Zgłoszenia nowych urządzeń 2026 [bramka ZigBee]
Moderator: vajera
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Proszę o dodanie Urządzenia
Unknown model Sonoff::ZG-204ZL-z, no binding is possible
Jest to czujnki ruchu taki :
https://pvvx.github.io/ZG-204ZL-3.0/
z wgranym alternatywnym softem @pvvx w ver.1.3.6 to jest aktualizacja dla HOBEIAN ZG-204Z
Dużo nie pisze autor softu co wnosi jego uaktualnienie a wdaje się że dotyczy zużycia baterii :D ;)
logi w razie czego ;)
Using 'COM10' as serial port.
Unexpected error: could not open port 'COM10': PermissionError(13, 'Odmowa dostępu.', None, 5)
[20:00:31]NLME Status Indication, status: 0x12
[20:00:33]Send: [53 55 50 4C 41 1C 0E 00 00 00 28 00 00 00 10 00 00 00 61 4B DD 69 00 00 00 00 C4 B2 04 00 00 00 00 00 ]
[20:00:33]Send: [53 55 50 4C 41 ]
[20:00:33]Recv: [53 55 50 4C 41 1C 0E 00 00 00 32 00 00 00 10 00 00 00 41 2F DD 69 00 00 00 00 15 00 09 00 00 00 00 00 53 55 50 4C 41 ]
[20:00:37][ 45460][V][ZigbeeCore.cpp:503] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[20:00:37]NLME Status Indication, status: 0x12
[20:00:51][ 60001][I][Z2S_Gateway.ino:1101] loop(): New UTC time 829425651, new local time 829425651
[20:00:51][ 60002][I][Z2S_Gateway.ino:1133] loop():
[20:00:51]Local Time Cluster Time status attribute 2
[20:00:51]UTC time attribute 829425651
[20:00:51]local time attribute 829425651
[20:00:51][ 60004][I][z2s_web_gui.cpp:1081] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 8388608 B <b>| <i>Free Sketch Space:</b></i> 3407872 B<br><b><i>HeapSize:</b></i> 357004 B <b>| <i>FreeHeap:</b></i> 92228 B <b>| <i>MinimalFreeHeap:</b></i> 47080 B <b>| <i>MaxAllocHeap:</b></i> 69620 B<br><b><i>uxTaskGetStackHighWaterMark:</b></i> 2940 B <br><b><i>Total PSRAM:</b></i> 0 B <b>| <i>Free PSRAM:</b></i> 0 B<br><br><b><i>Local time:</i></b> Mon Apr 13 20:00:51 2026
[20:00:51]<b><i>Supla uptime:</i></b> 60 s
[20:00:52][ 60465][I][ZigbeeCore.cpp:475] esp_zb_app_signal_handler(): Device 0xc2a7 authorized (status: 0, type: 0)
[20:00:52][ 61296][V][ZigbeeCore.cpp:503] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[20:00:53][ 61830][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:00:53][ 61831][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
[20:00:53]APSDE INDICATION - src_addr_mode: 1, cluster_id: 0x0013, asdu_length: 12
[20:00:53]APSDE INDICATION - dst_short_addr: 0xfffd, src_short_addr: 0x9c01
[20:00:53]APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 51, rx_time: 0
[20:00:53][ 61833][I][ZigbeeCore.cpp:390] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9c01)
[20:00:53][ 61833][V][ZigbeeCore.cpp:394] esp_zb_app_signal_handler(): Device capabilities: 0x80
[20:00:53][ 61834][I][z2s_devices_table.cpp:6601] Z2S_onBTCBoundDevice(): BTC bound device A4:C1:38:1C:32:F0:C5:91 (0x9c01) on endpoint(0x0), cluster id(0x0)
[20:00:53][ 61834][I][z2s_devices_table.cpp:6610] Z2S_onBTCBoundDevice(): zb_device_slot 255
[20:00:53][ 61835][I][z2s_devices_table.cpp:6614] Z2S_onBTCBoundDevice(): No ZbDevice - full registration required
[20:00:53][ 62345][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:00:53][ 62345][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
[20:00:53]APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8006, asdu_length: 6
[20:00:53]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x9c01
[20:00:54]APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 51, rx_time: 0
[20:00:54][ 62347][D][ZigbeeGateway.cpp:489] find_Cb(): BASIC cluster found: short address(0x9c01), endpoint(1)
[20:00:54][ 62349][I][Z2S_Gateway.ino:406] disableZ2SNotifications(): disabling Zigbee Gateway notifications
[20:00:54][ 62350][I][ZigbeeGateway.cpp:1094] printJoinedDevices(): joined devices:
[20:00:54][ 62351][I][ZigbeeGateway.cpp:1097] printJoinedDevices(): Device on endpoint 1, short address: 0x9c01
