Tego też nie mabokk wrote: Sat Oct 25, 2025 10:21 am Proszę o dodanie MiBoxer ZL5
Unknown model _TZB210_jogusbq1::TS0505B, no binding is possible
- Has thanked: 289 times
- Been thanked: 161 times
A co to jest? Jakiś opis by się przydał
Przepraszam, umknęło mi. Kontroler LED ZigBee 3.0 + 2.4G ZL5 jest dedykowany do obsługi źródeł światła RGB+CCT, RGBW, RGB, CCT, MONO.
Coś w tym stylu: https://www.zigbee2mqtt.io/devices/SZ5.html
zokopian
Log z parowania:vajera wrote: Sat Oct 25, 2025 2:24 pmMożesz wrzucić, skoro zapisałeś - danych do analizy nigdy dosyć.
[ 31559][V][ZigbeeCore.cpp:264] openNetwork(): Opening network for joining for 0 seconds
[ 32029][I][ZigbeeCore.cpp:432] esp_zb_app_signal_handler(): Network(0xecf5) closed, devices joining not allowed.
[ 32030][I][Z2S_Gateway.ino:223] Z2S_onOpenNetwork(): Network closed
[ 32030][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[ 32030][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 32031][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[ 32172][V][ZigbeeCore.cpp:264] openNetwork(): Opening network for joining for 180 seconds
[ 32642][I][ZigbeeCore.cpp:427] esp_zb_app_signal_handler(): Network(0xecf5) is open for 180 seconds
[ 32643][I][Z2S_Gateway.ino:216] Z2S_onOpenNetwork(): Network open for 180 s
[ 32643][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[ 32643][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 32644][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
Send: [53 55 50 4C 41 17 0D 00 00 00 28 00 00 00 10 00 00 00 EC ED FC 68 00 00 00 00 1A 3F 01 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 0D 00 00 00 32 00 00 00 10 00 00 00 CD D1 FC 68 00 00 00 00 94 80 01 00 00 00 00 00 53 55 50 4C 41 ]
[ 56934][V][ZigbeeCore.cpp:472] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 57184][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 57185][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 244, cluster_id: 0x0013, asdu_length: 12
APSDE INDICATION - dst_short_addr: 0xfffd, src_short_addr: 0xdbf4
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 96, rx_time: 0
[ 57186][I][ZigbeeCore.cpp:370] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xdbf4)
[ 57187][V][ZigbeeCore.cpp:374] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 57240][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 57240][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8006, asdu_length: 5
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xdbf4
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 102, rx_time: 0
[ 57242][D][ZigbeeGateway.cpp:353] find_Cb(): Broadcast short address returned - trying to retour
short address(0xdbf4), endpoint(255)
[ 57245][I][ZigbeeGateway.cpp:899] printJoinedDevices(): joined devices:
[ 57245][I][ZigbeeGateway.cpp:902] printJoinedDevices(): Device on endpoint 255, short address: 0xdbf4
[ 57246][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
[ 57248][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 57248][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
[ 57249][I][ZigbeeGateway.cpp:501] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 57301][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 57302][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 3, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 13
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 96, rx_time: 0
[ 57303][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[ 57304][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x3, dst endpoint 0x1
[ 57304][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 57305][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 57306][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 12 size: 10
[ 57306][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[ 57306][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 57307][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 57307][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x42
[ 57307][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x05
[ 57308][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4F
[ 57308][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x53
[ 57308][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x52
[ 57308][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x41
[ 57309][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4D
[ 57309][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xdbf4, 0xdbf4, 0x0, 0x0
[ 57310][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 57311][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 57311][V][ZigbeeHandlers.cpp:262] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xdbf4) src endpoint(3) to dst endpoint(1) cluster(0x0)
[ 57312][V][ZigbeeHandlers.cpp:270] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(5)
[ 57312][I][ZigbeeGateway.cpp:555] zbReadBasicCluster(): Peer Manufacturer is "OSRAM"
[ 58250][I][ZigbeeGateway.cpp:507] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 58250][I][ZigbeeGateway.cpp:501] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 58296][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 58297][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 3, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 15
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 117, rx_time: 0
[ 58299][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[ 58299][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x3, dst endpoint 0x1
[ 58299][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 58300][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 58300][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 16 size: 12
[ 58301][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x05
[ 58301][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 58302][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x42
[ 58302][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[ 58302][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x50
[ 58303][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6C
[ 58303][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x75
[ 58303][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x67
[ 58304][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 58304][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x30
[ 58304][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[ 58305][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xdbf4, 0xdbf4, 0x0, 0x0
[ 58305][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 58306][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 58307][V][ZigbeeHandlers.cpp:262] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xdbf4) src endpoint(3) to dst endpoint(1) cluster(0x0)
[ 58307][V][ZigbeeHandlers.cpp:270] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[ 58308][I][ZigbeeGateway.cpp:565] zbReadBasicCluster(): Peer Model is "Plug 01"
[ 59251][I][ZigbeeGateway.cpp:507] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 59251][I][Z2S_Gateway.ino:1009] loop(): LIST matched OSRAM::Plug 01, entry # 133, endpoints # 2, endpoints 0x3::0x4001,0x1::0x0,0x0::0x0,0x0::0x0
[ 59252][I][Z2S_Gateway.ino:1037] loop(): DESC matched 0x4001, 1, 0x6, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x3
[ 59253][D][ZigbeeGateway.cpp:655] bindDeviceCluster(): Requesting ZED (0xdbf4), endpoint (0x3), cluster_id (0x6) to bind ZC
[ 59334][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 59335][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8021, asdu_length: 2
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 132, rx_time: 0
[ 59336][I][ZigbeeGateway.cpp:315] bindCb(): ZED (0xdbf4), endpoint (0x3) cluster (0x6) has bounded to ZC
[ 59337][I][ZigbeeGateway.cpp:332] bindCb(): Semaphore give in binding
[ 59454][D][ZigbeeGateway.cpp:716] bindDeviceCluster(): Requesting ZC to bind ZED (0xdbf4), endpoint (0x3), cluster_id (0x6)
[ 59455][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 59456][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0021, asdu_length: 22
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x0000
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 0, rx_time: 0
[ 59459][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 59460][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
[ 59462][I][ZigbeeGateway.cpp:312] bindCb(): ZC has bounded to ZED (0xdbf4), endpoint (0x3) cluster (0x6)
[ 59462][I][ZigbeeGateway.cpp:332] bindCb(): Semaphore give in binding
[ 59663][I][z2s_devices_table.cpp:719] Z2S_addZbDeviceTableSlot(): New ZB device - adding to the ZB devices table
[ 59664][I][z2s_devices_table.cpp:696] Z2S_updateZbDeviceUidIdx(): Manufacturer name: OSRAM, model name: Plug 01, device uid = 10605, devices list index = 133
[ 59665][D][z2s_little_fs.cpp:25] Z2S_saveFile(): Z2S LittleFs: saving file zb_devices_table_v2.z2s
[ 59739][I][z2s_devices_table.cpp:1120] Z2S_saveZbDevicesTable(): Zigbee devices table new size(3840) write success!
