Brak pamieci ikon w aplikacji supla
elmaya
rozwiązany
#include <FS.h>
#include <ShiftRegister74HC595.h>   //https://github.com/Simsso/ShiftRegister74HC595
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
// create shift register object (number of shift registers, data pin 14 on 74595, clock pin 11 on 74595, latch pin 12 on 74595)
ShiftRegister74HC595 sr (2, 15, 16, 0);
#include <math.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <DoubleResetDetector.h>
#define DRD_TIMEOUT 30 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
#define DRD_ADDRESS 0 // RTC Memory Address for the DoubleResetDetector to use
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
bool eep = LOW;          //             ---------------- Eeprom ------------------
bool startEeprom = true; //             ---------------- Eeprom ------------------
int epr = 0;             //             ----------- Eepron read loops ------------
int s;                   //             ---------------- Status ------------------
unsigned long svr_update = 1800000; //mean time between update  30 minutes
unsigned long svr_update_lasttime;   //last time update
unsigned long wifi_checkDelay = 60000;  // wifi reconect delay
unsigned long wifimilis;
#define BEGIN_PIN 100
unsigned int Rs = 100000;
double Vcc = 3.3;
#define BTN_COUNT 16
WiFiClient client;
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char Supla_server[40];
char Location_id[15];
char Location_Pass[20];
byte mac[6];
//flag for saving data
bool initialConfig = false;
int timeout           = 120; // seconds to run for wifi config
void saveConfigCallback () {                 //callback notifying us of the need to save config
  shouldSaveConfig = true;
// The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  //add all your parameters here
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wifiManager.setMinimumSignalQuality();
  // set configportal timeout
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla 595")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      //reset and try again, or maybe put it to deep sleep
      ESP.restart();
      delay(5000);
    //if you get here you have connected to the WiFi
    Serial.println("connected...yeey :)");
    //read updated parameters
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
double get_temperature(int channelNumber, double last_val) {  // 10k Ntc Adc to Gnd and 100k Resistor Adc to +3,3v
      int val = 0;
      for(int i = 0; i < 10; i++) {
      val += analogRead(A0);
      delay(1);
      val = val / 10;
      double V_NTC = (double)val / 1023;
      double R_NTC = (Rs * V_NTC) / (Vcc - V_NTC);
      R_NTC = log(R_NTC);
      double t = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * R_NTC * R_NTC ))* R_NTC );
      t = t - 273.15;
           Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
                             //        ---- this happens every few seconds
      return t;
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_timer() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           if (v==0)
              if ( btn[a].ms > 0 ) {
                     SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( (btn[a].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
        pinMode(btn[a].pin, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin);
        btn[a].last_time = millis();
int supla_DigitalRead(int channelNumber, uint8_t pin) {
      if (channelNumber == 0){
        if (btn[0].mem ==0) return 0;
        else return 1;
      if (channelNumber == 1){
        if (btn[1].mem ==0) return 0;
        else return 1;
      if (channelNumber == 2){
        if (btn[2].mem ==0) return 0;
        else return 1;
      if (channelNumber == 3){
        if (btn[3].mem ==0) return 0;
        else return 1;
      if (channelNumber == 4){
        if (btn[4].mem ==0) return 0;
        else return 1;
      if (channelNumber == 5){
        if (btn[5].mem ==0) return 0;
        else return 1;
      if (channelNumber == 6){
        if (btn[6].mem ==0) return 0;
        else return 1;
      if (channelNumber == 7){
        if (btn[7].mem ==0) return 0;
        else return 1;
      if (channelNumber == 8){
        if (btn[8].mem ==0) return 0;
        else return 1;
      if (channelNumber == 9){
        if (btn[9].mem ==0) return 0;
        else return 1;
      if (channelNumber == 10){
        if (btn[10].mem ==0) return 0;
        else return 1;