[20:00:54][ 62351][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[20:00:54][ 62352][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[20:00:54][ 62353][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[20:00:54][ 62353][I][ZigbeeGateway.cpp:631] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[20:00:54][ 62569][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:00:54][ 62570][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[20:00:54]APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 14
[20:00:54]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x9c01
[20:00:54]APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 51, rx_time: 0
[20:00:54][ 62572][I][ZigbeeHandlers.cpp:246] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[20:00:54][ 62572][I][ZigbeeHandlers.cpp:249] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:00:54][ 62572][I][ZigbeeHandlers.cpp:253] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[20:00:54][ 62573][I][ZigbeeHandlers.cpp:257] zb_raw_cmd_handler(): manuf_specific 0x0
[20:00:54][ 62573][I][ZigbeeHandlers.cpp:261] zb_raw_cmd_handler(): RAW bufid: 21 size: 11
[20:00:54][ 62574][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x04
[20:00:54][ 62574][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[20:00:54][ 62575][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x42
[20:00:54][ 62575][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x06
[20:00:54][ 62575][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x53
[20:00:54][ 62576][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6F
[20:00:54][ 62576][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6E
[20:00:54][ 62577][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x66
[20:00:54][ 62577][I][ZigbeeHandlers.cpp:274] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x9c01, 0x9c01, 0x0, 0x0
[20:00:54][ 62578][I][ZigbeeHandlers.cpp:301] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[20:00:54][ 62578][I][ZigbeeHandlers.cpp:89] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:00:54][ 62579][V][ZigbeeHandlers.cpp:374] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9c01) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:00:54][ 62580][V][ZigbeeHandlers.cpp:382] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[20:00:54][ 62580][I][ZigbeeGateway.cpp:705] zbReadBasicCluster(): Peer Manufacturer is "Sonoff"
[20:00:54][ 63036][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:00:54][ 63036][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
[20:00:54]APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0002, asdu_length: 3
[20:00:54]APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 10, rx_time: 0
[20:00:54][ 63354][I][ZigbeeGateway.cpp:637] zbQueryDeviceBasicCluster(): basic tsn 0x0
[20:00:54][ 63354][I][ZigbeeGateway.cpp:631] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[20:00:55][ 63828][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:00:55][ 63828][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[20:00:55]APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 18
[20:00:55]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x9c01
[20:00:55]APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 5, rx_time: 0
[20:00:55][ 63830][I][ZigbeeHandlers.cpp:246] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[20:00:55][ 63830][I][ZigbeeHandlers.cpp:249] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[20:00:55][ 63831][I][ZigbeeHandlers.cpp:253] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[20:00:55][ 63832][I][ZigbeeHandlers.cpp:257] zb_raw_cmd_handler(): manuf_specific 0x0
[20:00:55][ 63832][I][ZigbeeHandlers.cpp:261] zb_raw_cmd_handler(): RAW bufid: 6 size: 15
[20:00:55][ 63832][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x05
[20:00:55][ 63833][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[20:00:55][ 63833][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x42
[20:00:55][ 63834][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x0A
[20:00:55][ 63834][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x5A
[20:00:55][ 63834][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x47
[20:00:55][ 63835][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x2D
[20:00:55][ 63835][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x32
