Cześć,
wygenerowalem certyfikat i podmieniłem go w podfolderze /ssl/cloud i /ssl/server (podmieniam w obu?).
Po restarcie i wpisaniu adresu przeglądarka widzi certyfikat, ale traktuje go nadal jako nieważny/nie zaufany.
W HA bez zmian:
2020-05-29 22:49:40 ERROR (SyncWorker_15) [homeassistant.components.supla] Server: 192.168.1.130 not configured. Error on Supla API access:
traceback (most recent call last):
File "/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 488, in wrap_socket
cnx.do_handshake()
File "/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1934, in do_handshake
self._raise_ssl_error(self._ssl, result)
File "/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1671, in _raise_ssl_error
_raise_current_error()
File "/usr/local/lib/python3.7/site-packages/OpenSSL/_util.py", line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 976, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 370, in connect
ssl_context=context,
File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 390, in ssl_wrap_socket
return context.wrap_socket(sock)
File "/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 494, in wrap_socket
raise ssl.SSLError("bad handshake: %r" % e)
ssl.SSLError: ("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')])",)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.130', port=443): Max retries exceeded with url: /api/v2.3.0/server-info (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')])")))
Co robię źle?
Wezmę udział w Supla Offline Party 2023. Weź udział i Ty.
