Has thanked: 290 times
bokk wrote: Wed Apr 09, 2025 7:39 am
Jeden z czujników zaczął pokazywać właściwie stan, ale jeszcze dwa mam które nie chodzą. Później posprawdzam
OK, pamiętaj, że każdy z nich może mieć inny model_id - nawet jeżeli są od tego samego sprzedawcy.
[email protected] wrote: Tue Apr 08, 2025 12:54 pm
[email protected] wrote: Tue Apr 08, 2025 12:21 pm Proszę o dodanie:
BITUO TECHNIK SPM02-U02
https://www.zigbee2mqtt.io/devices/SPM02-U02.html
[14:48:53][881888][I][z2s_device_tuya_custom_cluster.cpp:359] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
[14:48:53][881888][I][z2s_devices_table.cpp:95] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0x94:0xec:0x32:0xff:0xfe:0xb8:0x54:0x87, endpoint 0x1, channel type 0xffffffff
[14:48:53][881889][I][z2s_device_tuya_custom_cluster.cpp:320] processTuyaDataReport(): processTuyaDataReport failed - no Supla channel for that device
[14:48:53]NLME Status Indication, status: 0x9
[14:48:53][882109][I][ZigbeeHandlers.cpp:36] zb_action_handler(): Receive Zigbee action(0x1040) callback
[14:48:53][882110][I][ZigbeeHandlers.cpp:369] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0xa94d
[14:48:53][882110][I][ZigbeeHandlers.cpp:371] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[14:48:53][882111][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[14:48:53][882111][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x1c
[14:48:53][882111][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[14:48:53][882112][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[14:48:53][882112][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[14:48:53][882113][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[14:48:53][882113][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[14:48:53][882114][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[14:48:53][882114][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[14:48:53][882115][I][ZigbeeHandlers.cpp:373] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x6
Urządzenie wygląda bardzo intersująco i chętnie je dodam do bramki, ale w zależności od modelu (nie tego ze strony WWW tylko raportowanego przez urządzenie) różny będzie standard przesyłanych danych (standardowy klaster ElectricalMeasurement vs. Tuya custom cluster 0xEF00).
Z Twoich logów niestety niewiele wynika (chociaż można podejrzewać TCC), ale tak czy inaczej potrzebuję manufacturer i model id.
Potrzebny jest log z samego parowania urządzenia - im więcej danych tym lepiej.
Uruchom bramkę, poczekaj 1-2 minuty, wyczyść monitor portu szeregowego i uruchom procedurę parowania na urządzeniu Zigbee a później skopiuj i wrzuć całość logów albo zainstaluj Scanner i wrzuć logi z parowania ze skanerem.
trozwadowski89
Producent - "ADEO"
Model urządzenia - "ZB-SMART-PIRTH-V3"
https://www.leroymerlin.pl/produkty/czu ... 33205.html
Czujnik Lexman 4 w 1 z funkcją wykrywania ruchu mierzy i monitoruje temperaturę, wilgotność, jasność oraz wykrywa ruch w domu. Wyposażony w czujnik podczerwieni (kąt detekcji: 100° / zasięg detekcji: 5m) może służyć do powiadamiania o ruchu lub włączania podłączonego światła. Wartości temperatury, jasności i wilgotności pozwolą na uruchomienie działania np. opuszczenia rolety, załączenia wentylatora czy gniazdka. Do działania czujka 4 w 1 wymaga skrzynki Enk. Posiada 5-letnią gwarancję.
trozwadowski89
Producent - "ADEO"
Model urządzenia - "ZB-DoorSensor-D0007"
https://www.leroymerlin.pl/produkty/czu ... 33207.html
Czujnik otwarcia drzwi i okna ENKI LEXMAN
bokk
Has thanked: 7 times
Been thanked: 25 times
vajera wrote: Wed Apr 09, 2025 8:47 am
Dodane mam 3 urządzenia - czujniki otwarcia, nr 0 działa tj. prawidłowo wskazuje otwarcie i zamknięcie natomiast 1 i 2 cały czas otwarte. wyjęcie baterii, wzbudzenie przyciskiem, restart bramki nic nie daje.