[20:00:55][ 63835][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x30
[20:00:55][ 63836][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x34
[20:00:55][ 63836][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x5A
[20:00:55][ 63837][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x4C
[20:00:55][ 63837][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x2D
[20:00:55][ 63837][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x7A
[20:00:55][ 63838][I][ZigbeeHandlers.cpp:274] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x9c01, 0x9c01, 0x0, 0x0
[20:00:55][ 63838][I][ZigbeeHandlers.cpp:301] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[20:00:55][ 63839][I][ZigbeeHandlers.cpp:89] zb_action_handler(): Receive Zigbee action(0x1000) callback
[20:00:55][ 63839][V][ZigbeeHandlers.cpp:374] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9c01) src endpoint(1) to dst endpoint(1) cluster(0x0)
[20:00:55][ 63840][V][ZigbeeHandlers.cpp:382] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(10)
[20:00:55][ 63841][I][ZigbeeGateway.cpp:715] zbReadBasicCluster(): Peer Model is "ZG-204ZL-z"
[20:00:55][ 64356][I][ZigbeeGateway.cpp:637] zbQueryDeviceBasicCluster(): basic tsn 0x1
[20:00:55][ 64356][I][Z2S_Gateway.ino:1345] loop(): sizeof(Z2S_DEVICES_LIST) = 28204
[20:00:56][ 64358][D][Z2S_Gateway.ino:2079] loop(): Unknown model Sonoff::ZG-204ZL-z, no binding is possible
[20:00:56][ 64359][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[20:00:56][ 64360][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[20:00:56][ 64361][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[20:00:57][ 65362][I][Z2S_Gateway.ino:360] enableZ2SNotifications(): enabling Zigbee Gateway notifications
[20:00:58]Send: [53 55 50 4C 41 1C 0F 00 00 00 28 00 00 00 10 00 00 00 7A 4B DD 69 00 00 00 00 D1 C6 04 00 00 00 00 00 ]
[20:00:58]Send: [53 55 50 4C 41 ]
[20:00:58]Recv: [53 55 50 4C 41 1C 0F 00 00 00 32 00 00 00 10 00 00 00 5A 2F DD 69 00 00 00 00 D2 11 0A 00 00 00 00 00 53 55 50 4C 41 ]
[20:00:59][ 68030][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:00:59][ 68031][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
[20:00:59]APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0002, asdu_length: 3
[20:00:59]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x9c01
[20:00:59]APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 5, rx_time: 0
[20:01:00][ 68836][I][ZigbeeCore.cpp:475] esp_zb_app_signal_handler(): Device 0x9c01 authorized (status: 0, type: 1)
[20:01:01][ 69407][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[20:01:01][ 69408][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
[20:01:01]APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0036, asdu_length: 3
[20:01:01]APSDE INDICATION - dst_short_addr: 0xfffc, src_short_addr: 0x9c01
[20:01:01]APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 10, rx_time: 0
[20:01:01][ 69410][I][ZigbeeCore.cpp:447] esp_zb_app_signal_handler(): Network(0x6186) is open for 180 seconds
[20:01:01][ 69410][I][ZigbeeCore.cpp:450] esp_zb_app_signal_handler(): channel 20
[20:01:01][ 69411][I][Z2S_Gateway.ino:324] Z2S_onOpenNetwork(): Network open for 180 s
[20:01:01][ 69411][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[20:01:01][ 69412][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[20:01:01][ 69412][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[20:01:01][ 69414][I][Z2S_local_action_handlers.cpp:292] handleAction(): &&&&&&&&&&&&&&&&&&&&&&&&&&event 16417, action 0
[20:01:02]
Serial port closed!
Jaroni
Has thanked: 3 times
Been thanked: 4 times
RomanG wrote: Tue Apr 14, 2026 2:03 pm Akurat mam pod ręką Putty; musisz sprawdzić pod jaki port podłączona jest bramka, z której zbierasz logi. W Putty wpisujesz ten numer "com" i przyciskiem "Open" "odpalasz" zapis z tego portu. Otworzy się okno w którym widzisz wszystko. Po zakończeniu np. parowania zaznaczasz i kopiujesz wszystko, później wklejasz np. do notatnika lub worda i udostępniasz to tutaj Mistrzowi :) Łukaszowi.