      if (channelNumber == 11){
        if (btn[11].mem ==0) return 0;
        else return 1;
      if (channelNumber == 12){
        if (btn[12].mem ==0) return 0;
        else return 1;
      if (channelNumber == 13){
        if (btn[13].mem ==0) return 0;
        else return 1;
      if (channelNumber == 14){
        if (btn[14].mem ==0) return 0;
        else return 1;
      if (channelNumber == 15){
        if (btn[15].mem ==0) return 0;
        else return 1;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {  //------------------------------------------------  Virtual ----------------------------
       btn[0].mem =val;
       sr.set(0, val); // set single pin
       btn[1].mem =val;
       sr.set(1, val); // set single pin
       btn[2].mem =val;
       sr.set(2, val); // set single pin
       btn[3].mem =val;
       sr.set(3, val); // set single pin
       btn[4].mem =val;
       sr.set(4, val); // set single pin
       btn[5].mem =val;
       sr.set(5, val); // set single pin
       btn[6].mem =val;
       sr.set(6, val); // set single pin
       btn[7].mem =val;
       sr.set(7, val); // set single pin
       btn[8].mem =val;
       sr.set(8, val); // set single pin
       btn[9].mem =val;
       sr.set(9, val); // set single pin
       btn[10].mem =val;
       sr.set(10, val); // set single pin
       btn[11].mem =val;
       sr.set(11, val); // set single pin
       btn[12].mem =val;
       sr.set(12, val); // set single pin
       btn[13].mem =val;
       sr.set(13, val); // set single pin
       btn[14].mem =val;
       sr.set(14, val); // set single pin
       btn[15].mem =val;
       sr.set(15, val); // set single pin
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
    if (startEeprom == true){             // ----- don't change memorized state until connected and restored all the channels
      return;
      for(int i=0;i<BTN_COUNT;i++) {  //  ---check relay except it have delay (staircase)
         if ( btn[i].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[i].mem);                    //  --- read relay state
        if (eep != EEPROM.read(i)){            //  --- compare relay state with memorized state
         EEPROM.write(i,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(i);
         Serial.print(" write.");
         Serial.println((eep));
         Serial.print(" channel ");
         Serial.println((btn[i].channel));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
   // for(int i=0;i<BTN_COUNT;i++){      //  ---check relay except der have delay (staircase)
     //if ( (btn[i].ms) > 0 ) {
                //     continue;
        // } else {
        eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
        if (eep == HIGH){                    //  --- if 1 send relay on
          SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
    if (epr == (BTN_COUNT-1)) {
      startEeprom = false;                //  --- once finished we do not need more
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  Serial.begin(115200);
  EEPROM.begin(512);
   if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    ondemandwifiCallback ();
  } else {
    Serial.println("No Double Reset Detected");
  if (WiFi.SSID()==""){
    //Serial.println("We haven't got any access point credentials, so get them now");
    initialConfig = true;
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        // Allocate a buffer to store contents of the file.
        DynamicJsonBuffer jsonBuffer;
        //json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
   uint8_t mac[WL_MAC_ADDR_LENGTH];
  WiFi.macAddress(mac);
  char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6],
                                mac[WL_MAC_ADDR_LENGTH - 5],
                                mac[WL_MAC_ADDR_LENGTH - 4],
                                mac[WL_MAC_ADDR_LENGTH - 3],
                                mac[WL_MAC_ADDR_LENGTH - 2],
                                mac[WL_MAC_ADDR_LENGTH - 1]};
  SuplaDevice.addRelay(101, false);
  SuplaDevice.addRelay(102, false);
  SuplaDevice.addRelay(103, false);
  SuplaDevice.addRelay(104, false);
  SuplaDevice.addRelay(105, false);
  SuplaDevice.addRelay(106, false);
  SuplaDevice.addRelay(107, false);
  SuplaDevice.addRelay(108, false);
  SuplaDevice.addRelay(109, false);
  SuplaDevice.addRelay(110, false);
  SuplaDevice.addRelay(111, false);
  SuplaDevice.addRelay(112, false);
  SuplaDevice.addRelay(113, false);
