Widzę, że i tak jest lepiej niż miałeś wczoraj, bo pobiera Ci relase file dla repo raspbiana. Wyedytuj plik tak jak @pzygmunt poradziłtijo wrote: Wed Jun 26, 2019 8:17 amCode: Select all
pi@raspberrypi:~ $ sudo apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Ign:3 https://download.docker.com/linux/raspbian 10 InRelease Err:4 https://download.docker.com/linux/raspbian 10 Release 404 Not Found [IP: 52.84.198.41 443] Reading package lists... Done E: The repository 'https://download.docker.com/linux/raspbian 10 Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. pi@raspberrypi:~ $
sudo nano /etc/apt/sources.listCode: Select all
https://download.docker.com/linux/raspbian 10 ReleaseSOP 2023
SOP 2024
cz->b
+ila
SOP 2024
tijo
- Been thanked: 1 time
mój plik sources.list wygląda tak:
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
A co masz w /etc/apt/sources.list.d/docker.list ?
pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/docker.list
deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable
SOP 2023
SOP 2024
cz->b
+ila
SOP 2024
tijo
no właśnie tak mam...lesny8 wrote: Wed Jun 26, 2019 10:12 am A co masz w /etc/apt/sources.list.d/docker.list ?Code: Select all
pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/docker.list deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable
- Been thanked: 59 times
Tak dla jasności. Używasz aktualnego obrazu ?
https://www.raspberrypi.org/downloads/raspbian/
tijo
używałem tego z pierwszego posta...ściągam terazpzygmunt wrote: Wed Jun 26, 2019 1:35 pm Tak dla jasności. Używasz aktualnego obrazu ?
Raspbian Buster Lite
Minimal image based on Debian Buster
Version: June 2019
Release date: 2019-06-20
Kernel version: 4.19
ale to chyba nic nie da....przecież noobs ściąga nowego raspbiana....miałem instalację online...
superprzemo
Ja 3 tygodnie temu instalowałem na RPI 3 B+ tylko bez proxy i teraz wszystko śmiga, tylko parę razy musiałem powtarzać polecenia, bo czasami wywalało mi błędy.
Moja wersja systemu:
Linux raspberrypi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l-
tijo
u mnie cały czas wyskakuje że nie ma dockera dla rapsbiana 10superprzemo wrote: Thu Jun 27, 2019 10:27 am Ja 3 tygodnie temu instalowałem na RPI 3 B+ tylko bez proxy i teraz wszystko śmiga, tylko parę razy musiałem powtarzać polecenia, bo czasami wywalało mi błędy.
Moja wersja systemu:Code: Select all
Ostatnie instalowałem na tym samym sprzęcie. Zainstalowało się bez problemu. Gdzieś popełniasz błąd.
Postaw czysty OS i udostępnij mi to raspberry albo wystawiając port 22 albo przez teamviewer-a
