Stawiam wszystko od nowa ale już na początku jakiś problem (no jak żeby inaczej
pi@raspberrypi:~ $ docker -v && docker-compose -v
Docker version 19.03.6, build 369ce74
Traceback (most recent call last):
File "/usr/local/bin/docker-compose", line 6, in <module>
from compose.cli.main import main
File "/usr/local/lib/python2.7/dist-packages/compose/cli/main.py", line 18, in <module>
import docker.errors
File "/usr/local/lib/python2.7/dist-packages/docker/__init__.py", line 2, in <module>
from .api import APIClient
File "/usr/local/lib/python2.7/dist-packages/docker/api/__init__.py", line 2, in <module>
from .client import APIClient
File "/usr/local/lib/python2.7/dist-packages/docker/api/client.py", line 10, in <module>
from .build import BuildApiMixin
File "/usr/local/lib/python2.7/dist-packages/docker/api/build.py", line 6, in <module>
from .. import auth
File "/usr/local/lib/python2.7/dist-packages/docker/auth.py", line 9, in <module>
from .utils import config
File "/usr/local/lib/python2.7/dist-packages/docker/utils/__init__.py", line 3, in <module>
from .decorators import check_resource, minimum_version, update_headers
File "/usr/local/lib/python2.7/dist-packages/docker/utils/decorators.py", line 4, in <module>
from . import utils
File "/usr/local/lib/python2.7/dist-packages/docker/utils/utils.py", line 13, in <module>
from .. import tls
File "/usr/local/lib/python2.7/dist-packages/docker/tls.py", line 5, in <module>
from .transport import SSLHTTPAdapter
File "/usr/local/lib/python2.7/dist-packages/docker/transport/__init__.py", line 3, in <module>
from .ssladapter import SSLHTTPAdapter
File "/usr/local/lib/python2.7/dist-packages/docker/transport/ssladapter.py", line 23, in <module>
from backports.ssl_match_hostname import match_hostname
ImportError: No module named ssl_match_hostname
lesny8 narazie nie odpowiada, a że mam chwile to może ruszył bym z tym dziś dalej. Ktoś wie o co może chodzić.
