Sprawdziłem jeszcze raz - jest lag taki koło sekundy - nie trzeba puszczać suwaka. Tożsama sytuacja jest z regulacją jasności.
[ 35098][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 35099][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 35099][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 35100][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 9 size: 4
[ 35100][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 35101][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 35101][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 35101][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x29
[ 35102][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 35102][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 35103][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 35103][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 35104][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 35105][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 35105][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 35106][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x29
[ 35107][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x29
[ 35107][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 35108][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 35109][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 56, cluster_id: 0x0008, asdu_length: 7
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xb938
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 51, rx_time: 0
[ 35110][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 35111][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 35111][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 35112][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 35112][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 10 size: 4
[ 35113][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 35113][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 35114][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
[ 35114][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 35115][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 35115][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 35116][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 35116][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 35117][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 35118][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 35118][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x21
[ 35119][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x21
[ 35120][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
Send: [53 55 50 4C 41 17 0F 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 0D 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
[ 35426][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 35426][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 56, cluster_id: 0x0300, asdu_length: 8
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 56, rx_time: 0
[ 35428][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x300, command id: 10
[ 35428][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 35429][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 35430][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 35430][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 27 size: 5
[ 35430][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x07
[ 35431][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 35431][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
[ 35431][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x10
[ 35432][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
[ 35432][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 35433][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x300, cmd id 0xa
[ 35433][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 35434][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 35434][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 35435][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 35436][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x300)
[ 35437][I][ZigbeeGateway.cpp:1358] zbAttributeReporting(): color control cluster color temperature 0x110
Recv: [53 55 50 4C 41 17 12 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 0D 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Z2S_DimmerInterface[1]: red=0, green=255, blue=0, colorBrightness=0, brightness=13, command=0, toggleOnOff=0
Recv: [53 55 50 4C 41 17 13 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 10 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Z2S_DimmerInterface[1]: red=0, green=255, blue=0, colorBrightness=0, brightness=16, command=0, toggleOnOff=0
[ 36528][I][Z2S_dimmer_interface.cpp:69] handleNewValueFromServer(): DIMMER ALREADY ON - SEND LEVEL(brightness
Recv: [53 55 50 4C 41 17 14 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 1A 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Z2S_DimmerInterface[1]: red=0, green=255, blue=0, colorBrightness=0, brightness=26, command=0, toggleOnOff=0
[ 36794][I][Z2S_dimmer_interface.cpp:69] handleNewValueFromServer(): DIMMER ALREADY ON - SEND LEVEL(brightness
Recv: [53 55 50 4C 41 17 15 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 1A 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Channel(1) value changed to RGB(0, 0, 0), colBr(0), bright(26)
[ 37455][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37455][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 56, cluster_id: 0x0008, asdu_length: 5
[ 37457][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 11
[ 37458][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37458][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37459][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37459][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 11 size: 2
[ 37460][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37460][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37461][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xb
[ 37462][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37462][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37463][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37464][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 37464][V][ZigbeeHandlers.cpp:388] zb_cmd_default_resp_handler(): Received default response: from address(0xb938), src_endpoint(1) to dst_endpoint(1), cluster(0x8) for command (0x0) with status 0x0
[ 37465][V][ZigbeeHandlers.cpp:392] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 37466][I][ZigbeeGateway.cpp:2573] zbCmdDefaultResponse(): tsn = 4, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 37466][I][ZigbeeGateway.cpp:2588] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 4, _custom_cmd_last_tsn_flag = 255
[ 37467][I][ZigbeeGateway.cpp:2591] zbCmdDefaultResponse(): custom cmd rssi 1413480448
[ 37470][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37470][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37472][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37472][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37473][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37474][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37474][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 22 size: 4
[ 37474][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37475][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37475][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37475][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x24
[ 37476][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37476][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37477][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37478][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37478][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37479][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37480][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37480][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x24
[ 37481][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x24
[ 37481][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37482][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37483][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37485][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37485][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37485][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37486][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37486][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 12 size: 4
[ 37487][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37487][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37488][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x28
[ 37488][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37489][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37489][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37490][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37491][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37491][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37492][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37493][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x28
[ 37493][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x28
[ 37494][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37497][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37497][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37499][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37499][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37500][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37500][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37501][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 14 size: 4
[ 37501][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37502][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37502][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37502][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x2B
[ 37503][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37503][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37504][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37504][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37505][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37506][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37506][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37508][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x2b
[ 37508][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x2b
[ 37509][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37510][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37510][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37513][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37514][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37514][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37515][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37515][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 17 size: 4
[ 37516][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37516][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37517][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x2E
[ 37517][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37518][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37519][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37519][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37520][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37521][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37521][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37522][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x2e
[ 37523][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x2e
[ 37524][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37527][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37527][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37529][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37530][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37530][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37531][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37531][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 15 size: 4
[ 37531][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37532][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37532][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37532][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x31
[ 37533][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37533][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37534][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37535][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37535][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37536][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37537][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37537][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x31
[ 37538][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x31
[ 37539][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37539][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37540][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0008, asdu_length: 7
[ 37542][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37542][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37543][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37543][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37543][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 19 size: 4
[ 37544][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37545][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37545][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x35
[ 37545][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37546][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37546][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37547][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37548][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37548][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37549][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37550][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x35
[ 37550][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x35
[ 37551][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37555][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37556][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 134, cluster_id: 0x0008, asdu_length: 7
[ 37558][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37558][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37559][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37559][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37560][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 16 size: 4
[ 37560][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37561][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37561][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x38
[ 37561][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37562][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37563][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37563][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37564][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37565][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37565][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37566][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x38
