Proszę o dodanie czujnika dymu:
[ 26094][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 26096][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 26424][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x19da)
[ 26425][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x84
[ 26425][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x19da), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0xa3):(0x37):(0x98):(0x65)
[ 26426][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x19da), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0xa3):(0x37):(0x98):(0x65)
[ 26507][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[ 26507][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x19da
[ 26708][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 27208][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 29270][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 29271][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x81
[ 29272][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 29320][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 29320][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 29321][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 29322][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 29323][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 29406][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[ 29406][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[ 29438][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 29438][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 29439][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[ 29440][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "Heiman"
[ 29823][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 29823][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 30323][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 30723][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 30724][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 30724][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 30725][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 30726][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[ 31226][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 32011][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 32011][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 32012][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(3)
[ 32013][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "3"
[ 32014][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 32514][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 33300][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 33300][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 33301][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(8)
[ 33302][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "SMOK_V16"
[ 33303][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[ 33803][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[ 34563][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 34563][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 34564][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 34565][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
[ 34566][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[ 35066][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 35566][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 6618
[ 35844][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 35844][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35845][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 35861][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 35861][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x19da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35862][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[ 37119][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 6618, endpoints count 1
[ 37120][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 38404][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 6618, endpoint # 1
[ 38405][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 1
[ 38405][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 38406][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 38406][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[ 38407][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[ 38407][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 9
[ 38408][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 1282
[ 38408][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 39671][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 39672][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 39673][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 39699][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 39699][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 39700][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 40965][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40966][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x500) for command (0xc) with status 0x84
[ 40967][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41014][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41014][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x1) for command (0xc) with status 0x84
[ 41015][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41097][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 42241][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 42241][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 42242][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43508][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 43508][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x19da), src_endpoint(1) to dst_endpoint(1), cluster(0x502) for command (0xc) with status 0x84
[ 43509][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43557][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 43557][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 43558][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 43558][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x6
[ 43558][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 10 size: 2
[ 43559][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 43559][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 43559][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x19da, 0x19da, 0x0, 0x0
[ 43560][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 43578][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 43602][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
oraz zasilanego 230V czujnika gazu:
6] esp_zb_app_signal_handler(): Network(0x9622) is open for 180 seconds
[ 25579][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 36075][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 36077][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 36392][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x10de)
[ 36392][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 36393][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x10de), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0x5b):(0x30):(0x34):(0x1e)
[ 36393][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x10de), ieee_addr (0x0):(0x50):(0x43):(0xc9):(0x5b):(0x30):(0x34):(0x1e)
[ 36442][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[ 36442][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x10de
[ 36472][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 36472][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x81
[ 36473][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 36643][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 36679][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 36680][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 36680][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 36681][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 36950][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[ 36951][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[ 37143][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 37143][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 37165][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 37166][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 37166][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[ 37167][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "Heiman"
[ 37645][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 37645][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 37666][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 37666][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 37667][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 37668][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "1"
[ 38146][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 38146][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[ 38181][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 38181][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38182][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(0)
[ 38183][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "0"
[ 38647][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 38647][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 38676][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 38677][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38677][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[ 38678][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "GAS_V15"
[ 39149][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 39149][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[ 39194][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 39195][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 39196][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
[ 39196][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "1"
[ 39651][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[ 39651][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[ 39685][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 39686][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 39686][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 40153][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 40191][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 40191][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x10de) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 40192][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[ 40653][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 4318
[ 40698][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 4318, endpoints count 1
[ 40699][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 40743][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 4318, endpoint # 1
[ 40744][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
[ 40744][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 40745][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 40745][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[ 40746][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 9
[ 40746][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
NLME Status Indication, status: 0x9
[ 40832][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40832][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 40833][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 40868][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40869][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 40869][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 40889][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40889][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x500) for command (0xc) with status 0x84
[ 40890][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43791][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 43792][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x10de), src_endpoint(1) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 43793][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 43801][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 43801][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 43802][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 43802][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x6
[ 43802][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 3 size: 2
[ 43803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 43803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 43804][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x10de, 0x10de, 0x0, 0x0
[ 43804][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 51078][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 51225][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
