Nie wiem jeszcze jak poprawnie skanować kod. Dodawałem wszystko co wypluło putty. Mam nadzieje że to wystarczy. Z góry bardzo dziękuje. Super projekt.
[190531][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[190532][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[190533][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[190533][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x06e0
[190534][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[190534][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[190535][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[190535][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x3a
[190536][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[190536][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[190536][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[190537][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[190537][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[190538][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[190538][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[190539][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x8
[190539][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[190540][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
[200560][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[200561][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 224, cluster_id: 0xef00, asdu_length: 13
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x06e0
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 30, rx_time: 0
[200562][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
[200563][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[200563][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
[200564][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[200564][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 12 size: 10
[200565][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[200565][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x40
[200565][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[200566][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[200566][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[200566][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[200567][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[200567][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[200568][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0A
[200568][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x6e0, 0x6e0, 0x0, 0x0
[200569][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xef00, cmd id 0x2
[200569][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[200570][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[200571][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[200571][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x06e0
[200572][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[200572][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[200573][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[200573][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x40
[200573][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[200574][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[200574][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[200575][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[200575][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[200576][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[200576][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[200577][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xa
[200577][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[200578][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
[210596][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[210596][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[210598][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
[210599][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[210599][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
[210600][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[210600][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 15 size: 10
[210600][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[210601][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x46
[210601][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[210602][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[210602][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[210603][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[210603][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[210603][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x10
[210604][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x6e0, 0x6e0, 0x0, 0x0
[210604][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xef00, cmd id 0x2
[210605][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[210606][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[210606][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[210607][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x06e0
[210607][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[210608][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[210608][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[210609][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x46
[210609][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[210610][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[210610][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[210611][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[210611][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[210612][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[210612][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[210612][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x10
[210613][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[210614][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
Send: [53 55 50 4C 41 1B 12 00 00 00 28 00 00 00 10 00 00 00 E8 13 75 69 00 00 00 00 1B 54 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 1B 10 00 00 00 32 00 00 00 10 00 00 00 D8 05 75 69 00 00 00 00 8F AC 09 00 00 00 00 00 53 55 50 4C 41 ]
[220631][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[220632][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 35, rx_time: 0
[220633][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
[220634][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[220634][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
[220635][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[220635][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 18 size: 10
[220636][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[220636][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4C
[220636][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[220637][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[220637][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[220637][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[220638][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[220638][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[220638][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x1E
[220639][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x6e0, 0x6e0, 0x0, 0x0
[220639][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xef00, cmd id 0x2
[220640][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[220641][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[220641][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[220642][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x06e0
[220642][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[220643][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[220643][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[220644][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x4c
[220644][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[220645][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[220645][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[220646][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[220646][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[220647][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[220647][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[220648][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x1e
[220648][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[220649][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
[230210][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[230211][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 224, cluster_id: 0x0000, asdu_length: 67
[230212][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x0, command id: 10
[230213][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[230213][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[230214][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[230214][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 20 size: 64
[230215][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xDF
[230215][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xFF
[230215][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x42
[230216][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x3C
[230216][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x03
[230216][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xCA
[230217][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230217][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[230218][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230218][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0D
[230218][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230219][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230219][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230220][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x72
[230220][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xCA
[230220][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230221][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[230221][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230221][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x7C
[230222][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xCA
[230222][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230222][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[230223][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230223][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x86
[230223][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xCA
[230224][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230224][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[230224][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230225][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x90
[230225][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xCA
[230225][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230226][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[230226][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230226][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x9A
[230227][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xCA
[230227][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230227][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[230228][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x69
[230228][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x05
[230228][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230229][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230229][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x66
[230230][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x06
[230230][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230231][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230231][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x12
[230231][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[230232][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230233][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x65
[230233][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x09
[230234][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x65
[230235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x22
[230235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[230236][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230236][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x65
[230237][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x6e0, 0x6e0, 0x0, 0x0
[230237][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0x0, cmd id 0xa
[230238][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[230239][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[230240][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[230240][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x6e0) src endpoint(1) to dst endpoint(1) cluster(0x0)
[230241][I][ZigbeeGateway.cpp:752] zbReadBasicCluster(): attribute reporting with short address(0x6E0), updating IEEE address
[230241][I][ZigbeeGateway.cpp:756] zbReadBasicCluster(): Basic cluster: attribute(0xFFDF), type (0x42), size (0x3D)
[230242][I][z2s_devices_table.cpp:3128] Z2S_onBasicReceive(): A4:C1:38:08:0F:D6:0A:1E, short address 0x6e0 endpoint 0x1, attribute id 0xffdf, size 61
[230477][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[230477][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 224, cluster_id: 0x0000, asdu_length: 17
[230479][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x0, command id: 10
[230479][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[230480][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[230481][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[230481][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 21 size: 14
[230481][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xDF
[230482][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xFF
[230482][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x42
[230482][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0A
[230483][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x23
[230483][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[230483][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230484][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230484][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x12
[230484][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x24
[230485][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[230485][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[230486][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x65
[230486][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x6e0, 0x6e0, 0x0, 0x0
[230487][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0x0, cmd id 0xa
[230487][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[230488][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[270830][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[270831][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x06e0
[270831][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[270832][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[270832][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[270833][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x6a
[270833][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[270834][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[270834][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[270834][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[270835][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[270835][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[270836][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[270836][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x26
[270837][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[270837][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
[279037][I][ZigbeeCore.cpp:442] esp_zb_app_signal_handler(): Network(0x7189) closed, devices joining not allowed.
