Moderator: vajera
Mario78
vajera wrote: Wed May 14, 2025 1:17 pm
Mario78 wrote: Tue May 13, 2025 6:49 pm vajera uprzejmie proszę o dodanie czujnika ruchu
Peer Model is "SNZB-03" Manufacturer is "_TZ3000_bb6xaihh"
A jesteś pewny tych danych - wygląda to trochę jak krzyżówka Sonoffa z Tuya?
vajera wygląda, że log są ok
poniżej wklejam całość z próby parowania
czujnik z linu : https://pl.aliexpress.com/item/10050084 ... pt=glo2pol
Using 'COM14' as serial port.
Unexpected error: could not open port 'COM14': PermissionError(13, 'Odmowa dostępu.', None, 5)
[19:26:55]Send: [53 55 50 4C 41 17 06 00 00 00 28 00 00 00 10 00 00 00 7E EE 24 68 00 00 00 00 96 C1 0E 00 00 00 00 00 ]
[19:26:55]Send: [53 55 50 4C 41 ]
[19:26:55]Recv: [53 55 50 4C 41 17 07 00 00 00 32 00 00 00 10 00 00 00 5F D2 24 68 00 00 00 00 4D 5F 0D 00 00 00 00 00 53 55 50 4C 41 ]
[19:27:01][ 35235][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd22d)
[19:27:01][ 35235][D][ZigbeeGateway.cpp:517] zbDeviceAnnce(): zbDeviceAnnce short address (0xd22d), ieee_addr (0xa4):(0xc1):(0x38):(0x30):(0xef):(0x8):(0x4f):(0xab)
[19:27:01][ 35236][D][ZigbeeGateway.cpp:520] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd22d), ieee_addr (0xa4):(0xc1):(0x38):(0x30):(0xef):(0x8):(0x4f):(0xab)
[19:27:01][ 35237][I][ZigbeeGateway.cpp:544] zbDeviceAnnce(): Tuya magic last hope
[19:27:01][ 35440][I][ZigbeeGateway.cpp:587] printJoinedDevices(): joined devices:
[19:27:01][ 35441][I][ZigbeeGateway.cpp:590] printJoinedDevices(): Device on endpoint 1, short address: 0xd22d
[19:27:01][ 35442][I][ZigbeeGateway.cpp:348] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[19:27:01][ 35574][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[19:27:01][ 35574][I][ZigbeeGateway.cpp:381] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_bb6xaihh"
[19:27:01][ 35575][I][ZigbeeGateway.cpp:401] zbReadBasicCluster(): ZCL version id is "3"
[19:27:01][ 35575][I][ZigbeeGateway.cpp:407] zbReadBasicCluster(): ZCL application version id is "113"
[19:27:01][ 35576][I][ZigbeeGateway.cpp:388] zbReadBasicCluster(): Peer Model is "SNZB-03"
[19:27:01][ 35576][I][ZigbeeGateway.cpp:413] zbReadBasicCluster(): ZCL power source id is "3"
[19:27:01][ 35641][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[19:27:01][ 35642][I][ZigbeeGateway.cpp:381] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_bb6xaihh"
[19:27:02][ 35942][I][ZigbeeGateway.cpp:354] zbQueryDeviceBasicCluster(): basic tsn 0x1
[19:27:02][ 35942][I][ZigbeeGateway.cpp:348] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[19:27:02][ 36064][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[19:27:02][ 36065][I][ZigbeeGateway.cpp:388] zbReadBasicCluster(): Peer Model is "SNZB-03"
[19:27:02][ 36444][I][ZigbeeGateway.cpp:354] zbQueryDeviceBasicCluster(): basic tsn 0x2
[19:27:02][ 36444][I][ZigbeeGateway.cpp:1225] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[19:27:02][ 36571][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[19:27:03][ 36776][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[19:27:03][ 36776][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:03][ 36777][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:03][ 36778][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:03][ 36779][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:03][ 36780][I][z2s_devices_table.cpp:1116] Z2S_onIASzoneStatusChangeNotification(): onIASzoneStatusChangeNotification - no channel found for address 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab
[19:27:03][ 36946][I][ZigbeeGateway.cpp:1225] sendAttributeWrite(): Sending 'write attribute' command - id (0x9), type (0x20), size (0x1), value (0x1)
[19:27:03][ 37083][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[19:27:03][ 37448][D][Z2S_Gateway.ino:1655] loop(): Unknown model _TZ3000_bb6xaihh::SNZB-03, no binding is possible
[19:27:04][ 37677][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[19:27:04][ 37678][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:04][ 37679][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:04][ 37680][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:04][ 37681][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:04][ 37681][I][z2s_devices_table.cpp:1116] Z2S_onIASzoneStatusChangeNotification(): onIASzoneStatusChangeNotification - no channel found for address 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab
[19:27:06][ 40070][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[19:27:06][ 40070][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:06][ 40071][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:06][ 40072][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:06][ 40073][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:06][ 40074][I][z2s_devices_table.cpp:1116] Z2S_onIASzoneStatusChangeNotification(): onIASzoneStatusChangeNotification - no channel found for address 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab
[19:27:07][ 41055][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[19:27:07][ 41056][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:07][ 41057][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:07][ 41058][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:07][ 41059][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:07][ 41060][I][z2s_devices_table.cpp:1116] Z2S_onIASzoneStatusChangeNotification(): onIASzoneStatusChangeNotification - no channel found for address 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab
[19:27:11][ 44861][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[19:27:11][ 44861][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:11][ 44862][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:11][ 44863][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:11][ 44864][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:11][ 44865][I][z2s_devices_table.cpp:98] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab, endpoint 0x1, channel type 0x3e8
[19:27:11][ 44865][I][z2s_devices_table.cpp:1116] Z2S_onIASzoneStatusChangeNotification(): onIASzoneStatusChangeNotification - no channel found for address 0xa4:0xc1:0x38:0x30:0xef:0x8:0x4f:0xab
Has thanked: 290 times
Been thanked: 161 times
Mario78 wrote: Wed May 14, 2025 5:33 pm
Faktycznie - manufacturer name w stylu Tuya a model Sonoffa - pytanie kto to komu i co podprowadził 😉
Nic dziwnego, że ludzie się skarżą w komentarzach na problemy z parowaniem.
Dodam go z tym samym profilem, co w przypadku eWeLink::SNZB-03 tylko zmienię to manufacturer name i zobaczymy czy działa.
Mario78
Chinczyk Cinczyka okrada .....Co to się dzieje na tym świecie :D
Zibi_007
Has thanked: 10 times
Been thanked: 31 times
vajera wrote: Wed May 14, 2025 5:42 pm
Do mnie też idzie z tego linku. Jak dojdzie, to zobaczę, jak się będzie przedstawiał ;-)
Mario78
Zibi_007 w tej cenie to się majfrendom nawet nazwy modelu nie chce zmieniać :lol:
Znając życie to ten sam soft idzie do różnych czujników tylko ktoś zmienił jedną linijkę a miał poprawić dwie :D
Ps. W każdym razie ta chimera jest już w 0.7.81.
Mario78
vajera wrote: Wed May 14, 2025 5:54 pm Znając życie to ten sam soft idzie do różnych czujników tylko ktoś zmienił jedną linijkę a miał poprawić dwie :D
kurde działa :)
i nawet szybko śmiga lepiej niz czujniki ikea
Mario78 wrote: Wed May 14, 2025 6:17 pm kurde działa :)
Trochę jak z psami - mieszaniec sprawniejszy od rasowego :D
Zibi_007
vajera wrote: Wed May 14, 2025 7:34 pm
Już o tym pisałem. Jeśli zadziałają, to nie ma się do czego przyczepić. Działają szybko, sprawnie i mało zużywają baterię (szczególnie jeśli są na CR2450 - pomijam już fakt, że taka markowa bateria potrafi kosztować prawie tyle, co ten czujnik :lol: ). Gorzej, jak nie działa. Rozebrałem kilka i wychodzi na to, że najczęściej nie działa sensor, albo uszkodzony jest układ scalony. Przy cenie kilku-kilkunastu złotych za nowy naprawa jest kompletnie nieopłacalna. Przy jednym, który zużywał bardzo szybko baterię znalazłem zwarcie na płytce (przelana cyna na sąsiedni pad). Inne (uszkodzone) wrzuciłem do elektrośmieci.
Zibi_007 wrote: Wed May 14, 2025 8:39 pm Już o tym pisałem. Jeśli zadziałają, to nie ma się do czego przyczepić. Działają szybko, sprawnie i mało zużywają baterię (szczególnie jeśli są na CR2450 - pomijam już fakt, że taka markowa bateria potrafi kosztować prawie tyle, co ten czujnik :lol: ). Gorzej, jak nie działa. Rozebrałem kilka i wychodzi na to, że najczęściej nie działa sensor, albo uszkodzony jest układ scalony. Przy cenie kilku-kilkunastu złotych za nowy naprawa jest kompletnie nieopłacalna. Przy jednym, który zużywał bardzo szybko baterię znalazłem zwarcie na płytce (przelana cyna na sąsiedni pad). Inne (uszkodzone) wrzuciłem do elektrośmieci.
Może oni mają taki system, że Sonoff kupuje partię czujników za grosze, później robi kontrolę jakości i te, które ją przeszły idą już jako markowe?
Return to “Bramka ZigBee”
