Silnik w końcu na oknie
skalibrowałem ale chciałem poprawić precyzyjność kalibracji i tak odczytując id 1027 pokazuje 36 zmieniając tą wartość na 38 daje zapisz to bramka robi restart. Czy nie można edytować tego parametru ? To są te trzy pierwsze linie z próby zapisu
[19:14:19][108470][I][z2s_web_gui.cpp:5639] getClustersAttributesQueryCallback(): device_selector value 0
[19:14:19][108471][I][z2s_web_gui.cpp:5937] getClustersAttributesQueryCallback(): attribute_value = 38, length = 2
[19:14:19][108471][I][ZigbeeGateway.cpp:2293] sendAttributeWrite(): Sending 'write attribute' command - id (0x403), type (0x20), size (0x1), value (0x26)
[19:14:19][109031][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[19:14:19][109031][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[19:14:19]APSDE INDICATION - src_addr_mode: 110, cluster_id: 0xfcc0, asdu_length: 8
[19:14:19]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xf36e
[19:14:19]APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 40, rx_time: 0
[19:14:19][109033][I][ZigbeeHandlers.cpp:247] zb_raw_cmd_handler(): cluster id: 0xfcc0, command id: 4
[19:14:19][109033][I][ZigbeeHandlers.cpp:250] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[19:14:19][109034][I][ZigbeeHandlers.cpp:254] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[19:14:19][109034][I][ZigbeeHandlers.cpp:258] zb_raw_cmd_handler(): manuf_specific 0x115f
[19:14:19][109035][I][ZigbeeHandlers.cpp:262] zb_raw_cmd_handler(): RAW bufid: 10 size: 3
[19:14:19][109035][I][ZigbeeHandlers.cpp:265] zb_raw_cmd_handler(): 0x88
[19:14:19][109035][I][ZigbeeHandlers.cpp:265] zb_raw_cmd_handler(): 0x03
[19:14:19][109036][I][ZigbeeHandlers.cpp:265] zb_raw_cmd_handler(): 0x04
[19:14:19][109036][I][ZigbeeHandlers.cpp:275] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xf36e, 0xf36e, 0x0, 0x0
[19:14:19][109037][I][z2s_devices_table.cpp:6408] Z2S_onUpdateDeviceLastRssi(): short addr 0xF36E, rssi -72
[19:14:19][109037][I][z2s_devices_table.cpp:6413] Z2S_onUpdateDeviceLastRssi(): short addr 0xF36E, rssi -72
[19:14:19][109038][I][z2s_devices_table.cpp:6421] Z2S_onUpdateDeviceLastRssi(): short addr 0xF36E, rssi -72
[19:14:19][109038][I][z2s_devices_table.cpp:5741] Z2S_onCustomCmdReceive(): , endpoint 0x1, cluster 0xfcc0, cmd id 0x4
[19:14:19][109039][I][z2s_devices_table.cpp:279] Z2S_findChannelNumberSlot(): sub id -1
[19:14:19][109039][I][z2s_devices_table.cpp:5755] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[19:14:19][109040][I][ZigbeeHandlers.cpp:302] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[19:14:19][109040][I][ZigbeeHandlers.cpp:90] zb_action_handler(): Receive Zigbee action(0x1001) callback
[19:14:19][109041][V][ZigbeeHandlers.cpp:413] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xf36e) src endpoint(1) to dst endpoint(1) cluster(0xfcc0)
[19:14:19][109042][V][ZigbeeHandlers.cpp:420] zb_cmd_write_attr_resp_handler(): Write attribute response: status(136), cluster(0xfcc0), attribute(0x403)
[19:14:19][109042][I][ZigbeeGateway.cpp:1743] zbWriteAttrResponse(): tsn = 4, _write_attr_last_tsn = 4, _write_attr_last_tsn_flag = 1
[19:14:19][109043][I][ZigbeeGateway.cpp:1749] zbWriteAttrResponse(): zbWriteAttrResponse sync, tsn matched
[19:14:20]Guru Meditation Error: Core 0 panic'ed (Load access fault). Exception was unhandled.