[279038][I][Z2S_Gateway.ino:301] Z2S_onOpenNetwork(): Network closed
[279038][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[279039][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[279039][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[279042][I][Z2S_local_action_handlers.cpp:275] handleAction(): &&&&&&&&&&&&&&&&&&&&&&&&&&event 16418, action 0
[280856][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[280856][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 56, rx_time: 0
[280858][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
[280859][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[280859][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
[280860][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[280860][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 18 size: 10
[280860][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[280861][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x70
[280861][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[280862][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[280862][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[280863][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[280863][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[280863][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x23
[280864][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x6e0, 0x6e0, 0x0, 0x0
[280864][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xef00, cmd id 0x2
[280865][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[280866][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[280867][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[280867][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x06e0
[280868][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[280868][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[280868][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[280869][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x70
[280869][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[280870][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[280870][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[280871][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[280871][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[280872][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[280872][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[280873][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x23
[280873][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[280874][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
Send: [53 55 50 4C 41 1B 15 00 00 00 28 00 00 00 10 00 00 00 33 14 75 69 00 00 00 00 0F 81 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 1B 13 00 00 00 32 00 00 00 10 00 00 00 23 06 75 69 00 00 00 00 CF 84 0A 00 00 00 00 00 53 55 50 4C 41 ]
[289596][I][ZigbeeCore.cpp:474] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x06e0), rejoin (NO)
[300041][I][Z2S_Gateway.ino:944] loop(): New UTC time 822595774, new local time 822595774
[300042][I][Z2S_Gateway.ino:976] loop():
Local Time Cluster Time status attribute 2
UTC time attribute 822595774
local time attribute 822595774
[300044][I][z2s_web_gui.cpp:843] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 8388608 B <b>| <i>Free Sketch Space:</b></i> 3407872 B<br><b><i>HeapSize:</b></i> 358028 B <b>| <i>FreeHeap:</b></i> 52360 B <b>| <i>MinimalFreeHeap:</b></i> 37172 B <b>| <i>MaxAllocHeap:</b></i> 30196 B<br><b><i>uxTaskGetStackHighWaterMark:</b></i> 3004 B <br><b><i>Total PSRAM:</b></i> 0 B <b>| <i>Free PSRAM:</b></i> 0 B<br><br><b><i>Local time:</i></b> Sat Jan 24 18:49:34 2026
<b><i>Supla uptime:</i></b> 300 s
Send: [53 55 50 4C 41 1B 16 00 00 00 E0 01 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 1B 14 00 00 00 EA 01 00 00 1A 00 00 00 EA 07 01 18 07 12 31 28 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 2026-01-24 18:49:40
Recv: [53 55 50 4C 41 1B 15 00 00 00 CC 01 00 00 15 00 00 00 00 00 00 00 FF FF FF FF F0 23 00 00 01 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
CALCFG CMD received: senderId 0, ch -1, cmd 9200, suauth 1, datatype 0, datasize 0
CALCFG START SUBDEVICE PAIRING received
[313553][V][ZigbeeCore.cpp:272] openNetwork(): Opening network for joining for 180 seconds
Sending CALCFG result: CMD 9200 result: 1
Send: [53 55 50 4C 41 1B 17 00 00 00 D6 01 00 00 92 00 00 00 00 00 00 00 FF FF FF FF F0 23 00 00 01 00 00 00 7E 00 00 00 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
[314022][I][ZigbeeCore.cpp:437] esp_zb_app_signal_handler(): Network(0x7189) is open for 180 seconds
[314023][I][Z2S_Gateway.ino:285] Z2S_onOpenNetwork(): Network open for 180 s
[314023][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[314024][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[314024][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[314027][I][Z2S_local_action_handlers.cpp:275] handleAction(): &&&&&&&&&&&&&&&&&&&&&&&&&&event 16417, action 0
Send: [53 55 50 4C 41 1B 18 00 00 00 28 00 00 00 10 00 00 00 64 14 75 69 00 00 00 00 F1 94 0D 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 1B 16 00 00 00 32 00 00 00 10 00 00 00 55 06 75 69 00 00 00 00 E2 6C 07 00 00 00 00 00 53 55 50 4C 41 ]
