SONOFF
gaurav
should I replace the esp_init_data_default.bin with boot.bin?
- Been thanked: 59 times
gaurav
I flashed the esp_init_data_defalut.bin and then flashed the firmware. Results were same. It did't boots up.
This firmware
https://github.com/zchmielak/ESP8266/bl ... 2.0_p5.rar
is compiled for 1MB flash size so just change your settings to
FLASH SIZE 8 Mbit (1MByte)
and write esp_init_data to 0xfc000
gaurav
It worked. But whenever I flash the firmware I have to flash esp_init_data_default.bin. Is it necessary or I am missing something? Thank you for the help.
gaurav
I built the sonoff socket firmware from SDK and changed the led port from gpio 13 to gpio 15 and flashed the firmware in nodemcu now the led is glowing continuously instead of blinking in config mode. Why is it so?
