DHT 11 sensor does not work
Post Reply
jarvis007
Post by jarvis007 » Thu Mar 08, 2018 4:23 pm
Hello, I installed the firmware sonoff_dimmer_DHT11_v2.5.3_p5.rar (https://github.com/SUPLA/ESP8266/tree/m ... off/v2.5.3)
connected the sensor, but I do not see the temperature (sensor working)
Zybi
Re: DHT 11 sensor does not work
Post by Zybi » Thu Mar 08, 2018 5:27 pm
Are you sure you have connected the sensor correctly?
I have the impression, that the yellow wire is connected to the NC and not to the input S (data).
jarvis007
Post by jarvis007 » Fri Mar 09, 2018 6:41 am
real photo
Komar000
Post by Komar000 » Thu Mar 15, 2018 3:41 pm
What kind of power you use?
If You use power supply from usb,try connect sonoff to 230v.
jarvis007
Post by jarvis007 » Sat Mar 17, 2018 6:50 am
I connect to 220v
DaveRodda
Post by DaveRodda » Thu Nov 22, 2018 6:38 pm
Hello...I had the same problem with module with DHT11 and red LED. One of resistance was 1kOhm instead 10kOhm. Please, check it carefully.Have a multimeter handy? Test your connections to and on the module.You should take a delay of 2 seconds between readings, - see datasheet.
I do not know how it behaves it readings are made too fast.
complete pcb
Post Reply