[357884][V][ZigbeeCore.cpp:492] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[357908][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[357909][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 117, cluster_id: 0x0013, asdu_length: 12
APSDE INDICATION - dst_short_addr: 0xfffd, src_short_addr: 0x0275
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 30, rx_time: 0
[357911][I][ZigbeeCore.cpp:380] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x0275)
[357911][V][ZigbeeCore.cpp:384] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[357928][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[357929][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8006, asdu_length: 6
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x0275
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 45, rx_time: 0
[357931][D][ZigbeeGateway.cpp:495] find_Cb(): BASIC cluster found: short address(0x275), endpoint(1)
[357933][I][ZigbeeGateway.cpp:1042] printJoinedDevices(): joined devices:
[357933][I][ZigbeeGateway.cpp:1045] printJoinedDevices(): Device on endpoint 1, short address: 0x275
[357934][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[357935][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[357936][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[357937][I][z2s_devices_table.h:983] notifySrpcAboutParingEnd(): updating Cloud pairing status - 1
Send: [53 55 50 4C 41 1B 19 00 00 00 D6 01 00 00 92 00 00 00 00 00 00 00 FF FF FF FF F0 23 00 00 01 00 00 00 7E 00 00 00 2C 00 B4 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
[357947][D][Z2S_Gateway.ino:1780] loop(): Unknown model _TZE204_ogkdpgy2::TS0601, no binding is possible
[357948][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[357949][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[357949][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[358950][I][ESPUI.cpp:36] setCustomJS():
function myFunction() {
/*var a = document.createElement('a');
a.href='/update';
a.target = '_blank';
document.body.appendChild(a);
a.click();*/
//alert("CLICKED");
window.location.assign("/update");
/*document.addEventListener("click", function(e){
alert(e.target.id);
console.log(e.target.getAttribute("id"));
console.log(e.target.id);
const target = e.target.closest("#btn31");
if(e.target.id == "#btn31") {
console.log("#btn31");
myFunction();
if(e.target.id == "btn31") {
console.log("btn31");
myFunction();
document.addEventListener("mouseup", function(e){
//alert(e.target.id);
e.stopImmediatePropagation();
myFunction();
document.addEventListener("touchend", function(e){
myFunction();
a.href='/update';
a.click();*/
//alert("CLICKED");
alert(e.target.id);
myFunction();
myFunction();
myFunction();
myFunction();
[358962][E][AsyncTCP.cpp:1521] begin(): bind error: -8
[358962][I][Z2S_local_action_handlers.cpp:275] handleAction(): &&&&&&&&&&&&&&&&&&&&&&&&&&event 16432, action 0
[358965][I][z2s_devices_table.h:983] notifySrpcAboutParingEnd(): updating Cloud pairing status - 4
Send: [53 55 50 4C 41 1B 1A 00 00 00 D6 01 00 00 92 00 00 00 00 00 00 00 FF FF FF FF F0 23 00 00 01 00 00 00 7E 00 00 00 2D 00 B4 00 04 19 5F 54 5A 45 32 30 34 5F 6F 67 6B 64 70 67 79 32 3A 3A 54 53 30 36 30 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
[359108][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[359109][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0002, asdu_length: 3
[359223][I][ZigbeeCore.cpp:464] esp_zb_app_signal_handler(): Device 0x0275 authorized (status: 0, type: 1)
[359293][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[359294][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 117, cluster_id: 0x0036, asdu_length: 3
APSDE INDICATION - dst_short_addr: 0xfffc, src_short_addr: 0x0275
[359296][I][ZigbeeCore.cpp:437] esp_zb_app_signal_handler(): Network(0x7189) is open for 180 seconds
[359296][I][Z2S_Gateway.ino:285] Z2S_onOpenNetwork(): Network open for 180 s
[359297][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[359297][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[359298][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[359300][I][Z2S_local_action_handlers.cpp:275] handleAction(): &&&&&&&&&&&&&&&&&&&&&&&&&&event 16417, action 0
[360051][I][Z2S_Gateway.ino:944] loop(): New UTC time 822595834, new local time 822595834
[360052][I][Z2S_Gateway.ino:976] loop():
UTC time attribute 822595834
local time attribute 822595834
[360054][I][z2s_web_gui.cpp:843] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 8388608 B <b>| <i>Free Sketch Space:</b></i> 3407872 B<br><b><i>HeapSize:</b></i> 358028 B <b>| <i>FreeHeap:</b></i> 49852 B <b>| <i>MinimalFreeHeap:</b></i> 37172 B <b>| <i>MaxAllocHeap:</b></i> 30196 B<br><b><i>uxTaskGetStackHighWaterMark:</b></i> 3004 B <br><b><i>Total PSRAM:</b></i> 0 B <b>| <i>Free PSRAM:</b></i> 0 B<br><br><b><i>Local time:</i></b> Sat Jan 24 18:50:34 2026
<b><i>Supla uptime:</i></b> 360 s
[361162][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[361162][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 117, cluster_id: 0xef00, asdu_length: 13
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 40, rx_time: 0
