SONOFF
gaurav
Re: SONOFF
Post by gaurav » Thu Jul 06, 2017 7:22 am
should I replace the esp_init_data_default.bin with boot.bin?
Contact:
Re: SONOFF
Post by pzygmunt » Thu Jul 06, 2017 7:47 am
gaurav
Re: SONOFF
Post by gaurav » Thu Jul 06, 2017 11:16 am
I flashed the esp_init_data_defalut.bin and then flashed the firmware. Results were same. It did't boots up.
Contact:
Re: SONOFF
Post by pzygmunt » Thu Jul 06, 2017 1:09 pm
Flash parameters ?
Memory address for esp_init_data_default ?
gaurav
Re: SONOFF
Post by gaurav » Fri Jul 07, 2017 12:39 pm
I flashed nodemcu at 0x3fc000.
Contact:
Re: SONOFF
Post by pzygmunt » Fri Jul 07, 2017 12:40 pm
Flash Size ?
SPI mode ?
gaurav
Re: SONOFF
Post by gaurav » Fri Jul 07, 2017 12:51 pm
flash size 4MB and SPI mode QIO.
Contact:
Re: SONOFF
Post by pzygmunt » Fri Jul 07, 2017 12:55 pm
This firmware
https://github.com/zchmielak/ESP8266/bl ... 2.0_p5.rar
is compiled for 1MB flash size so just change your settings to
FLASH SIZE 8 Mbit (1MByte)
and write esp_init_data to 0xfc000
gaurav
Re: SONOFF
Post by gaurav » Thu Jul 13, 2017 10:07 am
It worked. But whenever I flash the firmware I have to flash esp_init_data_default.bin. Is it necessary or I am missing something? Thank you for the help. :)
gaurav
Re: SONOFF
Post by gaurav » Sat May 12, 2018 12:13 pm
I built the sonoff socket firmware from SDK and changed the led port from gpio 13 to gpio 15 and flashed the firmware in nodemcu now the led is glowing continuously instead of blinking in config mode. Why is it so?
Post Reply
