Szukałem w bazie i chyba takiego czujna temperatury i wilgotności jeszcze niema
[ 1562][I][ZigbeeCore.cpp:384] esp_zb_app_signal_handler(): Network(0x62c3) is open for 180 seconds
[ 9959][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 13649][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 13651][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 13681][I][ZigbeeCore.cpp:353] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd625)
[ 13682][V][ZigbeeCore.cpp:357] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 13682][D][ZigbeeGateway.cpp:459] zbDeviceAnnce(): zbDeviceAnnce short address (0xd625), ieee_addr (0x50):(0x32):(0x5f):(0xff):(0xfe):(0x60):(0xf1):(0xaa)
[ 13683][D][ZigbeeGateway.cpp:462] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd625), ieee_addr (0x50):(0x32):(0x5f):(0xff):(0xfe):(0x60):(0xf1):(0xaa)
[ 13684][I][ZigbeeGateway.cpp:496] zbDeviceAnnce(): Tuya magic last hope
[ 13953][I][ZigbeeGateway.cpp:531] printJoinedDevices(): joined devices:
[ 13953][I][ZigbeeGateway.cpp:534] printJoinedDevices(): Device on endpoint 1, short address: 0xd625
[ 14111][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 14112][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xd625) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 14112][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 14113][I][ZigbeeGateway.cpp:330] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_hzkeh3nv"
[ 14113][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 14114][I][ZigbeeGateway.cpp:343] zbReadBasicCluster(): ZCL version id is "3"
[ 14115][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(68)
[ 14115][I][ZigbeeGateway.cpp:349] zbReadBasicCluster(): ZCL application version id is "68"
[ 14116][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 14116][I][ZigbeeGateway.cpp:337] zbReadBasicCluster(): Peer Model is "TS0201"
[ 14117][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 14117][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): ZCL power source id is "3"
[ 14118][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[ 14119][I][ZigbeeGateway.cpp:359] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[ 14122][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 14122][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xd625), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with
Nie mogę go również dodać do supli.