  SuplaDevice.addRelay(114, false);
  SuplaDevice.addRelay(115, false);
  SuplaDevice.addRelay(116, false);
  // CHANNEL8 - Thermometer DS18B20
  memset(btn, 0, sizeof(btn));
  btn[0].pin =5;          // pin gpio buton  0 = no buton
  btn[0].relay_pin =101;  // pin gpio Relay
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =4;          // pin gpio buton  0 = no buton
  btn[1].relay_pin =102;  // pin gpio Relay
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =2;          // pin gpio buton  0 = no buton
  btn[2].relay_pin =103;  // pin gpio Relay
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  btn[3].pin =14;         // pin gpio buton  0 = no buton
  btn[3].relay_pin =104;  // pin gpio Relay
  btn[3].channel =3;      // channel
  btn[3].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[3].mem =0;
  btn[4].pin =12;         // pin gpio buton  0 = no buton
  btn[4].relay_pin =105;  // pin gpio Relay
  btn[4].channel =4;      // channel
  btn[4].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[4].mem =0;
  btn[5].pin =13;         // pin gpio buton  0 = no buton
  btn[5].relay_pin =106;  // pin gpio Relay
  btn[5].channel =5;      // channel
  btn[5].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[5].mem =0;
  btn[6].pin =3;         // pin gpio buton  0 = no buton
  btn[6].relay_pin =107;    // pin gpio Relay
  btn[6].channel =6;      // channel
  btn[6].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[6].mem =0;
  btn[7].pin =1;          // pin gpio buton  0 = no buton
  btn[7].relay_pin =108;  // pin gpio Relay
  btn[7].channel =7;      // channel
  btn[7].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[7].mem =0;
  btn[8].pin =22;          // pin gpio buton  0 = no buton
  btn[8].relay_pin =109;  // pin gpio Relay
  btn[8].channel =8;      // channel
  btn[8].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[8].mem =0;
  btn[9].pin =22;          // pin gpio buton  0 = no buton
  btn[9].relay_pin =110;  // pin gpio Relay
  btn[9].channel =9;      // channel
  btn[9].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[9].mem =0;
  btn[10].pin =22;          // pin gpio buton  0 = no buton
  btn[10].relay_pin =111;  // pin gpio Relay
  btn[10].channel =10;      // channel
  btn[10].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[10].mem =0;
  btn[11].pin =22;         // pin gpio buton  0 = no buton
  btn[11].relay_pin =112;  // pin gpio Relay
  btn[11].channel =11;      // channel
  btn[11].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[11].mem =0;
  btn[12].pin =22;         // pin gpio buton  0 = no buton
  btn[12].relay_pin =113;  // pin gpio Relay
  btn[12].channel =12;      // channel
  btn[12].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[12].mem =0;
  btn[13].pin =22;         // pin gpio buton  0 = no buton
  btn[13].relay_pin =114;  // pin gpio Relay
  btn[13].channel =13;      // channel
  btn[13].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[13].mem =0;
  btn[14].pin =22;         // pin gpio buton  0 = no buton
  btn[14].relay_pin =115;    // pin gpio Relay
  btn[14].channel =14;      // channel
  btn[14].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[14].mem =0;
  btn[15].pin =22;          // pin gpio buton  0 = no buton
  btn[15].relay_pin =116;  // pin gpio Relay
  btn[15].channel =15;      // channel
  btn[15].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[15].mem =0;
  supla_btn_init();
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);    //            ------Send Value to server -------
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);   //        -------  Read Value from server   -------
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);    //   ----------------------------- Status -----------------------------
  SuplaDevice.setName("Supla 8x16");
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
// read_initial_relay_state();
                     continue;
         } else {
        eep = EEPROM.read(i);               //  ---read relay state
         Serial.print("Recover.");
         Serial.print(i);
       // if (eep == HIGH){                    //  --- if 1 send relay on
          sr.set(btn[i].channel, eep); // set single pin
          //SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
void loop() {
  // Call the double reset detector loop method every so often,
  // so that it can recognise when the timeout expires.