[361164][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
[361164][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[361165][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
[361166][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[361166][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 12 size: 10
[361166][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[361168][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x46
[361168][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[361169][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[361169][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[361170][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[361170][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[361170][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xA6
[361171][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x275, 0x275, 0x0, 0x0
[361171][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xef00, cmd id 0x2
[361172][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[361173][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[361173][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[361174][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x0275
[361175][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[361175][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[361176][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[361176][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x46
[361176][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[361177][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[361177][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[361178][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[361178][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[361179][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[361179][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x7
[361180][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xa6
[361180][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[361181][I][z2s_device_tuya_custom_cluster.cpp:2591] processTuyaDataReport(): failed - no Supla channel for that device
Send: [53 55 50 4C 41 1B 1B 00 00 00 28 00 00 00 10 00 00 00 7D 14 75 69 00 00 00 00 6D 40 0F 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 1B 17 00 00 00 32 00 00 00 10 00 00 00 6E 06 75 69 00 00 00 00 20 F0 09 00 00 00 00 00 53 55 50 4C 41 ]
[364320][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[364321][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 117, cluster_id: 0xef00, asdu_length: 6
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 51, rx_time: 0
[364323][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 17
[364323][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[364324][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
[364324][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[364325][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 14 size: 3
[364325][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[364325][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x1E
[364326][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x40
[364326][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x275, 0x275, 0x0, 0x0
[364327][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xef00, cmd id 0x11
[364327][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[364328][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[364329][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
[364329][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0x0275
[364330][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
[364330][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[364331][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[364331][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x1e
[364332][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x40
[364332][I][z2s_device_tuya_custom_cluster.cpp:2867] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x11
[364333][I][z2s_device_tuya_custom_cluster.cpp:2966] processTuyaCustomCluster(): Ignoring TUYA_MCU_VERSION_RESPONSE message
[364372][D][ZigbeeCore.cpp:504] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[364373][D][ZigbeeCore.cpp:508] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 117, cluster_id: 0x000a, asdu_length: 5
[364375][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[364375][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[364376][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[364376][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[364377][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 16 size: 2
[364377][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[364378][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[364378][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x275, 0x275, 0x0, 0x0
[364378][I][z2s_devices_table.cpp:4312] Z2S_onCustomCmdReceive(): A4:C1:38:08:0F:D6:0A:1E, endpoint 0x1, cluster 0xa, cmd id 0x0
[364379][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address A4:C1:38:08:0F:D6:0A:1E
[364380][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed-----------------------------------------------------