Chyba niczego "na szybko" nie pominąłem. :D
Powodzenia!
Dzięki RomanG. Tracę cierpliwość, u mnie programy się zawieszają, Putty też nie odpala, długo czekam i error
PuTTY Error
Unable to open connetion to COM5
Configuring serial port: Error 121: Przekroczono limit czasu semafora.
Tera Term jakoś odpalał, raz nawet udało mi się zebrać log po porcie w płytce USB i wyeksportowałem go ale chyba nie kompletny się zapisał, wtedy wybierał automatycznie COM5, teraz się zawiesza, więc podłączyłem USB-C pod UART, pokazał tym razem COM3 i wygenerował tylko krótki log, który prosto z terminala skopiowałem do notatnika. Oba w załączeniu.
Czujnik niby poprawnie sparowany, ale transmisja Zigbee nie działa, nie wyświetla parametrów i daty.
Logi.rar
Zaraz chyba jeszcze wrzucę loga z Putty, bo jak podłączyłem płytkę pod UART, to mi się konsola odpala. Spróbuję jeszcze raz sparować czujnik i wygenerować log.
Edit:
W Putty też wygenerowałem z parowania czujnika (po UART) tylko taki krótki log. Czujnik sparowany, a nie działa transmisja Zigbee.
Putty log.rar
Has thanked: 291 times
Been thanked: 161 times
Jaroni wrote: Tue Apr 14, 2026 6:01 pm
Powodzenia!
PuTTY Error
Logi.rar
Edit:
Putty log.rar
Wypróbuj 1.5.8-14/04/26
zzrr
Has thanked: 76 times
Been thanked: 119 times
@vajera a coś zdradzisz w tym temacie viewtopic.php?p=234111#p234111
Umknęło? Czeka w kolejce? A może coś tam się już z tym dzieje? Bo nawet tak się zacząłem zastanawiać że może jakieś dane podałem niewłaściwie i odpadło z listy. Hmm.
zzrr wrote: Tue Apr 14, 2026 7:20 pm @vajera a coś zdradzisz w tym temacie viewtopic.php?p=234111#p234111
Pamiętam o tym, ale o ile poprzednie urządzenia dodałem na zasadzie nowe ID, to w przypadku Twojego potrzebuję trochę więcej czasu, więc zajmę się tym w najbliższych dniach.
zzrr
Super. Taka opcja tez mi przeszła przez myśl. Ale jestem spokojniejszy. Dzięki👍
zzrr
@vajera jeszcze tak sobie myślę...
Bo jak to jest jakis niestandardowy temat a chyba jest, bo z tuya np. wogóle to nie współpracuje to jeśli by to miało lub mogło pomóc to jestem w razie czego gotowy Ci to wysłać a później na mój koszt zrobimy w drugą stronę. W razie jeśli tak zechcesz to po mojej stronie żaden problem.
zzrr wrote: Tue Apr 14, 2026 7:37 pm @vajera jeszcze tak sobie myślę...
Raczej dam radę, to jest Develco - kiedyś @klew zrobił mi challenge urządzeniami tej firmy i musiał mi wysłać swoje zabawki, ale dzięki temu mam już doświadczenie z tą marką.
zzrr
vajera wrote: Tue Apr 14, 2026 7:48 pm
Aha. Spoko. :) W razie czego masz bufor w postaci mojej propozycji.
Jaroni
vajera wrote: Tue Apr 14, 2026 6:49 pm Wypróbuj 1.5.8-14/04/26
Nic z tego, urządzenie dodane, ale transmisja Zigbee nie działa.
Tu log z parowania
ESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:2
load:0x40875730,len:0x12e0
load:0x4086b910,len:0xdc8
load:0x4086e610,len:0x3180
entry 0x4086b910
Build:Sep 19 2022
rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x4001975a
SPIWP:0xee
entry 0x4086b910
NLME Status Indication, status: 0x6
Return to “Bramka ZigBee”