  // You can also call drd.stop() when you wish to no longer
  // consider the next reset as a double reset.
  drd.loop();
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    //end save
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
  SuplaDevice.iterate();
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
  case 17:      // -----     STATUS_REGISTERED_AND_READY
  if (epr<BTN_COUNT){
  Serial.print("Eepron_read...");
  Serial.println(epr);
   Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
   epr = epr+1;                   // -------- 1 loop for each output 8 in total ----------
  if (millis() > svr_update_lasttime + svr_update)  {
    epr = 0 ;
     startEeprom = true;
      Serial.println("svr update");
            svr_update_lasttime = millis();
    break;
    case 9:      // --------------------- DISCONNECTED  ----------------------
    svr_update = 5000;
    break;
    case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    svr_update = 5000;
    break;
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       WiFi_up();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = &get_temperature;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up() // conect to wifi
  if (millis() > wifimilis)  {
  WiFi.begin();
  for (int x = 10; x > 0; x--)
    if (x == 1){
    wifimilis = (millis() + wifi_checkDelay) ;
    if (WiFi.status() == WL_CONNECTED)
     return; // break;
    else
     yield();
     delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
  else
    Serial.println("");
    Serial.println("not connected");
8 x przycisk ,16 x relay , pamięć statusu
shimano73
No ładne , ładne , z tak dużymi ilościami jest pewien problem, Gdy się wszystko poustawia na serwerze , przypisze wejścia , typ wyjścia wszystko gra , ale gdy zmienimy coś w np dodamy czujnik lub zwiększyli ilość wejść / wyjść pomówienie należy przypisać 8/16 odpowiednich ustawień , Przerabiałem to w swoim ardu mega mając do dyspozycji 32 gpio każdorazowe ustawianie wszystkiego na stronie strasznie denerwowało mnie
dawidd
Wygląda na to ze teraz wszystko gra.
16 przekaźników na 1 eps to już jest wypas :)
Jeszcze dołożyć jakieś DHT22 i będzie bajka :)
elmaya
nie testowane
#include <FS.h>
ShiftRegister74HC595 sr (1, 15, 16, 0);
#include <math.h>
#include <EEPROM.h>
#include <DHT.h>
#include <OneWire.h>
#define DHTPIN 3 // GPIO 3-RX
#define DHTTYPE DHT22
// Setup a DHT instance
DHT dht(DHTPIN, DHTTYPE);
// Setup a oneWire instance
OneWire oneWire(01); // GPIO 01
// Pass oneWire reference to Dallas Temperature
double Vcc = 3.3;
#define BTN_COUNT 8
WiFiClient client;
byte mac[6];
  //WiFiManager
  //defaults to 8%
      delay(3000);
      ESP.restart();
      delay(5000);
    double t = -275;
    if ( sensors.getDeviceCount() > 0 )
         sensors.requestTemperatures();
         t = sensors.getTempCByIndex(0);
    return t;
void get_temperature_and_humidity(int channelNumber, double *temp, double *humidity) {
    *temp = dht.readTemperature();
    *humidity = dht.readHumidity();
    if ( isnan(*temp) || isnan(*humidity) ) {
      *temp = -275;
      *humidity = -1;
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  bool mem;
} _btn_t;
  char v;
           if (v==0)
                 } else {
                 } else {
   if (pin > 100) {
      if (pin == 101){
        else return 1;
      if (pin == 102){
        else return 1;
      if (pin == 103){
        else return 1;
      if (pin == 104){
        else return 1;
      if (pin == 105){
        else return 1;
      if (pin == 106){
        else return 1;
      if (pin == 107){
        else return 1;
      if (pin == 108){
        else return 1;
    return digitalRead(pin);
    if (pin > 100) {
     if (pin == 101){
       btn[0].mem =val;