[19:14:20]
[19:14:20]Core 0 register dump:
[19:14:20]MEPC : 0x40031c68 RA : 0x40037010 SP : 0x40869510 GP : 0x40817584
[19:14:20]TP : 0x40869cf0 T0 : 0x400283c2 T1 : 0x408695dc T2 : 0xffffffff
[19:14:20]S0/FP : 0x00000000 S1 : 0x00000004 A0 : 0x00000403 A1 : 0x0000002a
[19:14:20]A2 : 0x00000004 A3 : 0x408699e8 A4 : 0x00000003 A5 : 0x00000403
[19:14:20]A6 : 0x00000007 A7 : 0x00000020 S2 : 0x00000403 S3 : 0x40869d6c
[19:14:20]S4 : 0x40869958 S5 : 0x00000009 S6 : 0x00000003 S7 : 0x00000003
[19:14:20]S8 : 0x422007cd S9 : 0x00000000 S10 : 0x408695e4 S11 : 0xffffffff
[19:14:20]T3 : 0x00000014 T4 : 0x4082c000 T5 : 0x4082c000 T6 : 0x40869d6c
[19:14:20]MSTATUS : 0x00001881 MTVEC : 0x40800001 MCAUSE : 0x00000005 MTVAL : 0x00000403
[19:14:20]MHARTID : 0x00000000
[19:14:20]
[19:14:20]Stack memory:
[19:14:20]40869510: 0x00000003 0x00000073 0x00000000 0x422007cf 0x40048c48 0x00000000 0x00000000 0x00000000
[19:14:20]40869530: 0x00000000 0x00000001 0x00000062 0x00000002 0x00000000 0x4004e20c 0x4004aa68 0x00000000
[19:14:20]40869550: 0x00000000 0x00000000 0xffffffff 0x7fefffff 0x00000000 0x3fe00000 0x00000000 0x20001000
[19:14:20]40869570: 0x00000000 0x3fc00000 0x00000000 0x40300000 0x4086958c 0x00000000 0x00000000 0x42200647
[19:14:20]40869590: 0x00000002 0x4086962f 0x00000001 0x408699e8 0x8300a8c0 0x00000006 0x00310000 0x36323432
[19:14:20]408695b0: 0x00000004 0x00000000 0x4085f1fc 0x0000000a 0x4082c000 0x00000003 0x4082c838 0x40800f7e
[19:14:20]408695d0: 0x408695dc 0x00000001 0x00000015 0x422007b8 0x00000015 0x40048dc4 0x00000002 0x4086967e
[19:14:20]408695f0: 0x00000002 0x00000202 0x40880000 0x00000000 0x40818684 0x00000001 0x00000005 0x00000000
[19:14:20]40869610: 0x4086a196 0x00000000 0x40880000 0x40880000 0x00000146 0x40869d08 0x3031805c 0x32333935
[19:14:20]40869630: 0x0001a7b7 0x40828498 0x00000000 0x4080fb76 0x4220a4d2 0x40880000 0x4082c150 0x00000000
[19:14:20]40869650: 0x000008f5 0x00000000 0x40830dd4 0x00000000 0x4220c94c 0x40852218 0x4084f768 0x40852230
[19:14:20]40869670: 0x00000403 0x00016946 0x4084f6b4 0x38388d4a 0xffffffff 0xd8ca8677 0x4084f768 0x40852230
[19:14:20]40869690: 0x00000001 0x00016946 0x4086a1a4 0x42132a70 0x00000026 0x422698bc 0x4085bfac 0x42139f36
[19:14:20]408696b0: 0x0001a7b7 0x0000000f 0x00000006 0x00000002 0x421fead7 0x4086a1b8 0x000054ad 0x4084f768
[19:14:20]408696d0: 0x00001731 0x4085bfac 0x40852218 0x42132a9c 0x422002ac 0x4086a1b8 0x000054ad 0x4084f768
[19:14:20]408696f0: 0x40865600 0x00000000 0x40843de4 0x408089a2 0x4220a2c0 0x40808f12 0x40869780 0x40817584
[19:14:20]40869710: 0x00000088 0x40030dca 0x40808c3a 0x6e65222c 0x00000088 0x00000000 0x00000001 0x00000001
[19:14:20]40869730: 0x00000403 0x4082c000 0x00000000 0x20001000 0x40809d4e 0x40807b40 0x408697c0 0x40817584
[19:14:20]40869750: 0x40869cf0 0x40018ea2 0x00000000 0xffffffff 0x00000001 0x00000001 0x00000001 0x40869810
[19:14:20]40869770: 0x4087d953 0x00000039 0x00000000 0x20001000 0x420a5ad2 0x420a5ad2 0x40869800 0x40817584
[19:14:20]40869790: 0x40869cf0 0x40018ea2 0x00000000 0xffffffff 0x4082c000 0x00000000 0x00000008 0x4086980f
[19:14:20]408697b0: 0x00000000 0x00000001 0x00000001 0x40807b4a 0xa0000000 0x0000000a 0x00000064 0x4087d824
[19:14:20]408697d0: 0x408698d8 0x00000000 0x00000000 0x40018e9e 0x40869840 0x00000000 0x408698d8 0x4085d1b0
[19:14:20]408697f0: 0x00000091 0x00000000 0x4082c000 0x420a5ae6 0x40869840 0x4085d1e7 0x42212fae 0x0a85d241
[19:14:20]40869810: 0x00000000 0x19999999 0x0000000a 0x40018ebe 0x00000091 0x00000000 0xffffff6e 0x4001924e
[19:14:20]40869830: 0x00000000 0x00000001 0x00000000 0x421ff000 0x40809d4e 0x4210d0a4 0x408698c0 0x40817584
[19:14:20]40869850: 0x40869cf0 0x40030dca 0x408090cc 0xffffffff 0x4082c000 0x00000042 0x00000001 0x4086988c
[19:14:20]40869870: 0x4086988c 0x00000004 0x00000000 0x20001000 0x40822150 0x00000000 0x00000008 0x40838494
[19:14:20]40869890: 0x00000002 0x00000009 0x00000000 0x00000002 0x40809e1c 0x40809dfe 0x40869920 0x40817584
[19:14:20]408698b0: 0x40869cf0 0x40030dca 0x40824000 0xffffffff 0x4082d49c 0x00000000 0x00000001 0x00000001
[19:14:20]408698d0: 0x4082c000 0x4082c000 0x00000001 0x600c5090 0x00000001 0x40824000 0x00000000 0xffffffff
[19:14:20]408698f0: 0x4082d4c0 0x4220a4d2 0x4082c000 0x4220a000 0x067725f0 0x00000001 0x42200000 0x421ff000
[19:14:20]
[19:14:20]
[19:14:20]
[19:14:20]ELF file SHA256: 19b74cf7f
[19:14:20]
[19:14:20]Rebooting...
[19:14:20]ESP-ROM:esp32c6-20220919