list-zb-devices
ENTRY                   0
RECORD ID               1
MANUFACTURER NAME       LUMI
MODEL NAME              lumi.sensor_magnet.aq2
IEEE ADDRESS            0:15:8D:0:8B:84:FC:97
SHORT ADDRESS           0x1D86
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             0
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   1
RECORD ID               1
IEEE ADDRESS            0:15:8D:0:8B:84:FC:D0
SHORT ADDRESS           0x2FF4
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             1
SUPLA CH[1]             2
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   2
RECORD ID               1
IEEE ADDRESS            0:15:8D:0:8B:84:FC:A6
SHORT ADDRESS           0xA9AD
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             2
SUPLA CH[1]             1
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
bokk
bokk wrote: Wed Apr 09, 2025 11:55 am
list-zb-devices
ENTRY                   0
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             0
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   1
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             1
SUPLA CH[1]             2
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   2
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             2
SUPLA CH[1]             1
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
list-devices
ENTRY                   0
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   2010
SUPLA CHANNEL           0
SUPLA SECONDARY CHANNEL 255
SUPLA CHANNEL TYPE      1000
SUPLA CHANNEL NAME
SUPLA CHANNEL FUNCTION  0
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENTRY                   1
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   2010
SUPLA CHANNEL           1
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            1
ENTRY                   2
SHORT ADDRESS           0x20BD
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   2010
SUPLA CHANNEL           2
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            2
list-zb-devices
ENTRY                   0
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             0
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   1
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             1
SUPLA CH[1]             2
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   2
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             2
SUPLA CH[1]             1
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
Coś jest pomieszane z kanałami Supla - wrzuć jeszcze wynik polecenia list-devices
bokk
vajera wrote: Wed Apr 09, 2025 12:03 pm
list-zb-devices
ENTRY                   0
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             0
SUPLA CH[1]             255
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   1
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             1
SUPLA CH[1]             2
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
ENTRY                   2
RECORD ID               1
ENDPOINTS COUNT         0x1
POWER SOURCE            0x3
MODEL                   8208
LAST RSSI               0
LAST SEEN (MS)          2796
KEEP ALIVE (MS)         0
TIMEOUT (MS)            0
USER FLAGS              0
USER DATA               0
SUPLA CH[0]             2
SUPLA CH[1]             1
SUPLA CH[2]             255
SUPLA CH[3]             255
SUPLA CH[4]             255
SUPLA CH[5]             255
SUPLA CH[6]             255
SUPLA CH[7]             255
SUPLA CH[8]             255
SUPLA CH[9]             255
SUPLA CH[10]            255
SUPLA CH[11]            255
SUPLA CH[12]            255
SUPLA CH[13]            255
SUPLA CH[14]            255
SUPLA CH[15]            255
list-devices
ENTRY                   0
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   2010
SUPLA CHANNEL           0
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            0
ENTRY                   1
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   2010
SUPLA CHANNEL           1
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            1
ENTRY                   2
ENDPOINT                0x1
CLUSTER                 0x6
MODEL                   2010
SUPLA CHANNEL           2
SUPLA CHANNEL NAME
SUB ID                  -1
USER FLAGS              0
USER DATA(1)            0
USER DATA(2)            0
USER DATA(3)            0
USER DATA(4)            0
KEEP ALIVE(S)           0
TIMEOUT(S)              0
REFRESH(S)              0
ZB device id            2
trozwadowski89 wrote: Wed Apr 09, 2025 11:52 am Producent - "ADEO"
Widzę, że w Leroy cała plejada produktów Zigbee - akurat będę przejeżdżał obok mojego sklepu to wjadę po te dwa czujniki bo jestem ciekaw ich jakości.
bokk wrote: Wed Apr 09, 2025 12:05 pm .. .
Kanały wyglądają OK.
W tym poleceniu list-zb-devices jest taki parametr last_seen_ms - zapisz wartości dla wszystkich trzech, później "podrażnij" je trochę magnesami i sprawdź czy ten parametr się zmienił. Gdyby udało Ci się dodatkowo złapać logi z tego "drażnienia" to bo będzie więcej informacji.
