mi się wkleiło ten drugi to
_TZ3000_kqvb5akv::TS0001
z tego wątku
viewtopic.php?t=16638&hilit=michalasty% ... &start=640