[ 37567][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x38
[ 37567][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37568][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37569][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37570][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37571][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37571][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37572][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37572][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 20 size: 4
[ 37572][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37573][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37573][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37573][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x3B
[ 37574][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37574][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37575][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37575][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37576][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37577][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37577][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37578][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x3b
[ 37578][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x3b
[ 37579][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37580][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37580][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37582][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37582][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37583][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37583][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37584][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 21 size: 4
[ 37584][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37585][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37585][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37585][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x3F
[ 37586][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37586][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37587][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37587][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37588][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37589][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37589][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37590][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x3f
[ 37591][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x3f
[ 37591][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 37592][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 37593][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 37594][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 37595][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 37595][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 37596][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 37596][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 3 size: 4
[ 37597][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 37597][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 37598][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x42
[ 37598][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 37598][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 37599][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 37600][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 37600][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 37601][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 37602][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 37603][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x42
[ 37603][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x42
[ 37604][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
Send: [53 55 50 4C 41 17 10 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 1A 00 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 16 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 1A 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 17 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 1E 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Z2S_DimmerInterface[1]: red=0, green=255, blue=0, colorBrightness=0, brightness=30, command=0, toggleOnOff=0
[ 38770][I][Z2S_dimmer_interface.cpp:69] handleNewValueFromServer(): DIMMER ALREADY ON - SEND LEVEL(brightness
Recv: [53 55 50 4C 41 17 18 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 25 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Z2S_DimmerInterface[1]: red=0, green=255, blue=0, colorBrightness=0, brightness=37, command=0, toggleOnOff=0
[ 39047][I][Z2S_dimmer_interface.cpp:69] handleNewValueFromServer(): DIMMER ALREADY ON - SEND LEVEL(brightness
Recv: [53 55 50 4C 41 17 19 00 00 00 6E 00 00 00 11 00 00 00 76 1D 00 00 01 00 00 00 00 25 00 00 FF 00 00 00 00 53 55 50 4C 41 ]
Channel(1) value changed to RGB(0, 0, 0), colBr(0), bright(37)
[ 39746][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39746][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 39748][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 11
[ 39749][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39749][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39750][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39750][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 2 size: 2
[ 39750][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39751][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39751][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39752][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xb
[ 39752][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39753][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39754][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39754][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 39755][V][ZigbeeHandlers.cpp:388] zb_cmd_default_resp_handler(): Received default response: from address(0xb938), src_endpoint(1) to dst_endpoint(1), cluster(0x8) for command (0x0) with status 0x0
[ 39756][V][ZigbeeHandlers.cpp:392] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 39756][I][ZigbeeGateway.cpp:2573] zbCmdDefaultResponse(): tsn = 5, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 39757][I][ZigbeeGateway.cpp:2588] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 5, _custom_cmd_last_tsn_flag = 255
[ 39758][I][ZigbeeGateway.cpp:2591] zbCmdDefaultResponse(): custom cmd rssi 218103808
[ 39760][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39761][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 39763][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39763][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39763][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39764][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39765][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 5 size: 4
[ 39765][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39766][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39766][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x45
[ 39766][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39767][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39768][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39768][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39769][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39770][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 39770][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 39771][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x45
[ 39772][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x45
[ 39772][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 39775][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39776][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 230, cluster_id: 0x0008, asdu_length: 7
[ 39778][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39778][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39778][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39779][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39779][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 28 size: 4
[ 39780][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39781][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39781][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x48
[ 39781][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39782][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39783][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39783][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39784][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39785][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 39785][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 39786][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x48
[ 39786][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x48
[ 39787][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 39788][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39788][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 39790][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39790][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39791][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39791][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39792][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 4 size: 4
[ 39792][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4A
[ 39794][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39794][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39795][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39795][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39796][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39797][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 39797][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 39798][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x4a
[ 39799][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x4a
[ 39799][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 39802][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39803][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 39804][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39805][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39805][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39806][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39806][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 7 size: 4
[ 39807][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39807][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39808][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4D
[ 39808][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39809][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39809][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39810][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39810][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39811][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 39812][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 39813][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x4d
[ 39813][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x4d
[ 39814][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 39815][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39815][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 39817][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39817][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39818][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39818][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39819][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 8 size: 4
[ 39819][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39820][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39820][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x50
[ 39820][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39821][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39822][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39822][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39823][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39824][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 39824][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 39825][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x50
[ 39825][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x50
[ 39826][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 39829][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39830][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[ 39831][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39832][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39832][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39833][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39833][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 6 size: 4
[ 39834][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39834][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39835][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x53
[ 39835][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39836][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39836][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39837][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39837][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[ 39838][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 39839][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0xb938) src endpoint(1) to dst endpoint(1) cluster(0x8)
[ 39839][I][ZigbeeGateway.cpp:1311] zbAttributeReporting(): level control cluster current level 0x53
[ 39840][I][z2s_devices_table.cpp:3407] Z2S_onCurrentLevelReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, level 0x53
[ 39841][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xfa0
[ 39842][D][ZigbeeCore.cpp:492] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 39842][D][ZigbeeCore.cpp:493] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 66, rx_time: 0
[ 39844][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x8, command id: 10
[ 39844][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39845][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 39845][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39846][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 10 size: 4
[ 39846][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39847][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[ 39847][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[ 39847][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x56
[ 39848][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb938, 0xb938, 0x0, 0x0
[ 39848][I][z2s_devices_table.cpp:3814] Z2S_onCustomCmdReceive(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, cluster 0x8, cmd id 0xa
[ 39849][I][z2s_devices_table.cpp:159] Z2S_findChannelNumberSlot(): A4:C1:38:B3:C9:13:44:40, endpoint 0x1, channel type 0xffffffff
[ 39849][I][z2s_devices_table.cpp:3824] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
[ 39850][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