LittleFsConfig: writing to file "/supla-dev.cfg"
LittleFsConfig: writing to file "/supla-dev.cfg.bak"
[ 59758][I][z2s_devices_table.cpp:157] Z2S_findChannelNumberSlot(): 7C:B0:3E:AA:00:A3:90:EB, endpoint 0x3, channel type 0xffffffff
[ 59758][I][z2s_devices_table.cpp:3966] Z2S_addZ2SDevice(): No channel found for address 7C:B0:3E:AA:00:A3:90:EB, adding new one!
[ 59759][I][z2s_devices_table.cpp:3975] Z2S_addZ2SDevice(): model id 16385, first free slot 0
Channel[0] initial caption set to 'POWER SWITCH'
[ 59760][D][z2s_little_fs.cpp:25] Z2S_saveFile(): Z2S LittleFs: saving file channels_table_v2.z2s
[ 60021][D][z2s_little_fs.cpp:25] Z2S_saveFile(): Z2S LittleFs: saving file channels_table_v2.bak
[ 60280][I][z2s_devices_table.cpp:559] Z2S_saveChannelsTable(): Channels table new size(15360) write success!
[ 60306][I][Z2S_Gateway.ino:1037] loop(): DESC matched 0x0, 0, 0xffff, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x1
[ 60307][I][z2s_devices_table.cpp:157] Z2S_findChannelNumberSlot(): 7C:B0:3E:AA:00:A3:90:EB, endpoint 0x1, channel type 0xffffffff
[ 60308][I][z2s_devices_table.cpp:3966] Z2S_addZ2SDevice(): No channel found for address 7C:B0:3E:AA:00:A3:90:EB, adding new one!
[ 60309][I][z2s_devices_table.cpp:3975] Z2S_addZ2SDevice(): model id 0, first free slot 1
[ 60309][I][ZigbeeGateway.cpp:1903] sendAttributeWrite(): Sending 'write attribute' command - id (0x4003), type (0x30), size (0x1), value (0xff)
[ 60510][I][ZigbeeGateway.cpp:1903] sendAttributeWrite(): Sending 'write attribute' command - id (0x8002), type (0x30), size (0x1), value (0x2)
[ 60912][I][ZigbeeGateway.cpp:1615] setClusterReporting(): _set_config_last_tsn = 4
[ 61112][I][ZigbeeGateway.cpp:1622] setClusterReporting(): _set_config_last_tsn_flag = 2
Scheduling soft restart in 5000 ms
LAST STATE ADDED: Software reset (57)8x SRW-01, 1x SBW-01, 1x MEW-01,
10x TH 10, 7x Touch, 1x SV, 1x Basic R2,
2x S26, 4x mini, 2x POW R2, 1x S55,
3x Shelly 1, 1x nodemcu + BME 280,
2x H801. 4x Nous a1, 4x SP111, 2x NEO
1x MoesHouse, 2x SMTONOFF SMT002
1x Sonoff POW R3 25A
Dziękuję bardzo, urządzenie zarejestrowało się w bramce 4 kanały: Włącznik światła, Ściemniacz, Ściemniacz i Oświetlenie RGB.
Wojt.B
Dzień dobry,
Czy jest możliwość dodania czujnik jakości powietrza IKEA VINDSTYRKA?
Cześć,Wojt.B wrote: Sun Oct 26, 2025 12:35 pm Dzień dobry,
myślę, że bez problemu - sam już kilka razy chciałem go kupić, ale z racji tego, że na forum jest projekt bezpośredniego przerobienia go na Supla, to nie chciałem wprowadzać zamieszania.
Nad tym się jeszcze zastanawiam:
Właśnie udało mi się znaleźć to na AliExpress:
186,41zł | Xiaomi Miaomiaoce Detektor jakości powietrza CO2 Temperatura Wilgotność Czas Cztery efekty w 1 Inteligentna kontrola aplikacji Czujnik typu pionowego