     if (pin == 102){
       btn[1].mem =val;
     if (pin == 103){
       btn[2].mem =val;
     if (pin == 104){
       btn[3].mem =val;
     if (pin == 105){
       btn[4].mem =val;
     if (pin == 106){
       btn[5].mem =val;
     if (pin == 107){
       btn[6].mem =val;
     if (pin == 108){
       btn[7].mem =val;
  return;
   digitalWrite(pin, val);
      return;
                     continue;
         } else {
         Serial.print(i);
         EEPROM.commit();
                //     continue;
        // } else {
         Serial.print(epr);
  dht.begin(); // Init DHT library
  sensors.begin();// Init DS18B20 library
  EEPROM.begin(512);
  } else {
      if (configFile) {
        } else {
  } else {
  SuplaDevice.addDS18B20Thermometer();// CHANNEL8 - Thermometer DS18B20
  SuplaDevice.addDHT22();             // CHANNEL9 - Thermometer DHT22
  btn[0].mem =0;
  btn[1].mem =0;
  btn[2].mem =0;
  btn[3].mem =0;
  btn[4].mem =0;
  btn[5].mem =0;
  btn[6].pin =22;         // pin gpio buton  0 = no buton
  btn[6].mem =0;
  btn[7].pin =22;          // pin gpio buton  0 = no buton
  btn[7].mem =0;
  supla_btn_init();
  SuplaDevice.setTemperatureHumidityCallback(&get_temperature_and_humidity);// Set temperature/humidity callback
  SuplaDevice.setName("Supla 595");
                     continue;
         } else {
         Serial.print(i);
void loop() {
  drd.loop();
    if (!configFile) {
    configFile.close();
    //end save
    WiFi_up();
  if (epr<BTN_COUNT){
    epr = 0 ;
     startEeprom = true;
    break;
    svr_update = 5000;
    break;
    svr_update = 5000;
    break;
        if ( size > 0 ) {
        return -1;
         client.stop();
       WiFi_up();
          cb.get_temperature_and_humidity = &get_temperature_and_humidity;
          return cb;
  WiFi.begin();
    if (x == 1){
     return; // break;
    else
     yield();
     delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.print(rssi);
  else
    Serial.println("");
6 x przycisk ,8 x relay , pamięć statusu , Dht22=Gpio3 , Ds18B20=Gpio1
dawidd
Działa! :)
DS i dht podciągnąłem rezystorami 4,7kom i zasiliłem z 5V
Bibliotekę dht użyłem 1.20
Nie przerabiałem pliku dht.ccp
Po zerwaniu połączenia z supla oraz dołączeniu zasilania i ponownym podłączeniu pomiary z czujników są od razu
elmaya dziękuje za twoja prace, super moduł poskładałeś, brawo :D
dawidd
Po ponad miesięcznym używaniu kodu z postu wyżej zauważyłem pewne anomalie
Pod przekaźniki mam podpięte miedzy innymi 3 wentylatory i kilka zaworów termoelektrycznych. Co jakiś czas gdy ręcznie włączę np wentylator nr 1 to włączy się tez wentylator nr 2.
Druga rzecz: ikonka w aplikacji supla nie zawsze zmienia się pomimo włączenia lub wyłączenia jakiegoś kanału. Włączę wentylacje w łazience(przez aplikacje supla), silnik zaczyna działać, a w aplikacji ciągle pokazuje ze jest wyłączony. Dopiero drugi raz gdy włączę to ikonka się zmieni
elmaya czy jest na to jakaś rada?
elmaya
gdy wystąpi błąd i włącza się drugi wentylator
Jak jest to widoczne w aplikacji?
on lub off
Ikony zmieniają się czasem po kilku sekundach
dawidd
Ad1 Gdy włączę wentylator 1 i załączy się tez nr 2 to ikonka od wentylatora nr 2 pozostaje na off
Ad2 Sprawdzę czy po kilku sekundach eis zmieni ikonka
Sytuacje takie występują rzadko ale jednak są
elmaya
wydaje się, że iskra wytwarzana przez przekaźnik po podłączeniu zakłóca 74hc595
możliwe rozwiązanie
kabel krótki i ekranowany między esp8266 a 74hc595
74hc595 dalej od przekaźników
kondensator filtrujący na wyjściu przekaźnika
dawidd
tez o tym pomyślałem i dziś zamówieniem przekaźniki ssr, zobaczymy czy bedzie poprawa
Jaki kondensator filtrujący dać? To bym spróbował na przekaźnikach które mam obecnie. Odsunąć 74hc595 tez mogę bo sa one dokładnie nad przekaźnikami
