Unknown model _TZE284_qf5mzewi::TS0601, no binding is possible
Unknown model _TZE284_qf5mzewi::TS0601, no binding is possibleModerator: vajera
Unknown model _TZE284_qf5mzewi::TS0601, no binding is possibleCode: Select all
Code Type Values
presence_state Enum
"range": [
"none",
"presence"
sensitivity Integer
"unit": "",
"min": 1,
"max": 9,
"scale": 0,
"step": 1
near_detection Integer
"unit": "m",
"min": 0,
"max": 1000,
"scale": 2,
"step": 10
far_detection Integer
"unit": "m",
"min": 150,
"max": 1000,
"scale": 2,
"step": 10
checking_result Enum
"range": [
"checking",
"check_success",
"check_failure",
"others",
"comm_fault",
"radar_fault"
target_dis_closest Integer
"unit": "m",
"min": 0,
"max": 1000,
"scale": 2,
"step": 1
confirm_delay Integer
"unit": "秒",
"min": 0,
"max": 500,
"scale": 2,
"step": 1
fading_time Integer
"unit": "秒",
"min": 5,
"max": 1500,
"scale": 0,
"step": 1
cli String
"maxlen": 255
illuminance Integer
"unit": "lux",
"min": 0,
"max": 4200,
"scale": 1,
"step": 1
trigger_sensitivity Integer
"unit": "",
"min": 1,
"max": 7,
"scale": 0,
"step": 1
trigger_distance Integer
"unit": "m",
"min": 0,
"max": 1000,
"scale": 2,
"step": 10
relay_mode Enum
"range": [
"standard",
"local",
"force",
"none"
relay_state Enum
"range": [
"off",
"on"
running_sta Enum
"range": [
"off",
"on"
illumin_threshold Integer
"unit": "lux",
"min": 0,
"max": 4200,
"scale": 1,
"step": 1
relay_polarity Enum
"range": [
"close",
"open"
block_time Integer
"unit": "秒",
"min": 1,
"max": 600,
"scale": 1,
"step": 1
param_result Enum
"range": [
"none",
"trigdis_err",
"dis_near",
"dis_far",
"relay_no",
"inhibit_err",
"polarity_err"
sensor_ctrl Enum
"range": [
"no",
"off",
"occupy",
"unoccupy"
}+BWNU:1.5.6-13/04/26edm wrote: Fri Apr 10, 2026 10:13 pm Proszę o dodanie.
Wykryto niewspierane urządzenie. Sprawdź, czy masz aktualną wersję oprogramowania. (_TZE204_clrdrnya::TS0601)
Proszę aby w aplikacji supla była możliwość włączania / wyłączania 2 funkcji.
sensor_ctrl "no", "off" - włącza / wyłącza czujnik ruchu (radar)
relay_state "off", "on" - ręczne sterowanie przekaźnikiem.
Reszta ustawień wystarczy jak będzie z poziomu bramki "Tuya custom cluster (0xEF00) devices".
Czujnik obecności 24 GHz + czujnik natężenia oświetlenia + przekaźnik.
https://pl.aliexpress.com/item/1005005652985047.html
Testowałem krótko na aplikacji Tuya i zapowiada się dobrze. Ma możliwość lokalnego (automatic) sterowania przekaźnikiem po wykryciu ruchu i zdefiniowanego natężenia oświetlenia. Ponadto sporą ilość ustawień / dostosowań samego radaru, włącznie z wycinaniem obszaru.
Edycja.
Informacyjnie dodam, że z aplikacji Tuya smart nie działa funkcja "Breaker polarity", która w config nazwana jest relay_polarity "close", "open". Po wybraniu opcji closed otrzymuje komunikat "not supported". Także przekaźnik zastosowany jest tylko NO.
Nie wszystko działa również z dostępnych opcji w "Break mode". Po wyborze mandatory (field control), lub not support nie przyjmuje tych opcji i wraca na poprzednią jaka była ustawiona. W config jest to relay_mode "force", "none".
Poza w/w pozostałe funkcje dają się zastosować.
Poglądowo załączam oficjalny config. I screen z aplikacji Tuya.Code: Select all
Code Type Values presence_state Enum { "range": [ "none", "presence" ] } sensitivity Integer { "unit": "", "min": 1, "max": 9, "scale": 0, "step": 1 } near_detection Integer { "unit": "m", "min": 0, "max": 1000, "scale": 2, "step": 10 } far_detection Integer { "unit": "m", "min": 150, "max": 1000, "scale": 2, "step": 10 } checking_result Enum { "range": [ "checking", "check_success", "check_failure", "others", "comm_fault", "radar_fault" ] } target_dis_closest Integer { "unit": "m", "min": 0, "max": 1000, "scale": 2, "step": 1 } confirm_delay Integer { "unit": "秒", "min": 0, "max": 500, "scale": 2, "step": 1 } fading_time Integer { "unit": "秒", "min": 5, "max": 1500, "scale": 0, "step": 1 } cli String { "maxlen": 255 } illuminance Integer { "unit": "lux", "min": 0, "max": 4200, "scale": 1, "step": 1 } trigger_sensitivity Integer { "unit": "", "min": 1, "max": 7, "scale": 0, "step": 1 } trigger_distance Integer { "unit": "m", "min": 0, "max": 1000, "scale": 2, "step": 10 } relay_mode Enum { "range": [ "standard", "local", "force", "none" ] } relay_state Enum { "range": [ "off", "on" ] } running_sta Enum { "range": [ "off", "on" ] } illumin_threshold Integer { "unit": "lux", "min": 0, "max": 4200, "scale": 1, "step": 1 } relay_polarity Enum { "range": [ "close", "open" ] } block_time Integer { "unit": "秒", "min": 1, "max": 600, "scale": 1, "step": 1 } param_result Enum { "range": [ "none", "trigdis_err", "dis_near", "dis_far", "relay_no", "inhibit_err", "polarity_err" ] } sensor_ctrl Enum { "range": [ "no", "off", "occupy", "unoccupy" ] }
+BWNU:1.5.6-13/04/26Mati23414 wrote: Mon Apr 13, 2026 11:28 am Witam. Prosze o dodanie urzadzeń:
Czujnik deszczu (HOBEIAN::ZG-223Z)
Moduł Przełącznika 2ch (Zbeacon::TS0002)
+BWNU:1.5.6-13/04/26Mario78 wrote: Wed Apr 08, 2026 2:21 pm Uprzejmie proszę o dodanie czujnika dla mojego trawnika
https://pl.aliexpress.com/item/10050086 ... pt=glo2polCode: Select all
Unknown model _TZE284_sgabhwa6::TS0601, no binding is possible
Nie idzie, bo mają inne ID, co zresztą widać w Twojej wiadomości.Jaroni wrote: Wed Apr 08, 2026 6:47 pm Dziwne, taki sam czujnik temperatury i wilgotności wcześniej kupiłem i sparowałem bez problemu z pierwszą bramką (_TZE284_vvmbj46n::TS0601), a tych dwóch nowych nie idzie https://pl.aliexpress.com/item/1005009944344965.html:Próbuję i próbuję, krótko świeci biała dioda i potem czerwona się zapala. Mam najnowszy soft v.1.5.1.Code: Select all
Unknown model _TZE284_qf5mzewi::TS0601, no binding is possible Unknown model _TZE284_qf5mzewi::TS0601, no binding is possible
